PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. DW200 Fuel Pump
  2. zzp shorty header
  3. Which direction for new pistons?
  4. my build thread
  5. INTENSE racing?
  6. LSJ Supertech Valves Question.
  7. New lsj guy with a few questions
  8. trying to peice together a turbo kit need part list!!
  9. for sale injen intake
  10. Where are your water/meth nozzles, tanks and pumps mounted?
  11. Removing Bottom Belt Tensioner Bolt
  12. My car is running hot help pleas
  13. Wtb cobalt ss parts!!!!
  14. Help identify components
  15. Leaky Downpipe Flex Joint
  16. 300whp with catback only?
  17. Stroker Crankshafts
  18. Tuning Help
  19. ZZP stage 3 kits
  20. mod questions
  21. LSJ Build Book
  22. Last Call For Feedback Prior To M62 Porting/Polishing/Plugging
  23. Lsj transmission talk
  24. InfraRedline's all out turbo and build thread
  25. Need Help (mods)
  26. LS4 TB + M62 Porting - Need information
  27. Can we put a BOV on the supercharger?
  28. ottp fuel return system vs zzp BRFPS
  29. Exhaust question
  30. Im back :)
  31. CEL Codes
  32. LSJ Stock Head Bolt Torque Questions
  33. ZZP PCM 1.0 for LSJ YES/NO?
  34. Help!!! Cobalt 2.2 sc tuning
  35. I'm back!!!!!!!!!!!
  36. O2 sensor switching slow
  37. TTR INTAKE MANIFOLD fs
  38. Ttr intake manifold fs
  39. Want to run an E67 computer in your LSJ powered car? Its easy!
  40. The quest for 600whp
  41. Ebay Midlength Header
  42. Some questions
  43. SPDDMN's Winter build/Projects
  44. forged rods question
  45. Best Option Over Time
  46. Header primary size
  47. It's about that time
  48. TVS pulleys
  49. just wondering..
  50. Are ZZP'S Stage 2 Cam's Worth It??
  51. P0069 baro absolute manifold pressure. code 05 cobalt ss lsj
  52. Dropped turbo lsj off for tune.
  53. how much boost can the lsj sc handle?
  54. Custom intake pipe
  55. P0171 code "Bank 1 system too lean"
  56. Help With Supercharger Info
  57. I got my baby back!!!!
  58. Got my new ZZP shorty header
  59. lsj coil pack pin out
  60. GM Racing Exhaust Ported Cylinder Head
  61. Just Bought a 06 SS/SC with Failed Engine Swap
  62. Tensioner pulley questions
  63. 06 Cobalt SS S/C Stage 3 Kit?
  64. TDC on #2 cylinder
  65. Japeatr's install pics of Powell Custom Fuel System
  66. Blow off valve trouble, lsj turbo swap.
  67. Stock Pulley Phenolic Spacer
  68. how to get 05 ss to sound more like a subi
  69. Spark plug gap HELP
  70. What belt to use?
  71. zzp long tube Question
  72. Japeatr's pics of Powell PCV System install on TVS LSJ
  73. Turbo LSJ swap. BOV sound?
  74. m62 genV
  75. LSJ ECU pin locations?
  76. I need help. 06 cobalt ss will crank but not turn over
  77. Engine Misfire and Oil Leak??
  78. ZZP shorty header gains?
  79. meth problems :/
  80. Which BRAKE PADS to go with ZZP rotors??
  81. Swapping out SLP Resonator for something quieter!
  82. im going to look at a used 06 lsj.. help
  83. What Header DP combo? S3
  84. Misfire Cylinder 2 & 3 only getting code 300
  85. mustang cobra HE?
  86. 2.5 in. or 3 in Exhaust?
  87. LSJ turbo swap Need help MAF sensor
  88. Anyone have the new ZZP header?
  89. New Fuel Products at OTTP
  90. Magnaflow
  91. Revs too high in any gear after a pull
  92. Fuel pressure and Return style issue
  93. Premium gas
  94. What fuel pressure are you running and why?
  95. What CAI should i get
  96. pulley question
  97. lag???
  98. Bank 1 too lean CEL
  99. Engine life
  100. SS/SC Stage 3... header, dp or both
  101. Lsj clutch upgrade kit and clutch job question
  102. Clutch Problems
  103. Don't know what to do for my next mod
  104. Difference between T/C and S/C muffler?
  105. help with a build
  106. Chain skipping
  107. Good starting mods?
  108. So my black timing chain guide broke...
  109. Vacuum Line Question
  110. Idle Problem with Hahn Swap
  111. Tvs question
  112. Engine power reduced
  113. Engine Swap
  114. ebay intake... WTF?
  115. stage 3 ss sc
  116. M62 pulley
  117. Harrop any good?
  118. Spark plug help
  119. LSJ- 'tap' when hand cranking the motor
  120. Next on the list of mods...?
  121. 2.0 ss swap to 2.2 ???
