- Loud Ticking
- Hit a Pothole, Now Popping Noise
- Car Jerking
- 09' Cobalt SS Brake Squeaking??
- Grinding issue
- where do these wires go?
- ignition lock
- CEL code p2188
- Buyer Beware
- sunroof leak
- Turn signal
- trunk release not working.
- busted taillight/brakelight
- 2 issues...
- 2010 SS O2 sensor p/n?
- dealership drives me nuts
- Need opinion on diagnostics software.
- Steering column noises
- my o2 sensor riped off and car problems after replacment
- gas pedal quits working???????????? help!
- engine surrge?
- serious problem!!!!! blowing ignition fuse!!!
- Rev Drop on Hard Acceleration
- Spark Plug Poll
- HHR Intermediate Steering Shaft
- bearings assembly
- High pitched noise with trifecta
- limp mode after regap my plug??
- Help, loud noise...
- 08 SS/TC. No boost. No CEL
- slow and low boosting
- RPM spikes and smoke... help!
- popping noise
- Extremely weird clutch pedal feel!!!!!
- oil filter caved in?
- VIN check
- cant seem to put car in reverse...
- 100K Mile Maintenance
- NEED HELP WITH INTAKE issues
- HID experts, a little help
- water getting in air intake... help?
- Swaybar links, do they have to be torqued?
- need assistance please
- fuel pump voltage
- P0172!!! Help
- Driver floor soaked/vent
- car wont start
- Boost?
- zzp dp touching
- help! Help!! HELP!!!!- car is stuck in shop!!!
- noob question
- A/C clutch issues
- P2261 on recently tuned SS TC
- smoke screen
- Flashers comes on when i turn key off
- Surging
- car jerks on accel
- Motor Stalls sometimes/ no rpm's
- Hood release not work, need help.
- 08 Cobalt SS gear shifter broke...
- For Those Of You With Burnt Steering Button Bulbs...
- Need help with code P0449
- Engine flutter?
- why don't my brights work?
- Intake trouble..
- Tail lights stopped working urgent if you can help
- Outside Air Temperature Sensor????
- lsj alternator
- Technical Issue
- Random Misfire + Other Codes...
- Blower mototr ?
- Battery terminal bolt size?
- My 2006 2.2L shudders in idle...
- cold air intake
- Trunk Light Not Working ??!
- Shift Linkage maybe?
- Front bumper install NEED HELP
- need help figuring out what this part is
- lock cylinder f*cked up
- trunk button
- Which scan tool to buy?
- Hail Damage...NOOOOOOO
- Check Engine Light on!!
- ebrake setup
- think with your dip stick JIMMY
- Transmission Problem...PLEASE HELP
- IC bleeding
- I stalled out
- TSB for timing chain tensioner?
- what is this noise when turning???!!!
- header/downpipe gasket
- HELP broken..thing(ss/tc)
- coolant
- my poor car...
- can one of you gm guys look up a part number for me
- HELP!! gm stage 1 problem with forge bpv
- outside temp doesnt show on DIC
- Fog Light Fuse
- Fans don't turn on???
- Boost Problem
- HID problem
- how would this have broken?
- RIP Cobalt...
- 2005 ss/sc tb question
- Power Steering ?
- car wont turn over
- car bogs down at the race track and on highway
- Stock radio is really quiet..?
- burning oil
- it's a gas leak, not oil...need suggestions!!!
- not the normal headlight leak
- Brake Fluid Light
- Oil light staying on, upset with the dealer
- CV joints
- 1st gear WOT car shakes like crazy
- Hvac will not work after stereo install
- 06 Cobalt needs front links?
- driver info..
- oil leak here???
- how much mobil 1?
- Steering problem
- Keys locking in ignition?
- Maintenance/Road Trip Prep
- Left Tail Light Out Twice & Rear Defroster Stopped Working
- Car pulls to the left!
