PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Help with codes
  2. types of fluid for meth injection?
  3. Meth Or Dual End Pass Plate ??
  4. Supercharger Help
  5. Need help with filter!
  6. My car's engine rebuild and body work...
  7. Please help, fuel pressure issue.
  8. 06 ss/sc build
  9. I want more!
  10. cam gears benifits
  11. balts come lsd equpiied?
  12. What is the difference?
  13. Exhaust flex section
  14. Tapping stock downpipe for wideband
  15. zzp exhaust
  16. Will Car Detonate??
  17. H/E Brackets
  18. hard to install solid motor mounts?
  19. Rebel stage price
  20. exhast Re-vamp
  21. un tuned. but ok?
  22. Exhaust?
  23. Whisper Resonator
  24. Second try.. Major Exhaust Question..
  25. What is the next logical mod?
  26. Question on exhaust
  27. Exhaust issues
  28. 2.9 Pulley change
  29. downpipe ?'s
  30. intalling new spark plugs today
  31. Gmpp exhaust downpipe question
  32. torque brace
  33. Aem Cai
  34. Sti Mod
  35. cat or no cat?
  36. need some help
  37. new brakes???
  38. Anybody know how to....
  39. K&N Filter Part number
  40. 2.2 + 2.0 Sc Gmpp Exhaust ?
  41. 300HP Build?
  42. Just installed my zzp shorty header and downpipe
  43. FEDEX might as well be Santa today
  44. i feel stupid...but RAW stage kit question
  45. Pulley Sizing And A/f Ratios
  46. Best Fitting Intake
  47. Stage 2 on!
  48. probably a dumb question
  49. leaning out the stage 2 tune
  50. Stage 1 and 2 tune?
  51. 2.9 vs 2.85
  52. which stage should i pick?
  53. First couple mods to my car
  54. Hahn Racecraft LSJ GT35R Turbo Cobalt 440WHP 297WHQ
  55. the TVS supercharger?????
  56. Magnaflow Muffler help
  57. cooling mods needed?
  58. Software for cobalt tune
  59. Might be doing the airbox mod this weekend
  60. Fuel Filter
  61. ZZP Header/DP Combo on GM Exhaust?
  62. Cobalt sounds like machine gun
  63. Exhast Manifold
  64. Exhaust Question?? need idea please help..
  65. Boost leak?
  66. 3" vibrant catback and resonator
  67. What A/F ratio gauges are out there for the ss/sc
  68. expected hp?
  69. TTR Vs Bwoody!!!
  70. check engine light
  71. Exhaust question need help
  72. zzp header/dp combo HP #'s?????
  73. Upgrade exhaust-keep noise down
  74. Yet another addition to the balt :D
  75. ?? on dual pass installation - help
  76. Goodies arrived today...56k Beware!!!!
  77. resonators question
  78. NEED ANSWER!! please
  79. Which Exhaust???help
  80. Exhaust smell after install
  81. GM might be able to see a tune
  82. supercharger repair help!!!
  83. stage 2 question
  84. 10 sec balt
  85. is this safe
  86. will i have a bottle neck
  87. CXRacing Intercooler?
  88. 2.9 Spark Plug Gap
  89. Advancing Timing?
  90. Heat Exchanger question!?
  91. Intake Info Please..
  92. fuel pump pics
  93. Difference between the ZZP dual pass and GMPP dual pass intercooler?
  94. Boost problem
  95. Which exhaust?
  96. Alternative spark plug to NGK BRK7E (ACDeco FR1LS)
  97. intake instal warranty
  98. 2.9 pulley
  99. Aem Dry Flow Hydro Shield???
  100. mandrel bent piping
  101. Bucking?
  102. Unsure of what I should do with exhaust
  103. Header ?
  104. Question on 60lb injectors on a GM S2 Tune
  105. Complete Kit?
  106. gm stage 2 vs. gm stage 3
  107. exhaust theory WRONG
  108. gas mpg with stage 2
  109. My new toy!
  110. EGT temps
  111. Disabling O2 sensor/Spark anti fouler trick explained?
  112. price of install
  113. exhaust hp vs price
  114. engine mount tourqe
  115. High Flow Cat
  116. does anyone have the slp loud-mouth dual-exhaust?
  117. Wtb: Stage 2..........looking For It Bad!
  118. Aem Short Ram Intake
  119. Calling for a stock 2006 HPT file
  120. Stage 2 Reflash Question.
  121. ss/sc oil filter
  122. MSD Dashhawk
  123. wideband gauge
  124. Just got BWoody Solid Front Transmission Mount
  125. Installing my Hahn cat-back today!!!
  126. RAW 3" Intake VS AEM Intake
  127. 2.5 dp
  128. Need a Diagnosis
  129. taking forever to start...
