- Intercooler coolant = white smoke
- Wiring from Evap Vent Valve to PCM
- how does it look?
- ss/sc cold start issues
- Motor/Transmission mount
- Recall VIN check
- here a good place to start
- coolant fan issues
- Throwing code p1516, anyone know what causes this?
- cooling fan sissue
- Crankshaft Position Sensor fault
- Whats the Ohm output references for our coil packs?
- Need help please
- need a hand
- LNF P0100 and P0102
- Need help figuring out my problem
- Supercharger Actuator
- clutch pressure issue need input
- I need help!
- Causes of Negative Fuel Trims
- Exposed wires causing loss of power
- Loud whine after changing water pump
- inner door handle broke
- lsj cam info!
- 07 SS A/C Compressor
- Dealer timing kit install
- too lean code
- Sloppy Shifter!
- Boost problems...
- Water leak on the passenger side? Heres a fix.
- Help....HHR SS front wheel spins too freely in gear. Too much play? Quick vid inside
- Cobalt SS/SC No more ventilation blowing
- Symptoms of bad intake manifold gasket
- 2005 Cobalt lsj Starting up noise
- water leak in passenger side
- How to wash out the engine 07 cobalt ls
- Fog Light Problem
- Fuel delivery problem? Or a vacuum leak?
- 4T45E. help
- help 07 ss/sc problems high revs
- code P0016. ?
- LSJ Hesitation Above 3K
- ebrake not engaging no matter how tight the lever is
- Transmission Shift Solenoid B Stuck On
- PPS part 25902223
- Need some help diagnosing an electrical problem
- 2006 2.0 SS/SC Starting Problem
- headlights... really pissing me off....
- Got two problems..
- lost boost
- got a question
- AFR problem?
- Hose placement help needed
- tapping in passenger side dash when key is initially turned to on position. .
- Oil in the Charge Pipes?
- can't find intermediate shaft on rockauto
- 06 cobalt ss sc?????????
- 08 lnf cobalt Engine Power Reduced
- A/C Works fine at first, then gets warm, then works again
- no start after LDK swap
- Electrical Problems?
- fuel problem
- F'n flex pipe!!!!!!
- tranny problem, 06 ss sc
- Accelation Misfire
- help! no spark, cranks but wont start.
- Running lean and boost problems
- Tire rubbing
- Tire rub
- Tire rub on fender
- P0014
- Supercharger leaking oil
- HELP! rpm problem
- i deffently need to no what is going on here >>>
- Engine knock
- Engine knock
- "Once Per Trip Tests"
- cold start missfires
- idle surge and pcm code?
- Speedometer isn't functioning
- Engine runs rough - stalls when i give it gas
- Help Please!
- possible fuel injector failure???
- Ok peopleeee
- electrical issues?
- Car cut off
- Belt Tensioner Noise
- 2006 Cobalt LS 2.2L P0300 with loss of power
- Bad wheel bearing/hub?
- can't remember what goes here, intake manifold port
- low boost on 2.7 pulley
- Rattle following fuel pump recall service
- 09 LNF code p2176
- Misfire Problems
- misfire problems
- sputtering and black smoke!?? please help
- LSJ Transmission Leak
- electrical problem?
- Finishing engine swap - starter and wiring harness issues
- missfire count through the hood... ?
- Sunroof Woes.
- Losing boost and power like crazy!! I need help!!
- 2008 hhr ss brake?
- 2010 Cobalt passenger seatbelt.
- Airbag/Seat Belt pre-tensioner sensor
- Bpfrs now no fuel pressure
- KYB Excel-G Struts and Shocks?
- oil leaking in a weird spot ?
- 2.0 SC problem with supercharger and oil leak
- L61 timing issue need HELP!
- 2.2 Motor Blowout
- intermittent boost
- Car bogs in third gear
- 05 cobalt ss supercharged reduced engine
- Gauge Cluster Not Calibrating Correctly?
- LNF Boost Issue
- Grinding noise from left side when i turn right?
- turns but wont start
- e-brake cables
- CV Won't Budge From Half Shaft
- Engine Drop-In Help!!
- Unknown whine/squeal from supercharger area
- Need some help!!
- Need some help!!
- Intermediate Steering Shaft Help
- light lever took a crap
- 07 ss sc cruse control not working
- Not shifting? (automatic)
- clutch issue on 06 cobalt ss sc
- Misfire on cylinder 3
- Someone help me figure out what's wrong with my cobalt!
