- Hard time starting or wont start after filling w/ gas
- Wierd cracking door noise??
- dirt/oil in supercharger?
- Tranny Problem?
- Exhaust piping help?
- wheel bearing
- Low Coolant
- 4Door 05 Catalytic Converter
- grinding noise in engine bay
- Interceptor Help!
- Speed Sensor Question (ABS light on)
- auto trans troubles
- mechanics, i have a question.
- 1st gen Projectors...Help!
- How do I remove the rear seats?
- timing chain tensioner problem
- They coudln't Change my Oil Because...!
- driver side window stuck down. HELP!!
- Interceptor caught a code!
- Help Car Wont Start Carlock Light
- Weird humming noise while driving
- AUTO TRANS! key will not come out in park
- Annoying AC fan noise...
- Sunroof fuse ?
- help, ran up a pile of hard snow (ice)...
- Yup!! i'm tarded
- Might not be a biggy?
- Cv joint is going out
- Windshield Washer Failure
- What to do?
- Sunroof switch replacement part #
- Thermostat replacement anyone?????
- LSJ head issues
- belt scream
- my MIL is on
- Onstar Antenna
- fujita cold air intake...
- WTF is it?
- Steering feels loose? SSS/c
- Rapid Clicking Noise From Inside The Dash
- Installing Sensor Into Ion Recaros..??
- K&N Filter = CEL..??
- GM lost my Car?
- water in passenger side floor!!
- Oil Life monitoring system question
- clutch stage 3
- unleaded fuel
- code help please!!
- Shifting into gears often difficult
- What do I do
- key fob program/relearn
- Is anyone else waiting for a turbo Actuator from GM?
- only change oil filter and not oil
- Car accident today!!!
- Too much oil?
- blown engine or cat?
- Starter Problems
- Door issues
- stock radio unlocking
- Battery Saver Mode
- absolutly weird bogging...
- I have a Horrible Knock!!
- Downshift Into 2nd
- Switched to SS Injectors
- My car shuts off all electical components while driving.
- Another Mystery Noise Thread
- A/M Exhaust, Void Warranty
- Headlight Question PIC!
- Passenger side rattle?
- Moisture On oil cap
- car help
- anyone work at chevy dealer? warranty? ques.
- odd electrical problems
- Oil in the anti-freeze?
- low hanging exhaust
- Bogging Injen Problem
- Important question
- HELP !! 05 cobalt ss s/c wont start
- fuse block frustration
- Brake Question
- Tire Pressure Monitors??
- Hopefully simple fix
- CEL p0134
- Broken door handle, door panel etc....HELP
- Torque Specs
- boost shutter
- Front Bumper Help
- Stage 2 LSJ jerking
- transaxle differential exploded!!
- battery dying
- Ditched my baby in a white out
- aiming gen 1 projectors
- Driver Door Locked.. Need Some Help
- Major Door troubles!!!
- Back to the dealership for warranty!
- Clicking sound after new header?!
- Coupe door rubbing?
- How to remove E brake boot?
- axles or rotors?
- SS/TC w/20+psi?!
- Gm Pdi Ftl!
- OBD2 is not working..Ideas?
- HID Clor
- went to the dealer.. need opinions
- How to program keyless entry remote?
- TPM going nuts
- How many hours to do this job?
- So my key is stuck in the ignition..?
- is the dealership bsing me ?
- Baking Second Gen?
- clutch problems
- 08+ SS/TC Problems & Fixes / Waiting on parts..
- Burned Brakes?
- 1st time going in on warranty
- Code P0106 and P0128
- HID bulb problems...HELP!!
- Well..they finally did it!
- Car is idling funny on statup
- radio won't power on
- Pulley puller Colorado
- Possible transmission failure. any ideas?
- replacing fuel filter how to?
- Frost on The Inside?
- LSJ shuttering?
- Clutch issue i think...help?
- ? about wipers and lights please help
- Blizzard Driving+spining in hills=overheat+check engine light...
- Code P01174 for my 06 Cobalt ???
- oil life monitor
- header questions...smog legal??... help!
- Clean filter or Buy new?
