PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Weird noise from car only seems to happen as i hit boost
  2. Need a 3 to 3.5 coupler
  3. Is my car awesome @ 100,000 miles or what?
  4. Crazy PCM throwing 5 codes at once!
  5. Popped out of 5th gear
  6. Cold air intake
  7. Engine power reduced
  8. should i be running royal purple
  9. STU Mod?
  10. dual bypass??
  11. Exhaust Help!
  12. header or ottp stage 1
  13. intercooler pump issues
  14. Noob question, airbox mod
  15. explain afr's
  16. Cai
  17. people with gm stage 2 tune and 2.9"
  18. Turbo LSJ Help....
  19. Meth pump install
  20. Shortest throw
  21. Shortest throw
  22. ZZP 3" Intake?
  23. Cam gear question....simple one!
  24. cobalt vs ion fuel rail?
  25. need help
  26. engine bay tank size
  27. Best Redline??
  28. Can a dash hawk do a case crank relearn?
  29. Simple question please answer
  30. Co-Efficency/Curb Weight Quetion.
  31. cooling mods
  32. tvs vs hahn's s20 kit
  33. where + what to get... forged pistons
  34. Just installed meth kit
  35. aeroforce interceptor question
  36. anyone ever have this happend to them???
  37. OTTP heat exchanger + Stu mod installed = IAT2s got down by 30 degrees!
  38. Need some help from people with knowledge
  39. Option B
  40. r.e.p. mode
  41. HAHN full 3" Exhaust
  42. TVS Question...
  43. Differences between pre production and production M62?
  44. magnaflow mufflers ftl
  45. Random Misfire All Cyl
  46. Setting the timing chain...Plz help...
  47. catless to cat
  48. Tuning issues
  49. Tuning issues
  50. Anyone see these motormounts?
  51. Installed Cobra Heat Exchanger
  52. screws stuck n stripped!!! help!!!
  53. bolt ons
  54. Swap blocks?
  55. 3rd gear "grind"
  56. I need a Tune
  57. quick ?'s on internal specs
  58. diff between meth kits
  59. catless question
  60. Clutch....
  61. JBP vortex header
  62. JBP vortex header
  63. still spattin & sputton
  64. mani gasket
  65. Quick question about cold air intakes
  66. Where do I get this?
  67. ZZP Downpipe or XTC Downpipe?
  68. issue with fuel rail?
  69. Cold start/idle problems?
  70. Need some advice
  71. Distilled or not water + water wetter for the intercooler?
  72. Power Steering
  73. exhaust question
  74. The long awaited OTT 3" Intake
  75. Could I get some help with a Engine power reduced problem?
  76. Fuel Pump Question
  77. OTTP kit question
  78. Hard To Find Exhaust Leak !!
  79. tranny
  80. Stock Crankshaft?
  81. cti 3 inch catted dp vs. lsj catless dp
  82. aluminum or stainless steel
  83. Everyone with an aftermarket HEADER
  84. 2.5" exhaust gasket on a 3.0" exhaust?
  85. i've given up
  86. cleaning fueld injectors
  87. aeroforce interceptor scan gauge help?
  88. no one will work on my car!
  89. stage 1 SC upgrade.
  90. zzp pcm
  91. torn exhaust thread, no solutions?
  92. sway bar bushings
  93. injectors
  94. Got some questions
  95. sway bar bushings
  96. Dual Pass Install
  97. XTC Stainless Steel DownPipe - speak up if u got 1.
  98. TVS base tune HP tuners
  99. LNF swap?
  100. Any difference between production Harrop TVS and the prototypes?
  101. Spark Plug Rethreader?
  102. Deepest Sounding Exhaust/Muffler?
  103. Cooling Diagram (picture inside)
  104. Another Meth Kit question
  105. Placement of Meth pump & meth questions
  106. new mods
  107. Rebel 3" intake = loss of power with a GM stock tune?
  108. o2 sensor
  109. Need a clutch
  110. supercharger ???
  111. supercharger oil?
  112. 2.2dp=2.0dp?
  113. Is this normal?
  114. Just bought a GM Stage 2
  115. Im an idiot
  116. brembo's
  117. boost gauge issue
  118. Arp head studs
  119. Quick Question..
  120. 2.9 pulley on 07 ss/sc
  121. afr's?
  122. cooling mist water injection help
  123. ethanol??
