- Hahn Exhaust Question
- 42# injectors now funny sound?
- my build
- pistons
- sensor
- Pacesetter header questions
- lsj to lnf alternator swap question
- Jerky acceleration
- Relearn PCM for Stage II, how important is that?
- C I A header/dp
- Help please!!!
- Crank sensor relearn question.
- Tuning New Hampshire Area
- Ported Head Teaser Pics...
- Question about stage kit?
- bought lnf through out bearing from CED need help
- Quick Radio Question
- Mystery transmission.
- Blown engine?
- anyone ever done this?
- 17lbs of boost...
- Ottp stage 1 kit
- Mounts/inserts/torque damper?
- Running way LEAN!!!
- Gmpp exhausts?
- LNF Tran vs. LSJ Tran
- help
- still not enough boost!?!?!
- 5-lug pattern??
- rich problem
- Exhaust Leak
- Excessive Clutch Pedal Play
- cv axle seal
- Cam position sensor problems
- Return style fuesl system!
- dyno runs.
- Help!!
- exhaust problem
- Can't remember the name of a certain clutch
- HELP! With Cam Sensor
- Misfire
- ordered zzp s3 heat exchanger
- can it be done?
- hey im new
- Quest for 300whp
- Battery..
- fuse panel
- exhaust set up
- Problems with IAT2's...Thoughts
- o2 sensor question
- What downpipe?
- Fuel injector question
- wonderin
- exhaust and header
- Car heats up fast and cools down slow... HELP
- picture request: stock supercharger
- antenna
- GM stage 2 or OTTP stage 2?
- Help now!!! engine rebuild
- Looking at the ZZP Mid-length header/dp combo
- Piece an Option B kit together
- the game show
- Engine break in
- What's Ur Coolant Temprature
- NEW Vibrant catless joint
- 60s info
- how to plug supercharger silencer holes
- Turbo fitting Question!!!!
- Idling lean and pulling fuel...?
- Tvs!!!
- METH Meth METH Crackkkk
- stage 3 ??
- 2.8 pulley no tune?
- Plug Gap for LSJ turbo
- plugs
- fule rail problem
- Who Performs Your Car's Maintenance?
- Vertical fin on front bumper
- qtp cut outs
- Header DP question
- necessary to change fuel filter
- eaton 1320 superchager and injectors?
- Help me out: Ottp 3' intake or Zzp 3' intake
- good inexpensive muffler
- Misfire when AC is on
- self's turbo build
- 02 sensor problem
- Laminova core washers
- Fuel Economy ?
- flywheel help
- DC Sport CAI
- got a few questions..
- Ticking noise after beating on it?
- Good Parts/Bad Parts
- Injen intake filter size?
- question for installing a wideband
- Some easy questions
- MAF P101 problems
- issue need some input
- Those with 3 inch cat backs for Sc
- Where is the rice-ness coming from!?!?!
- Timing/drive chain Question
- Running a 2.4 with lsj TRanny ?
- how a stock endpalte and dual pass endplate work
- Hi Flow cat question
- I just got OnStar for free, if I stage 2 is this gonna effect OnStar?
- How hard is it to install a dual pass endplate?
- 2.6 Pulley Poll
- premium?
- code P1183 on my lsj
- found this from gm
- LSJ MAP Sensor Part Number
- 42s siemens injectors
- Turbo conversion
- Car wanting to die after I get gas!!!
- Think I might be doing a build
- Alrite to have stock exhaust??
- Intercptor questions
- Is there any clutch adjustment?
- do we have downpipes?
- ls4 throttle body any one running one?
- 06 SS Boost Gauge
- tuning problems
- need help
- what do I need for stage I ottp kit?
- option B
- NGK racing spark plugs
- easy question.. hard to answer for me
- coolent leak
- How do you know if its a g85 tranny
- Weight of lsj block
- Problem with heat exchanger
- need an 06 oem hpt file
- Some Insight Please
- **** this
- how the hell do i remove the bottom bolt on the intake manifold.
- gms3 pully
- Header/DP question
- GM Tech question (Chilton or Motors)
- Oil Catch Can vs Oil breather
- Catless DP Installed, Some Questions
- Long tube header
- Thermostat
- Head Gasket mix up??
- 42s harnesses
- LSJ lack of power?
- Lsj dp and header
- Worth getting a Intake?
- Best clutch for me?
- best throw out bearing
- Injen Intake $175.03 Free Shipping
- How much power can LSJ take?
- boost problem?
- Quick question
- stock lsj 15psi?
- CAI problems
- New IM but an idle problem
- NGK V-power ? these the right ones
- Brakes..
- Steering Box differences SC/TC
- How reliable
- how does a duall pass work?
- inexpensive mds?
- NEW clutch help
- Stage 1/2 PCM Question
- meth injection
- Questions .....Round 1
- G11's motor build...will be asking lots of questions
- Second IC Pump ?! Benifits ?!
- Need help weird problem.
- CUSTOM Intercooler Piping $???
- GM Stage 2 + 91 octane gaz, getting knock!!!! Is this normal?
- Help???
- LNF Intercoolers for Turbo'd LSJ's
- Accuracy of aeroforce interceptor gauge
- Crank case relearn
- clutch peddle has to presure
- s3 heat exchanger
- Cat question
- Cat recall appointment.
- royal purple trans fluid?
- Ripped my intake elbow
- pcm help
- Just installed zzp s3 HE
- What would i need to beat GXP?
- Car is down... Again.... Unsure what the cause is...
- Injen OR AEM intake?!
- Coolant Leaking
- boost/hg
- 2.7 and 2.8 pulley whp?
- I dont know if mine is staged or not
- Daily Driving on Drag Radials....
- Oil Pan
- stage 3?
- heat exchanger install
- what about the lsd?
- alternator help!
- Help on noise coming from either cat/muffler?
- coolant flow
- Smoking When Under Boost
- heat exchanger
- Help me fix these codes!
- OTTP stg 2 or ZZP stg 3?
- p2135,p0122,&p0223
- Need real quik help with boost gauge
- doin work
- cat/muffler noise ?
- is this
- Ethanol Blended or Straight up Premium?
- S/C bypass and hissing boost gauge problem.
- dual exhuast
- GM actually comes through!
- Where to get m62 cobalt ss supercharger rebuilted at???
- Throwout bearing / Master cylinder rod
- Car sponsorships
- Base tune for a massive setup
- meth vs header and d/p
- P0455 Engine Code
- Clutch problem
- no start no crank
- Exhaust problems or codes?
- 245/40/18 with pedders springs
- Rebuilt engine smoking???
- MSD Dashhawk
- Cobra H/e & meth or ottp H/E
- Rattling
- KNOCK wtf
- Tunerf
- radio
- pulleys
- car has no top end power
- bye bye axel
- Turbo build done. Some problems, Pictures soon!
- Tuning question?
- tvs max rpm
- clutch
- Injectors
- Should my car be doing this?
- Qiuck question about Alcohol injection
- OTTP stage 3 timing
- ottp stage 2 mount problem
- intercooler pump wiring harness part number?
- weird Q
- DC exhaust
- 2007 Cobalts SS w/stage 2
- meth vs. dual pass n otp b
- is there a way...
- better set-up??
- Symptoms of a bad bypass valve?
- bkr7e-IX part number
