- Help!!!!!
- Where to find CFM information
- Stage 2 Belt or Tensioner??
- noobish post, goofy tech related question
- About to join the Ranks of Stage 2
- Engine RunUp Meth kit on cobalt ss blades ok?
- stage 2
- Safe Boost?
- Knock...how much is too much?
- 0-60, 100 Times W/ Cars Hitting Low 13's
- people running smaller pulleys!!! look here!!
- Crate Engine Magnetic Drain Plug
- any ideas
- Full Exhaust Tubbing Sizes
- Help Needed How To Install GMPP Manifold...
- Easiest way to change oil filter???
- Specs On Stock SS/SC Injectors
- Stage 3 in GM catalogue
- Budget...
- GMPP Stage 3
- FINALLY STAGED! lol
- Injector Pulse Width
- Meth+nitrous= ok??
- crazy condinsation
- Rev Limit Increase With TAG Stage 1
- look what the FedEx fairy left under my pillow
- Why 205 hp???? when
- DC Sports Strut Bar
- Strut Bar
- Another Injen intake GB, anyone else interested???
- Check engine light
- lsj cometic headgasket available @ cobaltperformance
- Cooling Mods
- What am i missing? hows the list so far?
- tire and rim question
- Aeroforce gauge HP readings.
- SS/SC Oil Changes
- Disaster Please Help!!
- fuel inj
- Is intense a BAD TUNE??
- Cobalt-Addiction Tune?
- Safe psi??
- Motor+Drivetrain Limitations
- how big is this exhaust?
- Performance limitations
- ok soo i just did some research
- clutch?
- Who's running the lowest 1/4?
- Exaust??
- How to "Get Rid of Knock without Tuning"
- water/meth intake manifold tap?
- XTC frontmount intake???
- Are al the 2.0L supercharged engines 50-state legal?
- Stock Spark Plug Replacements
- Stock Spark Plug Gap .35
- Duals for the 2.0
- blown magnaflow
- Idler pulley Torx size?
- Which Cold air intake??
- Pulley Puller
- Custom Exhaust
- p0171
- 1/4 Mile Times List?
- Good website for new RUBBER
- What kind of exhaust is this?
- AeroForce question
- Anyone know the GMS pricing on the S/C?
- This a Safe Setup?
- Just Curious
- what's the difference...
- GM Stage 2 Cobalt SS S/C vs. RX-8 vs. 350Z
- Removal of GM Hub.
- Drag Air Bags any one have them?
- CA Header... What to do?
- Stock whp
- Clutch Help.............
- getting a ss s/c, any advice?
- Tag Stage 1
- MSD parts for our cars?
- Tire life ??
- Full Failure on the highway --- Anyone ever heard of this???
- CPS sensor question
- look what i found!!!!!!!!!!!!!!!!!
- exhaust mods?
- need major help
- psi on 76mm pulley
- Torque numbers?
- Long distance traveling in your ss s/c 2.0
- Corsa Header
- Throw on the 2.5?
- Cheepest place to buy forged 10:1 Pistons?
- Spark Plugs and Gaps! HELP!
- Fujita intake question (yes i searched!)
- question about modding
- is this right. 10psi stock
- How does the ordering process work?
- Anyone from St. Louis?
- victory_red_SS goes RWD
- The Bible-lsj-
- GM stage 2 with stage 3 pulley
- ZZP or Cobalt Addiction?
- A question Having to do with Twin Charging
- Header Back Exhaust Setup
- Pounds of Boost!!
- Wheel Tourqe?
- Allshot is Back........................ With New Mods
- Need some Help!!!!
- header primary sizes?
- Tag Racecraft 2.5in Header Back Exhaust System
- Eaton TVS Supercharger Question
- WHAT Clutch?
- Anyone with GM Stage 2?
- What did you pay for the 2.0 S/C?
- Need A New Clutch
- what is the best guage that goes with a wideband and a interceptor with chrome lip?
- megan vs gmpp cat back exhaust opinioin
- installing exhaust question
- CA stage 3 question
- COMETIC HEAD GASKET for SS/SC
- Replacing radiator, options?
