PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. 2 quickies
  2. stage 2 and 3 clutch from turbo tech the same?
  3. Installing Factory heated seat components in a SS/SC, Has Anyone done it?
  4. Stock Shift Light???
  5. JBP stage 2 cams
  6. GMPP Touring Exhaust...
  7. Motor mounts
  8. sturt bar help
  9. PB 2.8" Install Nightmare, Need Help!!!
  10. pistons swap
  11. Convince me of which CAI to get...
  12. aem dry flow filter thoughts...
  13. PB 2.8" install
  14. question about the stock exhaust size
  15. best bang for buk mod..
  16. Some Important Info
  17. Some Important Info
  18. Supercharger Measurements
  19. Is it me or are my rotors screwed?
  20. 2.0L supercharger pulley housing sealant
  21. Vendor Help! 2.85" pulley!
  22. 2.85" pulley for gm stage 2 hub?
  23. Switching Stg 2 Pulley w/ 2.8
  24. gmpp stage kits???
  25. Need part Numbers
  26. Need part Numbers
  27. Does the 03-04 cobra HE work for our car?
  28. Starting mods Safest Way to go
  29. Finally got on a dyno
  30. So my Spec 3+ is Toast.....
  31. Well Well, HeadGasket = Fine Piston = Not Fine
  32. Question about ramps
  33. Throwout Bearing Hose C Clip
  34. tuning gauges ???
  35. Just bought Ingalls Torque Dampner...
  36. HP Tuners Question
  37. This is what GM does to us SS/SC guys!
  38. My cobalt is gone.
  39. Stage II & 2.8 + supporting mods
  40. Hahn Racecraft 3"
  41. GMPP Catback or Aftermarket
  42. Cavalier DYNOED!!!!
  43. DYNO and tuning in CHICAGOLAND area
  44. Would a Cobalt Tune work on a Redline?
  45. Almost seized the motor!
  46. Working on a heat exchanger deal....
  47. aw, freshly recovered recaro for free
  48. Looking for some info
  49. Headgasket and Headstud Ordering & Information For Everyone
  50. Redline short ram intake
  51. Vaccum at idle...
  52. Help!!!! Removing the head
  53. For The Love Of God!!!!!!!!!
  54. Possible answers? No compression
  55. COBALT Air-to-fuel gauge
  56. Pulley Removal
  57. running rich with mods.. help
  58. Check this out
  59. HP tunners question? and prblem.
  60. 2.5" Pulley Questions
  61. the cat
  62. going to the track
  63. how to get G85
  64. Highest Gains with Tune?????
  65. Suggestions are welcome for performance.
  66. My Idea...
  67. Laptop needed for hptuners???
  68. Low Coolant
  69. Anyway to Eliminate Torque Steering?
  70. Intense Racing website?
  71. B pipe and O2 sensor... Master Tech Needed
  72. Tuning and 2.6" Installed!!!!!!
  73. Ingalls Torqyue Damper
  74. Question about stage 2 re-flash
  75. First to blow?
  76. CA heat exchanger??
  77. Finally got a dyno.......
  78. Parts
  79. Injen Hydroshield
  80. A little teaser for you guys
  81. K&N slowed me down
  82. cti or hahn
  83. Power @ 8,000 RPM ?
  84. quick question
  85. CEL w/2.9" install and BK7REs
  86. New Toys.
  87. blow out valve
  88. Thinking of buying HPtuners
  89. SS Intercooler
  90. Crawford Composites Pricing
  91. HPTuners help, new tune = hesitation (?)
  92. 7400 rev limiter???
  93. Exhaust
  94. SC Snout Machined
  95. Wheel hop..
  96. header back choice decision help
  97. AC pressure sensor
  98. Who sells hawk HPS brake pads
  99. Traction OverKill?
  100. Stage kit belt/76mm idler pulley/2.7 pulley...will the belt fit?
  101. Brake Pad Question..
  102. Just blew a headgasket
  103. Tampa Area Pulley Install!!!!
  104. Ingalls Torque Dampner Owners, Couple Questions
  105. Turbo Manifold Info I received and some ?'s
  106. I need to know some things about the SS
  107. Stage Kit Prices...look
  108. How to install the 2.8 pulley on a staged balt
  109. Trans Fluid Leaks Clutch Slipping And Broken Axles
  110. srt 4 stage 2 turbo
  111. Just installed the Corsa Touring!
  112. Parts and Warranty
  113. Im Getting GM Stage 2 Installed Friday!!
  114. cobalt addiction 2.5 DP review
  115. Pulley Puller...
  116. Dilema...
  117. What to do questions
  118. Too Much Boost?
  119. 2.6" and STG 2 BELT
  120. Have you had to change belts yet?
  121. Help with tensioner pulley
  122. need some help?? will this setup fit?
  123. need some help?? will this setup fit?
