- New SS/SC Perfomance Thoughts
- stage2 datalog
- zzp poly or billet tranny mounts???
- Ingalls Or Weapon R?
- my thoughts on the ZZP poly tranny mounts and the install.
- Questoin on MAf output voltage
- hp under warranty
- holy slow!?!
- Transmission Fluid
- Boost Gauge
- Minor Mods
- wheel weight
- Where to buy gm hub?
- 2.8 pulley supporting mods
- how many quarts to change oil?
- Psi help i know repost but i searched
- pics of Nate's pulley installed needed
- Big install tonight, thoughts appreciated
- LC-1 Connection Problems
- Need Help!!!! Loss of Power for no reason!!!
- Meth Injection Kit Help...
- What Gap for spark plugs do i need for stage 2??
- creaky exhaust
- Easy Performance Mini-AFC - from cobalt addiction
- PLX wideband install, narrowband question
- which catback brand should i get?
- Klunk??
- Crankcase Breather?????
- Intake question
- Wish me luck!!!
- no cat o2 question
- spark plug question
- What to do?
- Fuel filter fitting size?
- CO2 Cooling the H/E
- ordered a injen CAI yesterday
- 07 Cobalt Stage 2 finally
- 3" JBP vortex exhaust mean as hell!
- Magnaflow sounding like shit!!!!
- motor just died!
- rough idle on stock 07 ss/sc
- 1 Interceptor gauge, $205 shipped!
- Wheels & Tires for sale!??
- NEed some pricing help!!!!
- Finally got to the Dyno
- Car just doesnt seem to kick me back in the seat after NGK plug install
- intake question
- Help!!!
- Stage 2 and my clutch is slipping like a bat out of hell!!!!!
- B&m Shifter Only $119.99 @ Turbo Tech Racing
- What Do You Run For Cat-Less Exhaust?
- Stg 1, what pully?
- Which exhaust?
- Tsudo catback
- 2.9" pulley
- Gas quality choice for a 07 LT 2.2L
- Wideband Settings Question.
- heatexchanger help
- Tuning the Ingalls ETD
- Injen intake for sale!
- Limit?
- Much love for my 2.0 brothers!
- installing stage 2 after 22 000 klm stock.
- Exhaust? Stainless
- how to's
- Tuning Southwest VA region
- Cobra Heat Exchanger???
- need some help
- AEM header for SS/SC
- ????Got a quick question????
- header and downpipe
- 2.85 or 2.9
- Engine Sound S/C 2.0
- Stage II Badging??
- stage 2 belt length?
- Need Help Air Flow Sensor
- installed my Bwoody traction bars...
- Which Is The Best Hub And Pulley?
- 3" Pulley safe on Stock Injectors?
- We still have many Hurst Shifters IN STOCK
- Unofficial Blown Up Engine Thread
- Pully size?
- stage kit!
- Pully??
- Superchargers for everyone!!!
- best way to cool the engine
- Estimate what i would dyno with this...
- Monza Catback...
- help with constructing my engine
- Question on "vortex generators"
- a/fr guages
- Got My Header and Trans Bushings! Pics!
- Those of you who did valve springs
- GM Stage 2????
- What are the 2.5-2.6 pulley guys shifting at?
- Exhaust leak need help please!
- HP TUners correct for tire size?
- what is needed for an 8000 rpm redline?
- finally got stg II
- JBP STAGE 2 Cams
- Honed manifold VS Vibrant headers or any aftermarket headers out there??
- Some advice/Intake
- Factory Freak???
- TAG turbo kit
- What are the best mods to prevent or stop wheel hop?
- Which Exedy Clutch?
- GMPP Exhaust
- How does a Heat Exchanger work?
- how much coolant to add after cobra HE install?
- Shorter Belt
- GMS2 or Ingalls?
- Help Asap
- Project 4Banger
- cali chevy dealers
- oil change
- megan catback?
- Why Does My Car Sound Like Shi*!!!
- Engine/Tranny Mounts
- Ported Blower
- Let me get this straight....
- Dyno for the SS/SC
- Explain how you know you have engine knock
- K&N intake
- Anyone Have Vibrant Headers And Vibrnat Exhaust....need Help
- Po315
- Low End Power Loss W/ Bigger Exhaust?
