PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. jet power chip
  2. just another build thread
  3. To those of you with a gmpp upgraded clutch...
  4. what to do?
  5. Help!
  6. horendous squeking
  7. South Florida cobalts!!!
  8. last noob question lol i promise
  9. kinda stupid...but im new :D
  10. Why am I getting knocks?
  11. Want to drop pully sizes..
  12. Wideband question
  13. centrifugal supercharger idea/ thoughts
  14. Junkyards suck!!!
  15. Coolant temps
  16. engine power reduce message!????
  17. nys owners and ottp stage 2
  18. parts help!!!!!
  19. Shirt Shifter
  20. Best place to buy gauges?
  21. ottp stage 2
  22. thought about the devils own kit?
  23. LSJ and 2.2 Short Block
  24. Header install
  25. 2.8 pulley question ???????????
  26. A look at the Intercooler pump.( Lots of pics)
  27. Noise when driving
  28. 14psi on stock pulley?? Anyone have any input??
  29. Wat to do next
  30. new set up help
  31. Cracked # 4 piston
  32. stock ss s/c overboosting!??
  33. exhaust
  34. Cobalt mods is it worth it
  35. Option b hose routing?
  36. Question before purchasing
  37. P***ed off!!
  38. which mods are next?
  39. Should be simple question...
  40. Wheel-Hop Kit
  41. Where to find tool to remove Stage 2 pulley?
  42. How does a wot box work?
  43. Cobalt SS Vs. Brick Wall...
  44. porting intake mani
  45. stupid question.....
  46. header HP gain?
  47. Coolant Temps
  48. intense
  49. Boost gauge question
  50. pulling engine from top??
  51. Early Gift to myself need help
  52. codes and such...
  53. header/dp
  54. sc question
  55. OTTP 1: Now or Spring?
  56. 16's
  57. stage kits
  58. Dropping the car off tomorrow to get a few parts installed!
  59. Porting ls4 tb
  60. stock he pump ?
  61. For real.
  62. So I want a Downpipe/Header combo.
  63. Tuning the rear 02 senser out?
  64. idle pulley?
  65. Strange Idle after Cattless install
  66. m62 psi / pulley
  67. standard map sensor and 3 bar map sensor
  68. Quick question
  69. ported head results
  70. Tapping the intake manifold for Meth?
  71. top end = fail
  72. mounts
  73. trunk lid
  74. Secondary Stock H/E
  75. LSJ fuel line flush....holy #$%@
  76. whats your MPG running the NON GM stage 2
  77. trackbite on supercharger belt
  78. so i got an issue anyone help?
  79. Meth mix?
  80. improved intake manifold yet?
  81. wanna get an interceptor but..
  82. Christmas came early this yr?
  83. Trifecta for LSJ
  84. tuning and 60's
  85. N2MB Racing Holiday Sale and New Product!
  86. WOT box
  87. can somebody please end the 2.9 debate.
  88. polish supercharger less than 3 hours, no sandpaper
  89. Gm Stage 3 ?
  90. Speed Density
  91. OTTP H/E Installed still hot
  92. some head port pics :)
  93. brake squel
  94. lowering an cobalt ss/sc
  95. leaning out!! PLEASE HELP!
  96. Misfiring in the Second Gear
  97. Header/downpipe question
  98. 2005 SS/SC having misfire issues
  99. recall list
  100. stage 2 belt from zzp WTF
  101. cracked piston #1
  102. G85 SS's car will be faster than BLAZIN07SS's car build thread
  103. Rebuild Results
  104. Question TVS guys and tech please chime in
  105. bigger supercharger
  106. supercharger question
  107. ingalls
  108. need help asap
  109. Stock boost gauge stop working
  110. my 1st winter
  111. Mystery sound. Whoever can figure this out is the shit.
  112. Just pulley or just injectors?
  113. Upgrade Help
  114. A Few Questions
  115. spark plug help!!
  116. underdrive or overdrive?
  117. nys emissions
  118. cheapest place to buy Aeroforce Interceptor
  119. Petrol
  120. LS4 Tb worth it?
  121. looking to talk to a gm tech
  122. :) TVS is on :)
  123. Wierd clicking/ticking
  124. Help!!!!!
  125. TVS vs N2o
  126. loud ticking noise
  127. Roll Back.
  128. Replacing Axels
  129. Need help please
  130. tvs with meth problem
  131. Need an aftermarket clutch A.S.A.P!
  132. 50% OFF major brand exhaust system @ PFYC.com til stock runs out
  133. Water Injection Kit Question
  134. exhuast question
  135. exhuast question
  136. shorty header from ZZP is no longer availible
  137. 2 step colder plugs?