- 2005 Chevy Cobalt LS Coupe BCM issues
- Weird noise!!
- No MIL but codes still coming up
- growl coming from engine bay
- LED plate bulbs not lasting
- '06 Cobalt problems, RPMs shooting up, have to force to go past 20!
- Car won't start sometimes P0017 sensors changed
- Keep blowing fan fuse
- Oil usage/ oil leak problems
- Buying creat motor
- Boost Problems, I need help.
- Rpd and other problems
- Any help in South Tx? with 08 lnf
- lash adjuster noise?
- Car won't crank over
- My car battery is located in a weird place. Also a few additional questions (2007 LS)
- Wheel Shaking while on 5th gear
- Dipstick popping out and expelling smoke
- VATS issues wtf!
- his stopped working
- help please! keep blowing fuel pump fuse
- LSJ - disappearing coolant. Thoughts?
- Will it blow up?!?
- MAF codes
- Help! (video included)
- lsj exhaust cam sensor
- Help finding a serious short
- SS/sc Ticking noise. Fuel Rail?
- Help needed....fueling issue @wot
- put engine back together and it won't start
- LSJ 2.0 SC What should happen when map sensor on top of Supercharger is unplugged?
- Blue and black smoke??
- Engine Bolt Sizes/engine stand help
- any suggestions?
- ss/sc issue
- 2007 ss sc dtc
- Car won't start after hooking up battery.
- 02 problem
- TVS -Arrived
- metal rattle over bumps
- Spark and Fuel still won't start
- 2006 2.2 cobalt misfire problems
- Water, passanger floor board.
- A/C compressor cycles on and off
- Cobalt harder then normak to turn in only one direction
- Cruise control and steering wheel buttons not working
- ZFR Repair
- CRAZY electrical problems
- problems after engine rebuild
- p0010,p0171, p0833 with misfires.
- 06 Cobalt SS Start Issue (brake/clutch pedal
- Pulled these 6 codes with trifecta code reader from odb2
- A/C Thread - How Cold?
- Rear view mirror fell off
- Valve Cleaning on the LNF
- Check engine code says running too lean
- 2.0 blown. can i use 2.2?
- steering issue
- Help!!! p01182,P0033, p0068 code and limp mode
- 2005 cobalt ss supercharged problems running!
- transmission/clutch issue?
- Annnnnndddd its broke
- Broke antenna base - question about grounding.
- p1101 is kicking my ass
- LNF won't start
- Help needed!
- 2008 code P0011
- Abs - wtf ??
- security light
- Cobalt SS Trans bad for third time HELP!
- Looks like some oil in coolant reservoir
- 4th Pops Out of Gear After Tranny Rebuilt
- Cruise Control stoped working.
- Possible vacuum leak?
- 08 cobalt sport cruise control not engaging
- Cranking engine by hand
- can someone help me?
- My situation with GM
- Randomly won't start.. Theft Protection? Help please
- Cobalt SS No crank, No start, Theft Light -HELP
- still having idle issues....suggestions?
- Where in the **** do i ground my amp?!?!
- No steering response. U joint/rackopinion??
- P0107 low voltage and low boost reading
- 06 LSJ CEL party..
- problem with 2006 2.4 ss starting
- Slave Cylinder, No Start, Bad Power Steering Pump
- GM service Rep?
- need help all dash lights coming on
- LSJ excessive blow by, Bad Gas milage and P0068, P1182
- Is your Sunroof Bezel Busted?
- Could i get this done under warranty?
- Headlight amber bulb issue
- Possible cause of tick?
- Help: Replacing CV Axle
- Airbag problems
- Symptoms: During Acceleration, rpms continue to climb, power feels like it drops.
- low Boost after intake install.
- HELP!! shift cable clamps
- 2.2 vs 2.4 radiator fan
- Chirping noises from the right wheel.
- Loss of power, rough idle
- Clicking Noise when turning
- Radiator fan
- issue after installing mods need help fast
- Power steering is interminent
- How to even out parking brake cables?
- Upper charge piping breaking HPFP sensor
- Hesitation and white smoke during boost
- 2.2 06 Starting Problems
- zzp s3 heat exchanger questions
- Need new Catalytic Converter/Downpipe
- P0013 P0014 turning off and on?
- Quick battery drain
- ss/sc belt wont track right
- Uh-oh, engine rattling noise... sometimes..
- Light Issues
- Car won't start after WOT box installation Please Help!