- Apex Safc Neo
- why doesnt GM performance make a downpipe???
- The truth about Stage 1 and Stage 2
- What do you think?
- I realy need help!!!!READ THIS!!
- Help!!! I need case learn Done Anyone.
- broke the tranny linkage spring clip again!
- Meth and Nitrous.
- removing stock exhaust manifold
- Tuning For Meth Help
- Keeping Blower temps down
- spark plugs
- Ring gap postion?
- G G Ghetto fabulous shifter mod
- CEL with no intake
- Dangers of porting your blower?
- how long till i blow my motor?
- video clip of newly installed cold air
- Ok Ready to Buy..need a lil help
- What's the best Meth kit?
- Drivability without a tune
- pcm ?
- about sea level
- GM Stage 2 with CA 2.8"???
- Need Help Fast, Please!
- AC heat exchanger for intercooler???
- Control Arm Bushings Destroyed ( Pics inside)
- MAF controlled Meth Injection
- Idle fuel pressure?
- What should I gap my plugs to?
- Got my Devil's Own Kit in today!
- What do Wideband AFR #'s mean?
- Dyno Results!
- Speed Channel Now!!! Street Tuner Challenge
- will this fit?
- got fix it up
- Does the Ingalls Torque Damper Make a difference???
- Intake Question
- exhaust
- obx helical lsd ?
- Supercharged Stage Kit-3 from GM
- how accurate is aeroforce interceptor
- ? on hp tuners... come fast plz
- Driver mod stg 3?? Factory Freak???(pics)
- HELP! need part # from back of your 07 PCM!
- How durable are Billet aluminum pulleys?
- Hurst Shifter
- exhaust question!!
- NGK Spark plugs
- Boost Juice or Different Solution for Water/Meth?
- Check this shit out...How I ran lean.
- CA 2.79" Pulley
- What's Your IAT2 Temps???
- Stage 3 surge tank?
- Building a stroker motor
- where to buy Ingalls ETD?
- supporting mods for Tag Stage 2
- Need some help
- cold air intakes.
- GMPP Exhaust??
- GM Stage 2 Facts
- 260-300hp = wha exhaust?
- Ljavys Meth kit pics.
- High End? Low End?
- Fujita Cell - ya i searched :)
- meth injection HELP!
- Need help quick w/ MAF location
- 100 octane
- Cobra HE
- Do i need Colder spark plugs?
- AEM Wideband
- cooling the hp maker
- Coolant amount/ how-to fill
- Got my header on
- Done a lot of reading, still need a solid answer for stage 2 upgrade
- FInally installed the meth!
- Ingall's ETD Questions
- ZZP Modular Pulley System instead of GM
- Stage 2 3" Pulley?
- Interchangeable Exhaust
- 2.0 Stock Injectors for sale
- header and downpipe!
- high perform spark plug wires
- light weight undercrank pulley
- header question?
- RPM's drop slooowwww
- Got dynoed and got more questions than answers
- Last Meth INjection Question
- Magnaflow 2.2 exhaust on a 2.0
- zzp hub
- exhaust questions...
- CTI Header Fitment Issues
- Please I Need Major Help
- Does This Sounds pretty Good???
- Hahn turbo for cobalt ss
- Question for those who have the Stage II installed in Rochester NY area
- GMPP STAGE 3 ECU or GMPP Exhaust mainfold
- Intense Track Day?
- What's your closest call??
- Stock to GMPP Performance exhaust
- Exhaust help and suggestions!!!
- What Is Wrong?!
- Water/Meth Question
- PCM question
- Valve Spring Info Needed
- Stage 2 reflash quesion
- Who Stocks Pacesetter Ceramic Header?
- HP Tuners Question
- Is this a good price or a SS/SC Trany with LSD
- Well...... Stage 2 and other gmpp dyno results...
- CRYo2
- Install dealer problems w. stg II
- intake questions
- Dual pass intercooler plate
- speed channel on now!!!!!!!
- exhaust people help.
- Interceptor Questions
- finally...
- some newbie questions from a srt guy
