PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Wiper arm removal?
  2. AEM Uego Help
  3. hid issue
  4. Issue. Need Ideas.
  5. ZZP stage 3 or Ottp Stage 2
  6. need help asap car in limp mode
  7. Brake Rotors
  8. Can someone show me an explosive view of the supercharger?
  9. option b fill procedure
  10. ZZP Cams
  11. Anybody tuning with EFILive?
  12. Exedy
  13. Snow/Ice
  14. Violent Car Shaking
  15. catless dp safe?
  16. Stock boost gauge
  17. issues...
  18. neon green stuff under car
  19. replacing head
  20. code comes and goes
  21. Vibrant Header/dp Catless and Ark dt-s catback
  22. opening up the stock exhaust to 2.5
  23. lsj service specs
  24. Zzp lsj pcm
  25. HP TUNER needed vancouver/victoria
  26. My cobalt
  27. Interceptor, Uego and stock boost gauge
  28. Okay, let me see if I got this issue straight in regards to the new tensioner...
  29. anyone using amsoil ea nanofiber air filter?
  30. m90 on 2.2 vid
  31. Port & Polishing your supercharger
  32. Opt B kit Install
  33. Crazy Mexicans!!!!! (Piktar Story!!)
  34. Bad Mab = CA V1?
  35. I have searched, need opinion
  36. 2005 cobalt ss: a second factory supercharger offered?
  37. crusie control problem any ideas??
  38. Oil Galley Plugs
  39. Just an idea...water temp gauge for H.E. coolant
  40. Possibly off on timing?
  41. New Motor Build
  42. SS/SC rear parking brake not disengaging...
  43. also just pnp my throttle body
  44. need a part number of vin number
  45. Wheel hop on snow...?
  46. ABS light on help
  47. Ticking noise only when above 10 Hg
  48. Birthday present hmmm
  49. Which Pulley ? 2.8 or 2.9 ?
  50. Upgrading LSJ
  51. How do you take off intake manifold?
  52. has anyone...
  53. Blown Cat?
  54. wiring harness colors??
  55. AEM wideband Wiring?
  56. Supercharger engine code
  57. 3rd coil pack and pedal!!
  58. Spark Plug Gap
  59. Catch can installed picture from today
  60. Opinions for brakes..
  61. p2228 code
  62. Stage 2 shudder problem
  63. My Car is Happy now
  64. valve adjustment
  65. P0171 HAVE OBDii CODE READER
  66. high iat2 temps
  67. gaskets
  68. Stock 07 SS/SC boost?
  69. stripped screw
  70. Cam install
  71. zzp dp
  72. 2.9 with gm stage 2
  73. Engine swap help
  74. whats everyone use for meth injection?
  75. Cleaning MAF sensor
  76. Need help please
  77. So I took my M62 apart again today..
  78. Crack in Catalytic Converter!!!
  79. Those of u in the know about "canned tunes."
  80. 2 step.
  81. average IAT2
  82. TVS questions
  83. 06 pcm
  84. Wideband Really necessary?
  85. Engine Power Reduced after loosing traction
  86. Need exaust input !!
  87. PCM Removal?
  88. eibach coilovers
  89. boost problems on ss/sc help
  90. needs a clutch
  91. Abs module
  92. hid help please
  93. Mounts when buying ZZP downpipe
  94. missfire question
  95. Where to buy exhaust Gaskets
  96. Some help, new member!
  97. Port and Polish M62??
  98. question on exhaust
  99. zzp shifter bracket
  100. jet chip
  101. Anyone know what size threads are in the ZZP S2?
  102. 2007 cobalt ss/sc FMIC?
  103. start then no start HELP
  104. anyone ever have issues
  105. I haz problems
  106. meth question
  107. Cobalt Stock Dyno
  108. engine swap
  109. M62 maintenance questions
  110. Dumb Spectra Air Filter
  111. Trifecta vs HP Tuners.
  112. brakes?
  113. 2.5 inch zzp catless or catted?
  114. 60 ibs or 80 ibs....
  115. bad-mab
  116. Stage 1 mounts and cold weather
  117. Removing Gm Stage 2 Pulley Bolts ??
  118. Help And Advise Needed Please....
  119. zzp stage3 HE vs ottp stage1 HE
  120. 1/4 time
  121. Wheel Well Splash Guard
  122. Selectable tunes...
  123. ottp longtube q
  124. is it safe ?
