PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Plan on stage III upgrade soon. My ideas your input?
  2. Stage 2 Install Options?
  3. crankcase breather
  4. Supercharger Bypass Question
  5. Stage 2 Belt Slip???
  6. New head gasket
  7. Need help with HTV1320 development
  8. Prices on Stage Kits going down?
  9. intermediate shaft
  10. lil Info
  11. 40% power gain?!
  12. HP Tuner
  13. 2.4 Block
  14. new amp with stock alternator.
  15. Stage 2 Belt
  16. Going turbo???
  17. My stage 2 belt blew up.... help?
  18. AIS meth and water injection
  19. Best place to buy an AEM wideband?
  20. Little bit of help needed
  21. got my 2.9
  22. Dont know what to do
  23. Little help
  24. Come see my Dyno
  25. Fun in the Snow
  26. Oil Catch Can
  27. Downpipe went to S*&!
  28. Another Down Cobalt
  29. Underpowered 04's??
  30. Header/dp or Catback?
  31. Interceptor questions
  32. Cryo2 System Install! 56K No problem
  33. Ingalls Torque Damper (2 Questions)
  34. Found a place to get the mt-2 stage 2 tool from
  35. clicking noise on 2.0 ss s/c engine on start up
  36. installing intake
  37. Pulley swap
  38. what plugs??????
  39. Gmpp Exhaust tip question
  40. JBP Lightened Crankshaft Pulley
  41. Megan Exhaust or SLP single loudmouth
  42. New Plugs, Same old Spark blowout?
  43. Question about porting
  44. The new procharger thread!
  45. Smaller Pulley's for TAG hub.
  46. GMPP For cobalt Question
  47. 02 sensor
  48. Sings of a bad transmission mount?
  49. Pulley Puller
  50. 3 questions
  51. Finding different sizes of belts
  52. would our car run right if ...
  53. More power mods
  54. has this happend to anybody?
  55. wich one for ss /sc
  56. boost gauge....?
  57. up-grading fuel pump
  58. **important info regarding 2.0 LSJ**
  59. help , need tune in so cal
  60. gm stage 1 , is it worth it
  61. Angled exhaust
  62. Supercharger Bolts
  63. Brand New SLP Dual Loud Mouth exhaust
  64. gmpp exhaust tips
  65. HELP: Stage II reflash required (No GM-dealership support)
  66. Take ur cobalt from stock to 1400 hp!
  67. oil question
  68. engine hopping - questions - info
  69. bottle neck exhaust
  70. Cat Back Systems
  71. fuel additives with mmt
  72. 50LB injectors on a 2.8" pulley result
  73. turbo and meth injectors
  74. How did the dealer remove your pulley when installing stage 2?
  75. Turbo Kits
  76. blower spacer plate
  77. routine supercharger maint.
  78. How much $ to install dual pass with Option B
  79. something i have noticed
  80. need help with figurin out wat size DP i need.
  81. srt4 turbo manifold on a 2.0 ecotec
  82. aem wideband with vibrant header?
  83. where to buy
  84. who sells the best header for the ss/sc
  85. Trouble
  86. GMPP Performance exhausts?
  87. All turbo converted balts in here for question time!
  88. 2.9" pulley upgrade, do i need a reflash?
  89. Stage 2 + 2.9 First impressions.
  90. Heat Exchanger Vs. Dual pass
  91. twin charge ion questions
  92. stage 2 recently, CEL trippedd
  93. bogging problems
  94. Parts and warranty
  95. Cooling Questions
  96. 2.0 AEM CAI ...White filter?
  97. p1071 code
  98. Can anyone help
  99. gm performance parts?
  100. Help!!!!
  101. Cooling mist VS. Devils Own.
  102. Gm Stage Iii Pcm
  103. stage 2 kit
  104. GT2871r turbo or Gt3076 Turbo
  105. stage 6
  106. pulley size
  107. Stage 2 and airbox mod
  108. stock injector question
  109. smallest pulley on stock tune?
  110. 2.2 turbo
  111. looking to trade pully
  112. Wtb Nates 2.9
  113. Aem Meth Injection
  114. Re-Machining my old stock pully
  115. 2.0 Turbo build This Weekend!
  116. new WHP recored for a DD car?
  117. Stage III PCM?
  118. Max WHP before internals
  119. What size injectors do you have?
  120. co2 vs meth inj.
  121. sorry but another exhaust question...
