PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Aem 21-2110dk Where To Buy In Canada
  2. Which product for wheel hop?
  3. Pulley Swap Successful
  4. To Silence or NOT to Silence ???? Is that your Question?
  5. "Dual" Exhaust Question
  6. Why wheel hop is bad (vid)
  7. rolled over 72,000 miles this morning
  8. high flow air filter oil free
  9. stealing software?
  10. overdrive?
  11. every person with the K&N intake!!!!!
  12. Is an ss/sc a good car to buy??
  13. GMPP manifold install help
  14. Losing boost ? Help!!!
  15. LSD - Anyone going to make anther
  16. DC Sports Exhaust
  17. Quad pass intercooler
  18. What is needed besides clutch to change out the clutch
  19. What Should I Do First??
  20. Good engine build??
  21. pulley size
  22. TEASE :Ljavy's Parts waiting to be installed.
  23. How much power gain from Injen CAI ?
  24. Cobra Heat Exchanger vs. Aftermarket?
  25. Abnormally high highway mileage?
  26. Dyno Results
  27. Finally found my dyno sheet!
  28. pickin' her up
  29. quick question!
  30. Injector question
  31. what plugs should i run?
  32. Blinged Out CObra Heat Exchanger.
  33. Corsa Exhaust Broke!
  34. 3.0 exhaust
  35. cobalt is BACK!
  36. Dyno numbers from New Era 2.8 pulley package +
  37. some ss came with 17'' rims?
  38. Megan Racing Cat-Back Exhaust
  39. NGK V-power TR4 plugs??
  40. 2.6 Pulley Survey
  41. Radiator and A/C Condenser Questions
  42. Ingalls motor damper
  43. Looking for a good deal on a turbo kit!
  44. High Flow Cats
  45. cobra H/E brackets
  46. who has an oil press gauge on there LSJ
  47. Dual exhaust for the SS/SC??
  48. diamond pistons
  49. Intakes and MAF location
  50. Wideband Bung
  51. TAG's Latest 2.8" Pulley & 60LB Injector Tune Review!
  52. New Methanol Kits For 07'
  53. Launching
  54. Ceramic Vs. Stainless header
  55. 60lb injector harness install question
  56. Who is spitting flames??
  57. Best For $1000
  58. TAG reflash!
  59. crazy knock?
  60. Just installed my gmp header and exhaust
  61. Will this get me 300 whp?
  62. Beware Of Zex Plugs!!! *pic*
  63. Fujita....
  64. Turbo Update
  65. The LSD Explained
  66. H&R springs
  67. getting ready to install stage 2...questions...
  68. Supercharger overhaul
  69. Pics of new pulley made by Nate
  70. Without LSD, why bother?
  71. bwoody t/c bars
  72. Who's Running 2.6" Pulley On Stock Belt?
  73. idle temp keeps rising?
  74. Will the Injen CAI fit 2007 SS/SC ?
  75. Will the Injen CAI fit 2007 SS/SC ?
  76. methanol
  77. alligenment or am i f**cked
  78. Oil Catch Can?
  79. what is the best brand and place to get 60 lb injectors and harness?
  80. How Much Did The Dealer Charge You To Install Your Stage 2?
  81. gmpp vs. aftermarket
  82. Still wheel hopping
  83. Header and Downpipe
  84. turbo timers????
  85. stage 2 and in stock???
  86. Replacing halfshaft
  87. Custom Exhaust
  88. 2.5 with Cobra H/E
  89. What Happens When You Break An Axle
  90. Question on fitting rims ?
  91. *important* for any1 with a 2005 cobalt SS sc
  92. Duel Pass End Plate or CA Heat Exchanger????
  93. Best Pulley for the supercharger
  94. Anyone Running These Injectors???
  95. header leak
  96. important s/c Pulley question
  97. Unplugging a Sensor that Turns on the Fans?
  98. connecting rod bolts?? need help
  99. Scale of 1 to 10....
  100. gm stage 2 or 3?
  101. GMPP Long Tube Header !!!
  102. Help: Intake filter size for SS/SC
  103. something interesting?
  104. Knock Sensor Problem?
  105. 3.1in pulley and stock injectors= 140% idc
  106. GMPP Manifold
  107. Got HPTuned Today! Screenshots!
  108. Question about G85 Limited Slip Differential
  109. Exhaust Thread
  110. old intense stage 3 vs intense stage 4
  111. Downpipe
  112. Larger throttle body
  113. Spec 2 clutch?
  114. Dynoed the Cobalt today...im happy with the numbers
  115. Apexi SAFCII
  116. problem solved
  117. Heat Exchanger
  118. Injen Installed
  119. need answer fast
  120. i need some help
  121. Magnaflow Muffler
  122. Swapped out NGKs for Zex plugs, Pics!
  123. Stock tensioner size
  124. octane question
  125. Spark Plugs for Stage 1
  126. Any SS/SC's with PaceSetter Catback?
  127. xtc dp
  128. Pulley Puller is for Pussies!
  129. 60# injector Group Buy feeler
  130. Which motor mounts?
  131. got my intake today
  132. New Autolite XP3923's
  133. Gm Stage 2 Help Asap
  134. Will this happen???
  135. where to get an intercooler reservoir?
