PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99
  1. Gap of plugs and GM stage 2?
  2. gmpp exhaust manifold
  3. New Pulley Question?
  4. Break in - Stage 2
  5. Clutch slipping at 500 miles?
  6. Stage 2 and boost levels?
  7. I think im reading to much.
  8. Question about 2.8 pulley sfps
  9. ZZP Adjustable Tensioner
  10. Question about gears
  11. K&N Typhoon w/ "Drycharger"
  12. Idle Issue
  13. LSJ info
  14. Reflash/tuneing
  15. XTC intake installed!!
  16. GM teases us a bit more.......
  17. TQ brace bracket problems, (old style brackets)
  18. JBP CABs Vs. Ingalls Torque Brace
  19. Stage 1 w/ 2.8" or Stage 2
  20. Anyone have this product?
  21. will i ?
  22. Engine Belt
  23. Octane booster?
  24. Spec stage 2+ break in period
  25. Superstreet results
  26. Piston specs needed.
  27. Best exhaust for 06 ss s/c
  28. After extensive testing...verdict in JBP CAB's suck!
  29. Has anyone used the gm perf exhaust
  30. another stage question
  31. woohooo.... er oopsy
  32. cat removal....
  33. Intens kit opinion wanted
  34. Perfomance part numbers
  35. GM Stage 2 colder plugs?
  36. stage 1 into stage 2 info
  37. Dyno Results Almost Stock SS
  38. intense stage 3 question.
  39. Someone with Intense 3 help me out
  40. Owned
  41. Break boost
  42. Where i can find information about the warranty with stage kit ?
  43. B&M Shifter Install???
  44. GM stage 2 pully swap?
  45. Stage 1 and 2 1/4 mile time data base.
  46. Stage 2 Crateenginedepot.com ?
  47. dc sports exhaust?
  48. Location of PCV?
  49. RK Sport Dual Catback System (05-Up Cobalt)
  50. Max Blower RPM
  51. Different stock HPs ?? Im confused
  52. My new take on stage kits
  53. Review: 2.6", ZZP snout machining tool, JBP CA Bushings...Update on Ingall's
  54. Ordered stage 1 kit
  55. Installation cost of stage 2 kit?
  56. stage one dynoed
  57. Stage 2 Install for SC Cobalt
  58. Trouble Code P0103 with 2.8" pulley and Stage 1
  59. Stage 2 requires another reflash....?
  60. My results for Stage 2...
  61. ZZP Snout Machining Tool= Hawtness
  62. Injectors
  63. Whats our stock psi
  64. stage 2 gas milage
  65. Gatorback Belt
  66. Can my stage 2 ss/sc beat my bosses automatic stock 94' or so z28?
  67. KN typhoon problem
  68. What does a idler pulley do?
  69. 9.5-10 psi of boost it is normal ?????
  70. Performance Build time? Mahle Forged Pistons :)
  71. Stg 2 Help!!!
  72. Dyno Results Stage 1
  73. Problem with Stage 2 pulley
  74. Stage 2 owners....
  75. i dont know if the reflashes are the same
  76. stg 1 question
  77. popping noise????
  78. oh god not another intake thread
  79. boost gauge wont work......any tips?
  80. ZZP Puller work on Stage 2 HUB?
  81. Need injen help
  82. which kit would you get?
  83. Put my stock knob on my B&M .....pics
  84. Need Strut Tower Brace...where?
  85. Supercharger Pulley too...
  86. Unknown Problem, Take A Look Please
  87. intercooler
  88. Getting Dyno'd Tommorrow morning
  89. Question for MAF-T tuners (MAFT PRO?)
  90. I'm happy with MPG
  91. Max WHP for a 2.0L
  92. Need help making this stage badge!
  93. Anyone here have a 100% definate answer on the St 1/2 reflash question???
  94. Ngk colder range spark plug for bone stock SS/Sc ?
  95. A new owner of SS/SC is here
  96. The 2.0 Upgrade list
  97. autopartswarehouse.com is pissing me off!!!!
  98. Short Throw or Slotted Rotors?
  99. Question for all with Injen cold air intake and stage upgrades
  100. boost release bypass...wtf
  101. pulley sizes
  102. Question: SS S/C
  103. Injector Question
  104. Why Stage 2 affects low rpm power...
  105. Hurst Shifter ?
  106. Header Install ?'s
  107. New Aeroforce Interceptor w/ Shift Light
  108. Has anyone seen this? (Vid)
  109. Just got it today
  110. Intercoolers
  111. Stage 2 Roll Call
  112. First mods?
  113. Can an oil cooler core be used as a water cooler?
  114. ? about co2 shots
  115. air box info
  116. Reflash
  117. stage 2 up and running
  118. Another noob question
  119. intense stage 3 kit questions?
  120. New 06 SS/SC 4 ME
  121. Nice Exhaust Tip for GMPP
  122. GM Stage Kits On eBay
  123. What type of fuel do you use
  124. stage 2 question
  125. stage 2 injectror size?
