PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Can i get some opinions?
  2. Cheapest 2.5 catless D/P
  3. Wierd squealing noise from blower?
  4. Need Low End Power!
  5. im going to scream
  6. Joining The GM Stage 2 Club.
  7. quick notes on D.I.Y.S. stage II install(hub/pulley)
  8. Emissions?
  9. BSFC and Crank pulley size
  10. Anyone else have this prob with a gm stg 2
  11. What numbers do you think i'll be lookin at
  12. Gm Stage 3 Kit Info
  13. New
  14. Set-ups, which to choose?
  15. forged pistons take a 100 shot?
  16. will i blow up my motor
  17. getting 60# injectors and tune from New Era Performance!
  18. dumb question....wtf is this methane shit about
  19. Couple quick questions about Stage 2 and GMP Exhaust
  20. help with engine
  21. Mod. question
  22. GM Stage 2 or Intense Stage 2 or 3?
  23. Stage 2
  24. Bwoody Motor Mounts
  25. Summit Racing's ARP 2.0 Head Stud Listing
  26. yet another stage 2 SS:-)
  27. what a great day today...
  28. K&N drop-in or AEM dryflow, anyone here?
  29. Do cat backs and cold air intakes void warranty
  30. Well not so mad at gm anymore
  31. does anyone have a carfax account????
  32. what would it take to hit 270whp?
  33. Help Me Out Here
  34. Reverse Lockout
  35. interceptor
  36. What Size Water Injection Nozzle Do You Run?
  37. Vibrant exhaust
  38. Location Question
  39. Gmpp Cai?
  40. Cooling Mods....hmm
  41. hptuner or accel/DFI GEN-7
  42. how fast are u getting with ur gm stage 2?
  43. To SS/SC owners who think it's expensive to convert to turbo
  44. video of my 07 ss/sc
  45. supercharger oil?
  46. Got Stage 2!!!
  47. Hurst Shifter...NEED HELP PLZ
  48. I Hate Gm!!!
  49. Fuel pressure fix for 60lbs?
  50. corrent psi?
  51. DIY dual bypass??
  52. CA Stage 6
  53. where to get a cobra h/e
  54. Dual Pass Intercooler End Plate
  55. i fell victom4 ringland!
  56. Guys With Hurst!
  57. Intercooler Capacity..
  58. hey, im new here, just thought id try a post
  59. Coolant System Q's
  60. stage 3 pulley
  61. stock psi?
  62. Zex Plugs (again)
  63. Fellow ss/sc owners with vibrant header!!!I need help
  64. hp tuner?
  65. ho tuner?
  66. People running water/meth
  67. CA 2.79 Stage 2 pulley?
  68. Good Buy?
  69. flywheel/clutch bolts?
  70. GM stage 2 with 2.9....tune?
  71. car jerking
  72. Am I missing anything here? Please inform
  73. For those running the dual pass
  74. information please!!
  75. Bye bye to the SS/SC???
  76. 2007 Cobalt GM Stage 2 Tune
  77. how safe is a 2.85 pulley
  78. Zex Plugs & 2.90 Pulley Installed.. Wutz Next?
  79. GM Stage 3 Pulley Install = Success
  80. Quick question
  81. How does this fit to my stock dp?
  82. mechanic charges?
  83. Holy Snow Performance...!?!?!?
  84. any reviews of xtc front mount intake??
  85. would i bbe close to 250whp with.....
  86. Ngk R5671a-7
  87. Holy S!!!!!
  88. Installed Fujita
  89. need some help...how to tell if reflash is right
  90. what do u think?
  91. Removing valve cover... please help
  92. GM Info
  93. Hp numbers
  94. Stage 3...
  95. performance...what can i do to help?
  96. press on pulley
  97. First time to the track
  98. front strut
  99. Corsa from Cobalt Addiction?
  100. K&N CAI filter
  101. Twin Screw Supercharger!!
  102. A/C Removal?
  103. about pulley
  104. Turbo Cobalt 2.0
  105. Stock Rev Limit?
  106. Knock on a stock engine?
  107. Which cores flopped in dual pass??
  108. Front Mount Dimensions?!
  109. GM Stage 2 tune..Is there a new one?
  110. airbox mod or CAI?
  111. how did you press on the modular piece?
  112. Dyno Results! Post Yours!
  113. Guys At High Elevation, What's Your Boost???
  114. rotors..
  115. K&N intake Where to buy??
  116. 2 Questions
  117. Garrett t3/to4e Turbo
  118. Boost Control
  119. Which Spark Plugs to get.....
  120. OK...maybe dumb question
  121. Tire Pressure?
  122. 2.7 pulley fit on stage 2 hub?
  123. oil=synthetic??
  124. Ait to Fuel
  125. help I cant find a header and downpipe that fits my needs
  126. Spark Plugs
  127. MAP sensor and lead???
  128. AEM CAI Magnaflow Catback Stage 2 Dyno Results
  129. Zex pluggs
  130. cams
  131. if i go with a 2.6 pulley...
