PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Having trouble, INjector harness wont undo
  2. cheapest place to get pacesetter header?
  3. Injector install, Plugs??
  4. Intense Stg.3 + AEM CAI
  5. wideband wiring.
  6. Issue seems to be fixed...
  7. intense stg3 ?'s
  8. dealer install times?
  9. MAF Sensor
  10. GM Stage 1 or CAI?
  11. RIPP Mods Turbo kit interest thread
  12. Build my car
  13. Difference Between Pacesetter 2.2 and 2.0
  14. Major Problem!!!
  15. Those Who've Hit "Limp Mode," HELP!
  16. megan exhaust clip?
  17. Exhaust vs SC Upgrade??
  18. Tunning the information display?
  19. Resonator or no resonator
  20. Blower making funny noise under throttle
  21. new CAI for $<90 shipped
  22. EVAP purge valve?
  23. HP Tuners
  24. How much power with 2.0
  25. Best Brake pad
  26. Need Help With Exhaust
  27. did i just mess up?!?
  28. How to install the Injen CAI for 2.0 SS/SC without any rubbing!
  29. Bolt-On Guru's Wanted!
  30. Maf-t
  31. what a waste for a wastegate
  32. S2 Mpg Winter
  33. Make Your Own Poly Mounts
  34. Anyone with stage 2, please help
  35. just ordered catless DP from CA
  36. Bypass my boost surge problem..
  37. heat exchanger vs dual pass kit
  38. zzp pulley system
  39. The Royale purple XPR
  40. Headlight queston
  41. psi?
  42. 2.8 pulley
  43. help please
  44. Detonation with Stage 2 and 2.9
  45. Banks Performance for SS/SC
  46. Player 1 comes to life
  47. Has anyone upgraded their fuel system yet?
  48. The Ebay Intake...
  49. Tach Adapter for LSJ
  50. auto lite spark plugs
  51. quick header install ?
  52. 60lb...MPG?
  53. castrol syntec 5w50 vs mobil 1
  54. Removal of PCM
  55. GMPP exhaust tip specs
  56. Battery relocation
  57. I'm stuck...=(
  58. Shifter Bushings
  59. Who has this mod list?
  60. cutout
  61. Why no Chip for sssc?
  62. Just Installed
  63. AEM Filter Mod
  64. Aeroforce Interceptor Group Buy!
  65. head gasket
  66. Wideband Guage
  67. So I ordered my exhaust cutout.
  68. HP Tuners Limit Boost In Second?
  69. Will These Headlight Bulbs Fit In My 2007 Cobalt SS..
  70. got some new toys...
  71. best header for stock down pipe
  72. large + fuel trims
  73. INSTALLED!! MR exhaust
  74. CAN-bus
  75. Wich is the best CAI?
  76. dyno slips? don't make sence to me
  77. Need Help
  78. Help with downpipe
  79. New Installations!
  80. Hood/Intake Mod
  81. 2 Pass Intercooler End Plate Question...
  82. Engine mounts and Dampner
  83. CTI Header/DP
  84. Is 250whp possible with this?
  85. ...and the fun/wait begins
  86. raced a bmw 325i twin turbo
  87. 110 octane???
  88. Ingalls ETD adjustment
  89. torque braces
  90. Is this for real???
  91. Traction Bars...
  92. Adjusting for Torco Race Concentrate
  93. Intake cel's?
  94. Voided my Warranty!?!?!
  95. victory_red_SS' project, mini update.
  96. Injector Impedence
  97. Pulley sizes, corresponding max PSI, and power?
  98. Wow
  99. Flow Matched Vs NON and Wiring Harness
  100. More findanza questions
  101. gettin ready to make and order?
  102. Dual Pass Intercooler Plate Kit
  103. Remote Start Wiring
  104. Is there a dual exhaust for the Cobalt?
  105. No Warrenty Redline/ssSC...what to do hypothetically
  106. remote engine starter?
  107. Code Question
  108. Spark Plugs
  109. tensioner pulley.
  110. New PCM VS my car
  111. Dealership rip off for stage 2 install?
  112. E-Bay intake?
  113. Serious Issues!!!!
  114. 2005 Cobalt SS 2.0L Stalls Cold
  115. 2005 Cobalt SS 2.0L Stalls Cold
  116. knock? someone please explain
  117. 12's
  118. Need input please
  119. Has Anyone Swapped Out the Supercharger Coupler
  120. Dual Pass End Plate
  121. Intake...
  122. pulley????
  123. So I E-Mailed CORSA About a Possible 3" Cat-Back.....
  124. Fidanze Flywheel
  125. SS Holeshots SUCK!
  126. stg3 for $600
  127. exhaust questions already searched
  128. what do you think of GM stage 2
  129. What did you pay for the staged kits?
  130. GM Stage 3 Pulley
  131. Have 1k what to buy?
  132. CryO2?
  133. Help! Dealership trying to screw me!
  134. ca stg 3?
