PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Code Help!!! Anyone Pls...
  2. Do I have Stage 1 or do i not?
  3. Got a new toy today
  4. injen problems
  5. down pipe vs. high flow cat
  6. SS Trail Blazer to SS Cobalt
  7. Fujita CAI fitment
  8. What is your Oil Pressure PSI at idle?
  9. Fluidyne h/e?
  10. How good is the B Woody top engine mount
  11. plz explain the meth kit..
  12. Approaching 36k miles
  13. How many of you have this!!?
  14. 3 inch pulley untuned?
  15. just a few quick questions! so i dont mess up my balt
  16. Stage 2 Pricing & Where to Buy
  17. SS/SC questions
  18. Performance loss
  19. cry02
  20. ping da ding ding
  21. Question about my fuel pump and horsepower
  22. Random Tech Downpipe ...
  23. Snow Performance meth kit on stock motor?
  24. stage 2 vs supporting mods
  25. swapping pullies?
  26. Headlight problem
  27. stage 5
  28. What pulley size should i run?
  29. Ingalls Tourque Damper!
  30. Twin Charging may still be possible.
  31. Anyone hear of this exhaust???
  32. Anyone in PA Running 2.8 pulley?
  33. performance mods??
  34. Reprogram for stage 2 yourself?
  35. 2.5" pulley+50 shot, good or bad?
  36. 3" Catless downpipe
  37. Stock Dyno Numbers!!
  38. Pulley Swap
  39. Intense
  40. Questions about the XTC Downpipe
  41. NEED some advice about a 2.7 pulley
  42. P0341 Help!
  43. Just wrote to Vibrant ...
  44. Snowperformance Meth Injection with knock?!
  45. smoke
  46. buying exhuast need a little help
  47. how much time off your et from exhaust leak?
  48. looking for turbo mani
  49. what oil?
  50. intense stage 3?
  51. My CAI
  52. Which header should i get?
  53. GMPP Honed Header
  54. Pulley Options
  55. 2.8" pulley???
  56. Cobalt SS/SC Resonator remove and replacement??
  57. WTB 2.7 pulley ASAP!!!!!
  58. a/f gauge help
  59. Blower Question(s)
  60. Exhaust Question Please Help
  61. Stock SS/SC WHP?
  62. GM Tuner ECOTEC LSJ Build Book ...
  63. Stage 2 blue pulley bolts will not break loose, I give up
  64. 100% undeniable PROOF, STAGE 3 = WARRANTY INTACT!!!
  65. GM Dual Pass
  66. airbox mod
  67. Spark plug help
  68. Interceptor
  69. slp exhaust for cobalts
  70. Twin Screw vs Procharger
  71. Easy way to exstend my MAF wire harness?
  72. New to the Scene! Need some questions answered!!
  73. Houston! We have a problem!
  74. airbox mod
  75. cheapest injen intake??
  76. NGK Iridium or Copper
  77. GMPP Exhaust Installed
  78. What bov should i go with?
  79. Tranny mounts
  80. Correct Way for Water Wetter, Gain Power
  81. big problems help help help
  82. N. California tuner charging $600 to tune Cobalts!
  83. Eaton TVS superchargers
  84. Cheapest Stage 2 Kit??
  85. gm stage 2 install maryland?
  86. What exactly is a methanol kit and what does it do.
  87. Water Wetter anybody?
  88. lost boost
  89. zzp header & downpipe w/ high-flow cat
  90. Just got an SS, got some questions:
  91. Pulley Question
  92. HIDs in Fogs
  93. fuel pump!???!?!?!
  94. just got my magnaflow on!(vid)
  95. Thinking about cancelling my order
  96. Polyurethane mounts shore hardness
  97. How many miles are on your car?
  98. anyone emissions tested yet?
  99. hahn exhaust??
  100. Custom Tune
  101. Shops?
  102. Higher Octane=.3-.4 faster quarter times
  103. exhaust differneces??
  104. can you?
  105. MAF Screwed up
  106. 07 si supercharged
  107. Downpipe
  108. 2.0 dp
  109. need some PCM upgrade help as well as someone to tune.