- Broke the boost bypass actuator nipple
- MPG dropping, cobalt LS
- 08 SS/TC Loud whining from trans in 3rd and 4th & car smells like burnt oil
- pain in the ass headlights
- cold air induction
- Passenger side leak HELP!!!!!!
- I lost 10 psi??? I need help please
- Possible Exhaust problem?
- Door Lock/Unlock Issue ?!
- Stuttering Problem With My Girl's LS
- Check Gas Cap?
- Need Help
- Leaking Axle Seal
- Dealership Christmas Miracle? Ticking Noise
- tranny mount bolts broke
- Blown Fuse (im assuming)
- Messed Up My Ebrake!!
- Crankshaft Position Sensor!!!
- Frozen Door Hinge?
- what is the normal temp for a 2.2 ecotec
- need help with my tahoe
- TPMS sensor
- SRS Light On
- Resonator Rattle
- CEL went away!?!?
- 2nd gear problems
- "Service Traction" ??
- ABS light on
- Dipstick Popping Out
- My trunk wont open think its a fuse
- Do block heaters and superchargers mix?
- trouble getting into 1st sometimes
- 2nd Gen Projector repair?
- damn cel
- Need Help
- Air bag lights on, was in accident, need help quick...
- Oil leak from somewhere?
- stundering wipers PLEASE HELP!!!!!
- CAR POWERLESS!!! like no batteries...
- Power Cut-off above 4000 RPM
- HELP rear turn signal non workin
- RPm problem
- help wit my MPG
- i hate hub caps!!!!!!!!!!!
- automatic locking prob
- Need Help Now With Gm Dual Pass !!!!!!!!!!!!!!
- Squeaking when cold
- damage estimate?
- Cel P1133 P1072
- Alarm keeps going off when unlocked..
- Cel
- P0141
- Fixed Map Sensor and still having problems.
- HELP with dealer
- What is it guys, Alternator or Battery?
- Cobalt SS/TC...Service ESC
- Don't listen to yourself when you want to trade-in your car...
- i need a good how to for installing a dual pass
- 2006 Cobalt SS/SC Air Bag Module--Need Help
- P1101 And P0300
- Bad grinding noise. Half shaft and hanger gone. (Pics)
- 210 Degrees F?!
- Cost to Replace Timing Chain Tensioner?
- When I go WOT, my car 'shakes'...
- powertrain & tire size?
- Ugh Shaking
- Wipers not working
- new downpipe now im throwing cels
- Horrible front end noise in cold weather
- WTF35 Transmission Cracked...again
- out of service might be for good
- Service Dept. WTF?
- Have a Question !
- 93 z24 shakes really bad?
- Heater Fan Grinding
- 09 cobalt lt, making clinking noise
- Question for all 2007 LS cobalt owners about brakes.
- Stuck at 3k RPMs?
- 02 sensor cel eliminator
- Washed Car now I have a Problem!!!
- Squeking sound coming from front left wheel area ***Help***
- CEL is on
- Rough Idle..Ingalls to blame?
- sooo...got my back and :(
- Vaccum lines From man to bypass to actuator
- 06 SS/SC clutch issues??
- rats help!
- Car stalls on bumps
- zzp or xtc downpipe
- spring install vibration
- downpipe nuts
- Cruise Control Does Not Engage
- problems shifting...2.4L Sport
- Tire Pressure Monitor System (TPMS) problem
- Wtf
- New to engines...Dealer wont help
- power steering problem
- Questions Regarding DexCool
- chevy dealer
- HELP ASAP: Clutch/Throw-out Bearing Going!!!!
- new tsb for 2.2 and 2.4 ecotecs.
- downpipe
- Transmission problem?
- inconsistent power supply?
- Clutch and Gearbox problems
- muffler-tip moves alot
- wtf stall while driving?
- power steering? WTF
- wtf...headlights quit working
- Help!
- Rear brakes making noise
- Big Brake Kit squeak...
- Is it bad to erase the CEL?
- Temperature not Showing
- all sorts of front bumper problems and questions
- Soft Clutch Pedal Fix.... I think
- Manual shift cable GM upgrade 2008/2009 SS/TC
- AC clicking noise
- Worst SS/TC LUCK EVER!!!!!!!!!!!!
