- Urgent!! Beeping..?!
- P0443
- Gap in the bolt in the steering
- cel on
- Sputtering
- Wiring harness question
- 2.4 Automatic Tranny Problem
- Brand New Cobalt SS/TC 1st & 2nd Gear Dead
- Accumulated water in left tail light
- CEL, REDUCE ENGINE POWER, CPS learn error
- Just installed...
- Parking Brake FIXED!
- Flex pipe crack...need some opinions!
- Need some help with the halos....
- Engine coolant temp gauge malfunction
- Power Door Lock Issues after flood....
- a little explination of a bad day im having
- bout to buy talon tsi awd but have a question
- Power Steering Failure
- Quick Question plz need help!
- Dealer service
- general maintanence
- should i take my car in?
- 40K servicing?
- shaking at 5mph-20mph
- blown struts...30k miles
- shaking/vibrating problem with new wheels
- How do i take out my dash trim!!!
- Broken Speed-o?
- Bad set of Tail lights??
- Tach Spiking in 4th/5th
- Help!!!Plus part number lookup.Help!!!
- Put a hole in the radiator (PICS)
- door handle rattles
- 218ºF.... running a little hot?
- weird drum brake noise...intermitten rubbing?
- 12V plug not working?
- Help throwing code P0690
- Major problem
- Made a booboo putting wheels back on
- Steering Rattle
- Dealership install price?
- clutch slipping? lost boost.
- o2 sensor help
- gray smoke
- Passenger Side front Axle!
- Fuel Pump Issue
- So my car died today....
- Losing lots of oil after an oil change.
- i got my block back
- Head light problem
- Door Problem
- Power shut down problem...
- help P0132 and P1133
- Vibrating door handle.
- Metal on metal rattle
- Air bag light stays on?
- Damn Fuse
- Car is down...again
- Hood Strut?
- exhaust leak? not sure help.
- so.............
- p0481 help please
- 05 SS/SC questions
- how do i fix a broken lug
- Half-Shaft Boots!
- Need Help to pass Inspection
- ABS light problems?
- Gauges and Taillights now working?
- warrenty?
- boost pressure drop!!!
- Rattling from front end
- a/c not working (not a cobalt, silverado)
- Car not pulling its self
- Bad Stumble!!
- gas cap
- ac leaking
- trouble with reverse lockout
- Strange Sound
- getting the car in first gear problems
- Weird exhaust tone
- P0420?
- Headlights????
- Sun Roof
- Radio freakout
- Windshield: Replace or Repair
- supercharger coupler
- SS Stock Gauges go crazy, then work fine? I need help! Confused ?
- Won't start, theft lock symbol on
- Cam shaft sensor and misfire... HELP!!!!
- engine problems
- warrenty.
- Gas pedal sticking??!!
- boost gauge not working?
- Looking for OEM part
- *Read*
- Reverse lights dont work
- Boost Dips & Slow RPM Rise
- Horn honks until car is started
- I goofed
- I goofed
- p0036 && p0114
- Rough Idle issues...with DTC's.
- Oil replacement light wont go off...
- Loud Noise coming from rear....PLEASE HELP!!!
- CEL light for O2 sensor
- Where to find the general maintance?
- car running wierd
- Firing order?
- ebrake problem
- Threw some new codes
- supercharger clanking
- plz help
- Engine Code Problems...Please Help Fast!
- First DIY Oil Change
- Oil film on inside of drivers side window and two scratches on my tint!!!
- All the sounds in my Cobalt SS stoped working, even stereo... FUSE?!?
- High Rev, No power
- Car refuses to idle smoothly. Please help
- Air Conditioning smells like death
- Codes...arggggghhhh *wtf?
- Control Arm/ Sway bar Link
- Redused Power
- boost loss and slow climb?
- wiper problems!!!!
- what causes this code
- HELP: Taillights and dash lights out
- O2 Sensor
- thermostat replacement
- FINALLY a vid of eurochevy's shit engine! come in and listen
- Ignition locked! Anyone know why?
