- Air Cooling System
- h/e winter time! too cold to change!
- intake mod
- Smaller Pulleys question
- ZZP 3in catback?
- 2.6 Pulley Questions
- Exhaust to loud
- help guys final mins!!!!
- M62 temperature
- sabb 2.0 turbo ????
- help from turbo lsj guys.
- which is better
- help pleasee!!!
- ok ive searched everything
- Wet air filter? Engine Pwr Reduced
- Beating a dead cow..
- long tube header
- zzp 2.0 turbo kit?
- Home made option b tank?
- Fuel system
- Will this radiator Fit my ss?
- I need a radiator!
- How to check if your Intercooler Pump is working ok
- Bypass Valve
- How do you know?
- Catted downpipe...break-in period?
- dash hawk
- aem wideband.
- heatsheild hitting dp?!
- installing badmab header
- shorty header or mid length zzp
- transmission(?) question - revving really high in 3rd and 4th gear
- wheel hop fix?
- looking to port an lsj head
- installed cti header/dp now ticking?
- Hp
- Battery
- Does anyone have an exhaust vid of their car...
- Do i need a new harness for injectors
- single scan gauge people
- Reliability of turbo lsj's
- Wtb
- How much H.p at the crank ?
- Brand New Supercharger on the market! Never before seen!
- DIY Water/Meth/Alc Injection Under $50
- will it work
- not working
- e85 as daily driver
- cooling mods.
- LSJ + M90 Supercharger
- building my motor
- what do i need to turbo an lsj?
- Pulley fitment question
- 2 aeroforce interceptors needed?
- IC Pump Question
- Spark Plugs
- Does anyone do good tuning on LONG ISLAND?
- port and polish stock throttle body?
- just installed 2.7in pulley!
- whos installed springs and retainers?
- Spark plug cover - screws are stripped.
- Re routing the stock laminova system
- Cobra Heat Exchanger Question
- motor swap
- gauge install
- 400 horse? without going turbo
- Gauge question
- CANNOT get belt on!
- Need new muffler....
- this car/vent thread
- What to use to cut the exhaust off?
- p0171
- Whats the best intercooler for the LSJ?
- It is worth to keep modding without a LSD?
- Exhaust theory
- Gauging interest. S/C Plugs or plates machine fit.
- 150 stock. 142 stage 2??
- Turbo kit for LSJ..
- New Engine!
- replacin intercooler, ac condesor and radiator
- Stock Valves
- 12.9 to 13.2 possible with new upgrades?
- car wont start and cant get a scan
- overdrive crank pulleys
- TQ specs on flywheel and clutch
- Shaving the SS spoiler
- coolant temps really low
- Option B
- "Stage 2" vs. sourced kit...
- knocking and popping? axel?
- check engine.
- Looking for good Cat back open to 2.5 or 3"
- Need exhaust advice
- Aftermarket fuel rail?
- Boost Gauge help ???
- good turbo swap kit?
- safe
- Xmas for the ss
- E85 Question
- false p0300
- cheap upgrage
- been searching hard but cant find any straight forward answers on pacesetter header!
- Zzp supercharger spacer
- HP Tuners.
- Injectors
- dual pass
- aftermarnket radiators and fans?
- supercharger problem
- is a cobra h/e any good?
- has anybody..
- new clutch
- I think I'm missing something here..
- *Code* p0128
- Supercharger noise on shut down- help
- Lsj 2.4 stroker engine...
- stage 2 ??
- OEM Piston Rings
- 06 SS boost control solinoid
- smoke issue
- Adjustable Cam Gears - OGs Help!
- Procharger
- Flowmaster Hushpower muffler
- Set timing on LSJ
- Downpipe will fit or not???
- Getting retuned/dyno tomorrow
- Does the zzp 3in dp with 2.5 exit mount to stock exhaust mani ?
- Crank sensor Relearn?
- 2.6" pulley on a bench grinded snout XD
- how much boost can LSJ handle
- swapping motor
- Mod Question
- Can't figure out what size injectors it is
- wheel hop!
- Question on gutting the cat...
- Turbo Swap grocery list
- oil pan help
- Looking for someone to tune in wisconsin
- turbo questions
- ZZP Long Tube Header Sneek Pic
- I need you!!!
- TVS Pop Quiz
- Stock Four Pass Intercooling Route
- Bleeding Option B
- how to tell
- lsj alternator question
- Tune Help
- Cai
- dual pass cause internal leaks
- zzp dp
- Help!!!
- Serious Problem For My Friend Suggestions LSJ Guys?
- Disconnected hose from I/C coolant overflow/ fill cap...
- Ice problem
- Biggest exhaust gains?
- has anyone
- dp
- ZZP 3in Downpipe Rubbing
- gives me chills ugh hate that
- Looking for input on clutches for DD around 300 whp
- Looking for reputable tuner in Michigan(I live in Ann Arbor/Ypsilanti area)
- 2.8 or 2.9?
- close call...
- Need some help
- Lsj turbo daily drivers?
- Need some one with HP tuner
- Built Transmission
- Ebay header?!
- Check engine light
- Header DP combo
- finally made up mind TURBO!
- 4k towards upgrades need some insight.
- Front bumper
- Car Sputter and Runs Horribly When Moving In Reverse
- After all of the research and mistakes...
- I know this is amost impossible but beat a z28?
- Stock SC Boost question
- Thinking about converting 07 SS SC to turbo
- IC pump brought back to life!!!
- need info on injen intakes
- P0231 code help
- Could i hit 12s?
- if you could do it over
- Blown engine cobalt
- zzp snout tool work w/ ottp hub.
- Meth mix
- Hardwire in a Aeroforce interceptor
- Intake Turbo Adapter Plate
- Hit the Rollers
- Boma cai?
- CX Racing H/E cracking radiator.. Help.
- need exhaust help for this setup
- Balance shafts above 7000 rpm
- GMPP Clutch and LSJ Flywheel Q
- Cam timing effect?
- Aftercooler WaterPump
- finally got my heat exchanger on
- LSJ Rev Limiter
- 2.4 l head on LSJ
- ZZP Intake
- crank no start
- Tensioner Help
- TVS needed for 400whp? Nope.... ;)
- Next mods?
- driving the ss/sc cold
- What should i expect from the ZZP S3
- If I were to replace my s/c with a turbo what kit is the best
- Broke bypass valve
- zzp ls1 heat exchanger
- Break In Stage
- Stage kit or no stage kit
- Twincharging zzp =]
- Limp mode! =(
- crate lsj
- What DP is this?
- first time dyno
- Gmstg 3
- G's build :D
- 82,000 miles. My story and some questions.
- Just Rebuilt My Supercharger
- helppp
- need help slipped clutch really bad
- tire spin & overboost?
- Help!
- meth ?
- HpTuners - can you tell if an o2 is bad?
- Twin charged
- tvs setup questions
- cat or no cat that is the quiestion?
- headgasket??
- Finally going down to 2.5" pulley.
- Stage kits
- My setup and issue
- LSJ Clutch upgrade kit
- Stage 2 NO reflash
- tune!
- TVS or trifecta stage 3 with 50 shot
- Laminova Core Removal
- advice
- Sunroof rattle?
- Stage 2?
- high idle problem 03 srt4
- Have some questions on Stage 2
- ic pump flow rate
- Small jerk in acceleration and loud squeel
- question about coolant
- number estimate?
- Back pressure for the SC
- Car dying
- Which STS to buy?
- Near Wisconsin Tuners