  125. AEM intake question!!!
  126. aftermarket intake or stock?
  127. front cover gasget
  128. is my car running normal-ish?
  129. UPS Finally got here with..
  130. is zzp mid length good
  131. low coolant light
  132. GMPP exhaust, what down pipe should i get, size and brand???
  133. pulley
  134. Oil life % dropping quickly..?
  135. ottp header
  136. Coolant Filler neck - whats the part number?
  137. how whp with zzp stage 3??
  138. what muffler...
  139. Just ported my Throttle body.
  140. option B or killer chiller?
  141. Post your 60-100 Times LSJ/LNF
  142. Darn GM Stage 2 tune
  143. It Started with a squeal...
  144. ZZP shorty header: will not bolt up, WTF.
  145. Header
  146. new ark exhaust
  147. A little help please PO171 & PO300 And knock retard
  148. Need advice
  149. stock belt on 3.1 inch pulley to go 50 miles
  150. HAHN front mount intercooler
  151. Header price and Power
  152. its in lol
  153. Exhaust and Whine Vids
  154. he install
  155. Stock on E85?
  156. Who can tell me what this line is?
  157. going to attempt
  158. drivetrain issue i think
  159. 3 psi?
  160. cat or no cat?
  161. tuning/header question
  162. weird idle
  163. Low Coolant..
  164. quick question about k&n airfilter replacement
  165. Engine mount
  166. Boost reductions in 1st
  167. 3" to 2.5" exhaust reducer
  168. so...my car won't start..yes another one of these
  169. 1/4 time.
  170. tsudo exhaust rubber hangers
  171. My lsj performance question...
  172. Best Power Mods for $1,000
  173. Anyone Else Notice????
  174. Pcm & tb issue... Fixed!
  175. Car wont start???
  176. 2.5
  177. F35 trans fluid #88861800
  178. Stock Cat-Back Tubing Diameter???
  179. Low End
  180. Bad Mab Shorty Improved 60-100 time in HPT.
  181. OTTP Ecu Help ??
  182. Help!!!!!
  183. too much boost?
  184. Magnaflow
  185. 2.4L LSJ ZZP Stroker talk
  186. LSJ Sparkplug Question
  187. heat exchanger
  188. Boost gauge flicker
  189. Dipstick popping out? HERE IS THE SOLUTION!!
  190. 60lb injectors
  191. Exhaust Question
  192. Pulley Size???
  193. stock clutch
  194. Alignment or Tire Balance???
  195. Header/DP to Megan
  196. exhaust setup.
  197. Wiring Uego for HPT
  198. NEED some suggestion for spring
  199. ZZP e85 tune???
  200. Some Input!!
  201. Do I have everything??
  202. New Owner - 2004 ion redline : )
  203. What do they actually do
  204. head gasket?
  205. downpipe question
  206. Tvs..
  207. wont boost
  208. Clutch and flywheel. Any suggestions???
  209. af reading right??
  210. zzp stage 3 sc kit
  211. Custom Option B brackets?
  212. spark plug gap size for 2.6in pulley
  213. Engine and Super charger bolt kit?
  214. e85
  215. Tps
  216. sri
  217. Cx Racing or Cobra?
  218. best spot?
  219. VSS speed signal 2005 vs 2006
  220. afr
  221. GMPP manifold RIP
  222. duel intercepters
  223. ic pump
  224. Header noise?
  225. LS4 Throttle Body?
  226. Possible exhaust leak?
  227. Which in your opinion.....
  228. Help with different types of heat exchanger!
  229. rpm issue
  230. Need Radiator...ZZP Stage 3?
  231. ZZP pulley interchangeability
  232. complete motor minus supercharger
  233. Catback VS muffler
  234. Supercharger maintenance this weekend!
  235. intercooler pump (kinda funny)
  236. So much for "Just a radiator"
  237. cam caps
  238. ss/tc exhaust on ss/sc
  239. ???
  240. cometic head gasket.
  241. Going with E85..
  242. Cheapest GMPP?
  243. Two PCM's?
  244. Power Cable Arched PCM
  245. Intake and Exhaust Combo?
  246. getting some knock on interceptor..
  247. GM stage 2 hub bolts
  248. Brake lights..
  249. Water/Meth information help?
  250. Wierd problem, is it a problem?!
