PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. exhaust
  2. Question im a little worried
  3. Timing Chain Help!!
  4. rpms drop slowwwww
  5. Stupid Coolant Question
  6. Header Wrap: Good Idea or Bad?
  7. e85
  8. wideband working?
  9. Look at what UPS just dropped off!
  10. Strut tower bar question
  11. Running Lean up top with E85
  12. Will chevy dealer reflash a zzp stage 2 kit?
  13. Oil Pressure
  14. Looking to go E-85!
  15. high boost no power
  16. Problems...
  17. Continuing the build...
  18. LSJ Fuel System Question
  19. Blew a plug??
  20. LSJ GMS3 Questions/Troubleshooting.
  21. 2.6" pulley on tvs Supercharger
  22. 50 shot of NOS ok with stage 3 ?
  23. just to clarify
  24. is trifecta tune worth it for me?
  25. 35 shot safe with out a tune, do you think ill be safe?
  26. Meth?
  27. ZZP comp cams worth the price ?
  28. Spark plug question?
  29. metal shavings on oil filter
  30. Getting knock
  31. Green liquid
  32. 06 Cobalt SS/SC mods?
  33. GM Performance Cat-Back Exhaust
  34. 2.7 pulley
  35. pcm which?
  36. I need help
  37. Gauge question
  38. knock retard 1
  39. I don't understand this............
  40. zzp stage 3 problem?
  41. GM vs. aftermarket Stage 2 reliability
  42. (Another) Heat Exchanger Question
  43. LNF MAF on LSJ?
  44. Brake Fluid & brake light coming on
  45. Got my exhaust on!
  46. foam thing?
  47. spit, sputter, and stuttering.
  48. Well... that ain't good...
  49. Mpx catback
  50. Over fueling problem
  51. Can't boost past 5 psi
  52. Stage 2
  53. ZZP stage 2 kit
  54. ZZP 3" intake
  55. Supertech Valve Springs Don't fit in LSJ Head?? Look Inside.
  56. who to choose
  57. Where can I get fog light harnesses?
  58. weight split
  59. meth installed...question
  60. 400+ wheel horse power club
  61. oil filter cap
  62. flexpipe and converter
  63. ss/sc vs. saab 9-3 2.0
  64. Please help: In the Middle of a Brake Job, Can't Get Pads off Rotors (Lip formed)!
  65. Any problems I may run into?
  66. SS/TC boost gauge in IRL
  67. BOV on a supercharger?
  68. Quick Radiator Question
  69. Exhaust rattle with zzp downpipe?
  70. zzp 3inch exhaust vs gmpp exhaust?
  71. What pressure does the oil light come on?
  72. car is pissing me off
  73. Ottp
  74. Meth heads!
  75. Gen 3 retrofit
  76. stage 2 kit
  77. Mufflers
  78. Todays Dyno Results are in!
  79. best axles to buy?
  80. LSJ + nitrous + TVS = ?
  81. Ordered my K&N drop in...
  82. Oversized Heat exchanger for cobalt??
  83. SC/TC Questions ///Stage 2 to 3 SC
  84. GM kits to other kits?
  85. qtp cutouts
  86. installed Aem uego
  87. Dead battery leads to misfire?
  88. Wtf cam sensor?!?
  89. 2.0 SS/SC stock injectors for sale..
  90. Just dynoed
  91. New..used cobalt SS S/C
  92. A clean LSJ Throttle Body.
  93. price
  94. Switch to 2.7??
  95. 2.0 lsj spark plugs
  96. Blew my motor. Recycled or rebuild?
  97. 2005 Cobalt SS shuts off while driving
  98. stage 3 making 220hp???????
