PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Ram Air system in progress... Pics Inside!!!
  2. Guy wants to race me
  3. swaping pistons need some more opinions.
  4. Im kinda confused why people bash intense tunes??!!
  5. which cold air intake should i get?? INJEN,K&N or Fujita?
  6. what can i do to make my car faster?
  7. SS/SC Tommorow
  8. air fuel gauge question
  9. Ah! Bypass Valve Leak/ Solution?
  10. another exhaust question
  11. Exedy Hyper Single Stage 3 Finally In Stock!
  12. I have some choices to make
  13. Ported Stock Manifold VS. GMPP Manifold
  14. another one bites the dust
  15. TTR, Crazy Cutlass, and ?s
  16. Something wrong?
  17. Airbox Mod Cutout
  18. Stage 2 vs Cobalt Add s2
  19. Stage 2? maybe indash?
  20. 2006 SS/SC Mod Questions
  21. Please read and help ASAP
  22. Clutch dilema need input PLEASE!!!
  23. SLP exhaust for SS/SC?
  24. stock belt+2.8"=15.9psi..belt slip???
  25. questions regarding LSJ build guide
  26. better motor mounts
  27. Guys with breathers, got a question.
  28. some luck i got
  29. Tach Question
  30. Stage 2 Question
  31. Nate's Pulleys
  32. Just bought a 2007 Cobalt SS/SC, what should I know?
  33. Spark plug question
  34. Help with next mod for SS/SC
  35. Serious question
  36. I thought I could make it 1000km....
  37. Exhasut question
  38. Hahn 3" Catback $529 Shipped!!!
  39. stage 2 install
  40. dual outlet
  41. SLP Exhaust
  42. I need a BOV for my stock SS/SC
  43. SPOTTED!! who is it
  44. stage 1 & 2 installed
  45. SC question
  46. 2.9" pully
  47. torque damper idea?
  48. 50lbs injectors instead of 60lbs?
  49. running 2.8 pulley w/ 42.5 injectors. Will i have problems?
  50. bogging issue
  51. Ca H/e
  52. Good websites?
  53. Goodbye SS/SC!
  54. Which Injectors?
  55. where should i put my BUNG for my downpipe to get a proper reading???
  56. GM has our rod cap bolts on back order :(
  57. Blower Whine
  58. zzp downpipe?? n how it will fit
  59. What front lip can i get for my 2.0?????
  60. e brakes suck
  61. custom short ram intake idea
  62. Is the GMPP manifold worth it?
  63. SS/SC vs SRT-4!!!
  64. ca stage 3
  65. Stiffy engine damper.
  66. does anybody have a pulley puller?
  67. 2.0 turbo baby!!
  68. Stock Clutch
  69. stage 2, cat back and injen what next?
  70. Ebay Stage 2 and warranty questions
  71. Where can i get a turbo???
  72. 425-251-0329
  73. will these injectors work?
  74. Will ZZP DownPipe with Cat bolt up to GMPP Exhaust?
  75. Stage 2 Installed!
  76. Stage 2 TImes?
  77. qusetion
  78. Do you guys think this will help our cars?
  79. Anyone know the part number for the map sensor?
  80. 2.8 with 42.5lb's or 60lb's?
  81. question on ca stage kit
  82. Post pics/info of your turbo kit!
  83. TTR Solid engine mount
  84. Computer?
  85. Cobalt Turbo Canada
  86. Are these the best?
  87. Secret CAI..lol
  88. bigger radiator
  89. What is the Crank pulley size
  90. magnaflow or corsa???
  91. What to do next?
  92. New Performance Mod
  93. Ingalls Torque Dampner and Warranty
  94. Need a good clutch which one?
  95. Full Vibrant exhaust. How Loud
  96. thinking of cobalt addiction stage 3
  97. ported supercharger
  98. Weird RPM surging
  99. Exedy clutch in a 2.0l
  100. Recommendations for 3" Resonator
  101. where to buy a 2.9
  102. Intercepter gauge
  103. The Official EXHAUST CLIP THREAD
  104. those that have done pistons...
  105. Gauge Cluster
  106. Internals for 20+ lbs of boost
  107. your thoughts?
  108. Has anyone run a Cobalt Addiction stage 3 ?
  109. hurst shortie
  110. home depot mesh
  111. AFCO Heat Exchangers
  112. where can i find performance chips
  113. Cel....
  114. should i wait to mod?
  115. what should i do for engine performance?
  116. intake install
  117. eBay Intake installed
  118. Custom intake scoop
  119. stock block
  120. Is that what you call limp mode
  121. Installing The Stage 2 kit..need help!!
  122. quick question
  123. How much power is to much?
  124. How much power is too much?
  125. Next Mods?
  126. Custom tune really worth it?
  127. RE:#4:Anybody have a fuel pressure gauge hookuped?
  128. ECM swap
  129. Stage 2 Hub Screws
  130. quick fujita ?