- Fog Light Issues
- Huge problem!
- Yet another MPG question...
- TPMS covered under warranty??
- So My car blows....
- need help headlight harness
- WTF Rocker Arms
- Opinions on Extended Warranty
- bulb replacement
- mis firing on 1 and 3
- Replacing Dome Light Assembly
- how much to reflash the pcm
- Problems with the LE5 2.4 VVT
- fuel milage and performance issues
- 09 ss making a squelling sound when shifting fast
- Weird sound from back of motor after muffler install..HELP
- Coolant Temp Reading --- ?
- Steering wheel info button
- A/C Compressor Job
- Car wouldn't move this morning
- Is my cat blown, or is there a worse problem? 2.0 lsj
- plugs, wires, and boost gauge problems?
- Radiator broken. I officially hate Utah.
- Stupid Question
- What is the part number?!?!
- WTF? Wheel won't come off?
- New DP W/high flow cat, car runs amazing!
- Oil Spotting below head on TC
- getting very annoyed can anyone please help
- clutch got hot and slipped???
- Cruise Control Problem
- Headlight Adjustment
- Broke a lug. Help please!
- Shaking when at a complete stop
- 06 Supercharged boost problem...
- New ECM under warranty..huh?! HELP
- clutch pedal position relearn
- Something Wrong?
- evap and catalyst "not ready" help.
- Valve stem snapped...
- Catless
- Sunroof switch issue?
- While I have the rear bumper off....
- unusual driving
- Need help asap!!!!
- This cant be normal..
- Exhaust leak!
- Odd sound at start-up ???
- Starting Problems
- how to tighten ebrake ?
- severe sludge need help
- Brake problems
- door rattle
- engine coolant running hot
- Muffler Delete/Catback Sound Rice
- trim rejuvenator
- Antenna Trouble
- Quick Question (Noob)
- Typical Issues With LSJ?
- whats going out?
- damn evap system!
- center console help
- another noob question..
- pillar pod switch possible?
- Up on jackstands and...
- Bad IC pump that still works?
- Dash lights & Tail lights out!
- ODBII Problem
- fog light adjustment
- sudden terrible idle problem...
- Potholes
- Well, my transmission broke.
- very strange noise from passenger foot well....
- Removing side mirrors
- cold start up issue
- window mechanism
- Safe with 4 lugs?
- Electrical problems
- Help with Ground Wires
- No gears help!
- Save 15% on PIAA Super Silicone Wipers at PFYC - PartsForYourCar
- DIC reads "ENG PWR REDUCED"
- traction control and check engine comes on
- Transmission Noise
- help! ss/tc not boosting right
- guages / radio died... HELP!!
- p0230
- Cruise Control and E Brake Issue
- High RPM Stutter and Hesitation
- Brake issues!
- rpm weird going up and down without pressing gas
- few small issues with my 05 SS
- Transmission/Dealership Issue
- Door panel cloth rip
- Lease Return - Curb checks on rims??
- drive train lash / bucking in 1st gear
- The Infamous P0496
- changed the steering gear(motor and gear boxe under de steering wheel)
- I feel like an idiot but.
- Injector Question
- Dash lights!!! Need help :(
- HELP! Boost issue?
- is my car broke?
- Radio swap problems
- Recall - Intermediate Steering Shaft?
- Codes and rough Idle
- Really need help! (Alignment)
- Let's see here...
- noise under steering wheel
- Coolant light and cooling issues!!!!
- my CEL cherry has been popped...
- eng pwr Reduced
- Clutch issue
- Watery backfire?????
- Boost Issue, Help
- new tires and sensors
- Wiring gauges
- Cruise control problem
- Best Idea for cracked fender
- Coupe Passenger Seat Button
- need help with interceptor gauge
- Gas mileage and check engine code ???
- Will gm cover exhaust leak on warranty ???
- Car Shaking When Brakes Applied
- Passenger Door Problem
