- 2.0 lsj stuff in 2.2
- Super stock tune ?
- magnaflow exhaust pics
- Dual Pass, Option B's, Diagrams.
- Best IAT2s?
- OTT Stage 1
- Brake Pads
- Pulley Bolts
- CFM info from another forum Please debate
- !!!!installing: Ottp H/e Help!!!!
- Rpm
- Interesting Clutch issue, any ideas?
- ETC Area Scalar
- Who has the CTI Header/DP combo?
- OTT or Intense
- Hey guys need some help/advice
- Help on pulley decision
- diamond piston coatings
- anyone with hp tuners here in eastern nc??
- Heat Exchanger question
- OTT Stage 2 ideas
- Trouble code and scary ass sounds....
- what size to bore?
- Has anyone seen this??
- Clear image hedaer dp
- A few Saturday night issues.
- OTTP stage 1 vs GMSTG2
- my mods w/ gmpp exhaust?
- most reliable way to make more hp
- Stage 2 belt??
- Where to buy cams???
- iat 2
- what does a Fuel Rail Fitting do
- Fuel Rail Fitting
- ZZP Tensioner
- what would i be looking at,
- question on the harnnes and injectors
- Cobra h/e
- Exhaust Questions? HELP ME
- question about 2.6 pulley
- is it okay to remove the valve cover and reinstall without a new gasket?
- exhaust
- Cooling?
- megan racing cat back exaust
- Overkill???
- afr stock.
- GM Stage 1 Hoax?
- have a 2.9 want to go.......
- CEL help
- Belt Tensioner
- Screw sizes
- Meth quick connect leaking.. Anyone else had this problem?
- head work
- c/a v2 header
- where to buy stage kit
- Bigger Injectors, Return-Style fuel sytem ???
- Crazy Problem!
- Fuel Tank Not Empty?
- OTT Dual Pass Endplate
- Turbo Setup.
- no posts on changing a direct bolt on exhaust?
- What do u guys think
- Help on What can I do to my car Performance wise
- can a stainless steel resonator be welded to aluminum piping?
- how accurate is the aeroforce intercepor
- 3" exhaust or smaller?
- How much would it benefit???
- elaborate
- Larger Coolant Reservoir Tanks
- searched and couldn't find
- Get Alternator off w/o rem. S/C ?
- looking for part # for rear o2 sensor
- fuel pressure
- help i keep getting a lean code!!
- Codes help.
- AFR question.
- Cheapo CAI bad?
- Where to buy Alternator?
- 2 ways to get more tension with smaller pullies
- P0420 Code thrown, HPTuners fix?
- Hahn kit questions.
- whats the most hp for the lsj
- computer erased??? HELPPPP
- Supercharger surface temperature?
- how much whp gain?
- Quick LSJ Question...
- To stage 2 or not to stage 2 that is the question
- need help with next upgrade?
- Ok, I searched and couldn't find anything *COOLANT RELATED*
- some dumb questions
- another exhaust post
- exhaust question.
- Upgraded Fuel Rail
- GMP Exhaust ?
- engine reduce power?
- Boost Gauge Options
- supercharger bypass pulley?
- Best Full Exhaust
- intermediate shaft
- Best Aftermarket Clutch
- Tvs Supercharger
- Torque Dampeners?
- Which Vendor Sales New Throttle Bodies?
- Tensioner / pulley swap out?
- How does HP Tuners work?
- lsj throttle bodies
- Whats the best way to get through the Firewall?
- Meth nozzle (piece that connects to intake)
- dual heat exchangers why i belive its better then 1
- around 300-350 to spend
- pulley hub removal and shit
- Intenses Racing Stage Kits
- used catback borla or new catback megan
- Mechanical Boost Gauge
- i hate recaros
- 60 lb injector install help
- 2005 Stage 2 questions
- dp and exhaust ?
- 2.7 worth it?
- afr and a guage
- autolite platinum spark plugs
- so. wait..
- Anyone running the harrop?
- loosing boost!
- What gain is predicted with 2.9 with current mods
- ott stage 1 250-260 whp??
- How do you adjust boost settings on ais meth pump?
