- HELP MAP/MAF code.
- Adjustable Tensioner
- what do i need?
- Did you guy's know that the LSJ has.....
- Common problems?
- exhaust question
- OBD II Catalytic Converter?
- how much HP
- How does this set-up look?
- dual pass install
- next mod, what you think??
- Please Help Asap!!!
- 60# injectors??
- Easiest/Cheapest way of getting to 350 SAFE HP?
- pricing for hahns gt35r turbo setup thread????
- need some help
- stage 3
- Bassani Exhaust?
- vibrant d/p
- engine sputter at 6000
- How much black smoke is "normal" with stage 2?
- Starting A Parts And Forums Website
- Frustrating Backorder
- Camshaft Help
- fuel milage increase after injen cai???
- 0-60???
- at how many km's would u change your stock spark plugs?
- Help
- so i now have blowby on one of my pistons
- Stock vs. Catback
- megan or tsudo?
- Who wants to diagnose my problem...
- Dealer Re-Fuel trimming
- Running rich
- Gauges to get
- Vibrant header/dp and magnaflow cat back video!
- 2.7 on CA Stage 3??
- My Coolant Cap Blew off
- Dual Pass Gasket Question
- So I come from driving a neon.....
- Need a third gauge... opinions.
- stage installation opinions
- fast ticking from exhaust?
- Air Box Mod...Cel as usual....sort of
- Help with next mods!
- Option B kit part number?
- HTV 1320 with 2.75"
- Custom exhaust
- S/C Oil
- Exhaust Leak?
- fuel injectors
- 2.85 setup question?
- installing nates 2.9 pulley
- New exhaust, thrown code?
- Help.........
- Laminova Core Length?
- Suggested Upgrades?
- Jbp Or Zzp Header???
- knock?
- 60 lb's
- Help!!!!
- heat exchanger wars
- anyone with ksport springs?
- exhaust question
- For those with the CXRacing Heat Exhanger
- 2.9 warranty issues...
- Might sound stupid but just curious....
- Tuning for better gas mileage
- Wideband
- just picked up older td, how to adjust?
- Stage Question
- Exhaust leak help me?!!
- Just bought a Cobalt SS
- $500 to spend what should i get
- cx racing h/e installed with pics
- SC Rebuild kit
- Funny question
- Help
- AIS Kit - Boost Line
- WTF!!! Just bought this car, got Stage 2 installed thurs, FAILED EMISSIONS TODAY.
- meth kit: streetable?
- can u hook up wideband to logs with hp tuers
- A/F question
- coolant refill mix?
- front mount/heat exchanger install!!
- Stock belt
- Interceptor trouble
- Just got stage 2 installed.........love the speed, but; car is JERKY at low rpms..???
- cobra h/e
- 6.5 quarts for first oil change?
- Vibrant Catback Install Question
- CX Racing heat exchanger coming in today
- Leaky Meth
- pulley question
- about ss/sc resonator
- Odd dyno problem
- may be a dumb question
- Boost Problem?
- Woo Hoo, Got my new cx Racing h/e today, and installed it but.....
- Want to get 500 hp . . .
- Tsudo Exhaust
- Injector question
- Need Help Installing 2.9 Pulley
- Changing Pulley
- o2 sensor
- steering wheel shaking?
- Intake installation questions.
- Which wire can be tapped for dyno
- Son Of A B****!!!!!!
- 100oct. Low lead??
- Buying stage 2 Question
- biggest injectors tunable with hp tuners??
- downpipe vs catback size
- Does anybody know the service intervals
- PLease HELP!!!
- Oil Leak... Ideas?
- exhaust suggestions?
- In need of brake options?
- Exhaust Set Up - - - Need help/pointers
- Buying a stage 4 and exhaust. Will it all bolt in?
- need advice on getting CKV learn done right
- check engine light came on
- Clutch problem
- Boost Bypass???
- Tuning
- hope it don't blow up.. misfire.. need help!!
- need belt
- K&N or AEM Drop-In?
- Motor in my DD blew today....
- Car is running like crap, need help.
- coolant temp to high?