  138. pulley question
  139. Traction!!!!!
  140. Hahn Level III Turbo system
  141. Please help with adjusting Ingalls TD
  142. Pistons
  143. car doesnt get up to operating temp.
  144. Engine Swap:
  145. CEL help needed
  146. valve seal compatibility
  147. help needed with SC conversion guys ;/
  148. Clutch recommendations?
  149. How much HEET to windshield Fluid
  150. Cut out
  151. smaller pulley
  152. New product: Darton Sleeves for 2.0l
  153. crank shaft sensor
  154. weight reduction
  155. "can i swap the sc w/a turbo on my LSJ?" **answer inside**
  156. Engineered-Products heat exchanger review
  157. GMP extrude honed header
  158. h/e yay
  159. ZZP Twin Charge...anyone install it themselves?
  160. Aeroforce intercepter instead of boost gauge
  161. Timing chain tensioner?
  162. Porting the head...
  163. wideband question
  164. Clogged laminova core?
  165. exhaust
  166. supercharger
  167. cant do burnouts?
  168. LS4 TB on a TVS
  169. Going Turbo
  170. help from people with a 2.7
  171. Oh Noes!!!!!
  172. nubi with ????
  173. Ebay nugget ....Used corsa CB $260
  174. New Rods For The LSJ @ TTR
  175. belt squel
  176. OTTP can u explain this???
  177. zzp valve springs, cheap
  178. 3" hurt perforance?
  179. Removing Catalytic Converter
  180. MAP/MAF correlation problem- PLEASE HELP
  181. Need some help with installing smaller pulley and other supporting mods!
  182. 2.0 hahn turbo kit help
  183. help stupid questioin
  184. Gas Milage
  185. Computers don't lie? or do they?
  186. Worth the money?
  187. WOT Box with CATALYTIC CONVERTERS
  188. Magnaflow 30" x 6" Round Muffler...anyone use this?
  189. By pass air filter?
  190. probable vacuum leak
  191. The Project needs your feedback!
  192. Stage 2 problems/issues HELP!?!?!
  193. 0tt stage 2 pcm question
  194. would thid make a difference in temp?
  195. My exhaust smells like corn
  196. 3in exhaust redone
  197. Toys....
  198. Will my warranty cover this?
  199. stage 2 pulley
  200. CA V2 Header clearance problem.
  201. Knocking/Fluttering.
  202. ? about timing my cobaltSS
  203. E-brake question.
  204. Stage 2 harness and 60 lb harness.
  205. New exhaust louder than I'd like
  206. Best Car Alarm
  207. throttle body question
  208. header/dp question, need suggestions please
  209. Is there something to make my 2.0
  210. cut out vs full exhaust
  211. Tranny Question
  212. O2 sensors Interchangeable?
  213. Next mod ideas
  214. Lifters
  215. Diy: Meth inj.
  216. How many shots of NOS?
  217. HELP! Weird sound comming from the engine bay
  218. LSJ Injector harness question
  219. Idel problem
  220. Turbo Calculations
  221. problem with dp/catback flange
  222. Gauge Cluster
  223. question
  224. Redlining from 1st to 3rd
  225. coolant in my intake manifold. HELP.
  226. Removed supercharger. Couple questions.
  227. JBP Vortex Header Sound clips
  228. vibration
  229. 52000 miles
  230. k & n drop in filter
  231. Rico's Turbo swap
  232. exhaust
  233. Quick Question.
  234. My winter build
  235. Smallest pulley that will fit with OTTP Stage 1 kit?
  236. Looking to get a tvs anything i should know!?!?!??!
  237. 2005 Cobalt SS Wiring Diagram
  238. spark plug question on steps colder
  239. pulley question
  240. Tranny Fluid?
  241. Having Some PROBLEMS
  242. I need a little help with measurments
  243. Difference between 4 bolt and 5 bolt pulley
  244. Stumbled across a possible 2"primary LSJ Header?..
  245. 2007 SS/SC MAJOR problem!!
  246. Weird Problem!!
  247. Problem with a P2101 DTC
  248. power reduced problem
  249. What are your winter IAT2's?
  250. in/out?
