- Smallest Pulley you would run w/ 60's, Colder Plugs, and a dyno tune?
- whichhhhh to GET??
- megan racing?
- starter removal
- Brake Fluid Help
- 42 vs 60 lb injectors
- GM stage 2 or CA stage 1
- Headers / DP Installed!!
- Is this the..?
- quick question on stock pulley removal/swap
- Cobra Heat Exchanger fluid capacity
- Serpentine Belt Help asap please!
- Help Finding Superchargers
- Exhaust Silencer?
- Parts Evaluation.
- Whats it take guys?
- Belt tensioner
- Catback
- Zzp Tuned
- ford injectors
- meth with a 2.79
- K&N Typhoon problems...wtf
- GMPP Extrude Honed Manifold
- Getting frusterated..Please help.
- Code HELP!
- Gutted cat??
- Cobra H/E
- largest throtle body upgrade.
- Supercharger bolts???
- Need help fast!!!
- Drag
- Ejecting Intercooler Coolant HELP PLEASE!!!
- Looking for 60lb injectors
- need advice on power...
- Changing the cam timing?
- Okay idk about this but
- Shit!
- build parts
- Header Question
- Using Innovate WB's Narrowband simulation
- Oil Filter Socket ??
- Standalone ECU options for LSJ?
- Lean On Bank One Engine Code Please Help!!!
- Vibrant help. Please..
- What Clutch Should I Get?
- Canned Tune
- drag tires
- ZZP header ordered!!
- New Mods On The Way!!
- Quick Question.
- Meth Question.
- I found this amusing, you might too
- where to buy 2.9 and injectors
- Exhaust tone
- new project doable?
- Head removal
- hp tuners superchager torque managment
- Tsudo N1
- what does this mean :(
- 1/4 Mile Time And Horsepower
- exhaust opions?
- Order Clear Image Header / DP Combo
- Cleaning hydroshield
- !!cooling!!
- would you buy used injectors??
- My Cobalt is eating spark plugs! Is this normal?
- exhaust gaskets?
- what should i do???
- trying to find options
- gm tune question
- Total motor build...
- Mounts!!!
- Dyno AFR's with stock tune and smaller pully?
- is there more
- Will this sound raspy??
- Got tuned and dynoed
- does this sound like a boost leak?
- Aeroforce Interceptor Question
- CAI cleaning
- Ok, so who here installed a vibrant header/catted DP and DID NOT have a CEL problem?
- Help, Coolant leaking
- Next Mod....
- Extra long O2 sensor?
- Looking into Cams
- Magnaflow Resonator.
- meth kit installed
- noob question
- sucking noise after pulley swap
- Stage 3
- Vibrant exhaust people i need help
- Custom exhaust. (Info/pics/vids)
- Heeeellllp!!! Ic Pump Problems, Need Help Asap!!!
- Need a STOCK HPTuners file for 2006 SS/SC
- Another stage 3 question (yes I used search)
- motors out
- K&N Typhoon Intake Cleaning
- Altiery54's Dyno Vid + Graph
- Stage 2 AFR
- anyone use zzp stage kits>? their pcm>?
- Stage 2 hub FRUSTRATION!
- max power for sc
- Megan Racing Catback
- Bad Coil packs?
- meth kit hook up
- k&N shield
- stock ss header and downpipe
- Need some help having 1st gear problems
- Big cxr h/e ?????
- differences in years?
- with aftermarket H/E
- Piston help.
- help finding the right parts
- Gains from 2.7 too?
- sparking BAD!!!!
- Ordering new pieces..Need some guidance on what to properly do.
- Only Redlinin at like 7000rpm need help?
- Will this work?
- Priceless
- Intake Manifold won't budge!
- You LSJ guys should get in on this!
- When removing supercharger...
- Can you help me with four questions?
- Surge Tank info
- Shifter problem
- long road to ruin
- Keep blowing valecover seals.
- Flywheel bolt part#?
- Question
- Injen CAI causing CEL, Stumbling
- If you want to run a pully smaller than 2.8" get in here!
- An idea i had...
- Magnaflow Catback
- you might be a ricer if......
- Cobaltblackss returns to stock
- Heat Exchanger
- Why no engine light?
- Cat or no Cat
- battery, atl, starter HELP PLEASE!
- Question...
- cat-less?
- Problem with overheating/compression.
- hub install question
- Problem??
- Stock plug.
- freaking another boost dilemma
- Full exhaust = hp...
- New Dyno #'s
- a Nasty sound...
- Car Won"t Run
- Quick Question
- Intake Manifold Info
- gasket
- Just found a few BRAND NEW sets of TOG headers if anyone wants them...
- Exhaust manifold flange
- godspeed
- looking at getting Stage 3
- Spark plug I know I know
- Meth and plugged silencer holes???
- back pressure question
- sticking boost gauage
- stage 2 belt part number
- My list of stuff
- Help with cam grind
- 300$$ to spend lil help
- Inspection Issues
- Fueling issues
- question: gm stg2 and then back to stock?
- Who thought things could go wrong...
- ditching the laminovas
- 3" Catless.... no rice sound???
- Ideler Pulley
- Before I order..
- short shifter
- lc-1 problem with hptuners
- AIS fender mount with windshield washer tank
- turbosmart
- WTF is wrong with my car?
- GM Camshafts
- CEL P0137 and 2101
- Oil Change -> Reduced Power -> check Engine -> After I forgot to connect censor
- Miss or lags for a split sec. with the ac on!
- Engine sucked up lots of water! HELP!
- general info
- Getting a custom exhaust need opinions
- vibrant 4-2-1 header / downpipe
- 2.0 stroked to 2.2
- spending 700-1000 bucks need help
- Help me spend $1500....I already have S2, 2.9, H/E, intake
- ZZP dual pass intercooler kit
- Dead interceptor???
- Help! Cel P0172
- Question
- fluid in heat exchanger
- 2 range colder plugs
- Zzp Mail Order Tuning
- car wont start!!!
- My car, few questions
- Stage3?
- Help With Pulley Removal
- Fouled Plugs
- Fix Your Idle For $6
- 3in Exhaust Fitting Stock DP?
- Question
- Erratic Idle
- Well, Doin the install myself...
- shift linkage? anyone have pics? please help
- alternator options for turbo
- CX heat exchanger or ingalls?
- Quick Question if anyone would know
- From Ported Manifold And Zzp Downpipe To Clearimage Combo
- Modifying the ECM for CNG Fuel
- how did you guys adjust your hurst?
- hurst short throw
- tuners near maryland
- meth kit
- engine bearings
- another meth question
- is this book any good?
- stage 1 or 2??
- Power and Torque Curve
- Will this STS fit
- Filter Options for Airbox mod...
- Hardwiring Interceptor
- alright alright
- boost guage question
- cam comparison
- exhaust help
- ls4 throttle body
- Tune Time in New Jersey
- Leak????
- 2005 SS/SC CEL...Need help PLEASE...
- Time for a short throw
- Stupid question... but a must before spending my 250$
- Intake?
- devils own vs AIS
- best sounding cobalt exhaust...wow
- exhaust, any gains?
- stroking questions
- Replacing Hub...
- Plugged Silencer Holes...
- any gains??
- If it was you...
- Picture Request-Intake Manifold cutting
- this will fit right??
- pulley
- Whats LSD gonna cost me?
- A little confused
- Spark plug help
