- Dash/elctrical
- Fuel pressure spikes at idle and causes rough idle
- Crank no start
- 2009 Pontiac G5 No Crank/No Start
- Buick Regal Gs with LHU low boost issues
- Pulsating vibration at 2500-3000 rpm
- 09 LDK SS makes no boost. But no boost leak.
- Bleeding coolant?
- Installing aftermarket radio
- F40 trans swap axle problems!
- P0411 with new solenoid valve - need wisdom!
- Really odd issue for you cobalt masters to figure out! pls help
- Did some engine bay cleaning
- Rear axle swap problem.
- 2005 Cobalt SS Crank No Start
- No crank no start can’t get anti-theft to go away on dash
- Replacing AC Line Help.
- LNF Brembo brakes
- Driver vs. Passenger Strut
- Gabriel Struts - $61 Clearance Price
- Bad ball joint, or?
- Bad gauge Cluster???
- 4.45 trans issue?
- Crankshaft position sensor
- 2009 SS loss of boost, misfiring, intermittent
- P0128
- 2007 cobalt ss supercharged rough idle
- Loud during cold warmup - 2009 Cobalt LT 2.2
- 1 front wheel hub or 2?
- I’m about to set this car on fire!!
- E-Brake Cable Alignment Off
- reduced engine power-P0017-P0420-P 0068-P0300
- Service Traction/ Reduced Engine Power
- Random loss of power LSJ
- Back doors won't unlock
- stiff steering when stopped
- Auto axles
- K&n air intake
- Engine not reaching optimal coolant temp
- no start no crank no click
- Wet back seat?
- No Power after VSS Output Replacement
- Air/Fuel ratio running Lean...
- Top of driveway scrapes bottom of my car. Help please
- Problems after MAF replacement
- Odd temps
- *HELP* Long Term fuel always rising and limp modes at 25% compensation
- 2007 cobalt ss supercharged radio no power
- Random misfires built LDK long block
- howl noise remains after replacing hubs
- Steering column help
- Rattle / clattering @ low rpm with little load on motor. (Video)
- Need help with ignition switch
- Buying 09 Cobalt SS, has sat garaged and undriven for 5 years.
- Boost issue
- LNF and LDK OVERHEAT FIX
- Need guidance
- Need help
- Not another P0446 !
- Engine Fans Always On
- Front end noise
- Headlights/Blinkers issue
- Dual interceptor Aero force gauges went out
- Need DIC help!
- Slammed on brakes to avoid accident, now have a strange sound?
- Colbalt o2 sensor cheap one does not work
- 2.4 Fuel Pressure specs?
- P300, P301, P302, P303, P304, Blinky CEL
- 08 cobalt ss low speed vibration
- Wastegate Actuator Broke
- Bad piston rings.
- exedy clutch
- Only getting about 1.5 psi boost at most.
- Cobalt Bogging down while Driving
- Muff Hair?
- INTERMITTENT p2261 bypass valve CEL at full boost
- Weird idle when rolling
- Fuse keeps blowing
- Just bought an 09 Cobalt ss and having issues
- Painted valve cover pain in oil
- Pontiac g5 gt transmission not engaging
- Cel p287, oil in charge pipes, misfires
- Clutch fixed n now power steering gone
- Used supercharger
- Fluctuating rpm at steady throttle
- Put original head lights back on. Gauge lights no longer work.
- Gear indicator Part
- LNF will NOT crank after intake manifold job
- sstc engine mount part #?
- Seriously Super Stuck....
- multiple issues......p0101
- Trying to find a replacement part
- Low boost or normal?
- Surging when coming to a stop.
- 09ss
- Anyone heard this before?
- E brake Light Help
- Boost dropping at 5k RPMs
- Valvoline Modern Engine Oil
- Supercharger coolant pump
- p0101 code, many broken parts, please help!
- ac clutch on compressor noise
- 2005 SS/SC No start/No crank/No radio?
- Powersteering
- bad boost solenoid?
- Need your help
- Need opinions on Mityvac
- Fuel leak ahhhh!
- P0340 and P0341
- 2008 LNF: Service ESC/ Service Traction
- Sunroof pops open
- Intermittent turbo flutter
- Engine cooling fan not running?
- 2010 Cobalt rear signals and brake lights not working.
- cold startup issue
- A/C fan stopped working
- No start but has power.
