- 07 Cobalt Sedan door handle Part #
- Knock Sensor?
- Door unlocks but wont lock. PLEASE HELP! I'm stumped
- Steering column noise?
- Body Panel Question..
- cracked front lip
- Car wont start, security locked me out :(
- What can happend without the grills??
- Loud noise when turning wheel!?!?!????!!??!!?!?!?!
- Gas Gauge Problems
- key stuck in on position at 12,800 miles...
- No heat and noises from inside the dash?
- security learn for zzperformance lnf pcm.
- Door won't open
- Need help with photo enlarging problem!
- safe to remove heatshield?
- Scheduled Maintenance to far from each other
- Car shaking between 50-70mph?
- ecu fried??warranty?
- Starting Issues
- WTF..weird sounds in the RAIN
- 2007 Cobalt Windsheild wipers stopped
- Battery terminal issue
- Tranny problems???
- Need some help
- Aftermarket Downpipe Issues
- No boost! Why?!?!
- LSj tranny problems
- how to tell if a hid bulb is burnt out?
- HIDS with relay
- Recent Cobalt issues..
- More Power Steering Questions
- water in light houseing
- SS/TC Driver Side Door Rattle
- Cobalt alarm issues?
- 3 codes, a CEL and my car does the JERK.
- Burning smell
- Cyl 4 misfire water in my gas?
- how to tell if i have bad catalytic converter
- Idle problems
- Brake Problem, Help
- poor running/ sputtering
- broken balt.. need quick advice
- TQ specs on pressure plate?????
- Transmission issue...
- jackstands??
- headlamp replacement 2010 ss
- Cold start- Low coolant problem
- Flashing CEL P0300....
- Key stuck, can't figure out how to open compartment under steering wheel.
- oil on pistons
- how to tell if my ic pump is broke
- CobaltSS.net's 2010 Holiday Charity Drive!
- Trying to figure out a fix for two codes...
- Clicking Noise
- Cruise Control..
- cig lighter went out
- I dont think this is normal
- cobalt 2.2 oxygen sensor
- Codes...overwhelmed. Where do I begin the troubleshooting?
- Cylinder Misfire...... Every 6 months??
- HVAC light went out
- Engine power reduced
- battery going dead in under 48 hours
- LSJ injectors not pulsing
- 109deg on the highway after 145 in my driveway?
- Radio makes weird noise
- I swear I hate this car. (Help please)
- Rattling Passenger Seat
- Shift knob stuck on cold startup
- Weak hvac blower
- Heated Driver Seat No Workie
- A/C makes squeaking noise when turned on
- Wheels coming loose after tire change! Dangerous, please help!
- airbag light help
- Broken Resonator Pipe. Dealership to blame?
- door problem
- Boosting high
- Cobalt Alignment issues-Rear Compensation?
- keyless entry remotes
- Transmission/Clutch problem!
- rpd knob won't push in...
- clunkin noise
- HELP Ignition prob.
- TPMS Incorrect
- tc light on
- Service Manual PDF
- brake problems
- Tail Light out, got questions....
- p0411 code, help?
- Engine Rattle: How to reproduce?
- Iginition Question
- No Fan Operation on 1-4
- Keyless entry remote
- having a bit of an issue
- 2nd gen headlights
- What kind of oil do you use?
- Headlights Wanted/Selling Mine
- Special Bulletin: Fuel System
- Steering Wheel Light Burnt Out...
- loud clunking noise
- Car not accelerating
- Stage two SS SC boost issues
- Out of Storage, Horrible Gas Mileage
- HELP! Loud clicking coming from passenger side front area
- steering wheel feels "loose" at 70+ MPH
- 4 codes and need help!
- Need help now!
- Where to have brake DRUMS resurfaced?
- Problem filling up with gas
- gears squealing
- GM Downsizes 100,000 Mile/5 Year Warranty
- CEL and boost gauge acting wierd
- e-brake wont stay up!
- Key stuck in ACC/ON position...
- Codes P0122 P0223 P1183
- Replace rear axle beam
- RPD "reflash graphics" ?