  122. zzp blown out resonator
  123. LS4 TB back to stock
  124. Stiegmeier porting
  125. Compression test, what's yours?
  126. Low boost fix!
  127. My potential mini-build list...
  128. lost in sauce
  129. Siemens 50# injectors and a 3.0 Pulley
  130. mac 4 port boost solenoid
  131. List of parts and steps for LSJ engine rebuild
  132. Keep blowing exhaust fuse
  133. Lsj/tvs engine build #2
  134. Advice Please: CEL for Too Rich, Misfires Bank 1, Only Came on for 30 Seconds?
  135. Trouble Starting
  136. Canned tun and 60 lb injectors
  137. Help With Sensor (MAP?)
  138. R&R of Project "ALIEN" {IRL Build Thread}
  139. Wideband not reading on HP Tuners
  140. Supercharger Maintenance?
  141. SS/SC problems 8 codes
  142. aem e85 fuel pump
  143. ne1 with exhaust vid of...
  144. CBM Billet Water Neck
  145. Locked up the SS
  146. Need Help, Fujita intake inlet size, PLEASE!!
  147. S/C bolts...need ideas.
  148. Tune was perfect, now running a little rich with colder plugs and wider gap.
  149. lsj cams
  150. tvs set up help
  151. Anyone running an Option B tank without the dual pass?
  152. 2.8 Pulley Question
  153. Option B Problem.. Tank Fills up.
  154. High compression vs higher boost
  155. Boost issue!!!! Cannot determine problem!!!
  156. lsj map sensor dimensions
  157. 2.1L TVS Redline
  158. Cant go WOT
  159. Ignition system failure!! Please help!!
  160. Cooling mods
  161. Bypass solenoid
  162. are the lsj and lnf blocks interchangeable.. also looking on make hicomp LSJ sc
  163. IAT 1 temp issue
  164. Strange Hesistation when Fuel Tank Below Half Full on LSJ
  165. M62 Porting
  166. Inter cooler pump performance decrease.
  167. option b tank??
  168. misfire at idle?
  169. Iat 305 degrees f...?????
  170. fuel pressure questions
  171. zzp header dfferences?
  172. stock he with option b
  173. how bad really is an stock heat exchanger?
  174. Where to download hptuners?
  175. stock cobalt ss?sc 2.o
  176. The search button is useless point me in the right direction.
  177. gmpp exhaust any good?????
  178. GM stage 2 injector color?
  179. Guessing Game.. Bought a Pre-Owned LSJ
  180. Stage three option b tank...!!!!
  181. Finally starting to work on it
  182. 2006 LSJ rebuild?
  183. Any S20G LSJ's Out There?
  184. my car is running to rich
  185. LSJ Turbo Issue...
  186. Is Euthanasia a scammer?
  187. ideal vacuum supercharged?
  188. Oil pressure sender
  189. WIX Oil Filter 57082
  190. O2 Sensor Question
  191. Runs wierd after high speed?
  192. Smoothflow Hub - which way does it go?
  193. exhaust identification ???
  194. LSJ Header and Downpipe Options
  195. Looking for Custom Covers
  196. Coverting to E85
  197. Who wants to help me diagnose a problem?
  198. Hydro locked due to rollover
  199. PCM Error
  200. p0171 why?
  201. Interceptor Gauge Question
  202. exhaust question
  203. why hasn't the killer chiller been a success?
  204. Some guidance needed
  205. stock LSJ intake manifold plus turbo
  206. boost bypass question
  207. Supertech Issues
  208. Stock Heat Exchanger Mod....lower IAT2 temps 40 degrees
  209. does this look right? (piston ring question)
  210. Methods to change lash adjusters...
  211. seriously thinking of buying this
  212. Gm Stage 3 kit
  213. Not feeling enough power in 2nd gear
  214. 2JZ swap?
  215. Injector fit on 06 LSJ
  216. Help!!! 2nd gear problems, and cel
  217. Stage 3 vs turbo?
  218. Luk Repset Clutch Kit
  219. lysholm problems... spun bearing and bypass valve?
  220. lysholm problems... spun bearing and bypass valve?
  221. E85 set ups???
  222. ZZP Stage 2 cams. dyno proven difference.
  223. intake
  224. lsj turbo swap super high idle
  225. Need help finding some 2 step colder plugs
  226. Intercooler pump
  227. those turbi lsjs come inside
  228. ZZP SC Kit issue and ZZP long tube Q
  229. Vavle Cover Has Hole???
  230. What resonator do you recommend?
  231. timing chain tensioner & crank pully
  232. Stage 2 verse Stage 3 questions
  233. Tick/knock and burning oil.
  234. will a gtp pulley work on my cobalt
  235. cant find the answers...link me?
  236. Another intercooler question...
  237. Quick header help!
  238. Resonator Question
  239. Question/opinions on ZZP Catted Downpipe
  240. Question/opinions on ZZP Catted Downpipe
  241. TVS Vs. Turbo?
  242. HELP! old vac lines are deteriorating
  243. yes im full of questions. ..teach me!
  244. info on my exhaust. ..?
  245. crank pulley
  246. installing Nitrous
  247. Muffler Selection? Help! Want clean sound
  248. slave cylinder questions
  249. Stage 2 hub/pulley bolt length/pitch?
  250. 2.4 block with a 2.0 head