  135. Magnaflow Cat
  136. Engine build questions...
  137. Fujita F5 CAI question? Help?
  138. Racing oil catch tank
  139. 60lbs inj. + 2.79 pulley + GMS2 ONLY!!
  140. Is This Possible?
  141. Touring vs. Sport (Exhaust)
  142. Intake ?'s
  143. Quick 2.9" Pulley Question
  144. GMPP Honed Exhaust manifold
  145. injectors?
  146. TAG clutch or meth injection???
  147. fuel pressure regulator or safc 2
  148. wideband
  149. these should work!!!
  150. Best Bang for the buck?
  151. Progress sway bar install...
  152. Camshaft questions/ideas
  153. 3" or 2.5" exhaust?
  154. Install on engine dampner
  155. New To the Car Mod Scene
  156. Clutch and Flywheel...
  157. areoforce only reading 87 % throttle.
  158. GMPP Exhaust Anyone?
  159. 100 octane unleaded
  160. Just made my much anticipated purchase!
  161. 76 mm pulley safe??
  162. Exhaust compatibility
  163. brake rotor issues anyone?
  164. Rear Sway Bar Question
  165. AFR question
  166. header/DP/exhaust question
  167. new record(track)
  168. Calling all pacesetter header user's
  169. Anyone Have Any Problems with Gasket!!
  170. Would GM do this for me?
  171. Tire Rotation q
  172. GMPP help
  173. My review, megan racing exhaust
  174. How much did u guys pay to get our full exhaust installed?
  175. FedEx guy better than SANTA??
  176. Stage 2 Prices??
  177. Removing Stage 2 Pulley
  178. Need help with new mods.
  179. Non Slip Pulley
  180. another hp ?
  181. Gm Stage 3 pulley
  182. SC Belt slipping?
  183. One more GMPP exhaust question
  184. Anybody have a problem w/their Tog header?
  185. New intake gasket for popping dipstick.
  186. AEM UEGO Gauge Surrounds!
  187. CA stage 1 vs Intense stage 1
  188. how much hp ??
  189. Best Header Out?
  190. Another Wideband Thread, Opinions Wanted
  191. Cobalt-Addiction.com Stage 6
  192. DC Sports Header
  193. Advance Auto Parts still doing synthetic Penzoil sale buy one get one free
  194. Exhaust Cutout
  195. HIGHEST MILEAGE on a SS/SC
  196. Need Some Real Help with Exhaust!!
  197. Quick Pacesetter header question
  198. Running a 2.8" pulley with the Stage 2 injectors; OK or dangerous?
  199. Wheel hop damage?
  200. exhaust help
  201. GM Stage 3
  202. need some serious advice on twincharge kit
  203. Upgraded radiator??
  204. True Header
  205. exhaust ?
  206. Stage 3 with nitrous dyno
  207. GMPP Touring Cat-Back and Warranty
  208. Anyone have JBP Vortex header yet?
  209. How to install the GMPP exhaust manifold
  210. How come there is no How to on the Stage 3 Yet!!!
  211. GM Stage 3
  212. Can you ss/sc owners give me some advice??
  213. Which Downpipe To Pick?!
  214. aeroforce interceptor question!
  215. Making my own exhaust!
  216. give me some advice on some parts...
  217. gm stg3?
  218. Reflash PCM on 2006 SS/SC
  219. What would you do?
  220. Fujita Cai Help
  221. Stage 2 and a 2.8 Pulley
  222. Stage 2 w/60s
  223. Heat Exchangers
  224. Need Install Time For Stage 3 From GM
  225. 2.80 pully
  226. Is it honestly worth it????
  227. Intense Stage 4-Switch to GM stage2...
  228. Couple of quick questions.
  229. Help: Need Info
  230. Maf Translator needed when??
  231. Engine / Exhaust, Statement / Question
  232. Fastest most stable cobalt ss/sc
  233. people with the eibach sportline lowering springs???
  234. Stage 2 pulley
  235. Reduce IAT's with DEI CryO2 Now on sale at SMG
  236. Great Idea or a brain fart?
  237. possible leak?
  238. Stage kit manuels and 300HP build manuels
  239. Custom Exhaust
  240. acceleration problem
  241. cams??
  242. torque specs??
  243. Car Won't Start, Stage II install fail?
  244. New Head Gasket for 2.0
  245. I have an odd grouping of codes on my SS/SC ...need help
  246. Gm F**kin Sucks!
  247. Stage 2 For Sale In Detroit, MI
  248. Questions about injectors, spark plugs, and tuning
  249. Questions about injectors, spark plugs, and tuning
  250. Exhaust Pipes ( Houston )
