PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Cool Air Intake
  2. this mod i tried
  3. Looking to buy SC wing $$$
  4. Octane Boost
  5. M62 Glossary
  6. Exhaust or Pulley
  7. Just installed my Stg 2!
  8. What is this?
  9. Exhaust leak question
  10. RWD tranny on fwd platform???
  11. A Debate
  12. pulleys
  13. Heat Exchanger?
  14. turbo timer
  15. Stage 2 with CA 2.79 pulley
  16. Upper tranny mount????
  17. Just went from the stock pulley to a 2.9"... WOW
  18. Stage Confusion...What to do/get?
  19. Quick Boost Question
  20. HELP! Detaching sensor on bottom of supercharger
  21. Clutch issues
  22. Clutch Slip at 2000miles!!!!!!!
  23. Ebay intake installed!
  24. Mounting Nate's 2.9" pulley on stage 2 hub, what torque for screws?
  25. SLP Loudmouth Exhaust?
  26. loudest exhaust, best performance
  27. 272WHP dyno chart on 2.8" pulley
  28. comp test and other things
  29. stage 2 really thinking about....
  30. cabalt addiction stage kits worth losing warrenty???
  31. questions about 3" catback
  32. 42s or 60s with a 2.8
  33. PCM Question? Maybe Possible to use Dashawk
  34. Those with CA heat exchanger
  35. Altough turbo....
  36. Supercharger Porting...
  37. Check Engine Light
  38. AEM Filter for Injen CAI
  39. Stage 2 and GMPP sport exhaust...installed!!!
  40. CAI for 2007 question!!! please answer
  41. just got off the dealership about my stage 2 kit plz help
  42. CED brought me presents=)
  43. GM S2 Belt VS ZZP Tensioner
  44. check this out
  45. Adding LSD and Axles....
  46. Stg 2 Cams Or Better
  47. What do you think about my order.
  48. Which Shifter?
  49. My future mods
  50. Some help please?
  51. K&N is looking for Cobalt SC for additional dyno testing !
  52. Stage 2 Kit getting only 12.5 psi???
  53. new
  54. idle vaccuum?
  55. Not making boost...
  56. reflash for free!!!!
  57. Mobil 1 or Royal Purple??
  58. Stage 6
  59. Heat Exchanger Help
  60. cold ait intake for 2007
  61. i need advice
  62. Stage 2 question
  63. Turbo 2.5" or 3"
  64. The True Abouth Airbox
  65. Exhaust Popping Under Deacceleration!!..??
  66. What Does Everyone Think Of Nos??
  67. Blow off valve?
  68. 2.7 pulley+ stock injectors= safe!! Dyno proven!
  69. Shift Light
  70. Spark Plugs for high boost application - asked the experts !
  71. How to get the dealership to fix it???
  72. Weird sound after install of CAI!
  73. Leak down test
  74. Damn these GM Stage 2 Bolts!!!
  75. Stock pulley direction ?
  76. Ported blower gains
  77. Tranny mount
  78. Got some more parts for my turbo swap
  79. Redline on stage 2
  80. Anyone Running Stage 3 8k Redline??
  81. Got Dynoed!!!
  82. stage 6 questions
  83. MAF sensor max voltage?
  84. intense racing stage 5 question
  85. cylinder sleeve pressin in car?
  86. stage 2 competition??
  87. against sti's??
  88. Pulse Spark Plugs, new kind on the market ...
  89. Blower Oil
  90. hurst shifter..
  91. Exhaust sizing formula VS RPM range on the LSJ.
  92. cat or no cat
  93. Magnaflow vs. factory resonator
  94. Header emergency!!!
  95. Need some help plz.
  96. Water Methanol Alcohol Injection??????
  97. strut tower install
  98. the answer to get me 300 hp
  99. smallest pulley on gm stg 2 belt
  100. Part Number Please?
  101. hp tuning?
  102. sportlines vs pro kit
  103. HELP cold air problem
  104. 2.0LSS SC vs 2.4L SS Turbo
  105. I need a scanner setup for HPTuners and a AEM UEGO ASAP for the twinscrew!
  106. Recommended gap.
  107. Smallest Pulley on Twinscrew w/ 8k redline
  108. Question for the Modifiers!!
  109. Stg 3 +zex??
  110. 2.5" or 3"?
  111. $ to install forged pistons?
  112. Cobalt ss/sc cutaway
  113. Baddest blow off valve.
  114. Spike in KR...
  115. cams....
  116. question on stage 2
  117. Stage 2 with 2.85 pulley base dyno run done today
  118. Snow Performance Kit installation question
  119. 42lbs injectors
  120. Who sells new S/C rotors??
  121. next mod???
