- 3 psi!!!!!
- I'm getting a new PCM
- My First Cooling Mod!
- Pics of lowered in front and stock in back
- swapping in lsd
- swapping in lsd
- Headers
- Car not starting (electrical)
- Newbie hear and in need for some insight
- found this articale thought i would share
- Need help!
- Tvs 1320 vs mp90 sc dyno
- Need Help :(
- winters coming... should i remove CAI??
- How-To take the head off
- Oil filter leaking
- Need a used TB with low miles..
- Ticking on Cold startup
- Do I need a pulley hub?
- Zzp s3 he
- DEI Chill Charger Intercooler Additive
- Manley I Beam rod with 22mm piston pin.....
- An awesome ride home last night
- lsj build thread
- Ebay LSD?
- tuning help for 07 s/c.
- yes Question...
- Anybody have??
- belt slippage???? help
- serious issue "engine power reduced" HELP
- Car making weird noise
- Stage 3?
- canadian car shift light 100 octane mode
- e85..
- lack of power, KR :(
- Bought A TVS
- do's and dont's with a supercharger???
- this is what im dealing with...
- gm stage 1 supporting mods.
- ZZP LSJ phenolic intake spacer
- need a hand
- GM stage 2
- H/E coolant?
- zero boost
- muffler help
- exhaust wrap
- Tuner in Phoenix, Az
- Just spotted a Coupe SS in NJ on the GW bridge
- Phenolic plus 2.5 on a tvs results
- Question
- Anybody seen this type of leak ?
- Need s/c coolant filler neck
- goin a new route...
- Interceptor Scan Gauge Hp reading accurate or not?
- installed phenolic spacer now idles rough
- GMPP parts 07 cobalt ss
- sc tear down and questions
- M62 cooling
- i need a how to:)
- What parts will I need to rebuild.
- best price for forged piston and ring
- need help with ottp stg1 h/e if u have one post up
- Tune question
- exhaust manifold
- Tvs Injector Size
- 2l pcm help
- Intercooler leak
- motor mount vibration
- which spark plugs for 2.8 pulley?
- GMPP touring exhaust and 3" DP
- Fuel system upgrade and CAI
- Cobalt Stage 2 kit vs individual???
- Option B help needed. Picture inside.
- Tired of searching ....
- Stock H/E filler Neck
- Lsj intake valves same as l61?
- Goldchain's Turbo Build Thread
- BadMab Shorty Header With Thermal Coating
- Stainless Steel Works, anyone?
- 12volt to 14-15 volt
- 11.5 arf to 12.2???
- ZZP Shuifter bracket upgrade
- oil gauge
- tuning/e85
- HKS Muffler on 3" pipe
- yay broken valvetrain!
- EVAP Purge "C" Fault
- I think I Blew up
- OTTP Custom Built Exhaust
- Dual IC Pump setup?
- PHOTO REQUEST: Ingalls torque damper close up and mounting points
- Lnf clutch in lsj
- Car running like crap
- Need Help with a friends LSJ!!!
- bout to go zzp stg2... few questions...
- Downpipe and o2 sensor ?
- Gaskets Question
- Visiting BYT this Weekend for Parts Install & Tune!!
- Rom raider for lsj?
- After all that!
- dba level of magnaflow catback
- um i have some codes on my car!
- help boost opn 2.9 pulley
- Clutch master cyclinder
- the next phase, need some input
- Insulation Under Fuel rail Cover
- low hanging exhaust?
- where to buy a good sc pulley
- Problem after build
- E85+Water injection Questions
- Cat/Cat-less
- buzzing sound
- Wideband reading wrong(I think) HELP
- Question on using a rotrex on a lsj
- Lash adjuster problems? *tick tick tick tick*
- I need a fuel pump module
- ZZP Upgraded Throwout Bearing, Any Good?
- zzp true 3 in exhaust?
- thinking of buying stage kit..need info
- How difficult?
- how does the lsj and lnf balance themselves
- HP Tuners
- What kid of power should I be making?