  122. What size pully do you run?
  123. Gapping my NGK's? Advice needed.
  124. Is this as good?
  125. gas
  126. Crank Pulley
  127. cold air intake
  128. how to adjust shift cables
  129. Dynoed
  130. Model Years For CAI
  131. off to SMG tomorrow
  132. I Need Help Asap...:(:(
  133. Is this what i want?
  134. Wheel hop
  135. update on stupid cel again
  136. o2 censor?
  137. Quick question about converter code.
  138. I wonder if.....
  139. I Need Help Trouble Shooting
  140. Cobra Heat Exhchanger Question
  141. stupid cel again
  142. Need help on tuning
  143. CIA Concerns
  144. boost line / firewall
  145. Dualpass endplate
  146. Gutting Cat/ Taking out cats?
  147. Redline problem
  148. popping from steering
  149. GMPP Sport or GMPP Touring?
  150. Timing Chain Tensioner
  151. Exhuast Quiet Questions
  152. Got the exhaust on
  153. just dropped my car off at tune time. and also.....
  154. 2.9 and happy
  155. gm stage III
  156. rich as hell with 2.9...will 2.8 be safe
  157. New spark plug anybody know of them
  158. aeroforce interceptor question?
  159. OMFG someone please help me.
  160. rattling sound at idle?
  161. Dumb question Stage Install
  162. High Altitude Airflow Curiosities
  163. upshift light?
  164. zzp downpipe
  165. 2.2 turbo kit on 2.0
  166. what will work
  167. Header/Downpipe
  168. Well finally got something installed
  169. GM Stage 3..?
  170. help me decide on header and downpipe
  171. Po128
  172. Heat Exchanger Question - Help pease
  173. Stage 2 FTMFW
  174. Injectors going bad?
  175. Right Price For Stage 2?
  176. Devil's Own Alcohol Injection QUICK!
  177. supercharger question
  178. air to fuel guage help
  179. Could use a little help
  180. plugs
  181. torque damper
  182. ?'s on Aeroforce Interceptor Gauge
  183. help!
  184. Cobra H/E Q
  185. Does the twm shifter fit?
  186. Just noticed this
  187. phantom knock
  188. Ingalls or motor mount!?
  189. fuel pump and regulator
  190. Rebel Auto Worx 3" CAI
  191. WOT shifts
  192. Polished Blower Question
  193. RacingSolutions.com LWCP
  194. Head bolts breaking?!?!?!
  195. Big wing makes you slower?!?!?
  196. What do i do next???
  197. exhaust problem/leak after ingall etd install?
  198. Airbox mod question
  199. really loud exhaust
  200. What coupler for LS4 TB?
  201. Stage 2 Ordered
  202. 2.0 engine specs
  203. ZZP 3" DP / Headers...
  204. GM site for checking software version?
  205. Car not boosting over 2psi, what gives? (Friends vehicele, modded)
  206. .50 Trim Turbo ?'s For You Turbo Guru's
  207. Stock heat exchanger dimensions?
  208. Timing Chain!
  209. Ordered parts finally!
  210. Headers... Which.?
  211. 2.0 and 2.4????
  212. Need some opinions.
  213. Ultimate Cooling: Question
  214. cooling question
  215. What is out there as far as a s/c swap?
  216. Repost, Wrong Section, idk...need ? asked
  217. Swapped Engine, Car Won't Start!?!?!
  218. finally stage 2!!
  219. Famous P0068 Code & Engine Power Reduced
  220. GMPP Exhaust Touring or Sport???
  221. Cobalt-Addiction Stage kits???????
  222. spark plugs
  223. ss/sc injectors help
  224. Help!
  225. JUST GOT STAGE 2 & GMPP performance exhaust
  226. How Superchargers Work.
  227. 3.5 Tb
  228. Where can I find
  229. NOT a 2.5" vs 3" thread
  230. car race gone bad
  231. Please Help Check Engine Light
  232. Hahn Racecraft catback?
  233. New to forum- stage 2 upgrade!
  234. P0171 Again
  235. HP Tuners Help!!!!!
  236. miles on one tank of gas
  237. GM screwed me.. please read
  238. Knock retard ?
  239. stripped bolt head
  240. Coilovers vs clutch
  241. stage 2 or turbo???
  242. Catalyst Issues!!! Need some help
  243. Injector Debate
  244. Intake
  245. Header Question
  246. My Future set-up! Questions inside.
  247. Silicone hoses???
  248. eliminating cat/08 Cobalt..turbo'd??
  249. stage 2 tweaking
  250. NEED HELP from our engine savvy members
