- Clutch goes hard at WOT
- Codes AGAIN
- Help electrical problem!
- New Shifter
- Thoughts on Aero Exhaust or Dynomax
- oil pan question
- cant get my tail lights off >:(
- RPD Mod
- ZZP Stage3 critique?
- DC Sports Cobalt SS Supercharged Cold Air Intake (2010 Release)
- Aftermarket header?..
- some people
- Boost problem?
- is there a way to add more back pressure?
- lsj downpipe
- PA people help
- exhaust rattles after header install
- What should i do Cobalt ss or GTO
- front mount heat exchanger ????????
- DIY on Option B?
- Odd shaking
- Installing a ZZP S2 H/E, coolant question?
- car making ticking noise??
- Free IAT2 reduction for the LSJ
- Dual pass or Meth?
- Help Intercooler pump not working!
- eng power reduced
- can I use 07-09 cobra HE?
- Lighter crank pulley?
- SS/SC radiator brackets vs. base model brackets?
- Help with new shifter
- meth and E85
- Wanted 06 ss-sc i/h/dp/e
- weird noise...need help
- Need help i sound like a honda
- will it hurt anything?
- Stock boost? 8psi or 12psi
- Tune!!!
- change oil now or later
- help pleaseee
- helpp please
- helpp please
- Ppl with base devilowns kit plz chim in
- wierd noise coming from my lsj
- Valve spring install
- finally upgrading, input needed
- buildup
- E85? Can it be run in a stock SS/SC?
- Headers??
- Where to get LS4 throttle bodies
- Supercharger oil?????????
- Torque spec for tranny mount, valve cover...
- sea foam
- belt tensioner issues
- Possibly Bad Clutch Or Bad Slave Cylinder ??
- aftermarket exhaust HP gains?
- LSJ Boost Issue Fixes
- Stock hood weight?
- possible set up
- Option A.1 Tired of bleeding your I/C system?
- Aluminum Radiator!!!
- New to the LSJ world!
- supercharger stoped working
- heat exchanger??
- ECU relearn
- Need Valves...Thoughts? Options?
- OTTP'S New Mounts
- Normal Operating temps
- Cobalt ARP Flywheel Bolts
- Wideband Issue
- Option B
- Check these ebay mounts out
- question on jbp intake
- fuel milage
- Trifecta tune on a stock ss/sc?
- help finding a part number
- Rattle/Buzz noise w/ new exhaust
- Quick help please
- Stupid codes wont go away!
- 06 ss sc help!!
- Muffler Specs Question
- ac delete
- OTTP stage 2 or ZZP stage 2
- Ottp
- Wideband question
- Goin performance...what next???
- Help With Dual Pass and H/E
- Dynomax VT "Drone Free" Muffler is AWESOME: Quiet 3" Exhaust At Last
- Saab Intake Mani Quick Question.
- I want mods for my lsj head!
- My car pops out of 5th gear when i accelerate please help!
- weapon r dragon intake
- Cel 2246?
- Brfps
- 2.8 only pushing 14-15 psi
- Gm Stage 1-2 kit
- Engine is apart, here is the damage...
- zzp pulley fit on smootheflow hub?
- Squeelin noise cant figure it out
- Humm Quick Question
- I think my belt is slipping!!!
- would GM STG 2 be worth it for me?
- Unsure...help plzzzzzzzzzzzz
- hooking up boost gauge????!!!!!
- i need a tune bad can someone help
- Experiencing blow by?
- Got dyno Tuned yesterday
- M62 porting questions
- safe shit bad idea?
- Vacuum Pump for SS/SC
- Pics of new engine parts
- ZZP Stage 3 Heat Exchanger
- Just got Hp tuner
- Option B kit or Dual pass?
- somewhat of a childish questions but i've gotta ask, relates to modding.
- supercharger coolant system on turbo?
- stock cobalt exhaust
- The rules for pulleys swaps
- cracked radiator
- mounting wideband???
- aux fan switch=success!
- cars at OTTP
- Couple of issues with my lsj
- Need some help
- OTTP Heat Exchanger (4th Version/Newest Version)
- Coolant Fill Procedure
- Does any one know if WickedSS2005 is still tuning?
