- Pics of LAP/LE8 piston face or short block with the head off?
- Secondary Air Injection
- Big 3 upgrade question
- Running rough in rain
- 2.2L super charger swap
- ZZP longtube header fun
- 2.2 LAP Supercharged Belt tensioner question
- 2.2 Supercharger Build WOT Problem
- Electric water pump
- Wiring and Communication DTCs - No Start, No Crank
- Coolant temp not reading and no start
- 2.4l trans swap
- Engine troubles
- 2.4 swap options?
- Tuning
- 2008 LE5 Throttle body on 2009 2.2 LAP
- 09 2.2 lap m62
- LAP i4 mods
- P0171 code issues
- 2010 cobalt 2.2 wiring harness diagram
- p0480 Cooling Fan 1 Control Circuit Malfunction
- Is a lap wiring harness comparable with a le5 engine
- 2010 cobalt 2.2 mass airflow problem
- 2010 cobalt 2.2 ecu pinout
- Supercharger build Lap
- Cobalt LS 2006 does not start!!!!!
- lsj throttle body wiring
- 2.2 LAP Intake sound
- Will this Ex. Manifold work for me?
- Can I use another Cobalt ECU?
- 2.2 sc clutch reccomendations
- l61 block with LAP head
- 3 codes n was wondering what it could b
- Where is my MAF?
- 2.2L stumbling.
- Auto Turbo Aspiring
- New to cobalt ss
- Occasional Misfires
- 2009 2.2l lap fsm
- Help: 2009 2.2L cranks but wont start
- Know anywhere near London Ont that will tune?
- Low RPM's and stalling issue after supercharging
- Computor Swap
- Gmpp clutch for the 2.2?
- Help car cranks but doesn't start. Fuel pump not coming on. At all.
- Exhaust questions header dp
- Camshaft grind number
- Manual 2006 2.2 SC Cobalt
- 2009 2.2 ecotec into 2007 2.2 ecotec?
- Engine code in VIN
- Cai and exhaust
- Engine swap
- Exhaust Question
- Throttle body info
- 2007 2.2l supercharge possibility?
- Wideband o2 Stimulating Factory NB o2
- Help identifying part
- custom trigger wheel
- Air Filter with SAI
- air intake
- 2.2L ZZP supercharger install
- Please help! I don't know what I need.
- 2010 cobalt 2.2 lap 2 or 3 bar options?
- Eaton M62 Supercharger in 09 Cobalt LS
- 2009 Cobalt SS 2.0 turbo onto 2009 Cobalt LS 2.2
- Oil pressure sensor removal. WTF?
- 2.2l swap from 2 diff cars, will it work?
- Back by popular demand
- LAP move
- LAP blown up.
- LAP rods and pistons
- went from stock exhaust,header,muffler,piping,resonator
- in need for input
- rewiring zzp TB harness?
- No acceleration power
- Will it limp???
- Heater core leaking
- Got a CEL and these codes
- Need help
- LE5 cams in LAP
- A little FYI for you
- why is it so hard to find someone to tune an LAP?
- trans mount problem
- Need help
- Intake Swaps
- Supercharged 2009 G5
- Vacuum Leak? SeaFoam Smoke Under Hood
- intake manifold
- Supercharger for 06 ls 2.2 ecotech
- Products for fixing cracked header
- can I install....?
- PO411 Question.
- LAP Axle strength?
- Full service
- building turbo kit
- Supercharger kit to sell?
- LE5 SS/NA cat-back to LAP
- supercharging - 2.5 bar map rewire + iat2 ?
- gas matters?
- LAP swap questions.
- turbo vs super
- when to change some thing?
- Wow
- New to the scene and
- turbo lt
- Airbag codes help?
- Since GM won't help me...
- LE5 gone SC!
- You follow the oil life?
- "Normal" Engine Sounds?
- Looking for used cobalt 2.2 turbo/supercharger kit
- 2.2 LAP to LSJ tb wiring diagram
- max hp on street legal upgraded everything 2.2 lap xfe
- Retiring the balt.
