- HAHN TURBO CONVERSION for ss/sc
- How do you guys like CA headers
- help on lauch
- Another for TVS
- shorty vs midlength header??
- Wind up toy sound?
- Everyone needs to see this!
- header/dp combo..gotta ?
- Gauges
- how much $$$
- passing emissions w/ no cat
- Boost Problem
- GM Dealership is Dealershit
- what to expect.....
- surrendering car
- need help. i want to tune my cobalt
- 2.8, meth, 60s.. Advantages over 2.9 with 42s?
- Torque Managment
- What Next?
- how reliable is the ss/sc?
- turbo manifold
- Meth Problem.....
- exhaust and boost?
- 300whp without n20 or meth?
- Air filter no FIT.
- how reliable is a 2.6/ 2.7 inch pulley with a stage kit and a good tune on 17.5 boost
- question about stage 1
- Going to 60's, meth, and a 2.8.. Product recommendations?
- Opinions?
- Just bought Meth
- rev limiter and torque management. Please help.
- bad injectors
- 2.8 pulley question
- XTC 2.5 DP - What Header?
- question about buying custom exhaust
- gm stage 2 vs addiciton stage 2
- DC Sport Cat-back
- JBP header anyone running this?
- cobalt addiction stage 1
- Ticking?
- stock stage 2 tune
- tranny swap ?
- Methanol and cat converters.
- Some inside info on the bypass solenoid
- supercharger grease
- What else? Help please
- 2.9 tune
- I need some advice.....
- stripped bolt
- Opinions?
- Goodies??
- Baseline dyno today (mods this weekend)
- Fluttering sound from engine!
- plans for the end of the month!!!
- Got boost? (short video hahn lvl 5)
- Problem with Ingalls TD
- odbii codes
- Piston rings and gaps
- stage 2 tune
- tvs blower help plz.
- heat exchangers
- Tuning Question for Witt, or Tom
- A few questions
- timming for a 2.6 ring
- how much will it cost?
- is this dumb?
- everyone this has to be the hottest cobalt around check it out.
- Help with my stock h/e
- PSI with stage 2
- "Lightweight" 3" Stage 2 style pulley
- P0171 Lean code
- gaskets blew
- Red Star Performance Tune
- throttle boody/injector harness
- is it benficial to run a 2.5??
- Looking to get some goodies!
- Dealer issues on my stage 2
- question for the educated...
- advice needed
- KR and prothane mounts
- Wheres the oil cooler?
- Part Number request
- switching exhaust, gains?
- deleting the catalytic converter = +HP?
- cobalt sssc is it worth modding????
- What exhaust should i get?
- Harrop supercharger Upgrade
- How do you tell if your cobat is a G85
- ZZP adj. tens.
- Hesitation
- SS/SC molded splash guards??
- Most Miles?
- stupid Timing chain
- Anyone With Mechanical Boost Gauge and or Narrow Band AFR Gauge
- tsudo? wtf
- What pulley size?!?!?!
- What size hydroshield for the Injen 2.0L CAI?
- Searched, but can't find it
- stage 2 code
- where is it?
- the tip part of the GMPP catback
- performance short blocks
- Installation question on Injen CAI for 2.0L
- Members who have tuned over STG II
- trying to go stage 2
- heater control malfunction
- highflow cat and highflow resinator
- Choosing intake
- Airbox mod
- check engine light/trans problem?
- car wnt run
- Advantages/Disadvantages over 2.6???
- belt slip help please
- Cant find part
- Resonator question
- oil cooler
- Air filter install
- dyno guesses?
- Need Help Asap
- pacesetter header how to.
- Power Loss...?
- teach me
- tvs owners.
- Mahle LSJ Forged Pistons $250 shipped!!!
- help disconecting halos.....
- 225/35/18 on stock sc wheels
- HeadGames ported throttle body dyno results!
- boost problems?
- stupied question how meny q of oil till it reads on your dip stick
- Any Advice
- oil cap help
- SS/SC with 30PSI boost gauge
- O2 sensor Mv and AFR ??
- Milage reset?
- Engine Misfiring!!
- MRZ Lightweight Crank Pulley..
- blown head gasket
- k&n cai
- Internals???
- organic clutch?
- lowered... now vibes.. Wth?
- Thermostat q..
- IC pump hose routing
- PSI Boost Gauge from SS/TC??
- HELP! Projector Lamp out!
- LNF in 05-07 LSJ
- another TWM sts question
- Lose power and boost at WOT...WHATS WRONG????
- Exhaust Prefrences
- Want to quiet down exhaust.
- power flow charts
- Help, I can't turn ignition key to off!
- how to pry off the plastic cover under steering wheel?
- cluthes?
- Wideband Senson placement....
- UH wtf probelm....
- Are these 1 step colder spark plugs>?
- Piston Swap
- Stage 2 belt?
- For all you with Cam Gears...
- shorty vs mid headers
- Clear Image Head and DP
- My daughter and I spent 2 hours
- Thc's Build Thread
- Independent rear suspenion
- turbo mani cracked
- BlazinbaltSS Rebuild Thread
- speedo slow?
- Bone stock 06'..what's the fastest way to 230 or so hp?
- Where to buy cams?
- pinhole in the brakeline
- cheapest place to buy a GMPP catback?
- Pistons possibly blew?
- twm shifter
- Header guestion
- I Need Help Finding
- downpipe to fit vibrant
- Need help!
- This Sucks...
- Pacesetter fitiment Q
- Front o2 sensor
- Did i do H.E. the rite way?
- SLP Loudmouth II Exhaust
- GMP Pedal Cover Kit?
- Saab??
- noob gmpp catback question
- Now to spend my Christmas money...
- Meth injection, it is worth it for me?
- my pulley/hub do not fit together
- what to do next?
- Cobalt SS/SC brakes
- Just an Idea?
- motor mount torque spec
- bwalker turbo dyno
- Kincaid Performance is going to hate me for this but... KILLER CHILLER EXPOSED!!!
- haha another exhaust question
- Fuel Pressure Gauge
- P0503??
- wtf is wrong. turbo guys help.
- heat exchanger.
- BlazinBaltSS Blew his cobalt up
- Flywheel Hp gains
- 400 wheel horsepower supercharged...
- anyone with stage3 got a ?
- gm stage 2 or ca stage 3
- downpipes ????
- Need help picking a Throttle body spacer for meth!!
- Trans?
- cruise control
- Need help with power upgrade!?!?!
- how much did stage 2 cost you
- Random Engine Misfire
- Magnaflow muffler part#??
- Due to the current problems with Cobaltperformance parts
- gm stage 3?
- GM's wheel hop kit or OTT'S Rotated Mounts
- Degrees of Timing
- Wewpon r header and dp
- re limit on stock balt
- Help!!! Exhaust Too Loud
- new header and d/p
- Atermarket Intakes ?
- Car won't Start!! Help!
- SS Underhood Liner
- Oil dilema
- GM Stage 1 Question...
- Question about FMIC
- tsudo vs Megan
- Might be saying goodbye to the cobalt
- Dont know if this has been posted yet but
- yayyy another exhaust thread
- Exhaust
- intake and hp
- You WILL wanna check this out.
- need to know wat size bolt!
- which one faster?
- i need help wrecked my car
- ss/sc exhaust
- stock throtle body?
- Think this would work well with Cobalt SS/SC?
- ZZP Stage III or IV?
- HE Install how to thread?
- need help quick!
- Best downpipe for GMPP exhaust setup
- Dynoed the balt!
- rebuild
- exhaust cutout
- Portrd and polished head
- The under 100.00 mod list!
- Driving without IC pump?