- 3 guage pod pillar guage setup???
- Project 12's
- Buyer Help For the Cobalt SS S/C
- CA header and XTC DP with high flow cat
- megan racing catback video
- just installed hurst shifter, quick question
- How much power do I have?
- stock lsj internals
- rear bow tie
- What kind of spark plugs do i need.
- Wierd Supercharger Noise?
- code p2228?
- Custom Made Reservoir (GM Option B) Cooling System!
- 2.6" pulley install went disasterous!!
- stage 2 first then 65lbs injectors?
- I need help ASAP!!!
- supporting mods or stage kit
- anyone with meth injection ..
- Matching guages for the ss/sc???
- Help with stage 3
- Got my custom exhaust
- Pcm Location
- To buy an AEM intake...
- blew the end off my dp
- Intense stage vs. GM stage
- Cobra HE
- Anyone have this header?
- Stage 2 is now installed
- do any vendors have the pacesetter header in stock?
- Heat Exchange/Dual Pass or Meth?
- intense 2.5 with tune or CA 2.5 with tune
- Insane blower porting = SUCCESS!!!
- Up-shift Light
- Another one of those "how much hp?" questions..
- Difference with 2.6" pulley compared to a 2.8"?
- What can you do to modify our superchargers?
- I got a delivery
- Need help quick.. Corsa vs. GMPP
- mm... what is going on..?
- Pics of my o2 / car fixed!
- SS/SC Performance in Snow
- Cams?
- Stage 2 install
- New CAI help
- got the he ready to install.
- intense stage 4?
- oil catch can who has one?
- Last ? B4 Purchase
- Guys some advice
- GM Stage II self install???
- what would it take to hit 12s
- Header/Dp question
- power difference between gm stage 1 and 2
- Intense Downpipe
- Stock Air Box
- HPTuners tune pricing
- GMPP Stage I
- Wrong oil?
- Blower bearings = fuct
- Ark Catback Exhaust
- Stock intercooler hp limits
- My exhaust cutout video!!
- who has twincharging done??
- Injen injen numba 9....
- Pulley Belt????????
- video=twincharged cobalt
- Which exhaust?
- Error Codes
- GM Stage 2 Installation Questions...
- 1 More Step Done!
- Just installed the Hurst...
- What do you guys use to clean your MAF
- need axles
- 2.6 pulley
- Few questions
- air box mod question
- 2.8 Pulley Finally Installed!!!!!!!
- Jut got my cutout in!!
- New Brakes?
- Megan racing Cat-back system
- Twinchaged!!!!!!!!!!
- Recommended Exhaust Sizing
- quick question
- got a new downpipe
- boost bypass valve
- What to buy with $600- yay taxes
- Megan Racing?
- quick question
- Taking A Step Back - 2.8 - 3.0 pulley
- GM Stage 2, Will you be my Valentine???
- Does Anybody Have A Video Of...
- why 60lb injectors???
- whats next
- GM stage 3
- Dyno Tuned
- heat exchangers??
- Exhaust Ticket
- Electric Cut Outs
- Just orderd stage 2
- 2.0SS vs SRT
- need help plz fast
- GMPP bypass plate or GMPP manifold
- A Warranty Question
- Stage Kits From C-A
- cams???
- Dyno as a diagnostic tool?
- stupid question
- lbs of boost - ho?
- Need some help
- Factory XM Tuner Location
- just dropped her off
- low compression pistons??
- Lumpy acceleration
- Car Shimmies....
- Pictures of My Spark Plugs...
- test pipe?
- Stage 2 & 2.8 PLUS 50 Shot????
- Help! GMPP Stage 3
- Max boost on supercharger?? and smallest pulley size??
- gmpp exhaust with stock exhaust tip
- Any GM techs with Stage 2 experience..
- noisy INGALLs TD
- Everyone with a CAI, check your filters, I'm glad I did.
- Settings
- Zex Spark Plugs
- Stage 2 Installed!
- I want to go faster...
- Tag stage 3, havin trouble!
- a little help please