  126. Photos of GM stage 2 kit?
  127. GMPP Manifold
  128. GM Stage Kit Warranty
  129. Note To Everyone With An Ingen Cold Air Intake
  130. Is There Any Underdrive Pulley Kits??
  131. I see 15psi stock
  132. Bypass Mod
  133. What is the g35 kit?
  134. stage 2 setup info????
  135. stage 1 w/2.8 dyno results
  136. B@M short throw shifter
  137. supercharger rpm
  138. What do stage kits include?
  139. Stage 2 going on right now.
  140. Air Box Mod
  141. 2.8" SFPHQ pulley & GM Hug?
  142. Reduced pulley size = X horse power...
  143. Chevy assh0les
  144. Help with my Stage 2 kit......
  145. Those with Magnaflow Cat Back for 2.0
  146. Methanol Injection!
  147. Questions About GM Stage 2 Kit And The Intense Stage 3
  148. sparkplugs
  149. flip chip info
  150. cel any ideas?
  151. G85...Worth It or Not
  152. Stage Kits in Canada
  153. Miles?
  154. Cobalt SS Street Performance, Among other things?
  155. sc whine with intake
  156. Question about NGK BRK7E Gapping
  157. Smaller Belt part # that comes with Stage 2
  158. Clutch Slipping?
  159. Help! 3rd gear clutch throw back!?
  160. Question About The Supercharger
  161. just to clarify
  162. Noob Alert
  163. Those with Stage 2
  164. Baseline dyno tomorrow morning
  165. Stage Kits or Aftermarket Injectors, Gas Mileage?
  166. G85 package and limited slip ...?????????
  167. header for the supercharger motors
  168. C.A.R.B EO# for stage 2 guys in California?
  169. Installing Stage 2 myself!
  170. Tranny clutch problems
  171. stage 2 update
  172. GM Employee discount in US for stage kits
  173. Stage 1 rev limit and MPH...
  174. Build book for 2.0 SC from GM coming (not soon)
  175. saturn sky redline 2.0L turbo
  176. Factory wing Removal
  177. GTP Idler (Tensioner) Pulley?
  178. PLEASE RESPOND ASAP Need dealer phone# that's installed stage 2
  179. GM STAGE 1 w/2.8 INSTALLED!!!!!!!
  180. quick question
  181. Stage II Wait Time
  182. stage 2 here, things i should mention?
  183. Need Special Tool for Stage 2 pulley?
  184. SS SC Owners PLEASE READ! Need your help!
  185. ecotecs are fragile Tune with Care
  186. GM Pisses Me Off
  187. GM stage 2 dyno
  188. After install exhaust question?
  189. How Great is this
  190. Stage kits overpriced....
  191. Short Ram Intake???
  192. CEL code p0033 need help
  193. GM is Pissing me off.
  194. k & n drop in????
  195. Where to buy NGK plugs?
  196. Who do you guys want to see?
  197. Stage came today!
  198. CEL for cai fix by GM
  199. GM Stage III Kit
  200. Stage II Kits available @ dealer
  201. Pulley question
  202. New SS/SC Question
  203. AEM Intake...anyone have it?
  204. Reflash time?
  205. Spec Stage 3
  206. Stage 2 Instruction Manual
  207. GMPP Extruded Honed Manifold
  208. k&n intake
  209. pinstripping?
  210. 3.0 Pulley
  211. engine calibration for stage 2
  212. Rev Limiter
  213. feedback of the kit???
  214. Anyone with SFPH DUB system..
  215. Gm Stage 1 kit program vci number
  216. Injen CAI Fitment Quick Fix!
  217. everyones boost numbers
  218. boost with ur intake?
  219. Rev limiter not working?
  220. How is the driving in the SS/SC
  221. Fuel Injectors Question
  222. Im having problems ...please help
  223. The Vibrant Header is Out!?
  224. Trouble Code P0101?!?
  225. Just installed the GMPP Performance exhaust......
  226. Harmonic Dampener
  227. Any S/C SS's try a lightweight crank pulley yet? Like this one?
  228. K&N DROP-IN CEL or NO CEL
  229. Finally Installed K&N W/NO CEL!!
  230. Inaccurate dyno #'s
  231. gauge connections ?
  232. How important is LSD
  233. CANADIAN Cobalt Performance Retailers PLS read!!
  234. Raptor Shiftlight
  235. Dyno advise please
  236. Gm Stage Three????????
  237. Ok, dumb question...
  238. Rattle in Exhaust
  239. 2.8 Pulley with Gm kit
  240. I put Redline water wetter in the intercooler
  241. Recommendations For Stage Kits??
  242. Poly control arm bushings...
  243. question about a vci number
  244. CAI Care
  245. Which wheel spins faster without a LSD???
  246. THIS is what i want to do
  247. How come...
  248. GM STAGE KITs FAQs - Read Me First!
  249. Cobalt Died Help !!!
  250. Red SS in the bay area
