- hesitation problem
- 250whp
- stupid question
- Parts list before i start my build
- Wanting to run bigger injectors
- a/c system
- Killer Chiller!!!
- Headers.
- GM stage 3/nitrous and water injection?
- Injector Firing???
- Need a tuner's advice on exhaust
- Airbox Mod Vs. Injen CAI
- Tip for anyone running or considering a TVS
- return fuel system
- meth Q
- Meth Help
- SMS Intake Manifold
- EFI live.... anyone here using it?
- Finally decided on a mod route...
- Installed Header..now a problem
- ss sc potential
- Grinding reverse
- What You Want.
- Engine Shutdown Please Help!!!
- Injector Connector???
- What next
- Exhaust Problem: Any thoughts?
- wideband question with p0017
- Check out the Ebay post!!!
- Meth w/ stock exhaust system
- ZZP + opt b
- Rotor Direction?
- ZZP Header bult up to stock exhaust
- Thrown Rod - What's needed to Fix?
- F---kin Pissed!!!!
- Which Header for Stock Downpipe, Stage 2
- HP tners and...
- Rebel Turbo Kit VID
- Upgraded H/E needed with H2O/Meth??
- 2007 SS/SC Stock Boost
- C/X racing h/e installed w/pics
- Tranny Mounts??
- whisper or slp resonator
- Stage 2 with stage 3 pulley
- Will vibrant 3 inch be ok?
- Cant Find How To
- Just Made a Few Orders, Check it Out
- 42s injectors
- Bolt on High flow Cat downpipe
- smallest pulley stock snout??
- Best Sound
- Need so help!
- cold air intake advice fast!!!
- shiftlight/stage 3 and being canadian
- meth instal HELP
- stock timing advance
- power steering?
- srt 4 vs cobalt ss
- SLP loudmouth exhaust
- Vibrant header question
- more spark plug crap
- 06 stage 2 supercharged owners!!!
- Oil Feed Fitting Location
- 60's worth it??
- Fitment w/TB Spacer & CAI??
- Option B
- H/E in line with or in place of stock H/E
- no Aeroforce Interceptor shift light
- pacesetter monza exhaust
- Which kit?
- lc-1 issues
- Wideband question
- HP prediction
- LSJ WOT Box?
- AIS Meth install help
- weekend fun
- Cutout
- Spark plugs
- need help
- just came today!
- Resonator.
- stupid injector question
- Controlling timing
- Torque Damener
- Questions about coolant temps
- Ss Turbo Conversion Progress Update
- Injectors
- GM Stage 3 PCM
- will a dry flow cold air intake cause hydro lock?
- changing ic pump
- Best Meth injection kit?
- does Pacesetter header alter exhaust tone?
- still eating intercooler fluid
- IC pump
- My new ss/sc and heating up
- Option B.
- Someone Please Help Asap W/methanol
- Shimming the camlifter followers, why not?
- My parts arived tody
- performance tuners
- has anyone heard about this exhaust?
- Header/Exhaust
- Running a 2.5" Pulley
- Looking for someone with HP Tuners
- Header/DP or just go for it?
- Gauges ? Which ones ?
- another question
- supercharger silencer holes
- Injen Intake
- Timing chain noise. have you had this problem??
- things i should do
- Supercharger noise...
- newb question
- how to bleed
- Dual Pass + Opt B
- So.. LSJ owners.. switching to 87 octane?
- AEM wideband Help
- what to buy first: zzp dual pass endplate OR cxr heat exchanger?
- GMPP Header Wrapped?
- Wrapped Intake...
- removing headlight for drag racing?
- megan cat back
- need help ASAP please
- clean TB
- 2 birds with one stone. Aeroforce?
- car runing like shit
- A simple ? that i dont know!!
- throttle body help
- Best Performance Mod Ever!!!! Better Than Fi!!
- Dual pass part #
- launching
- what dealer in illinois for stage 2?
- MAF Sensor Reset?
- IAT Sensor #2
- porting my s/c RIGHT NOW AS WE SPEAK
- H/E off ZR1?
- Cobalt Part List
- cx racing (small one) clean install w (pics)
- corsa faling apart
- Best buy on a H/E?
- How to: Crank shaft sensor???
- question about plugs
- TRADE hahn 3inch for vibrant 3inch
- coil ?
- how do i get boost gauge out
- What Plug Gap
- cars breaking up top
- Running Rich.... 2.8 pulley+meth > 10.9 @WOT
- Boost gauge acting up!
- full boost in 1st gear
- Pulley.
- boost gauge stopped working.
- pulley puller. zzp and nates
- HP Tuners?
- Megan Racing Exhaust owners please come inside!!
- Just installed my AFR gauge...
- SS/SC Manual trans oil ?
- which tire size is smaller
- w00t performance!
- Spark plug gap for 2.85" pulley.
- Got Some Goodies
- Where to buy injectors/pulley?
- Darn Downpipe..
- Meth Install Help
- What can I do to my soon to be cobalt?
- anybody....
- Engine code problems need help!!!!!
- Mobil 1 Vs Royal Purple (tranny)
- Heat Exchanger Question...again.
- Valvetrain
- What Pulley?
- Confused Meth...
- Moisture in exhaust?
- best spark plug to use
- just as fast as a turbo
- stock iat 2
- Need advice
- Car is running like crap!!!
- Do They?
- My cat falling apart???
- Safe to drive?
- Question..
- HE Brackets
- Who would be intrested in...
- Cold Start Problem with my SS/SC + Weird Noise
- Cant stop pulley from spinning
- Will computer tell me i'm lean?
- Pick my mod
- taking off the s/c
- what is all under warranty.
- Clutch Slipping
- question about a clutch
- 07 ss/sc help
- just purchased
- Cant get the CEL OFF! P0017
- Throw out Bearing for LSJ Transmission SKU
- universal turbo kit only $500
- First dyno 266whp
- psi on 3.0 pulley
- wheel
- My order!
- lossing coolant but no leak
- LSJ Potential..
- ZZP or GM
- Cobra Heat Exhanger
- CA H/E Help
- header/downpipe???
- full synthetic oils are they the same?
- Heat Exchanger Help
- Question about Injectors
- I need tech Help....
- New toys on the way
- Aeroforce list
- heat exchangers
- retune after s/c port?
- Dumb Question...
- Downpipe is on
- AIS Meth injection kit install complete but Engine Power Recuded problems
- To ZZP Painted Header/DP owners from first GB
- Intake
- instaling DOWNPIPE
- Crazy Plan Possible?
- Couple perfomance part questions...
- ignition upgrades?
- Which Meth injection?
- knock retard help????
- Cooling Overkill
- anyone close to buford..... H/E
- should i or what?
- just ordered!!!
- Heat Exchanger.
- Dyno'd my car today...
- Oil Catch Can?
- Fuel Pressure Question.
- Flywheel hurting me?
- i want opinions.
- why are cobalt addictions stage kits so cheap?
- Intercooler Help
- ok. so i dont get it. kind of
- Magnaflow Exhaust
- High Performance LSJ Cams for Sale
- Turbo
- HPT in Denver/Ephrata Area
- Innovate wideband lc-1
- Safe to use a 2.7 pulley without cooling mods?
- Timing Chain Tensioner???
- who has dc exhaust?
- Throttle Percentage
- Possibly going turbo?
- time for a new block