- Fuel system help
- dp help
- eng power reduced problem
- Intake Manifold Bottom Mount Identification
- Help me take my belt off
- 2 Step Colder
- stock muffler new??
- im retarded!!
- exhaust advice
- Need valves
- Want more low end torque
- ottp stage 2 dd?
- Injectors for tvs
- meth question
- hahn 3 inch catback..bad resonator??
- wanna mod my lsj, need some advice!
- ZZP stage 2 questions
- oil pan
- Need help finding parts
- K&N intake or other?
- Can I?
- catback which makes more power/loudest
- ottp 3in intake
- will stage 2 affect my gas mileage?
- Random lean AFR at idle
- Smallest pulley you can run on GM stage 2
- NGK 4644 1 step gap?
- HELP PLEASE!!! check engine light and lowered fuel economy and throttle responce
- tvs same boost with two different pulleys
- Finally bit the bullet on new headers...
- Looking for a place to get tuned
- OTTP stage 1 mount opinions
- Shifter Pops out of First Gear and Is Slow To Get Into Second
- Hole in another cylinder
- New to the LSJ, where does this hose go?
- Minimum to reduce engine movement
- Weird problem
- ZZP modular pulley system hub installation question
- Anything Compatible from an 09 Malibu 2.4 Auto with my SS/SC?
- zzp down pipe disclaimer
- Inspection question
- More GM Stage 2 questions
- BRAKES!! i must change all 4 rotors/pads...WHat do you Recommend?
- Stage 3++ or Twin Charged
- Possible HP with TVS
- Seen 205 degree engine coolant temp. Need to know if thats bad...
- best of the best with lsj's inside plz
- Engine Components with pics
- why is getting the pulleys off so hard?!?!?
- Random Misfire
- Why is there a thread on changing your SC oil, is it not oil for life?
- Ottp stage 1 mounts.
- Front mount oil cooler
- tracting mods
- Not sure which pulley I have.
- Any one Know the exact circumference of the Stage II Belt
- OneCOLDBIZL272's Custom Oil Cooler Set-Up
- What is the Correct Transmission Fluid
- muffler
- JetChip MAF?
- Intermittent "brake" warning light?
- Need location.
- Unpluging Throttle Body Connector
- how much coolant/w.e goes in your h/e?
- reverse lights out!!! help
- Blackstone Lab Test?
- dynoed the car a little pissed
- help. limp mode
- GM stage 2 questions.
- cosmo short throw in my 2.0
- Looking for quick cheap hp and performance.
- racing gtp
- Tune please
- coolent temp?
- best H/e
- heat soak?
- lsj+k04=?
- Any1 w/ HP Tuners on LI? Need a CASE Relearn
- Weird problem please help
- Looking For a Stock Boost Gauge for 05 SS/SC
- OMG My Exhaust Sounds Like A Honda !!!!
- upper grille h/e
- JE pistons
- Cleaned out my throttle body last night.
- What do you guys think about this?
- "erratic" A/F reading
- Finalllyyyy :)
- Simple Part Identification Please
- 17lbs of boost with a 2.9 pulley
- HELP MEE! I just got stage 2 installed
- A/F Ratio Question.
- backfire and powerloss....
- mounting wideband????
- Unhooking Throttle Control Plug IN
- Which Downpipe? Need Opinions...
- 80 lb injectors
- Engine Power Reduced...This car Sucks..!?
- looking for a tune for my 2005 ss/sc
- hurt performance?
- Car kept trying to quit?
- Turn Fan On By Switch
- intercooler help?
- brake clean vs carb cleaner
- another heat exchanger Q real fast.
- ATTN LSJ's!!
- Eww i cant belive it lol
- installing h/e help?
- what mixture goes into h/e
- how tight to tighten this bolt?
- need help upgrading GM stage 2 pulley
- Loss of boost with K&N Filter
- canned tunes
- clutch pedal goes hard at wot
- Wideband O2 Bung?
- Need help with a wiring issue!!!!
- OTTP stage 2 kit
- Funny idle.
- im confused wtf
- 2 questions please
- check engine light?????????
- Gutting the Magnaflow highflow cat
- 120# injectors