  130. 2.6 pulley
  131. Water Injection???
  132. Stage 2 Impressions.
  133. Installed Header and DP...
  134. HP tuners
  135. rods
  136. Some questions and info for tri-state people
  137. question about CA performance stage kits.....they say you can send them your ecm
  138. Anyone wanna come help...
  139. Twin Screw back from the dead
  140. new member! would like to mod my new car...can I do stage 3 by myself?
  141. Semi-Dual Exhaust with cutout
  142. Rubber connector between throttle body and Injen intake
  143. What exhuast do you have?
  144. Serious Help Needed
  145. black smoke
  146. CEL due to CAI
  147. Getting HP tuned, tips?
  148. Ingalls settings
  149. New Dyno Numbers from Today
  150. HPTuners Worth It?
  151. Exhaust install how to?
  152. Oil!!
  153. well im at the dyno!!!!!!! gettin ready right now
  154. Motor mount bolt specs
  155. 93 octane or 87
  156. anyone try transmission cooler in line with stock heat exchanger?
  157. K&N Filter
  158. Stage 2 Installed!!
  159. Box tuners?
  160. LSJ and mod sugjestions
  161. differences of gm performance and touring
  162. zzp downpipe/aem wideband
  163. gm stage 2 cel
  164. Stage 2 Tomorrow
  165. Has This Happen To You?
  166. Got Meth?
  167. Torq dampeners or poly mounts?
  168. LSJ / LNF Difference?
  169. need help bad
  170. stock h/e
  171. megan exhaust
  172. resonator/muffler ideas
  173. gutted cat
  174. Wideband ?s
  175. help with dual h/e
  176. GMPP Exhuast Question?!!!
  177. Cyclinder 2 Misfires
  178. getting stage 2 today
  179. Vibrant or ZZP?
  180. Cany you monitor knock W/tech2?
  181. Troubles !!!!!
  182. Question on dp
  183. zzp header to dp washer/bolt
  184. Which clutch should I get?
  185. Help Understanging Meth??
  186. zzp header, pacesetter header; the same?
  187. Dual Pass vs. Heat exhanger
  188. Kinda lost and confused here?
  189. Who has this set up?
  190. Header and Downpipe
  191. Cam Help
  192. WOOW!! Finally got my stage 2 kit and 2.85" pulley put on!!!
  193. Quick Question, Please Help.
  194. Anyone have the Vibrant header/DP setup? what kind of gains?
  195. Scary...
  196. My Stage 2 Not Rich?
  197. luanch controll on ss/sc????
  198. airplane application/o2 usage, VALID IDEAS
  199. Getting dyno'd after clutch install
  200. Boost Gauge Question?!!!!!!! Need help
  201. Belt wear???
  202. JBP performance exhaust
  203. Custom Exhaust
  204. Best intake?
  205. Custom Exhaust
  206. what size intake hydroshield?
  207. Torque dampener?
  208. Need Stage 2 Pulley Tool!!!
  209. Can you tell me what this is???
  210. Help with out of place hose
  211. Weird Scenario - need advice
  212. Wiring a Meth Kit
  213. DC strut bar
  214. catilytic converter problems
  215. need help installing cobra HE???
  216. Approx # of Hours to install GMPP Dual Pass with Option B
  217. ss/sc video plugged sc holes
  218. What are Safe IAT2's?
  219. pics of plugging supercharger holes
  220. Quick question about horse power.
  221. camshafts
  222. how to clean intake filter??
  223. If the Injen and Fujita were the same price.....
  224. CAI vs. Motor Mount
  225. EGT question?
  226. Q Horsepower Motor Oil
  227. Eaton M62 louder than the 112?
  228. Got question, NEED SOME ANSWERS PLEASE!!!
  229. i got 3 grand and want turbo what do i need
  230. meth kit and spark plugs
  231. Water/Meth question...help
  232. Quickie - Removing S/C
  233. intake question
  234. s/c filter
  235. SC cleaning.
  236. Tuning Programmers Available?
  237. anyone in maryland, or close by
  238. WTF is my car doing.
  239. 2.0 trans ?
  240. magnaflow exhaust.. 1 yr later
  241. Intake Installed Next Mod?
  242. How to get stage 2 bolts off NO TOOL??
  243. Applaud ZZP
  244. stages question
  245. Intercooler Cooling system Idea...
  246. Need a Tune
  247. ingals trq dapper help
  248. steel braided lines
  249. Clutch & Flywheel Help.
  250. Why PCV Valves SUCK. And pics of my S/C...
