- exhaust question
- ott performance.
- Considering 2.79" ZZP pulley. What else do i need??
- Cat restricting boost?
- FS Brand New Stage 2 kit $470 shipped
- HP gain?
- getting kinda worried please read
- boost gauge acting weird
- Reflashing
- Which clutch
- Props to BLILBT!!!
- Throwin P0017
- Problem HELP with H/E
- downpipe is here!!
- AEM Wideband question?
- meth nozzle
- using nates pulley tool
- Pushing the limits?
- Guess my dyno numbers
- cat/catless question
- Best cooling mods
- DEvils own/ engine
- 100 octane
- 3" Custom Exhaust w/leaks Clip
- CEL and Codes
- help please....help
- Nate's 2.93 Pulley FTW
- nuts from d/p to catback
- cat or no cat?
- Quick Help Please.
- gas mileage difference
- exhaust question
- Gm Stage 3?
- h/e questions
- bouncing tac at idle stop?
- leaking coolant.....
- No fun running stright headers!!!!!!
- Pulley Question.
- fuel pressure regulator
- mother &@!?er
- IAT2's
- mass air flow sensor help
- bwoody cobra he brackets problem
- zzp combo with megan exhaust
- Water Temp Gauge for Manifold Coolant Temp
- NGK Iridium BKR7EIX & 2.9" pulley. What gap would be better? .40 or .35?
- NEED some specs..
- H/E help
- is anyone zzp twincharged
- pulling the pulley
- Your Guys Input
- Vibrant Stainless Steel Resonator ?
- Maintenance Day
- help code p1182 4th time
- my new full exhaust
- 2nd Gear???
- Corsa touring or sport?
- engine hungry?
- Meth
- ingalls or weapon R ????
- Slight Problem, Help Needed.
- gmpp performance exhaust driving me nuts
- 2.9 and 60s
- 42lb limit
- p0300
- Line Lock on a ss/sc
- Found this on ebay
- GM I/C pump
- changing my meth setup!
- stage 2 on its way
- AFCO Heat Exchanger
- Piecing Together Stage 2
- 2.7 safe?
- just got my H/E in
- squeeling from diff
- question
- enough cooling?
- rear o2 censor
- devils own ???
- Immediate Help Needed!!
- maxing boost gauge with 2.9
- Meth Question
- H/E with turbo..
- crank pulley puller
- Tune on the way
- P1182 & P0068
- Motor mount part number ???
- Fuel Pressure Gauge
- Few Quick Questions.
- Cel P0420
- Help with IDC's w/pics
- HP tuners
- sooo i need some help
- Anyone know how to use a tech 2?
- installing meth injection in the intake manifold
- Spark Plug Wires?
- CTI header and downpipe
- im out of the game........ :(
- ss/sc help problem!!!!!!
- Boost Vacuum Line
- How to on Devils Own Meth injection????
- Ported supercharger?
- 2.8" and 60's safe with STOCK exhaust?
- 300WHP build, thoughts?
- Need help with part number
- Need Some Help!
- really aggervating
- is this supercharger ported too much?
- wideband options
- Boost Question
- Got a package in today (56k forgeda boutit)
- Timing Chain Rattle & Hesitation
- Which downpipe?
- Launch Control for SS/SC?
- new pcm?
- Turobcharged Cobalts..... Is it true??
- autolite plug compared to stock
- 100% IDC with stage 2? Or my reasonning behind is wrong...
- MAF help needed..
- Major Help PLEASE!
- stage two question
- buying a downpipe(need help)
- Not sure what to do next...
- Tires
- 3.5 r.a.w TB
- stock header/ installing new one
- injectors in a 2.4
- Supercharger Grease! NOT OIL!!
- Dry flow or oil based cold air intake?
- GMMP exhaust sizes
- Tuning Question
- what would be safe
- plug in injectors?
- Leaky Headlights??
- help me Cam my LSJ
- making the vibrant exhaust livable
- gmpp stage 3 question a/c
- What should I get
- About the PCM
- I need help about to make purchase
- cold air intake make the supercharger louder?
- CX Racing Mounting Hardware
- when getting tuned
- CX racing HE
- replacing my supercharger at 10k miles?
- P1183 Supercharger Inlet Pressure Sensor
- car is about to get some performance mods but have some questions
- talk with NGK rep thoughs?
- Header Problem
- 1st Dyno Run.
- New Super-Low Compression Rods!
- 42 lb/hr with dyno tune
- gm performance
- Strange exhaust leak or is it?
- Air con delete pulley & brk
- Brakes SSBC? or EBC pads/rotors?
- Question regarding a Header
- Pulley size?
- Problems with 2.9 Pulley.
- Zzp Whisper Resonator Installation as we speek
- Cat-back exhaust poll
- 1st Gen Projectors.
- Ordering my stage 2 and getting it put on for $75! Phoenix, Az
- Help!
- So after all the BS my stage 2 kit is finally on
- voltage stabilizer?
- car runs like crap
- 91 Octane selling for $5.30/Gallon.................oh in Canada....:)
- To all the dual exhaust Balts....
- just got my spark plugs
- stage 2
- LED Question.
- Zzp Pcm
- anybody use jbp intake
- 0-60 times?
- spark plug help
- little problem... heat exchanger, and meth
- FMU + Hand held tuning devices
- Exhaust Question
- Stage 1 worth it?
- which spark plugs do i need and what is the best??
- Cam gears
- Meth Injection Installed - MAF High frequency fail
- whats your 0-60
- Dex-cool
- Best Heat Exchanger.
- 2.6 and 60s?
- how to lower compression ratio?
- strange noise at 5k rmp or higher
- will our injectors work on the 2.2 grand am?
- Underdrive/Overdrive/OEM Pulley
- Stage 2 Installation - Rediculous!
- Dealer sent me home today with stage 2, but without the tune
- Idle problem CURE!!!!!!!! Finally!!
- 2.5" with simple mods
- Honing Vs. Sleeving $$$
- Return style fuel system
- Will the LNF help..
- stage 2 question
- I went ahead and got both
- NGK BKR6E's
- Which base tune is best
- Injector Question.
- downpipe CEL. help
- Stage 2
- Why is my car so slow
- Tranny VERY jerky!!!
- Took my car to the Dyno.
- Feeler, cryo'd rods.
- vibrant header/ heat wrap
- Dc Sports Cat Back
- Carbon Fiber Intake Short/Long
- SS/SC been the shop for three months!
- K & N intake - tight fit issues?
- stage 2 price has dropped
- belt tensioner rattle?
- HP estimate?
- crap engine
- jb weld on my downpipe
- Injen Installation
- a/c problem?
- safe set-up?
- SLP loudmouth
- Does anyone have a rebel auto worxs downpipe?
- what psi should I be hitting?
- is this worth it?
- Any one know the price of the OEM air intake for ss/sc?
- knock??
- For Those Who are DynoTuned....
- cooling that supercharger down!
- Need some help please.
- Tune or N20 opinion
- Bad Stumble/Hesitation/Popping After Upgrades
- new zzp number
- New Noise, PLS Help
- Couple Questions RE: Header & DP
- tune
- problem with meth...
- Cobra Heat Exchanger Help
- speedo dual gauge pod
- boosting
- Installed Meth.. got some questions!!
- header and dp question
- Custom Exhaust
- Can't decide between these two..
- Was your cobalt boost limited untill X miles??
- Getting CA Stage 2 This Friday!!!
- Hearing knock w/ 2.85 pulley and 60# injectors
- anyone have cobalt addiction stage kit