- Engine swap
- Is this a good deal?
- 2.2 LAP Turbo Build need help with Saab lk9 Intake
- Orange wire with what stripe.
- connecting rod torque specs needed!!
- exhuast question.
- LAP Auto Trans
- info about the point of tuning.
- Solid-state
- Engine build!
- Update!! :d
- Door Latch Question?
- Full Bolt ons?
- Oil Pressure
- 2.2 lap surcharged build.
- lap intake manifold
- engine code P0011
- Balance shaft delete
- 2.4 tb kit
- intake installed
- darn plastic engine cover
- tune up
- 2.2 problems help?
- Is this possible...?
- Steering wheel shakes after braking hard a few times
- Building for turbo
- Air Injection and Header
- Auto trans shifting kinda odd...
- Trans Swap
- Anyone else notice this...
- Clutch and tune
- turbo help
- 2.2 lap turbo question
- 2010 Cobalt LT help
- P0010 engine tick and sputter
- S/C prep
- can you really?
- Engine tick and sputter
- should i S/C my 2.2?
- coolant problem!! help cobalt friends!
- throttle response
- lets talk turbos!!
- swap options???
- average coolant temp??
- coolant heat?? and steering.
- 350hp??
- Wideband/Add A Circuit?
- My 2.2 vs 2.4
- New Engine P0365 Cannot Relearn HELP PLEASE
- side exit ;)
- Odd Problem, Any Help Appreciated.
- oil leak
- need help with map sensor.
- bad idle issue, help!
- Tranny fluid?
- 0-60
- Need some opinions!
- Chip.
- Meth..
- o2 Sensor?
- engine rattle
- boost
- Credits?
- Fog Lights?
- lets try again...
- The build
- C a m p h a s e r s ? ? ? ?
- i need help, and possible guidance
- sc build with no power
- need help zzp injectors.
- engine rattle
- I Smell Gas.... Help!!!
- head swap on LAP
- lsj fuel rail cover on 2.2?
- Holy cow crap.
- lash adjuster install help/actuator locking tool?
- Header Question.
- oil on ONE spark plug
- Dc front strut bar not fitting >:(
- 200?
- gibsonj4's LT/SC Detailed Build Thread
- Need help ASAP!!!!
- Ev6 to EV1?
- 09+ TB LSJ Wiring Harness Adapter
- Lazy ZZP
- Silencer
- Ssssssssssssssss
- new ZZP downpipe and CEL problems
- jerking
- Parts Feeler
- What to do?????
- Need help deciding which header/DP to go with?
- Anyone done a swap??
- Valve Cover Help
- Silencers, ways to make it more quiet
- Warrenty?
- LAP head with SAI ports
- 2009CobaltLT's 2.2LAP SC Build Thread
- oil pump
- Header downpipe question
- Installing Badmab header on a 2.2L LAP while removing SAI
- Exhaust Opinions please?!?!?!
- HP vs Trifecta?
- Eventual TC Build for my 2.2
- Headers and backpressure
- need power.
- Bigger injectors
- 2.2L Eco Catback exhaust
- Thoughts on 2.7 pulley
- LT exhuast removal? help
- Exhaust Options
- 09-Cobalt-LT Supercharger Build
- Going to the Track Tonight
- friends car needs help.
- Using LE5 TB for turbo setup.
- turboed 2.2's
- What more can I do?
- 2.2 LAP Mods?
- LAP Throttle Body
- That engine whistle
- LAP Oxygen Sensors
- Couple of questions
- cobalt ss bumper mouldings?
- Downpipe and exhaust!
- Badmab header
- steering issue?
- Bad Mab header issues
- Mufflers - Best bang for your buck?
- Radiator Hose ID?
- ecu swap
- 2.2 tranny fluid change how?
- exhaust problems...
- B&M ShiftPlus Electronic Shift
- Somebody Identify This!! PLZ