  136. GM's shortcomings
  137. New to the forum need opinions please
  138. Just ordered Header/Downpipe (Hahn)
  139. Hurst shifter sales?
  140. Change Final Drive to 4.45?
  141. 2.85 for the S2 hub?
  142. Spark Plugs
  143. so excited
  144. Bragging Rights?
  145. Engine Damper
  146. Maybe a stupid question...
  147. Cat delete
  148. Under car shot
  149. Vendor Help!!
  150. Stage 2 belt or zzp adj tensioner for 2.85 and smaller pulleys?
  151. ignitions?
  152. jbp cams? experiences?
  153. Pulley and Fuel Injector Education
  154. Stage 2+ More?
  155. Premium
  156. I need some input?
  157. Custom cat back
  158. Help with Plug Gap?
  159. How long does it take?
  160. PCM Question
  161. cobalt puts down 222whp-193tq
  162. How Much was Your Cobalt SS S/C?
  163. Picked up cobra H/E
  164. any one wanting to build up there car
  165. every one speed chanel
  166. every one speed chanel
  167. Ideal IAT2 Temps.
  168. tires are done already?
  169. Quick Question Before Install!
  170. I Dont Know What To Do!!!!!
  171. tab racecraft motor mount gb
  172. 15psi W/ Plugs And Airbox Mod?
  173. clutch
  174. Engine Mounts
  175. 2.8= stage 2 belt?
  176. New to ss/sc new tunning help!
  177. Transaxle Fluid
  178. Q's about GMPP CNC Ported Head(s)
  179. Heat Exchanger
  180. Fujita Intake. Good deal?
  181. part numbers on oem clutch?
  182. fried my pcm
  183. Need help finding parts!
  184. back wing
  185. what next?
  186. Just got my SS s/c
  187. max stock psi?
  188. Defining CEL 0030
  189. Safe to?
  190. is it worth getting
  191. ZZP 3.0" Gains
  192. hp #'s for full exhaust
  193. Stock Fuel Injectors
  194. Losing boost
  195. some opinions
  196. Want To Order Tonight!
  197. WHen do you need a wideband.
  198. Whats wrong with my engine??
  199. Fuel filter
  200. Cold Air Intake
  201. quick question
  202. gm or custom?????/help me plzz
  203. Pic of my new ported blower
  204. Snout Machining
  205. GM Stage 3 Part Numbers?
  206. Help with transmission fluid
  207. Injector ?! Need ansower ASAP
  208. Solid Engine Mounts
  209. Traction Bars
  210. question
  211. 17's vs 18's
  212. AFCO heat exchanger?
  213. Colder Plugs
  214. Help Me Decide Which Is The Better Route To Take
  215. "Heat" Methanol in gas?
  216. Over 400WHP Piston sleeves? Has anyone heard of that?
  217. Got my stage two kit in!
  218. CA Stage 4
  219. CA Heat Exchanger
  220. Just Ordered...
  221. Dynoed Today!!!
  222. octane fuel
  223. DP w/ High Flow Cat/ extra bung for Wide Band
  224. Stage kits
  225. where to buy pacesetter
  226. J Body performance intake
  227. pulley boys 2.8" pulley questions
  228. how much lower is the ss/sc then the ls
  229. SC silencer
  230. Who's installed a GMPP's Dual Pass Intercooler endplate?
  231. Attention Ss/sc Owners With Corsa Sport....
  232. Pulley tensioner tool
  233. stage 1 question
  234. Spark Plug question
  235. Been gone for awhile, but I know this question has probably been asked MANY times.
  236. Dryflow on Injen?
  237. Spark plugs and high flow cat
  238. Approximate Miles Per Gallon for all Stage Kits
  239. Fujita
  240. Don't Under Est. The Cobalt SS/SC
  241. which one?
  242. stg II question
  243. Quick Quick question.
  244. Fastest Cobalt Under Warrenty??
  245. ? for people running ca header
  246. Need Your Imput on 60lb injectors + 2.8 pulley
  247. stage 2 and stage 3 kits are in
  248. GMPP all the way
  249. My thoughts about water/meth injection
  250. Meth users look here..........