- Deer Hit and Insurance Problems?!?! crap!
- Magnaflow Best Buy???
- best mods for a grand
- Can't get meth pump to come on..
- meth...the big unknown
- Lotus M62 SC, generation?
- Can I buy this anywhere local? (Meth nozzle picture..)
- got around $500 to spend on an exhaust, where's the best place to buy?
- Gotta Beat That Hemi!!!!
- ghetto cooling mod!!
- ls4 throttle body......
- Where can I get a meth nozzle that goes on the intake?
- 03-04 cobra heat exchanger
- 2.9 pulley installed!
- Cams In 07 Ss/sc
- '06 SS/SC Headlight Upgrade
- vibrant catless downpipe
- 2.3 pulley for 2 years??
- oil pan?
- CTI or ZZP downpipe?
- Name your IATs and pulley
- ott stage 1
- Let's discuss the Whipple W100AX.
- Need help asap?
- Jbp/zzp/cti
- Jbp/zzp/cti
- vibrant catback
- 2.5 or 3 exhaust, Simple
- How do i get rid of torque steer??
- ported blower?
- Whipple W100AX kit interest.
- Electric Problem! Please Help ASAP
- whats a better cooling mod, H/E or Meth injection?
- axle back exhaust gains?
- Question
- question... please no flaming
- snout grinding
- what are the odds of blowing the LSJ?
- Engine noise!?
- Whats the best resonator???
- ZZP Mid length header or Hahn shorty header?
- Boost Gauge Exchange
- high rev limiter
- Vibrant Header/DP
- 2006 stock pcm need help!
- Option B?
- Need help
- Aftermarket Catted DP CEL POLL
- s/c grease
- Question for anyone who has changed a clutch
- what are the best mods????
- Cars being goofy HELP Please
- Fuel pumps! i know! i know! lol
- Nates bolts on GM s2 puleey
- CTI DP opions
- Just got my 60's.. Should I have them flow tested?
- Stock PCM 3.1 pulley...
- knock relearn???
- dual pass end plate
- ott stage 1 tune???
- zzp 2.7" pulley install
- Some turbo swap questions.
- Question about my aem wideband and dual interceptors?
- wideband thru a/c
- Man Brembos look good!
- People who are 2.6 pulley'd???
- stock ngk part #?
- Broke it!!! I nees a new one!!!
- 500 Whp Cobalt On Stock Internals And 1.6 Inch Pulley!
- time attck cobaltss????
- Which plugs should i use?
- 60lb injectors info urgent
- Those who replaced Timing chain tensioner
- Injector question?
- whats the biggest exhaust tip connecting to a 2.5 in inlet?
- Running injectors without tune?
- short ram intake (K and N) vs cold air intake (injen)
- SS/SC Hp question...
- 09 SS/TC Brembo's on a 06 SS/SC ??
- #60 injector question
- A-Pillar Gauges
- Some GM performance info for you guys
- Replacing Thermostat?
- option b tank
- Oil Catch can
- meth pump and nozzle question
- what type of air filter would you recommend for a CAI?
- stage 1 ott
- dual heat exchangers. and josh from ott.
- Need Help Plzzz.
- JBP Vortex Header vs CTI Racing Header
- ott help plzzzz
- choosing header
- Fender or trunk mount meth kit?
- Stage 2
- drilled and slotted rotors
- Reduced Engine Power
- Anyone Who Has Aftermarket Downpipe
- how much would you guys pay?
- Dropping Pulley Size
- Questions about going turbo
- Cobalt with ferrari-ish sounding exhaust
- Installing fender mount meth kit.. Why does it take so long?
- CA lightweight oversize crank pulley
- Ott stage
- 3 Gauges
- 2.2 header on 2.0 and vice versa?
- 3" Hahn Catback Good or Bad on a SS/SC?
- JBP vortex
- Knuckles
- How much timing????
- Meth systems?
- Show me your blower! hehe
- supercharger holes
- will this work
- Aeroforce Interceptor reliability?
- Suspension
- ottp stage 1, intake, exhaust vs gm stage 3
- Return Style Fuel Systems