- Help Big Problem..Need to fix cobalt antenna
- Boost Gauge problems
- Steering wheel shaking under braking?????
- Car stuck in limp mode
- slight squeel when turning left? 07 ss/sc
- Question about "air" noise
- Gas Pedal Sticking
- Whining noise from engine bay. Not the supercharger lol
- Accelerometer Location?
- mileage issues
- Cobalt tc backfire!?
- Rearview Mirror lights wont turn off
- headlight damaged
- Blower went out need help.
- Possible headlight short???
- P0017 HAAALP!! Haha
- looking for a chip
- Eng Pwr Reduced (SS 2.4L)
- seafoam questions
- Ion BTSI help
- burnt valve cause?
- weird CEL???
- cars shaking like crazy (motor mount?)
- Blow Up
- finally recieved recall notice.
- MAF sensor backwards....
- Cobalt experts help!
- PLEASE HELP! Bad start up...
- gas indicator sticking
- Meth light
- CEL due to o2 sensor
- PO496 can eat sh*t.
- Please Help.. Flimsy Exhaust..
- High Beams Have Me Flumoxed/Confused/Mixed Up
- RPMS Jumping/Engine Power Reduced
- Interceptor showing misfire
- where can i find a new sunroof?
- Driver door won't open!
- how to set timing chain tensioner
- Knocking sound
- cel: high purge flow
- Temp reading --- today... and
- timing chain tensioner
- key fob and gmparts
- Need control arm help asap!!!!
- Help
- fuse box help
- power steering
- need help!!! front wheels wont move and weird light is on
- No boost (sometimes), car running rough
- cel on
- Cruise Control Won't Set
- Alternative Coolants/Racing Advise
- timing chain tensioner...
- Supercharger no boost no CEL??
- Check charge system, battery saver
- E-Brake Doesn't Work
- clunking noise
- knock in front suspension!!
- Need wheel alignment from springs
- shaking of front end
- Uhh, wtf?
- acc stays on when i remove key car wont start
- Help PLease
- 07 stage 2...dyno'd at 201hp WTF
- serious problem! need help!
- Help please
- Battery Cables
- License plate light HELP!!!
- Broken flex pipe? What if??
- Steering "Rattle"
- Taking car into dealer, should I rerun tune to stock?
- Need Some Help With An Issue!!!
- Wheel will not turn on start up?
- Engine Randomly Revs On Start-Up..??
- Having problems with the stealership. HELP!
- Head Gasket Maybe
- Electric steering motor service question
- New here - Having a problem
- parking brake
- ... and service
- Rocker/Lifter/Cam chatter? HELP
- Horn will not work.
- humming that gets louder with speed, not wheel bearing
- Driver Door Problems
- p0300 misfire question!
- smoke out the tail pipe ( need help please)
- no start after changed fuse
- Key fob sensor
- Gauges (electrical problem)
- Now ****ing what!
- What is this hose/line?
- Seafoam Issues..??
- Need Quick Help With CEL
- Loud knocking, metal shavings in oil.
- Passenger Side Rattle SOLVED!
- clutch or transmission?
- Help
- Misfire Cyl 4???
- Leaks and snoring sounds on exhaust
- Annoying noise
- New throttle body issue
- Exhaust Gasket Question
- fuel pump noise
- My shifting is odd and intermediate shaft rattle
- Play in axle
- AEM off throttle readings
- Vent smashed in?
- Fan Clicking
- Multiple problems that could use discussion
- Front end noise?
- Back to the dealer
- Long drunk night story, with a Rekey question.
- front o2 sensor keeps going out
- Throttle Position Sensor
- you give me your opinion
- Timing chain tensioner install question
- P1174 on '06 non SC
- 2008 SS - Purge Solenoid location
- Stock SS downpipe cracking
- Anyone ever replace a rear axle?
- Installed CA Stage 1, new gasket set, ported TB. Car won't run. PLEASE help!
- need help traction control code!!!!!
- Weird shuddering
- engine cut
- Radio Insanity......
- best place to get oil change?
- Wheel Bearing or CV Joint?
- Engine Power Reduced
- Identify this noise?
- evap purge solenoid part number
- Sunroof wont open
