PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99]
  1. Clicking during gear change.
  2. south jersey blower porting
  3. K&N Intake done?
  4. Buyers Beware!!!!!!
  5. BOV Install on Supercharger?????
  6. vaccum line mod
  7. Cobalt SS exhaust question? VW R32 exhaust sound Wanted
  8. If you had a Rattling exhaust chech this out.
  9. 06sc/ss
  10. Part # needed
  11. any mods other then engine?
  12. amount of boost @3000rpm
  13. Heat exchanger upgrade
  14. HELP!!! Trans Grind
  15. ? Coil Cover Cracking ?
  16. Blower Oil?
  17. Short Ram Intake
  18. K&N Intake
  19. Ported Blower
  20. TOG Group Purchase.....Sign up here!
  21. piggyback install update
  22. Rev limiter?
  23. Cai
  24. BOV (DUmp Valve) ON SS
  25. SS Aluminum Door Sil Plates
  26. For the cold season
  27. Smaller Crank Pulley
  28. Street tuner challange
  29. Lookin Good!
  30. Close Up-Engine Pictures for Swap.
  31. cobalt like the wots
  32. Ss/sc Injen Intake!
  33. Ordering My New Exhaust system
  34. smaller pulley
  35. Performance chip on eBay..
  36. filter drop question
  37. FREE HEADERS... from theotherguysproducts.com
  38. any1 tried that south florida pulley?
  39. magnaflow catback system
  40. Got my car dynoed
  41. Break in my cobalt SS for 12 lbs.
  42. engine skipping
  43. SFPH now has the NGK BKR7E Copper Tipped Sparkplugs!
  44. msds headers.. for the 2.0
  45. Spark Plugs?
  46. K&N intake coming soon
  47. gm performance catalog?
  48. video of my cobalt ss w/ semi cai
  49. Eaton M62 blower specs
  50. Difference between s/c and turbo
  51. The Z Rated Tire issue
  52. Oil FILTER?????
  53. SS Major Issue
  54. just bought a new SS/SC
  55. Intake question
  56. Finished Semi Cai System On My Ss
  57. Racing Chip
  58. Something to think about....
  59. Cobalt SS vs. SRT4
  60. Who to buy from?
  61. Vacuum @ 70mph?
  62. injen intake for ss
  63. 12.5psi???
  64. DYnoed my car- 102 degrees outside
  65. Non Supercharged 2.0
  66. name this exhaust manifold
  67. Cut-Out?
  68. Boost Cooler
  69. Launching an SS
  70. ECU Reprogramming
  71. engine assembly
  72. Damn She Moves!
  73. Wheel/Tire Size
  74. Weird Noise
  75. Safe to run octane booster with high test?
  76. Blower Porting
  77. SC Pulley swap
  78. Protecting the intercooler radiator
  79. Rk sport Cat-Back
  80. LSJ in other cars?
  81. K&N Intake Coming In
  82. Some video ideas
  83. How much did you get your SS for???
  84. $500 to spend and wanting an opinion
  85. Shift Light
  86. g85 performance package
  87. K&N needs a Cobalt SS for development of intake in Southern CA ! Get a free intake !!
  88. Shifting help
  89. ss clutch problem fixed
  90. Piggy Back ECU/Smaller Pulley
  91. First Dealer service
  92. SS/SC Dyno Results
  93. Corsa SS cat-back
  94. Will There Ever Be Any Performance Upgrades For This Car?
  95. Break In
  96. Airbox Mod
  97. GM Upgrade Kits...???
  98. Only one recall found
  99. Boost: Anyone getting 12psi?
  100. Sticky **GM Racing Releases New Sport Compact Performance Build Book
  101. Intercooler plumbing diagram
  102. K&N Filter E-1009 ? Fitment ?
  103. LSD Available Aftermarket???
  104. SCdyne LSJ Header
  105. Tire Opinions
  106. Shredded intake tube
  107. New Cobalt SS Video
  108. redline intake on cobalt ss
  109. intake
  110. Anyone with a SS around Youngstown Ohio???
  111. aftermarket intake question
  112. Mods??!?!?!!?
  113. ss clutch
  114. Exhaust Question
  115. Scantool and some test results
  116. Cold Air Intake
  117. Cold Air Intake
  118. Whats Better
  119. Redline / SS Short Ram Intake
  120. Chevy or not Chevy
  121. press on pulleys already available
  122. Headers: The Other guys
  123. Ss S/C Air Intakes
  124. Dyno results of our 05 SS, Video of car on dyno !!
  125. Single or Dual Exhaust
  126. SC Whine
  127. I need more video/sound bytes!!!!!
  128. Autotap
  129. Comp Cams
  130. Rksport Exhaust
  131. SS/SC Air cleaner
  132. Has anyone used or researched Royal Purples Purple Ice Coolant Additive?
  133. could i?
  134. Motor Trend
  135. Scan Tool...
  136. cold air intake or intercooled?
  137. All About the LSJ
  138. K&N Intake Dyno Results (Redline)
  139. Gas Milage
  140. What octane of gas are you guys putting in your SS/SC?
  141. Headers
  142. Govener on the Cobalt SS
  143. Supercharger whine
  144. Supercharger whine
  145. Cobalt Pictures
  146. Do they even make anything yet?
  147. Saturnalia Ecotec Review
  148. Break In?
  149. 2.0 Ss Supercharged Crate Engine From Gm!!!
  150. performance/warranty
  151. Looking For More Mods!!!!!1
  152. NO Cams! (coates spherical rotary valve Cylinderhead)
  153. 2.0 vs 2.4?
  154. Question RE: Fuel
  155. Performance Package
  156. Free Power for the LSJ?!?
  157. EXP4 Gas and Oil Additive
  158. Dyno Vids
  159. throttle body?
  160. 2.2 gm performance head fit the cobalt SS?
  161. active oil cooling??
  162. whats the word on a header
  163. Oil Changes
  164. Cobalt SS SPECS!!!
  165. PSI-FI developments???
  166. Saw this on Redline Forums...
  167. 2.0 s/c Pulley's
  168. Stock Boost???
  169. DYNO Results!!!!!
  170. AndysAutoSport.com
  171. Easiest way to make more power.. More Airflow
  172. Cam regrind on F/I
  173. AEM coming out with CAI for EcoTec 2.0 s/c
  174. 270 HP!!!! From 2.0 S/C
  175. consistant dyno numbers, i like it
  176. 2.0L SUPERCHARGED DYNO NUMBERS!!!
  177. cobalt looking better ?? Redline new dyno numbers look!!!
  178. Crank In Cobalt SS
  179. buying a 2.0 supercharged motor
  180. Cobalt SS supercharger.
  181. 2.0L Supercharged Specs
  182. LSD
  183. An Inside Look