  99. Free M62 ZZP Meth Plate Guess my Lucky Number
  100. Questions about the Idle problem.
  101. boost controlled meth
  102. Ticking while engine is running or not???
  103. Tiny metal flakes in exhaust...
  104. Sad day...
  105. Turbo Swap problems
  106. Timing Help!
  107. Dual Pass Laminova core Q
  108. Cat or Catless...
  109. remove stock heat exchanger
  110. Stage 1 h/e
  111. Lsj whp
  112. Oil pan removel, whats the trick?
  113. New to me 2006
  114. cannot get rid of eng pwr reduced
  115. Took my car into the dealer for IC Pump and engine noises
  116. Hurray!!
  117. Treastone Upper Lower Silicone Radiator Hose group buy
  118. heat exchanger
  119. Pulleying down??
  120. Fuel Pressure Flux
  121. finally got tuned
  122. Turbo swap help
  123. Hp Tuners
  124. crazy noise!!! please help
  125. think i blew up my engine
  126. Stage 2 Problem?
  127. trouble starting
  128. Aem wideband help
  129. Cooling fan not turning on
  130. How to make supercharger whine louder?
  131. just kinda wondering about this
  132. Help
  133. Need a TVS...vendors let me know!
  134. Installed ZZP rotated mounts and..
  135. LSJ valvetrain help
  136. Need to know if this is normal!!!!
  137. Wanting to go farther
  138. 2.6 pulley only making 16.2 psi
  139. question on downpipe
  140. Injector/pulley combo? Please Help!
  141. Muffler inlet/outlet question
  142. Major Power loss...HELP!!!
  143. Modification questions
  144. i want more power!!!
  145. only 15 psi max with 2.6 pully
  146. Coolant ?
  147. ZZP Stg2
  148. 1/4 mile question
  149. Header Wrapping Cold Air Intake. Worth It?
  150. Cam Correlation HELP!
  151. Help! - Weird option B/Dual Pass symptoms
  152. Green gunk for cause of high IAT'2?
  153. Hit Raccoon, need help
  154. Possible Throw out bearing? Doesn't move..
  155. header/dp ?'s
  156. map and boost gauge question
  157. pulley setup question
  158. Wicked's car is down...... Troubleshooting assistance needed
  159. check engine light after intake install
  160. Exhaust besides Corsa?
  161. Gauge ideas plz
  162. meth and the dd, thoughts?
  163. Couple of questions if anyone has the time =)
  164. Questions about hp tuners.
  165. tuning
  166. exhaust question
  167. The "rasp" is killing me.
  168. i need to buy something for the car
  169. Tvs?
  170. multiple cylinder missfire injectors?
  171. How to install a wideband
  172. First hand experience?
  173. Are there any simple drop in 255lph fuel pump swaps for the LSJ Cobalts?
  174. injector harness
  175. 45 degree elbow for CAI to LS4 TB
  176. Broken Rockers
  177. New member to the Stage 3 club
  178. Loss of power!!
  179. Interceptor Gauge... MUST?
  180. Engine whistling?
  181. 4-5psi Boost on 2.8" Huston we Have a problem!
  182. How to tell if your pump is wired wrong?
  183. tire size
  184. New H/E fixed bouncing revs?
  185. 06 ss/sc
  186. Is a bov possible on a SS supercharge
  187. How to replace manual shift knob???
  188. TVS vs M62 - blower speed IATs
  189. questions about aeroforce interceptor gauge
  190. ZZP Stage 3
  191. got my magnaflow muffler and chrome tip today
  192. Boost problem Again!!!!! Help!!
  193. curious about stainless works products
  194. Ghost in my electrical
  195. Meth kit and cooling mods?
  196. Bov problem
  197. Goodies installed!
  198. Single Pass IM
  199. AMMFAB longtube header
  200. new pulley sqeekie sqeekie?
  201. Summer Tune Question
  202. thinking about getting a magnaflow muffler for my 07 ss sc
  203. True performance gain with header and dp questions
  204. gm stage kits
  205. JBody performance
  206. Stage 3 opinion.
  207. Turbo belt issue
  208. Where are you ZZP?
  209. Lets talk turbo!?
  210. zzp axles??
  211. E85 vs meth injection
  212. Killer chiller
  213. supercharger pulley really really hot?
  214. Interceptor Gauge ?'s...
  215. 100k mile fixes
  216. Direct port meth injection
  217. which tune....
  218. question about zzp longtube header
  219. Tuned: 2ng gear leaner than 3rd and so on?
  220. need a good catch can set up
  221. converting turboed lsj back to stock
  222. new fuel pump
  223. new injectors
  224. Dyno results....
  225. lsj stock cams VS gmpp cams
  226. running rich, causing a misfire code????
  227. belt squeel
  228. Compression Checks
  229. which boost gauge?
  230. track time
  231. ss/sc boost controller?
  232. LSJ alternator
  233. WTF!!!! piss off
  234. whats your opinion
  235. no code
  236. clutch ?'s
  237. Crateenginedepot.com header for cobalt question
  238. Header Calculator
  239. running wierd
  240. exhaust
  241. Need Help finding the BEST Exhaust System for my 2007 Cobalt SS s/c
  242. Stage 2 Question s/c
  243. Wetter Water in H/E system, how much?
  244. Wich Header Should I get?
  245. Exhaust Manifold
  246. Spark Advance?
  247. ZZP 2.4 Max Power Testing
  248. I'm in a pickle
  249. Bypass valve going bad?
  250. Help Please
