PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Stage 2 CEL, As well on being on a 230k Mile motor
  2. 06 cobalt ss recommendations on spark plugs
  3. Digital Dash
  4. Help With AEM Wideband Sensor
  5. Boost solenoid Mod Clarification Help
  6. All Sensors Changed Got "Reduced Engine Power"
  7. Any help appreciated
  8. ZZP long tube question
  9. Help! Overheating problem!
  10. P0171 and P0300 CELs 05’ 2.0 SS
  11. Cylinder 4 No Compression
  12. No Crank/No Start Issue
  13. I need help with my engine replacement
  14. New LSJ Cobalt owner, few issues
  15. LSJ Lifter Question
  16. Can’t figure out misfire, HELP!!
  17. What is this noise
  18. Crank pulley/harmonic balancer replacement
  19. how to tell trans axle is fully seated ?
  20. Please help! No start no crank
  21. 06 Cobalt LSJ engine swap
  22. LSJ 2-3psi Low Boost Issue, Circuit ‘A’ IssueCode P0202
  23. Boost Problems
  24. cobalt ss 2007 superhcarger code p0300 problem
  25. LNF crank in an LSJ no start
  26. Fuel Buckets - Venturi or No?
  27. Help with no start.
  28. LSJ Full Rebuild
  29. Schmitty's LSJ-T Build
  30. 2007 SS 125,000 Miles
  31. Need cruise control set & accel signal wire number
  32. 06 SS Doesnt drive in the rain?????
  33. ZZP long tube header warped
  34. Hi, new member with a Saab 2.0T/ using an LSJ swap harness and ecu needing help
  35. Does a 2006 Cobalt SS have an imobilizer?
  36. Cobalt SS/SC wont hold idle.
  37. Identifying a sensor
  38. IDLE Surge --> Now P0171 Code
  39. Surge tank overflow/return line connects to what?
  40. F35 Trans Rebuild or Replace
  41. Can anyone please help me out with figuring out where and how to change the vss
  42. I need to find the vss location on my 06 ss sc
  43. Need a 2.0 lsj
  44. Performance cat choice
  45. Smoke out the exhaust
  46. Single groove valve "upgrade"..?
  47. Starts & Dies after engine rebuild; no PCM 12V ouput to cam sensor
  48. Engine Power Reduced light comes on Cobalt SS
  49. Hp tuners mpvi pro
  50. LSJ Chasing "low boost" again, this time with data readouts
  51. Saab/ Cobalt compatability info
  52. NEED HELP, starts then dies. Evap, sc bypass only 2 codes
  53. How to adjust bypass valve?
  54. Code P2176 And P2135
  55. In over my head
  56. Need help identifying and locating cut wires..
  57. need info and picks of saab intake mani swap
  58. Are the zzp and ottp modular pulley systems interchangeable
  59. P0017
  60. P0017 issue weird???????
  61. Serious bogging issue need help
  62. WOT hiss
  63. Bullet Proofing an LSJ
  64. 15mm bolt under LSJ intake manifold
  65. Engine Reduce Power, Engine disables and car shuts off.
  66. Need help identifying LSJ turbo kit.
  67. TVS 132O full kit
  68. Laminova core supply
  69. Intercooler mods
  70. "Premium" 91 Octane + Stage 2
  71. Engine noise
  72. M62 threads
  73. P1185 and P1186
  74. Problem with ZZP dual-pass endplate
  75. 06 LSJ, Time to start planning upgrades
  76. Help
  77. stage 3 engine power reduced
  78. Gas in oil 2006 Cobalt SS Supercharged
  79. Running rich - P0172 intermittent
  80. Engine Power Reduced
  81. Oil Spewing From Valve Cover Gasket and Fill Cap
  82. Need Transmission Help Please
  83. Header/Downpipe combos
  84. NO rear sway bar?!
  85. Car goes into limp mode when over 5 psi of boost
  86. Belt slipping Bad
  87. Need some help
  88. Low boost, rattling supercharger
  89. Wire setup questions
  90. 2007 cobalt ss lsj no boost
  91. LSJ Swapped 300zx
  92. Camshaft Position Sensor wiring? Which pin is which?
  93. ZZP Stage 2 kit for LSJ
  94. Supercharger Cooling (Ecotec Miata)
  95. LSJ Exhaust Help
  96. Coilovers and Brembo upgrades
  97. Lsj mod help (new)
  98. How accurate is Inceptor HP meter?
  99. Cobalt SS SC idle/ P0171/vaccume problems
  100. TVS is in and ZZP is almost done tuning
  101. USMCFieldMP's LSJ Build: A Redemption Story
  102. LS4 throttle bodies galore
  103. Can I build a 2.2 block into an LSJ?
  104. LSJ no boost
  105. Help!
  106. Crank pulley question
  107. Issue with Air/fuel mixture
  108. LSJ bypass valve actuator upgrade
  109. Car Sitting for a year! Crank, No Start
  110. Swap 2006 lsj motor into 2006 ss 2.4 shell? Is the wiring the same?
  111. GMPP Clutches back in stock
  112. Idle Issue
  113. 07 LSJ dies at operating temp - out of ideas
  114. 05 lsj intermittent reduced power and p2138 code
  115. Lsj n2mb wot box no flames?
  116. clutch pipe replacement
  117. Low to no boost, bypass valve or solenoid?
  118. Help connecting the headlights cuts power to ECU and fuse box
  119. Which injectors do I have? Do I have GM stage 2?
  120. LSJ Throttle Body Bolts
  121. How will I know if my balt has a tune?
  122. lsj build problem
  123. MAF Sensor help!
  124. Cracked intermediate shaft bearing housing.
  125. stripped pressure plate bolt. HELP
  126. Compression numbers, am I safe to go turbo or rebuild motor first?
  127. Help: MEFI 4B and Cranks Sensor Wiring not starting
  128. No start after clutch replacement... please help
  129. LSJ fuel pressure?
  130. P1183 Code
  131. Heat exchanger creating a vaccum?
  132. Loud rattle on startup (when battery is dead?!)
  133. What would this sound be
  134. Stage 3 Tune?
  135. Cobalt sc 238psi each cylinder
  136. Abnormally High Boost Pressure (LSJ)
  137. Need some help with my 07 cobalt ss supercharged
  138. 2007 Chevy Cobalt SS intercooler pump problems.
