PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. couple questions about my header
  2. Need some advice going on long trip
  3. Engine rebuild question...
  4. Tune in Illinois?
  5. Turbo timer on lsj?
  6. Injectors issue
  7. GMS3 100 octane and 94 Sunoco
  8. noob on installing stage kit
  9. Sn!perwolf's Hahn Build... 56k No No!
  10. Cobalt Injectors W/O A Tune
  11. Stage 2 Belt
  12. A demonstration of our gearing
  13. ZZP header/dp exhaust sound?
  14. Solution To Changing Alternator On Turbo Lsj's!!!!!!
  15. Any Ideas?!
  16. gas 91 or 93?
  17. Aftermarket intake = warmer air charge?
  18. has anyone ever used a saleen h/e on there car??
  19. My thoughts on the cti catback
  20. What do i choose?
  21. need help installing clutch
  22. front mount he
  23. Airbox mod too lean?!?
  24. Spark plug cover
  25. Got Tuned Today
  26. Heat Exchanger
  27. looking for the guy with a red ss with purple wheels
  28. 60lb injector?
  29. harrop SC??
  30. dyno n tune
  31. I need brakes
  32. tq specs
  33. Got the tvs installed today.
  34. Blown Piston Ring and a suprise...56k=death
  35. diamond spirlox
  36. blown lsj
  37. clutch/mods
  38. Multipurpose Gauge
  39. Loose Shifter
  40. noob question on a stage 1
  41. Cooling
  42. common reduced engine power solved
  43. Hahn Exhaust & O2 bung
  44. 07 problem
  45. Meth Nozzle thread size
  46. meth problems...
  47. Cam Shaft Sensor
  48. Engine Power reduced
  49. wrecked car need help
  50. ott stage 1 kit
  51. Quick question
  52. Best header & DP options?
  53. future mods, wanna know if i'm correct!
  54. Have some CELs?
  55. Vibrant header on stock exhaust
  56. need help asap
  57. p0315 help
  58. Injen intake problem
  59. i broke this...
  60. Meth nozzle help
  61. CTI vs OTTP vs Hahn vs ZZP 3" Cat-back systems
  62. How much will a tune do for me?
  63. Running with race gas suggested changes?
  64. Harrop
  65. Memorial Day weekend
  66. walbro 255 install
  67. HELP... stupid me
  68. hurst STS install problem
  69. I/C Pump Limits
  70. Anyone know where...
  71. trifecta tune good or bad
  72. Dipstick
  73. need opinions on a/f gauge
  74. Same Code Every week!!!! Make It Stop!!!!
  75. 2.9 safe with gms2?
  76. gmr exhaust ported head
  77. pics of TB Cleaning?
  78. whats wrong???
  79. help please, which one is for my car?
  80. Is it possible for a tune to "go bad"?
  81. OTTP Stage 2 Rotated Tranny Monts - Review
  82. harrop tvs
  83. harrop tvs
  84. Header Question
  85. O2 Sensors
  86. Plug Gap????
  87. exhaust noise/ rattle
  88. vibrant 4-2-1 header + dp problem
  89. any one w/ cammed lsj??
  90. strange idle problem?
  91. exhaust help(resonator)
  92. LSJ upgrades in HOT ROD magazine
  93. Exhaust swap
  94. Got my car tuned today!
  95. What is wrong with my car?
  96. Catless Dp
  97. feel vibration after install Ingalls Stiffy
  98. Got my LS4 Tb Back today
  99. ottp heat exchanger
  100. a few questions
  101. ATT: people running the Rebel Kit
  102. brake swap... plz help...
  103. Pulley size change question
  104. How to swap pulleys?
  105. RPM linger
  106. 2009 ss/tc bov
  107. driving Boom Boom Boom Stall
  108. I'm only 1.5 car ahead of my friend's one???
  109. where can I get 42.5lb injectors for the lowest price
  110. spark plug gap?
  111. Valvetrain Noise.
  112. need ideas tranny losing gears
  113. how
  114. Possible boost reduction
  115. Anybody know.....?
  116. spark plug gap??
  117. Is this a safe daily driver set-up?
  118. 2 step colder autolites
  119. Need Tuning Help!!
  120. ported supercharger housing worth it??
  121. Codes from OTTP Rotated mounts?
  122. help please
  123. Idleing....
  124. What should my next mod be?
  125. duel exhaust set up?