  122. Last Thread on this dual pass i swear
  123. what size is....
  124. How-To: Megan Racing 2.5" Catback Exhaust
  125. belt slip 2.9?
  126. stage 3...who has it
  127. 42lb STage Question?
  128. UNEEK Pads and Rotors
  129. WTF? HowTF? YTF?
  130. how much $
  131. Interceptor doesnt register KR
  132. AEM Dryflow filter help PLZ!!!!!!!
  133. Severe HELP hurry!
  134. best down pipe?
  135. Quick question
  136. 2.85 pulley on and now dipstick blows out
  137. 2.85 pully and plugs Q?
  138. super noob ?
  139. Airbox Question
  140. K&N responds to MAF myths
  141. Nates 2.9"=10psi
  142. Fans and Intercooler bump on all the time (with switch)
  143. does the cobalt have a BOV
  144. cobalts acting sluggish..
  145. Interceptor
  146. Weapon R and Magnaflow?!
  147. quick question
  148. wide band?
  149. The Path to power... Need help!
  150. Anyone With Weapon-R Header
  151. stage kits
  152. I'm soon 2 be screwed!
  153. K&N cold air intake
  154. Rebel Ported Head Group Buy
  155. Cobalt Addiction Stage Kits?
  156. stage 2
  157. Coming Soon!!
  158. M90 Swap Revisited
  159. My review of the 2.9" pulley
  160. ZZP Stage Kit?
  161. Oil Problem
  162. Quieter with Tip?
  163. Stage 2 install
  164. Whats next?
  165. save some gas?
  166. Stage 2 blue bolts finally off!
  167. Exhaust Leak
  168. way to check coed w/o scanner
  169. this damn mustang
  170. CA Stage 2?
  171. water in car
  172. 2.8 Pulley and...?
  173. Rim And Tire Question (no one goes in that section)
  174. about gas
  175. 42lbers/60lbers?
  176. top speed!!!!!!!!
  177. Turbo Sizing Calculation on 2.0 LSJ (Cobalt SS / Ion Redline)
  178. Cobalt Addiction Stage 4
  179. GM belt?
  180. acceleration
  181. What should I do next?
  182. Porting Supercharger
  183. Oil weight
  184. 2.0 header
  185. another exhaust question...
  186. Gauges and Pillars.
  187. Flames out the exhaust!?!?
  188. Stage 2
  189. Injectors and Pistons
  190. Megan exhaust lost of sound in high rpms
  191. Spark Plugs I Got
  192. about the pulleys again
  193. For those with 2.8 or smaller pullies.
  194. high wing removal
  195. spark plug question
  196. Power cap?
  197. How Long to install?
  198. Question??
  199. My bet about the Lysolm Twin Screw Swap.
  200. about those ebay chips sorry guys
  201. Question about 2.8/2.9 pullies
  202. Friend wants to race...am I gonna die?
  203. new here, i have a big question
  204. 400 HP axles?
  205. Engine Power Reduced!!!
  206. Can you use those corvette jack pucks to lift the car?
  207. can't decide on exhaust
  208. cooling fan on auto pilot??
  209. Supercharger grind.....
  210. cost of mods
  211. Cobalt Addiction Stage Kits....
  212. EGT readings. interesting...
  213. need pics of stock 06 SS/SC exhaust.
  214. what a/f
  215. Need a down pipe
  216. Twin Screw makes over 300WHP?
  217. pace setter exhaust
  218. 50 shot safe with GM stage 2?
  219. BOV for the Supercharger???
  220. New 6 Speed Transmission
  221. will parts be more expensive or hard to find
  222. Vibrant header installed!
  223. minifold question
  224. How hard is installation of Injen Intake?
  225. Dry Ice SuperCooler
  226. Prosport guages
  227. stage 3 intense installed but got a prob?
  228. Looking for info on stage 2 kit and calibration
  229. Where can i get a new/used boost bypass vavle? (For M62)
  230. Loudest exhaust-best exhaust
  231. exhaust manifold gasket?
  232. someone answer me please
  233. Help: Black under Aluminum wheel.
  234. New Custom Plates
  235. rims chipping
  236. Weapon r Install
  237. 2.0 LSJ Head, Cams and valve information ...
  238. GM build not removing motor
  239. Driving with Stage II - No PCM Flash
  240. 2.4 head swap
  241. Magnaflow Muffler = No SC Whine (from the inside)
  242. The truth about the twinscrew swap
  243. Heat Exchanger And Installing It!!!!!???
  244. Bone stock to 13s
  245. ecotec controller?
  246. Does anyone make a throttle body adapter for us?
  247. question about mod
  248. Best price & where to buy the Stage II kit...
  249. little help on stage two
  250. how does this sound guys?