- Cold Air Intake
- Cold Air Intake Systems
- Vibrant 3" exhaust
- Looking For New Exhaust Suggestions
- Cams
- Is anyone selling a megan cat-back or know where they have them in stock at????
- stage kit help
- thowing a cel with airbox mod
- quick turbo question for the ss/sc to turbo
- Cold Weather cutting POWER
- need plumbing schematic for CX racing H/E.
- Serious Ignition Problem!!
- Need Tensioner Pulley
- Cobra H/E ?'s
- Car is running again! (Big pic warning)
- Which TB is better/larger diameter?
- 2.8 Pulley Makes Me Sputter!!
- stage 2 cel
- 2.0 TurboSystems from Hahn RaceCraft: Voice your choice!
- ZZP Header installed and now it idles different
- 05 ss/sc question
- New LSJ create motor
- Is it normal for front wheels to tip in
- Wrong gas, help please
- Cxr aftercooler Questions
- Raptor shift light
- Shift Light
- ?'s about TVS
- need some numbers
- NEW Twin Screw Dyno Result
- Methanol
- Intake Problem and CEL?????
- Melted Piston Pictures
- Upgraded Heat Exchanger question
- Exhaust question
- Injectors with harness. Where to buy 60s..
- megan cat-back ?????
- some more fun stuff.
- IAT2 temps
- SPL header with spl dual exaust
- Need hose size ASAP
- studs broke off in bottom of stock header
- exhaust question
- Hahn Header Install Problem *Pics*
- grinding noise started abruptly today and isn't going away..?
- header/dp sound question
- Setting Timing?
- Torque specs
- Help Please!!!
- so i'm bored...
- kinda pissed at dyno results
- lean bank code anyone?
- So honestly, what do you think: Stage 2 first or header/DP ???
- Is this a good wideband? PLX
- Parts Needed For a Return Style Fuel System
- ok im trying to install my narrowband
- Resonated tip?
- head gasket Question
- Help Finding Vibrant Exhaust
- Front mount heat exchanger?
- Intense stage 3 is impressive!
- I think i did something wrong
- who has the vibrant headers/downpipe
- Gauging Intrest: Cobalt SS ice box
- vibrant header/dp or zzp header/dp
- Just got new stuff in,Need Help w/aeorforce
- advice neeeded for install
- Safe with 2.8?
- 2.0 fuel problem?
- How long before a cleaning???
- Need Info Asap!!!
- Vibrant Header/DP
- Ingalls Torque Dampner washers?
- Vibrant Header & Downpipe installed!!
- should i get headers/dp?
- Need Opinions
- gmpp or 2.0 stocker how can you tell??
- JBP crankshaft pulley
- Looking to build top end of my cobalt need help!
- zzp or intense
- hp gains , range?
- GMPP Ehaust question
- Does this look right?
- Griffin Rad
- Stage II: Who in Va.
- head pressure
- Smaller Pulley??
- return system fuel rail fitting
- cobra h/e
- Meth/HE? or Dual Pass/Option B/HE
- Aeroforce gague question
- hp tuners???
- What do you like/dislike about the ZZP 3" Downpipe?
- Cooling Mods
- custom catch can
- Putting together motor... need help!
- CEL on dryflow!!
- Pulley Comparisons: GM vs Others
- Cobalt SS vs Neon SRT4? Perfromance and mod friendly
- Help: Megan Exhaust Install.
- Intense Stage 3 Will be here tomorrow.
- horrid problems after warranty work
- Problem With New O2 Sensor 1 Bank 1 Heater Circuit
- just bought snow performance!
- Ok guys and Gals, I need help choosing a Heat Exchanger!!
- Warranty info please!!!!
- JBP Vortex Header?
- Cobra Heat Exchanger
- Tuning : What Gains?
- Help Fast
- Smoke from my dash : (
- week one with cams
- What am i missing?
- TurboCharger in line with SC
- Guage installation??
- Autometer Boost Gauge??
- Need help understanding the stage 3 kit
- Nitrous spray bar???
- post your aftermarket h/e!
