- zzp full exhaust
- LS4 Throtle body yes or no?
- Big bump=car shut down
- exhaust system when
- Inpection & IM Readiness Questions
- whats next
- ebay item too good to be ?
- Need photo of filled silenced supercharder asap
- LSJ header gasket?
- GM stage 99
- NEW!! Exhaust help please
- What is needed for a turbo swap?
- 4.5 degrees of knock, missing 3.5 psi?
- P&P Blower
- smaller pulley
- Crazy Idle...with CEL
- how are they
- What can I do..please help!
- unplugged maf - no cell
- Looking for Turbo Manifold!!!
- Best way to turbo
- purple
- loosing boost
- What would you do if you had 1500 bucks?
- hood fire tarp question
- HPT Case Learn
- testing o2 sensor?
- Injector Tune
- help ottp heat exchanger install
- Knock Sensor not responding?
- Brakes or Wheel bearing hmmm HELP!!
- exhaust, help me decide
- Vac - Breathing?
- Honest opinions on Hahn Catback LSJ
- JBP new cams?
- Comp cams for ECOTEC
- Need some new headlights...
- SS T/C H/E on an SS S/C?
- INFE's Turbo Build
- Am i missing something ?!
- Rough Idle
- I have searched and no real answer so....
- hows the vibrant weld on muffler sound???
- serious twin charge answers plz
- Rebuilding The LSJ
- nitrous wiring ?
- fast
- newbie warranty issues....???
- May be a dumb question but is this secure to put ice in the reservoir?
- quick question about my injen cai
- thread size of hole in blower snout???
- Reverse lights out
- 98lb injectors, installed and running
- DC SPORTS Catback Exhaust
- headers and exhaust
- My SS feels likes its going to fall apart!!
- run supercharger without rotors
- 2.7?!
- i just bought a 05 ss/sc and need help
- Z max
- pulley size w/ meth
- Cryo chillen a h/e?
- tb,s
- clutch install instructions
- Hey guys.. I need input
- IDC's???
- build question
- lsj turbo ?
- what gauges are the best
- front mount S3 for sale
- Help with code P0068
- is my SS/SC stage 2?
- 42.5lb fuel injectors
- Idle Issue
- Coolant smell
- ottp spherical cabs
- Wideband?
- Where can i get an oil pan
- Fmic??
- What is the stu MOd????
- Eaton M90 Supercharger
- Help with my build :).
- ottp
- short shifter
- Zzp stage kit 3 ????? And other ???? Zzp vendors?
- Should I ditch the stock Heat exchanger?
- what to get
- thiking of DIY single pass
- what do you guys think about this w/a manifold set up
- purchases in order..
- Intake temps 100 above outside temp
- Ecotec build book
- need info on dual pass water pump
- Aem cai
- What Do YA think 50shot??
- How do most people do the ice box mod? And why such a poor dragstrip performance?
- is it worth it??
- which kit to get?
- sc vs tc
- ZZP or OTTP stage kits
- ZZP Modular Hub
- Supercharger Question.
- Injectors.
- hp tuner
- more boost?
- coolant system
- Got power?
- Plugs & Wires Help
- HP gains
- Super on a Solstice
- ZZP Customer’s Twincharged Cobalt Runs 11s!
- buying ss sc
- things i need to know about after i buy a ss sc
- 2.0 LSJ EXHAUST!! 2.5" or 3"
- c0000 ? what is this
- Special intake for Seattle and NW based Cobalts
- nj ny tunners
- Take a look tranny mishap
- 3k clutch dump
- belt removal
- Difference between 2.0 and 2.2
- Lsj trifecta tune ?????
- po300
- option b bracket
- spark plugs
- Cold Air For Sale??
- Ottp stage 1 kit.
- map sensor?
- My 2006 ss sc
- mounts
- LSJ Tuning Fuel and Spark Tables
- short throw please help asap!
- engine power reduced...ahh
- option B
- boosted 12.5 with only exhaust today???
- Best header/downpipe/catback combo?
- Turbo build questions
- ZZP Full build m62 Redline track update!
- want 300hp
- gm upgraded clutch
- ZZP 2.3 stroker lsj twincharged
- Redline!
- hahn high flow cat?
- what is wrong?
- clutch bleeder screw
- leaking coolant, possible water pump?
- Tranny Problem..Need advice
- Need some expert advice on my new project..
- stage upgrades?
- fastest you have had your balt?
- How come?
- Fan 1 & 2
- Safe? 750ca / 660 cca Bat on the lsj?
- Another Header/dp Question
- pulley question
- Intercooler Pump WTF...somebody walk me through this
- weird Slipping?
- Miles + Stg tune = Trouble?
- Twin M62's
- pulley and injectors
- Rear Tranny mount
- grinding into reverse
- Pulley and Hub
- Royal purple.
- Stage 2 Emblem
- boost issue
- spark plugs
- FINALY IAT's for only $60!!!!
- slave cylinder
- 42lb to 60lb question
- oil breather worth it or not?
- Stage 2 kit dealership bull
- ZZP Boost Referenced fuel system and setup for 80lb injectors?
- tranny mount broken what to get
- pulley ?
- LC-1 wideband problems
- I need a tune
- Best PCM for my setup?
- Strange problem
- is it best to
- Stage II Guys...
- Intake Feedback
- More POWER!!!
- Gms2 to ottp s1 thoughts?
- Need some #'s
- Prototype TVS users question asap!
- AFE power is going to release a new intake for the lsj
- QTP Electronic cut out
- Update on Ben's twin charged build with some new part testing! 388/345
- WTFK....Same problem different day..
- rod and head stud torque specs
- Lsj ecu spare
- P&P stock throttle body or LS4 throttle body which is better?
- most miles least work...
- rasing rev limiter pass 7k?
- downpipe
- N2MB Racing Labor Day Sale!
- pulley difference
- Whats the best FMHE??
- catless vs High flow cat
- This week's twin charge build, 361WHP
- Intercooler Pump Replacement
- unlocking the pcm?
- GM reflash
- Coolant Temp
- Need help!!!
- 2006 SS/SC Cams?
- best canned tune out there
- Intercepter 1/4...
- Help!!!!! Fixing this computer codes
- TVS supercharger?
- best header and downpipe need downpipe endlet to be 2.5
- ls4 tb or no?
- Front Bumper Problem
- New Header/DP Kills O2 Sensor, Crazy Afrs.. Long Day (Need Ideas)
- look inside!!!!
- help please
- Help with upgrades.
- Anyone else ever had this happen?????????
- HOW to install pulley on supercharger
- Meth: Before & After
- supercharger info
- questions about boost gauge and s/c
- SLP header and downpipe, anyone have it
- P0171 solutions
- What should I do next?
- pulley size question
- dual pass
- Why dont we have.....
- Porting question..
- Exhaust help. Please
- Stock Boost
- engine oil
- cold air intake
- S/c / Throttle help please!
- Beating the heat with TVS?
- supercharger coupler question
- Compression 9:5 to 11
- control arm pricing
- how can i tell
- Need help finding new piston rings
- Need header w/cat possibly stock
- tvs and e85 dyno
- should i be getting knock?
- OTTP stage 1 vs. GM stage 2
- Questions for those that have gone turbo
- first time with a cobalt ss at the track
- need help cooling mods
