PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Finally upgrading the heat exchanger
  2. i need a idea
  3. SCcobaltSS Buildup
  4. A Sad Sad Story
  5. Got Me Some New Goodies!!!
  6. Inlet/Outlet sizes on Stock H/E
  7. =[ =[
  8. Fuel Line Disconnect Help
  9. Fuel Line Disconnect Help
  10. Got my rk sport front and sides installed!! PICS LOADED!!!!
  11. 2.80 44lbs
  12. Help me with my build eh?
  13. Stage 2 w/ 77.9mm not enough
  14. Checking for an exhaust leak
  15. Header Question
  16. help!!
  17. What type of meth to use
  18. stg. 2 = new oil change???
  19. Check out this CUSTOM RAM AIR
  20. Check out this CUSTOM RAM AIR
  21. water meth
  22. Stage 2 and GMPP sport exhaust
  23. Running a larger pulley
  24. stage three pully on stage two?
  25. stage 2 for sale
  26. Supercharger Oil
  27. ZZP Pulley Hub Question
  28. Installing Intake(2.0) question
  29. exedy stage one clutch
  30. No more ss for 2008
  31. Supporting Mods Questions...
  32. SC Pulleys
  33. Exhasut & Intake questions
  34. Ny Hp-tuners.
  35. Question about air/fuel's
  36. Getting Knock during shifts!
  37. CEL p2261
  38. Prothane Bushings in stock @ Turbo Tech Racing LOOK Inside
  39. CA Heat Exchanger
  40. running hot?
  41. GMPP mid muffler removed and this is what itd suppose to sound like!
  42. Anyone that can tune my car in midland or odessa tx, or buy there.
  43. Projections on TS max boost
  44. Cat or no Cat
  45. what does a heat exchanger do
  46. Just purchased the Twinscrew kit!
  47. last INTAKE thread EVER
  48. look at what i got today
  49. hahn headers/downpipe or ZZP headers/downpipe
  50. ZZP header/DP???
  51. Just got my ZZP header/DP installed..
  52. A/F gauge for a ss/sc
  53. Twin Screw Cobalt ????
  54. Question about my build!
  55. Flame thrower
  56. Exhaust help
  57. Exhaust help
  58. Rebel GM Stage Final Group Buy
  59. which one?
  60. adjustable slave cylinder rod?
  61. water wetter?
  62. Spark plug gap with 2.9" pulley
  63. i have two ss sc's!!!
  64. mustang dino
  65. Security Learn Procedure
  66. zzp stage kits
  67. Whats the filter size on the K&N for the 2.0?
  68. New Exhaust
  69. Noises with transmission going from first to second gear, suggestions?
  70. S2 and stock shift light
  71. Problem Please Help
  72. 1st drive
  73. SMS Competition header and 3in DP ...
  74. installing vibrant header+down pipe
  75. Second H/E
  76. Quick Air filter question
  77. Spray Bar
  78. spark plug question
  79. Cheap Parts
  80. Radiators
  81. need some advice...
  82. gm stage 2 and 3
  83. quick question for those who have dynoed
  84. 2.0L 3" Stainless CAI
  85. AEM Wideband
  86. Smaller Pulleys???
  87. Anyone with Hp turner in Virginia
  88. Best intake
  89. Make the supercharger louder?
  90. PLEASE READ! May have cracked a piston!
  91. what percent of methanol is in heet
  92. vibrant with corsa touring
  93. If you have Vibrant Header->Catback
  94. ZZP Mid-Length Header/Down Pipe Combo
  95. GM Stage 2 help (bad tune?)
  96. AEM dryflow
  97. throwing code P0420
  98. Need your help please
  99. CEL help
  100. nos?
  101. GM Stage 2 and 3
  102. Need a big name TS
  103. GM performance articles
  104. TWINSCREW who's sending them?
  105. megan catback pic
  106. just ordered my stage 3 intense kit
  107. Vibrations On Pedal
  108. Question For Those With The GMPP Exhaust....
  109. Stock SS/SC RPM???
  110. Round or Oval Muffler?
  111. CA Throttle Body Spacer
  112. Reverse Lights
  113. how many ppl got stage2 and did a 2.80 pulley swap?
  114. intermittent problem when cold
  115. 2.80 pulley one more time!
  116. HELP reflash for 2.8 pulley and 42lbs injectors?
  117. stage 2?
  118. Girls by a RED SS/SC
  119. Is this clutch too much
  120. Dezod Exhaust Installed w/sound clips!!
  121. Cobalt to Redline HPT question
  122. heat exchanger vs. meth
  123. to the people with vibrant headers
  124. my custom ram air intake(functional
  125. Dvd Player
  126. Write a review of your tuner
  127. Centrifugal blowers ... be careful.
  128. Question about the SS S/C engine
  129. how do YOU start your car...