  132. stage 2 installation HELP
  133. looking for stock 2.0 ss/sc header
  134. How Superchargers Work, with illustrations.
  135. dyno numbers
  136. Clutch is SLIPPING!.....Help
  137. Stage 2 with smaller pullies..
  138. 2.6 pulley work on stage 2 hub?
  139. Possible LSJ fuel rail solution
  140. Update on Stage 2.
  141. Ceramic coating your intake piping... good idea or bad?
  142. Exhaust...seriously, no one knows??/ordered CAI
  143. Water/Meth Question
  144. to 65, or to 50. that is the question
  145. Any thoughts on this?
  146. My new pulley made by nate!!!
  147. YES!! Getting stage 2!
  148. Front Mount Exchanger Question!
  149. Dual Pass installed, No more power...
  150. TD price
  151. GM Stage 2.....
  152. wrecked the camaro...ended up with a ss/sc
  153. Wierd Issue at ~3000 rpms...
  154. limp mode question
  155. 300HP Turbo Cobalt
  156. Who's running this anti-belt slip combo
  157. AEM or Innovate Wideband
  158. GM annoys me.
  159. Installed Instense hub+pulley..but doesnt line up?
  160. TAG stage 2??
  161. Hook up fans/ic pump to switch???
  162. What to buy first if running a 2.5" pulley
  163. Stage 2 Kit- and and Replacement 2.79" Pulley?
  164. GM Stage 3, 2.9" pulley= TEH Shit!
  165. Safe Or Not
  166. Balance Shafts delete
  167. WTB: pistons
  168. victory_red_SS' latest addition to the project
  169. Guess my dyno results!
  170. Exhaust and pulley question
  171. has anyone checked this place out?
  172. Largest pulley for pump gas?
  173. Pulley Install - Stage 2 to 3
  174. Pacesetter Header Video!!
  175. 2007 AEM Intake?
  176. Stage 2 pulley tool
  177. Anyone done a HE install from GB?
  178. When to bring in my ss/sc for first service/oil change?
  179. Removing Stage 2 pulley??
  180. Got done my first round of Mods!!
  181. Where Can I Buy A Silencer For My Exhaust?
  182. Where Can I Buy A Silencer For My Exhaust?
  183. Where to get stage 2 installed OHIO?
  184. what gm cat-back
  185. Surge Tank
  186. New ARK Exhaust????
  187. Catch can installed
  188. Max timing with 2.7 pulley 60lbs inj and 91octane
  189. Prices on a few things
  190. got my 2.90" pulley from nherbst454 **PICS** weight of pulleys also...
  191. clunk noise
  192. installing a pulley?
  193. is anyone running with a 2.8 pulley and 42.5 injectors? Any probs???
  194. I have a question about if i need to retune my car or not??
  195. Stage 1 dyno numbers, who's got them?
  196. bwoody mounts
  197. 2.7 and 60lbs
  198. "Blown it" SS/SC Piston#4 Blowing up information
  199. Blown Motor
  200. Odd RPM pattern
  201. More Horsepower?
  202. New Supercharger Thread!
  203. Engine Mounts or Dampers??
  204. ss/sc headers
  205. Stage 2=Big MPG increase?
  206. SC Gasket (stage 2 install)
  207. quick octane question
  208. How much s/c oil does the s/c take?
  209. Gas/Fuel/whatever you call it
  210. Catch Can Pictures/Comments
  211. Those who have a 2.8" pulley
  212. Fujita Intake CHEAP!
  213. tell me what u all think
  214. Question about supercharger stage kits.
  215. pulley size
  216. Twinscrew Refund!?!
  217. Meth Injection: Maf based versus Boost?!?!
  218. spark plugs??
  219. Stage flash question
  220. HOW GOOD IS YOUR HEADER Really?
  221. ss/sc interior in ss
  222. Air/oil seperator
  223. Cobalt ss/sc exhaust same as..LS/LT/SS?
  224. Question for Florida People
  225. hydrolock
  226. What are "flowmatched" injectors?
  227. AC Delco Oil Filters!!
  228. Fujita or AEM
  229. 2.75" Exhaust Silencer?
  230. CA ss gm stage 2 replacement 2.79 pulley?
  231. noob question about wheel offset.
  232. MSD ignition now possible on Ecotecs with coil on plug?
  233. GM STAGE KIT help
  234. still uder warranty....what all voids warrant!
  235. ::Heated Recaro's???::
  236. Stage II Delayed
  237. What You Seeing For Boost on a 2.6"
  238. would i be ok if
  239. Stge 2 belt
  240. okay 2.6 pully or bad idea?
  241. smokin
  242. how to add timing?
  243. gm stage 3 pcm
  244. Does your Stage 2 do this?
  245. 3.5 hrs for stage 2 install
  246. cobra heat exchangers
  247. limp mode
  248. Cat Question...
  249. Blower rotor bearings
  250. Oil smells like gas?!