  139. Ecotec cylinder head porting
  140. Questions about s256et and 80lbs injector's
  141. Multiple CELs
  142. P1101, P0300, loss of power, limp mode, sputtering, dipstick popped out, no start
  143. Sporadic codes. Aftermarket cold air intake.
  144. Need tuned?
  145. 2.4 pistions on 2.0 rods???
  146. Intercooler H.E dual pass end plate to pump routing
  147. LSJ Standalone Wiring Harness
  148. Car "bucking" in 4th around 3500rpm
  149. ZZP stealth inter cooler install ?
  150. Please help!
  151. Cobalt ss starts and then shuts off
  152. Misfire at idle
  153. To ZZP or not ZZp?
  154. Boost/vacuum issues?
  155. Air oil separator
  156. How much power am I making?
  157. How long will a stock 2.0 LSJ Cobalt SS last?
  158. 2006 2.0 supercharged cobalt ss
  159. 2 cylinder misfire lsj fix
  160. In desperate need of help with my 06 2.0 SC cobalt
  161. New plugs, spark blowout after 100miles?
  162. Injector Identification Help
  163. Cobalt ss sc
  164. Fuel Ignition Map needed for TVS
  165. Please explain this motor
  166. Need a fitting radiator 06 cobalt ss sc 2.0l
  167. LDK/LNF misfire issue
  168. need a new clutch
  169. Losing Coolant but where?
  170. Zzp entry turbo install
  171. ebay option b
  172. Only makes 5psi of boost at WOT
  173. Supercharger died?
  174. What to do, What to do?
  175. ECM pinouts
  176. Best Mods for lsj?
  177. Tranny maintence
  178. Aem fuel pump
  179. 2006 Cobalt ss p0033 p1183 and p1133
  180. Coolant in oil :(
  181. LSJ Clutch Replacement Info 2019
  182. Help with changing pulley and fuel
  183. Will this Aluminum O2 bung plug melt or seize?
  184. 06 2.0 ss/sc cobalt
  185. 2007 Chevy Cobalt SS/SC
  186. New pcm
  187. harmonic balancer torque specs
  188. Randomly doesn't boost?
  189. Cobalt LSJ - boost limited to 3 psi - boost control solenoid - PID for monitoring
  190. P0171 and Boost level issues
  191. Lsj camshafts
  192. is the 2.0 lsj interference
  193. Zzp entry turbo kit
  194. Lsj to l61 issues
  195. lsj low idle and bucking possible fix... .
  196. loss of power with WOT
  197. Strange Coil Pack/Harness Issues
  198. Adding a Cat, Do i need a tune?
  199. Supercharger snout swap.
  200. S/C + T/C set up and grocery list
  201. ZZP downpipe with cat have room for O2 bung?
  202. Cooling system won't burp
  203. Can’t identify this fuel injector
  204. LSJ Cooling Questions
  205. Lsj turbo swap. Need some advice!!
  206. 2.8 pulley install
  207. P0122 & p0223 lsjt
  208. normal lsj vacuum?
  209. do i have a vacuum leak
  210. GMPP performance exhaust is toast
  211. Dyno'd my stock 06 SS SC today
  212. Stock boost gauge
  213. 2006 2.0L SS cobalt 134a cap
  214. MAF missing!!
  215. Vacuum line for brake booster LSJ
  216. 2006 ss surging issues
  217. Are silicone hoses crap?
  218. Making a Kappa car whine
  219. Fuel system - BRFPR? -OEM or upgraded fuel pump?
  220. Pulley Identification
  221. 06 lsj shifting issues
  222. ~300WHP build with TVS; Part list advice?
  223. Need help diagnosing loss of coolant
  224. Lsj engine noise, bearing issue?
  225. Boost Issues
  226. Ignition issues
  227. 2006 SS (LSJ) won't start; thinking bent valves?
  228. Plastic piece
  229. Smashed header
  230. Few problem
  231. Problem
  232. LSJ reliability past 120K miles (motor swap or not)
  233. pullies
  234. 2006 stage 3 problems help!
  235. Replacing clutch, any other suggestions? (replace, upgrade)
  236. Trouble joining engine to transmission
  237. Cheapest clutch kit for durability??
  238. Ion Redline and SS ECU same?
  239. Trifecta LSJ Rant
  240. 2006 ss/sc
  241. Want to Buy LSJ Crank
  242. Stage 2 ZZP
  243. 60lbs & idle misfire
  244. 06 supercharged cobalt 2.0 exhaust system
  245. Twincharged LSJ
  246. transmission problem
  247. camshaft/crankshaft trigger pattern
  248. Brake Master Cylinder question
  249. Thoughts on Intake Valve Timing 3 degrees retarded
  250. Grease nippled SS SC A arms