- Need a stock down pipe
- P0606 PCM Processor
- Finally went on Corn! :)
- wheel hop
- Quick Header Question
- HP tuners
- New PCM, and car won't start
- LSJ turbo swap questions
- Heat Exchangers ?
- Catless downpipe
- Difficulty level of tuning an Turbo'd LSJ?
- Cooling Issue..
- Forged pistons on stock rods?
- So this is what happens when your LSJ gets a little thirsty...
- Weapon-R Secret Weapon Intake.
- Too Lean
- my zzp order, help please.
- RPM Limits
- clutch...
- Car Pulling to the right.
- With my Current MOD's will 92 Octane Hurt my Engine?
- Do all cobalts have same fuel pump?
- Damn!!
- Running EXTREMELY lean
- Anyone ever put a k04 turbo setup on a LSJ?
- Few Question's
- Turbo swap ??
- Iat2 temps
- cracked trans case, broken axle... wtf?
- Any downfall to running a lighter flywheel?
- 60s on a 42 tune
- Wanted - Cobalt LSJ owner in Wilmington, DE / Philadelphia PA area
- Header is here!
- Getting a Winter parts list together
- dual pass Q!
- swap question
- Buzzing sound while moving?
- M62 phenolic spacer.
- Gms3!
- E85 myths and facts.
- Another Aeroforce question
- Question about Bully Dog
- Got no power!!!
- lsj's whats ur 0-60? can't get mine that low...
- Need stage 2 help!
- fuel pump
- Will this IC pump work?
- Gas leak, anyone else with the issue?
- help identifying a couple lsj hoses/lines
- Can anyone identify this part?
- TVS sounds like marbles
- Zzp stage 3 keeps throwing codes
- How long to do a complete engine swap?
- Dual Pass Question
- Turbo lsj ?
- Need help fast
- IAT2 in Hot Weather -- HELP!
- muffler tip
- install questions
- LE5 crank
- Looking for good prices on OEM rotors or equivalent
- Mp90 or tvs
- interceptor gauge boost?
- e85/93 octane tune?
- A few quick (simple) questions....
- muffler
- clutch install problems...
- tune problems....
- When To Get A Tune
- Car leaning out every shift.
- Relative horsepower calculator and example.
- Piston Cracked
- MAF Freq = 0hz
- Are you "exhausted"?
- Twincharged
- COBALT SS/SC FOR 12s?
- Muffler Swap
- Engine swap + turbo?
- trifecta tune and issues
- downpipe
- Fairly loud Clacking noise after head replacement
- IS there any point running AEM uego with highflow cat?
- GM Stage 2 belt and ZZP Question.......
- My engine runs cool
- ive got a little problem
- High milage question!!!
- ZZP 3" Now AFR is Lean
- why does my car stutter and shudder?
- Solutions For My CEL/MIL Codes?
- Knocking Sound in Engine
- DP for 3inch vibrant and stock header?
- Oh what A day. Parts new and broken (PICS)
- exhaust question
- Badmab header, CTI downpipe and stock exhaust?
- Boost Solenoid hose
- Question for those on E.
- Possible New Setup
- 07 with soot all over exhaust and bumper
- Couple of questions about ZZP stage 3
- Car shut off at WOT today
- GM Exhaust Mani Gasket w/BadMab
- wot box
- Trade in value
- junk engine power reduced and horrible miss
- AC smells when i turn it on
- Too much?
- cleaning of intake
- Gm Stage 2 Tune
- Exhaust need help!!!
- LSJ Turbo Build
- ZZP S3 Cams
- Car will not start, help!
- Need help 650cc injectors
- Bad mpg's
- Need help deciding on axles
- need help with a whine after stage upgrade
- Options other then TVS?
- Is it worth going with 60's, 2.7, Tune?
- 300+ horse on the m62...
- FMHE hose routing question..
- are all LSJ throttle bodys 8 pin ?
- Whats she worth?
- Will a 2.7 be too small for a GM Stage 2 Belt?
- Stock fuel pump...how much flow?
- New air filter for the ZZP intake....
- oil and e85
- what sensor is this?