  126. stage 2 help.. new.. fuel info needed..
  127. 3" exhaust flange
  128. Looking for super quiet 3 inch muffler
  129. ss/sc... 1 inch exhaust??
  130. Senosor that is not hooked up? 07 Cobalt ss
  131. help
  132. Looking for LSJ rods weight...
  133. pulley
  134. pulley
  135. pulley
  136. pulley
  137. pulley
  138. pulley
  139. meth vs heat exchanger
  140. is this right?
  141. Cheap wideband
  142. What spark plugs to get
  143. maf question side of ROAD!!!
  144. Already having a prob with the Lsj
  145. Downpipe price wtf?
  146. stage 2 question.
  147. extreme noob question
  148. LSJ MAF Question (LSJ Turbo guys and tuning guys)
  149. Intake mod FTW
  150. muffler help
  151. How to remove GM security bolts?
  152. mandrel bend
  153. 2.0 engine swap in an ls?
  154. Stage 2 AFR
  155. Help installing a new PCM
  156. Back to Stock Tuning...
  157. IF you have a flowmaster please give your opinion
  158. interceptor guage
  159. LSJ Motor DESTROYED - PICS
  160. Help please Ported sc & tb on stock tune SAFE??
  161. going back to stock downpipe
  162. LSJ 2.0 in new Hot Rod Magazine
  163. Questions about my new SS
  164. Stock boost gauge ?
  165. air fuel ratio change. need suggestions
  166. Ls4
  167. Year round dd, stainless dp worth it over high temp?
  168. diffrence between 42# and 60# injectors
  169. Connecting Wideband via AC Pressure Switch for HPT
  170. Ported throttle body??
  171. What do you think about this ?
  172. meth injection problem
  173. megan racing exhaust
  174. Power and torque
  175. DIY - Head Porting
  176. 06 SS/SC + Dual Interceptors + IAT2 not reading = Question...
  177. Got my new car!
  178. Methynol question
  179. Bypass thingy...
  180. goodyear replacement engines
  181. WOT box help
  182. New Tranny!!!
  183. zzp stage 2 kit
  184. Need help..Vibrant Filter cleaning question
  185. Those who got the stage 1 OTT rotated mounts...
  186. normal temp?
  187. CEL Questions
  188. connecting rod direction
  189. 04 LSJ Need help car goes into limp code
  190. My Meth Tank
  191. wideband question.!
  192. HP tuners question
  193. gauge pillar fuses?
  194. airbox mod/k&n cone...
  195. Header studs
  196. IAT2's after H/E Install
  197. Warning!!! Dont do this..
  198. Brembos
  199. problem with car :(
  200. Engine disabled
  201. let me know if this sounds ok to you
  202. bolt fell into manifold.
  203. cheap wideband?
  204. Problem at high rpms. Sputter?
  205. F35 or not?
  206. Magnaflow Cat Back cheap!!
  207. need help finding post?
  208. Replacing the Timing Chain
  209. rods
  210. Do you know what would be the problem
  211. ..would i get walked by a ss/tc
  212. Gas. wtf.
  213. Tuner Info
  214. Gettin a Gm stage 2 soon got some ?'s
  215. Another supercharger?
  216. im so lost.
  217. wires
  218. heater hose
  219. pulstar plugs.
  220. NEED HELP ASAP Wire Harness Question
  221. is this a good setup??
  222. Broken sensor
  223. Killer chiller??
  224. gas mileage solution
  225. stripped mani. bolt
  226. need some help yall!
  227. Need Help!
  228. Radiator Leak
  229. how do you install a AEM wideband?
  230. fuel pump assembly filter socks
  231. spark plugs
  232. HELP!! Need torque specs for OTTP Stage 2 rotated mounts and steering rack spacers
  233. pluged cat?
  234. What to do?
  235. another how much power thread
  236. trifecta tuning
  237. Timing
  238. Timing
  239. Boost flutters and isnt right?
  240. Question about Downpipe with Cat
  241. SS/SC guru help needed!
  242. need a tune near blacksburg va
  243. had coolant flushed.
  244. any buy a blacks ss at cleo bay honda texas
  245. Damn Supercharger. Help Meee
  246. Having some problems...
  247. Buy new engine or build it?
  248. help
  249. what kinda power??
  250. Who here has switched to Royal Purple
