- exhaust farting?
- header and DP
- trifecta or ott stage 2
- No idea
- Water Temp Gauge
- zzp stage 3 finished!!
- Trifecta tunning
- Ott stage 1 kit
- zzp s3 heat exchanger question
- good news for transmission problems
- hub bearing..
- poer steering...
- Quick question.
- Exhaust for E85?
- rpm gauge bobing up and down
- Need some mounts!
- Short Throw Shifter
- misfire/power steering
- Clutch help 6 PLUCK know how
- E85 questions for people that are running it
- LSJ and LNF need to know if this works
- sputtering at high rpm
- 2 step colder plugs
- For those with an SS/SC that rattles...
- check engine light
- stock cat questions.
- Additional Mods
- Heat exchanger question
- Forged pistons NEED HELP
- What do I need to do with 2.6 inch s/c pulley???
- Head Porting Pics
- couple of problems..
- bushing
- PLX DM100/OBDII question
- belt squeak after pulley install
- Ingalls stiffy ETD
- Head Porting Tips???
- downpipe gasket?
- What downpipe do I need?
- Tranny help
- New twincharge build
- Spark Plug Question
- Which one..?
- NBS's Necessary for 8k??
- meth MAF box
- Should I tune?
- Recklessactn Rebuild Thread
- Timing chain guide bolts
- Steering Rack Spacers?
- sleeves and rods?
- Comparing ttr stop mounts to ottp rotated mounts
- your thoughts?
- turbo
- Supercharger make pulsing noise
- Which set of axles?
- She's Here :D
- 2.0 to 2.4 swap
- Removing Belt
- 2.6 -2.7 pros and cons
- 60s on stage 2 tune?
- OTTP Long Tube Header
- Turbo Swap ?'s
- Needing someone to tune..
- Tune.
- The Official TVS Dyno and 1/4 Mile Thread!!!!!
- Jason Smith header cracked on me
- AVID Motor mounts?
- ZZP Upgraded Throwout bearing?
- zzp cams
- Rattle Dissapeared After Stage 2 Install
- Gauge education
- exedy clutch
- license plate light not working!
- What should I do..insurance money
- NEED HELP: LSJ to Bradley
- yes ive searched
- puttin in a new clutch
- Will it hurt the SC???
- NGK plugs
- Engine stalled and wouldn't start
- Aem vs injen...
- Widest tires for the front
- gmpp catback
- Help- Cranking Issue
- meth
- Mid-engine build-LSJ -saab ecotec
- Torque damper making funny noise?
- Compression Test with Interesting Numbers?
- help me out.
- Removing stock pulley
- 2.7 and 60's: post your mods and power
- meth
- Engine Break-in
- Quick question
- Help me make sure i got the right one this time
- Hahn Down pipe question.
- RDFABS intake
- *TVS or Turbo or Twin Charged*
- bully clutch
- Exhaust getting Raspy?
- 07 SS/SC only firing on 1 cylinder
- Head Question
- low on cash but need a clutch
- k&n air filter
- question
- s/c bypass question
- Pulley swap
- lowering springs
- clutch calls my name. need help
- 2.4 Supercharging Questions.
- rods and piston installation question
- 20 PSI with stg 2?
- Need help asap!!!
- 2006 SS/SC Parts Car
- Hi FLow cat
- Post Pics of LS4 on a balt 07!! PLZ
- question help
- Blet tensioner help
- How much hp on 60lbs injectors
- just a question
- gas guage problem
- TVS vs Turbo vs Twincharge
- ZZP Header/Downpipe Combo + ZZP 3" Stainless Steel Catback Exhaust = WIN? Discuss...
- zzp header/dp combo
- drivetrain winding noise
- Heat Exchanger cut-a-away pics
- Hahn Turbo Swap
- leak on zzp header/dp
- stage 2 belt on 2.7
- New fuel pump for 80#ers???
- link to the CED TC grille combo?
- boost gauge showed belt slippage.
- 07 lsjcat failure GM notice?
- endplate ass istance
- Stage kit issues???
- zzp stage 3
- How to wire a aem uego wideband
- Whats wrong with these?
- coolant smoke...
- Restore?
- I love
- cat back exhaust
- Ins't BOOST .....BOOST
- IAT1 issue and thrown codes
- Thinking about going turbo.
- Loud Exhaust Help
- Where do I get parts for my f35 trans?
- high flow cat heat shield?
- Lowering car next week.
- Boost leak?
- CA V1 header.
- LSJ Custom Setup!
- Fix?
- power engine reduced need help
- shocks and struts
- wondering about oil cooler
- dual pass
- Anybody running a fuel pressure regulator?
- 06 ss loosing 3lbs of boost
- Just changed oil to 0w-30
- RESURFACEING A Fidanza Flywheel
- Performance mods!?
- No boost in 1st
- 60lbers with 2.7
- Random Misfire with 60's
- Exhaust Port Question
- going into a reverse
- questions....
- stage 2-3 questions
- Megan Exhaust?
- so i or souldnt i
- ottp stage 2, hub install question??
- plx dm100 gauge
- Please post pics of LSJ mounts vs LNF mounts
- 2.9 on then tune?
- Who's using this Clutch
- problem???
- Tune suggestion
- burnt/worn valve guides
- E85 w/ S20g
- water temp gauge
- EVAP system delete.
- warrentey work
- timing?
- ZZPerformance Got New Mounts
- Free Test Header!
- Zzp adjustable belt tensioner
- Whos got a crankshaft they can look at for the J-community?
- question!
- s/c Boost Bypass Mod
- which octane
- installing endplate, change gasket?
- Handling upgrade - experienced advice please
- GM STAGE bolts pulley tools
- oh snap!
- valve springs
- injectors
- header & downpipe combo from zzp
- Shocks/Struts ?
- Problem with interceptor...help!!!
- how to question
- Am i missing anything?
- Tune?
- Water Logged Update
- Anyone know of a good tuner close to Charleston, WV?
- ETC (Electronic Throttle Control)
- stage 1 or 2???
- How to tell what type of injectors I have
- Cost/Benefit of Front Mount Heat Exchanger
- CATCH can
- Which Turbo?
- Supercharger airflow question
- smaller pulley
- Hi Flow cat problem :/
- Problem with Harrop install..Harrop owners..help needed.
- Question on 2.8 with current Mods.
- Low oil issue?
- Interceptor gauge
- thread size for coolant return?
- Quick Question, 05/06 SS/SC Drivetrain Warranty, how many miles/years?
- NCstateredline finally goes E85 + Dyno
- questions
- Compression ratio and timing
- Help
- 2.9 pulley on blower problem?
- WTF why does my car always wheel hop?
- HELP ! I need Injectors
- issues with supercharger.
- Best Meth Kit??
- catless
- Looking Engine building advice
- Is this header Dp combo really worth it?
- Black smoke?
- howww would?
- m62 boost soliniodand flapper?
- Parts ordered!
- Pacesetter header questions
- Water pump 2.0 LSJ
- LSJ Building questions
- i'm kinda confused on the staged kits
- so possible cooling option
- HP and Torque for the stage 3
- 60# injector upgrade?/ twincharge upgrade
- GM stage 2 install
- need help
- 2.9?
- STRIPPED! 3rd cylinder spark plug threads!
- Make my car flex fuel?
- What a/f are you guys running on a 2.6?
- help with pacesetter install!!