  110. Too Raspy
  111. Pig Rich!! Any Help??
  112. Valve cover bolts stripped
  113. cai decision
  114. gas for stage 2
  115. Latoff Chevy aka CrateEngineDepot.com
  116. pulse width VS duty cycle
  117. zex plug users
  118. Let's clear-up that 3" vs 2,5" Catback thing for the LSJ.
  119. HKS Header and exhaust
  120. stage ii question
  121. Aftermarket Radiator
  122. Cooling Mods
  123. Finally got the dual pass installed (option B)
  124. Battery Disconnect on spark plug install?
  125. '07 Shorty Antenna
  126. Just a cool thought....
  127. Dealer to install Stage 2 in N. Alabama
  128. This Sucks !!
  129. Whats A Thermal Exhaust??
  130. Well idk what's going on? Factory freak?
  131. Pulley/ NOS ?
  132. who's got a zzp tensioner
  133. Pls Help Asap Need Belt
  134. Aftermarket Cobra H/E
  135. Another spark plug question
  136. Normal Vibration?
  137. Intercooler sprayer
  138. stage 1 vs 2
  139. spark plug??? PROBLEM HELP
  140. Spark Plugs
  141. Track Rant SOOO PISSED
  142. EGT Temperature?
  143. Will all these fit together?!
  144. trap speed
  145. Not as much boost as before
  146. Well I guess everyone was right sort of.
  147. Gm Exhaust
  148. Stage 2 Dealer Install
  149. What clutch?
  150. CA vs GM
  151. code question
  152. Nate's 2.9 pulley
  153. Help with Tranny Mounts
  154. Decisions and Opinions (Turbo, Procharcher)
  155. anyone seen this mod
  156. Please Help A Few Questions!!!
  157. step colder plugs??
  158. Old plugs
  159. electric turbo
  160. pacesetter catback
  161. gm stage 2 should i
  162. which intake do you prefer
  163. Exaust tip problem
  164. Leaking Coolant
  165. P103 what does it mean?
  166. Anyone Needing A Cheap Stage 2? Check it out!
  167. I think I might have a problem?
  168. anyone know a website that sells cams
  169. couple noobie q's
  170. best bang for the buck
  171. Proper Part Numbers For Main Studs
  172. K&N on an 07
  173. dual bypass w/ option B
  174. Half Shafts?
  175. heat exchanger?
  176. gauges
  177. Mileage Any Probs.
  178. custom exhaust
  179. Smaller pulley But are plugs really needed
  180. Boosting only 10
  181. Oil pan help
  182. SS/SC on the bottle, where do you spray??
  183. How is the ZZP mid length header and downpipe?
  184. Gearing rattles-yes I've read the posts
  185. AEM intake install 2.0
  186. Gas Milage
  187. Almost at 1500 miles!!???
  188. What mod to do first?!
  189. blue bolt replacements
  190. OBX Helical LSD on E-Bay for $395
  191. WideBand for Interceptor
  192. zeitronix wideband.
  193. supercharger bypass solenoid valve Part #?
  194. anyone live in GA with hp tuner software?
  195. servicable rotors?
  196. Question PLEASE HELP!!!!
  197. transmission question?
  198. check engine light
  199. 2.9 Pulley INSTALLED!
  200. Airbox Mod, AEM filter?
  201. Stage 4/tune issues
  202. Why does it take so long to rev down!?!?
  203. Mod Help!
  204. My Airbox Mod
  205. I Need Brakes!!!!!!!!!!!!!
  206. Slippin Clutch/Driving Advice
  207. Loss of Power with Exhaust
  208. getting stage 2 soon
  209. istalling your own cat back
  210. Anyone tried anything such as this?
  211. Want to go Turbo question about pistons
  212. GMPP Manifold Torque specs?
  213. Magnaflow Muffler Installed!! (w/pics & sound clips)
  214. would this turbo kit fit our car?
  215. Intercooler Pump Problems.
  216. magnaflow sound clips
  217. Pre stage 2 install Jitters
  218. Ingalls Torque dampener???
  219. Help.....car Crapped Out!!!!
  220. Best header?
  221. Well I finally got my car, questions and showing off!
  222. Fuel rail possibility??
  223. bang on 2-3 shift
  224. twin charge a cobalt
  225. how much horsepower?
  226. Performance time!!!!
  227. ss s/c dyno's
  228. Dyno
  229. megan racing cat back silencer
  230. The LNF turbo swap
  231. Oil
  232. O2 Sensor extension
  233. Photo At 4th Gear! And A New Hair Cut
  234. Tranny Cracking????
  235. Ebay INTAKE Install Questions
  236. help on shifter install
  237. question about the wing on a ne 07
  238. Just installed GMPP Sport Exhaust
  239. my first mod
  240. Pulley
  241. Higher Octane Fuel
  242. what am i doing wrong
  243. GM stage 2 with 100 octane??
  244. Just installed my ebay intake ! HELP
  245. Cold Plugs
  246. Boost in stock supercharger
  247. Threw A Code
  248. Superior LSJ Performance Parts
  249. ebay turbo manifold?
  250. how would i do??