  130. Which Muffler?
  131. power steering
  132. powersteering in supercharger?
  133. Heat exchanger
  134. heat-exchanger & fans switch MOD...
  135. Getting some ProCharger motivation till the kit arrives ...
  136. New parts on the way
  137. 47 pics of installs
  138. Stage II and Exhaust
  139. Fujita or Injen????
  140. is it safe? stage 2 2.8 pulley?
  141. pulling the motor
  142. Bumps, Potholes, Cause My Car To Just Turn Off
  143. Help!!!
  144. How to rebuild an m62 supercharger?
  145. Next mods?
  146. feathering in 1st
  147. Vibrant Header - Gravana
  148. aeroforce guage Problems!
  149. gm performance exhaust!!!!
  150. Cooling Mist Help?
  151. Rebel Auto Worxs Twin Screw tuning session and Video
  152. Lower Motor Mount
  153. Dual pass endplate fitting.
  154. GM Stage 2 vs. Aftermarket Injectors and Pulley.
  155. Motor Mount Q
  156. Two odd engine noises need help.
  157. 2.80 Pulley Question
  158. ATT: Anyone with GM Stage 3 Pulley + Wideband
  159. changing stage 2 pulley?
  160. what do the 2.9's do?
  161. Do you think the dealership would notice?
  162. dont know what i should get next
  163. Exhaust Backpressure & Scavenging ...
  164. cold air intake
  165. What's everyoens AFR
  166. airbox mod help
  167. Any one have hptuner that lives in NM or east TX.
  168. Dual pass intercooler
  169. hurst shifter knob....
  170. cobalt addiction front mount intake
  171. B&M short throw shifter
  172. Header/DP/Catback = How Many Horsepower?
  173. Nopi
  174. Weight Reduction some ideas please!
  175. GMPP Extrude Honed Manifold Install is a sucess!
  176. last minute ??'s before ordering zzp exhaust
  177. injectors
  178. gm performance exhaust!!
  179. Modifications and Which ones need a tune
  180. headers and downpipe?
  181. KSport GT Springs on SS/SC?
  182. Right area? Saab 2.0T turbo
  183. Import Tuner Cobalt SS bullsh!t article
  184. Transmision worries
  185. Whats this noise??
  186. ZZPerformance DP
  187. Best turbo MAF setup.
  188. Need Help With Stage 2!!
  189. intense stage 4 or custom kit?
  190. exhaust leaks
  191. just got done breaking in the motor and...
  192. GM Stage 3+ Methanol Injection Installed!!
  193. engine internals??
  194. Where can i find the Stage 3 Pulley?
  195. Couple of questions on Intakes.
  196. just got stageII
  197. Project 35R Redline
  198. Called Spec about their clutches :)
  199. spark plug cover bolts
  200. need some help before i buy my stage 2
  201. New exhaust
  202. Blue pulley bolts loctited update...the bit finally broke
  203. stage 2 on 07? whats wrong here
  204. turbo a 2.0
  205. cams
  206. Where to buy Injen intake?
  207. Vibrant Headers In Stock!
  208. Magnaflow muffler question
  209. NJ Stage II kit / install price check
  210. Base line dyno pull
  211. ION REDLINE dyno's 500+whp? WTF?
  212. Stage 2 Reflash
  213. is a 3" worth it?
  214. Flywheels...
  215. Stage 2 From CED
  216. Intense
  217. Stage 2 question
  218. only boosting 9-10 lbs
  219. Almost Done :d:d
  220. Drive by cable?
  221. heat exchanger fluid?
  222. 2.5 inch pulley??
  223. horsepower question
  224. stgI reflash qu?
  225. Stage 2 question
  226. Downshifting
  227. Hp Tuners
  228. clutch sticking???
  229. Turbo Engine Monitoring Display
  230. RPM recorder?
  231. Does the S1 reflash eliminate TM?
  232. Tired of my raspy cobalt!
  233. 2.6 pulley problem?
  234. return style fuel questions
  235. Whipple twinscrew
  236. Intake Manifold endplate price
  237. can make custom clutches for $260!!!!!!
  238. 2007 stage 2 tune number
  239. Getting my LFP DP H/E
  240. was a little bored today
  241. Clear image automotive ...
  242. Please Take A Picture Of The Maf Spot On Your Intake
  243. Magnaflow Exhaust installed...with pics!!
  244. Question about stg 1
  245. question about 42lbs and stock pulley
  246. Flow calculation for some LSJ parts.
  247. stage 3 blew internals
  248. stock manifold, power restriction?
  249. My ZZP high flow cat went bad after only 1,200 miles
  250. The best Springs on the market!!!????