  124. Twin supercharger????
  125. any form of boost
  126. Injen Intake Specs
  127. I need a recipe
  128. Just bought Stage 2...
  129. Aem Air Bypass Valve
  130. Probably a noob question...
  131. Who is selling HPTuner cheap...Plus dont know how to tune
  132. PSI Question
  133. is an idler pulley the only way?
  134. Running Lean
  135. new clutch install
  136. GMPP exhaust manifold installed
  137. Wheel Hop causes Clutch Failure
  138. 300whp?
  139. 3rd gear vs 4th gear dyno pulls!
  140. boost guage question...
  141. My charger is going gold O_o
  142. Rear O2 sensor
  143. Hahn Full Exhaust Vids I Promised Everyone!
  144. Transmission Stuff (Might wanna stciky the response to this)
  145. What You Thinkl?
  146. Wich intake?
  147. magnaflow exhaust
  148. Stage 2 dyno (crappy)
  149. Throttle position?
  150. Supercharger Hose(s) part number...
  151. Questions about upgrades
  152. Installed my injen intake and WOW
  153. How many full scan gauges are out there?
  154. Are U Serious?
  155. Exhaust system
  156. hurry!!! where to find bwoody traction bars
  157. Not getting the results I'd hoped for.
  158. would this work?
  159. ECM pinout
  160. Tech Data by Dezod Motorsports|| Topic: Collectors
  161. Extreme nooblet question
  162. What Should We Install?
  163. Just installed Vibrant 3''
  164. question about clutch?
  165. for anyone that has gm stage 2
  166. for anyone that has gm stage 2
  167. Installed my Intense trans mounts
  168. Thank you OniMirage and Cobaltss.net!!
  169. upped rev limit on gm stage2?
  170. cruise control turned off by cel
  171. Brought my stock SS/SC in for 7500 mile service and they did an PCM flash...
  172. GM Stage 2 + 2.8 Pulley
  173. KN filter install help
  174. Where do you weld in a new bung???
  175. Super Charger Noise After Intake Installation
  176. stroker kit???
  177. Just another stupid question needing an answer
  178. hp tuners..
  179. Which CAI?!!
  180. cti owners help
  181. Pacesetter header!!! PICS Turbotec...
  182. Stage 2 installed today with the new tune WOW !!!!!!!
  183. Installed Pacesetter Header to Complete Exhaust
  184. Urgent !! Please Help !!
  185. Bad news??? Victory_red__SS project.
  186. Ordered Hahn Full Exhaust!
  187. Cobalt SS CANNOT be hydrolocked!?
  188. Sweet SS! so..GM Stage kits or Aftermarket?
  189. Doh! I can't find it anywhere
  190. Cat-Back
  191. Intense computer Question
  192. Tri-Phase Performance Module
  193. Aftermarket LSD
  194. GM Flash on non-stage 1&2 SS/SC's?
  195. $599 for GM stage 1-2?
  196. Tuning Stock SS/SC
  197. Car Still running rich?
  198. people with 60lb injectors?
  199. 400-450hp supporting mods???
  200. Piston Question
  201. Traction rant
  202. tuning my car? hptuners help
  203. Trubendz Technology
  204. For those running 20+lbs. of Boost
  205. Stage 2 Install tomororow maby/2.9
  206. Suggestions for removing GM Stg2 pulley
  207. Can someone help me out on this pulley dilemma im having?
  208. I just got INTENSE stage 5 :)
  209. GM Manifold
  210. XTC header, XTC downpipe and GM cat back installed!
  211. GM offering CAI!!! OMG READ ASAP!
  212. Pistons!
  213. going with flows
  214. ingalls Torque Dampner
  215. Stock specs
  216. Piston and Rods
  217. Random Technology downpipe review?
  218. My review on my CTI 3" exhaust
  219. New idea
  220. Losing Boost
  221. ZZP Tensioner???
  222. A Q for Intense Stage 3 drivers
  223. Buying Heat Exchanger Need Advice!
  224. spec or fidanza flywheel???
  225. For those who have/had 42lb injectors and 2.8" pulley
  226. How safe are our Clutch and Axles with Stage II?
  227. Is the raspy......
  228. hp tuners ?s
  229. Opinons on tune
  230. question about injector installs...
  231. Vote! For the best compression Ratio
  232. Rear Diffusers...
  233. what tool
  234. Phase 5 cobalt engine mounts?
  235. Replacement Upper Enigne Mount interest?
  236. Sick of this Weak Superchager.
  237. Bad News!
  238. Cam Install & Stage 6
  239. New RD Fabs Intake on the way!!!
  240. Just bought my 06 SS/SC Cobalt
  241. Ported Head Question
  242. header and dp installed... cruise doesnt work
  243. 3" pulley on stock ss/sc
  244. PCM light gone with K&N intake stock motor!!!!
  245. no power through pinb 16 OBD-II
  246. To much fuel = bad???
  247. Supercharger Hoses
  248. What to do with 130 bucks
  249. 3.0 Pulley + engine Motor mount gains!
  250. Icing the stock after cooler