- So Guess What I Woke Up To This Morning..?
- Interceptor issue.
- inspection/cel
- Headlight fogging up
- recent issue
- 12v source
- cel after front end damage repair
- Just installed my hids and.......
- Quick Oil Change Question?
- Dealer says PCM is bad - Help
- What recalls?
- Tranny Problems......
- A rip in the stock tranny mount
- Brake light flashes once in a while
- Exhaust shake...?
- tire light
- Anyone having problems with their radio display?
- *sigh* more problems lost 2nd and 4th
- Serpentine belt
- need help for adjusting a bolt on actuator
- New plugs = running hotter and better mileage?
- Running A Bit Warm..
- Replacing air filter
- my car is sluggish
- Injector Testing
- CEL after removing SC
- TB Alignment Help
- Header/DP Install -> Many DTCs
- help wit CEL
- Speed Sensor, Speedometer Gauge Not Working!
- help with power loss, lagging.
- Steering feels loose on bumps
- Wiper controller on Column
- Struts and Tension linkage replaced
- Cracked casing?
- 06 sprchrged clutch problems,cv click,air filter
- engine dropped a valve after dealer service, warranty wont cover repairs
- Boost Gauge not reading right...
- weird noise.!.!.
- 07 cobalt 4dr - Brake Light Issue
- Stabilizer Bar Links?
- car goes to limp mode at 5500 rpm
- ABS light/braking issues
- DashHawk Problems
- E3 plugs destroyed LSJ stage 2!!!
- Anyone else breaking shifter roll pins??
- Screw Size
- leaking coolant.....
- Misfire Help
- Good 12V source
- Return kit
- just got another 06 g85
- Reduced Engine Power
- New clutch at 14'000K? Don't Think so.
- gas mileage problem
- power surging/poor idle sometimes
- my leds in my halo went out.
- Serpentine Belt Shredded
- got p1182
- Blower fan problem
- The Dealer is gonna have the balt til wed..
- damnn brakes
- Help-A/C stopped working
- condensation in headlights
- CEL light came on
- Car Shuts off, silps out of gear in 3rd and noise!!!
- Problems with my 07 SS/SC transmission! SH!T THIS!
- New noise...please help.
- washer fluid.....
- Can't get the Key out
- Header warranty?
- Please Help!! May have fried the PCM
- 4 CEL codes after zzp combo an stage kit
- Coablt is down!!!
- yet another broken wheel stud.....
- scracht rims =[
- Engine Blown.....AGAIN!
- 3K Seats coming apart!? Warranty
- P2261 - Turbo/Super Charger Bypass Valve - Mechanical
- What should i do???
- rear brakes apart
- Cheap Way to get rid of p0420
- Misfire all cylinders post-header leak fix....WTF?
- clutch slip?
- Cobalt DOWN!!!!!
- ZZP down pipe broke!
- 3 muffler shops and no luck
- Rant about service
- Lots of upgrades...where's the power?
- need help replacing rear left blinker
- Dead battery=headlights fault???????
- Interior lights question
- wtf? rough idle when a/c is off
- Something scary when I'm driving...
- ignition problem
- figure this one out...
- Tranny Pan
- 45000 mile maitenance
- a quick question
- How do you disconnect the airbag
- service air bag light..
- Serious help needed - fuel cutoff randomly
- FM Direct Adapter
- The Official "my Power Steering Sucks Thread"
- help quickly
- A/c Wont Work!!!!
- I got a flat!!! But had a question??
- 2008 oil plug TSB
- "service Air Bag"
- no crank/no start
- N2O then P0171
- Wtf Is With My Downpipe?!?! Please Look Now
- hose clamp not tight,radiator hose came off
- Boulder Goblins!
- 227 F Degrees at idle? Yikes?!
- Traction control light comes on and shifting changes
- Cobalt Wastegate?
- Squeek when starting car.
- bypass hoses