- Engine HELP - New Las Vegas 09 SS Build
- Snapped passenger side motor mount bolt
- New timing chain sprocket won't fit on to crank
- G5 GT turbo issues
- LSJ pvc unit
- Belt Squeaks with AC on
- Not starting first time every day
- Trouble with clutch/transmission
- SS/SC Heat exchanger hoses
- 2006 Cobalt SS/SC 2.0L - New battery, no power, no start
- FUEL Odor coming from injector area
- Roaring noise when turning from a stop or at low speeds
- Turn signal load resistors
- 07 Cobalt No Crank! ABS/TCM/Steering Control
- LSJ Oil Cooler?
- Evap po442 po455
- Cranking no-start
- LNF Issues please help.
- Boost leak?
- Strange codes
- Eaton m62 snout to housing bolts
- No power steering
- 06 ss/Sc intermediate axle shaft
- Help! car keeps going in and out of limp mode
- 134a capacity 06 2.0L ss sc cobalt
- 2006 cobalt misfires over half throttle or 20kpa boost help
- No Tach, P0335, Service traction control,
- P0335
- Front left clunk clunk
- Ignition switch problem
- P0236 nightmare
- Best website for cobalt parts??
- no start no crank
- Fuel gauge not working properly. Gauge or sending unit?
- Rich condition
- Pop and bind when turning and in throttle...
- overheating
- Might be experiencing a boost leak, need 2nd opinion
- Cel, tc light, hard shifts, Com error. have researched!
- running light won't disable; parked
- P0562 Code
- Po302 Misfire
- Starting issues with lsj
- Keep Blowin Fan 2 Fuses
- Tire wear
- snapped axle?
- Fuel filter ish problem
- Shifting problems
- Steering column noise
- Ka-chow .... How to do timing kit?????
- 08 Cobalt SS Turbo running rough, horrible gas mileage
- 06 2.2 randomly goes into "limp mode"
- P0014 won't go away
- How to change Lnf tensioner ?????!!?!?!?!
- Lnf excessive oil blow by.
- cobalt ss lnf codes help
- Leaking hose
- 2009 Cobalt SS trouble starting
- Door locks
- No electronics, no crank, nothing
- CEL Codes
- Intermittent Crank
- Only 7 psi
- 08 cobalt ss turbo p0036 code
- Oil leak in front of engine
- P0481 Code
- bottom timing guild bolt part #
- AC evap leaking
- C0550/abs, esc off, service stability
- Traction Control Light / shifting issues
- Intake Cam Slipped help?
- Less boost than before/acceleration surge under load
- AFR Jumps way high in boost
- 2008 Colbalt 2.2 head
- Do I need specific parts? 06 SS SC
- P2229 code popping up
- 12V Outlet Part #
- Lnf windshield washer pump
- Misfiring Under Load
- Crankshaft senor location
- High RPM clutch drag
- All rockers broken
- 09 cobalt ss p0191 and p2178 codes
- Porformence Problems
- Broken air intake
- No start issue (Crank position sensor?)
- 06 SS/SC Bogging issues
- fuel pressure problem lnf
- Corroded Fuel Line Leaks
- Stuck and need help... Bad idle with infamous P0171 code
- "check gas cap" message, always...
- LSJ Boosts Fine for 10-15 Minutes, Then It's a Bucking Bronco Under Boost
- ohio E-check Problem
- Misfires and running lean.
- air/fuel codes and more
- Suspension problems.
- Doors locking by themsleves
- Does'nt Start Cobalt LS 2006
- seatbelt/airbag & clicking?
- bent ac condensor?
- 2006 cobalt supercharged ss intercooler intake leak
- no start. one loud click.
- 2006 cobalt ss 2.0 supercharger coolant
- code 238,237,236 wont clear
- Lean At Idle
- High Idle Above 5mph
- Supercharged lsj lost psi
- Cobalt SS 2.4 won't start, wire issue/BCM
- Weird? Issue fuel related
- No crank with key, but remote starts fine
- LNF S257 install
- Knuckle on ball joint lube
- Car wont start new engine installed Help Please
- Trouble Starting the car
- No crank. Urgent
- No crank
- rough idle / random misfire w/ low gas
- Replacing Blower Motor
- What the heck is going on?
- Axle install and ring 24205145
- Car will not start.
- Metal debris on Cam Acutator
- First ever fuel leak 14 years running OEM lines
- 2006 cobalt SS Sc intermittent fuel problems
- Differential noise
- Surging while acceleration
- 2006 2.4 Cobalt SS transmission blown. What are my options?
- Help with wiring trace for P0100
- Evo series Gauges off Ebay
- LSJ CMP housing seal/P0017
- Urgent: 15-way Adjustable Coilover Adjusting 30-Way now?
- Boost Problem, Help Please
- Oily stain on supercharger, hissing sound, poor gas mileage