  131. Turbo 2.0 SS w/ 323whp/290wtq?
  132. Wheel Hop!!!!!!!!!!!!
  133. custom tuning
  134. got the motor tore apart!!
  135. Add me to the #4 list
  136. fujita
  137. Cutting Cat Or Stock Exhaustt
  138. AEM intake
  139. 10:1 pistons and 42.5# injectors
  140. Fueling issues
  141. Tune Problems
  142. whats the best exhuast tip?
  143. Stage 1 beats stage 2?
  144. RD FAB intake
  145. AEM vs. Injen
  146. trannie mounts
  147. Mufflerless exhaust???
  148. ME-gan or meg an
  149. Megan !!!
  150. Thermostat... can we go colder??? (i already searched)
  151. LSJ bypass air filter
  152. Ordering stage 2
  153. since when did slp make us a exhaust??? (vid)
  154. Dyno with gmpp parts
  155. For those with stage kits....
  156. Water spray for aftercooler?
  157. RWD Swap Hypothetically Speaking
  158. LSJ piston rod bolts torque to yield?
  159. PA Stg.2 SS/SC's
  160. Exhaust Questions
  161. Stock Dyno Chart
  162. Who cries themselves to sleep every night over not having stage 2?
  163. stupid fuse
  164. exhaust clip
  165. is it worth the $
  166. Good news 2.0 peeps!
  167. RPM spudder
  168. Stage 1 & 2 PCM Programming the same?
  169. Getting Stage II
  170. Vibrant help please!!!!
  171. Just ordered my Stage 2 kit!!!
  172. intake, hydrolock
  173. Quietest exhaust
  174. Official Procharger Build Thread
  175. spark plug torque????
  176. fan control
  177. next upgrade?
  178. Who agrees with this setup ?
  179. guess that hp
  180. Cobalt addicion quick delivery
  181. GM Satge 2 Reflash
  182. Video: GMPP Exhaust; GMPP Manifold; Stage 2
  183. Nitrous Question?
  184. Supercharger Maintenance
  185. stgII with 2.9?
  186. New Parts
  187. Planned mods, Will I need anything to make it work?
  188. Gmpp Performance Vs Vibrant Catback
  189. Engine Knocking in 2nd gear?
  190. anybody have a port and polished head on there car?
  191. spec+3 clutch
  192. OverHeated Clutch?
  193. Boost levels with 2.85 pulley ?
  194. Best clutch
  195. how small of a pulley?
  196. CAI warranty question
  197. knockin noise....what is it?
  198. GMPP Performance Cat-back
  199. question about octane boost
  200. konis installed ride still bumpy!! WHY???
  201. looking to buy cams
  202. Supercharger Blow off Valve...
  203. Where Can I get my Car Tuned
  204. vibrant exhaust?
  205. Those of you with the GMPP Manifold....
  206. recaro seats no longer, now im confused
  207. Loudest Exhaust Out
  208. which header? weapon r, vibrant, etc....
  209. PSI guage in Canadian car?
  210. guage fluttering?
  211. Cylinder #4 running lean question. please look
  212. I Need Your Opinion On This Car
  213. Water Wetter
  214. dont think I got the Stage2 Flash...
  215. Supercharger Needle Bearing Grease
  216. Almost there!
  217. what pulley with a stage 3 from intense
  218. AFR from my dyno the other day...
  219. Ferrea Dual Coil valve springs
  220. would this hurt my catback?
  221. Look at my plugs!!!
  222. what do you think about gmpp cams
  223. catalytic converter? good? bad?
  224. Headers JBPerformance
  225. 350 Whp ???
  226. DC Sport or GMPP Borla catback Exhaust
  227. Can The SS S/C Have a Hitch?
  228. COBRA H/E install
  229. Help With Airbox Mod
  230. Catless Downpipe...
  231. Can you tune the gm stage 3 pcm?
  232. Need Some Help!
  233. RD Fabs Intake
  234. Stg 3 Pulley on stg2 tune
  235. Another spark plug question
  236. gmpp sport exhaust back firing
  237. Electronic boost controler for the Eaton!
  238. sway bar link broke???
  239. Why #4?
  240. a well spent $60
  241. To the turbo folks
  242. Engine blown? Check the codes my car threw...
  243. M90, anyone actually done it yet?
  244. custom exhaust
  245. Any News On a GM 2.0 CAI
  246. Is the twinscrew really worth it?
  247. Need Part numbers
  248. Cobra HE for sale on ebay
  249. Ordered!!!
  250. First Oil Change