  124. Twin Screw Supercharger
  125. Someone stole the troll outa my trunk!!
  126. I need to be colder help.
  127. CTI Race header + downpipe installed but no gain at all?
  128. high coolant temperatures
  129. oil leak
  130. CXRacing Heat Exchanger?
  131. Cross-drilled rotors
  132. will a pullyboys pulley fit a smoothflow hub
  133. Turbo questions
  134. OTTP Stage 1 + a lil more
  135. Need Help
  136. meth or nitrous
  137. More exhaust questions
  138. Header Install
  139. Good Score?
  140. supercharger noise need help!!!
  141. Shifting Problems
  142. Moving To Sea Level Need Help...
  143. Camshaft Position Sensor Location
  144. Replacing turbo Part tomorrow!
  145. Head Cup O-rings
  146. GM Stage 2 ss/sc
  147. Cams.
  148. car running bad NEED HELP
  149. Best modd for buck?
  150. Engine Coolant Temp. Sensor.... Maybe???
  151. Hahn Header
  152. whats the most quiet muffler out there?
  153. will it fit?
  154. for a wideband where would u tap in for power?
  155. Low Coolant light
  156. Jet MAF sensors
  157. Modular pulley hub trouble
  158. Major questions about tvs and about twincharging
  159. Hahn Exhaust & O2 bung placement
  160. any one using this?
  161. exhaust set up questions???
  162. fuel line bleeding ?
  163. safe hp?
  164. OTTP H/E cam in today
  165. Best way to spend 1100
  166. vaccum lines?
  167. 05 ss pcm in 06 ss
  168. 2.9" or GM stg3 2.99" Pulley
  169. Question about Hahn kits
  170. Tune needed
  171. CA V2 Header/Stock Gasket
  172. Stage kit
  173. Long tube header question...
  174. 2.0 SS performance parts?
  175. How to flush your heat exchanger?
  176. Throwing some codes
  177. Ford Guy here....need help with a Cobalt SS
  178. getting more power need some traction info...
  179. Boost nipple
  180. Meth fail safe???
  181. injectors
  182. anoying idle!
  183. Supercharger Pressure/Replacing
  184. cammin yo
  185. any guesses?
  186. TVS Build up.
  187. meth
  188. Whats up the sunroofs?
  189. Air bag light? WTF???
  190. Bumps Causing engine to die ?
  191. what injectors do i have
  192. My Exhaust is cracked! Anyone selling exhaust?
  193. Need some help!!!
  194. Narrowband AF gauge question
  195. Thank you
  196. Stage 2 belt install
  197. what kind of time should I expact
  198. Supercharger Removal
  199. h/e problem
  200. Where to find a M62 shaft plug
  201. knock retard
  202. Meth before throttle body????
  203. Where to buy Stg 2 Belt
  204. Full Boost No Power!
  205. what gap for a 2.9" pulley?
  206. has anybody else had this problem
  207. so i just made some
  208. which connecting rods to go with?
  209. Weapon R intake install ?
  210. my build suggestions greatly appreciated
  211. valves ticking?????
  212. Symptoms of a map going bad?
  213. mechanicle boost gauge
  214. will ingalls fit with my option b tank next to it?
  215. shift light question?
  216. OTTP mounts.. stage 1 or 2?
  217. Question?
  218. tired of mobil one?
  219. ic blown?
  220. what size gap?
  221. royal purple ICE
  222. SS Logos
  223. Interceptor question..
  224. no coolant temp reading
  225. SuperSport4 Build thread!!!
  226. Enthusiasts and vendors alike... header testing inside!
  227. question on possible exhaust leak
  228. ottp stage 1 questions
  229. SLP loudmouth call
  230. Boost question
  231. question about our fuel pumps
  232. K and N Typhoon people I NEED YOUR FEEDBACK.
  233. TB Spacer Help???
  234. Meth after the blower?
  235. E85 in 2006 Cobalt S/C??
  236. 05 ss/sc crank no start
  237. Worth it to get tuned?
  238. Need some info
  239. High flow intake manifold***picking off where rebel stopped**
  240. gmpp catback, which header n dp
  241. Downpipe cat?
  242. iat2 numbers.. need help and input
  243. inspection time is coming soon!
  244. Where to get Stage II tuned/installed?
  245. E3 DiamondFire Spark Plugs
  246. wideband ?
  247. need assistance with meth install
  248. Anyone know?
  249. redline problems
  250. do i need a tune
