- Eed help Loki g for fuse
- Pop goes the weasel ;(
- launch control device for manual trans
- Will my setup be too loud?
- check this out
- Tales of an M62
- Fuel Pressure issue at WOT
- Car will not start!
- Whine Noise
- Bolt Help
- Car surges then shuts off
- What maintenance should I have done by 60k miles?
- Burnt Valve?
- Going catless
- YOUR current LSJ setup
- ZZP Midlength Header
- over heating
- dumb sensor question LSJ
- Anyone know?
- need help! lsj
- TVS owners with phenolic spacers.
- header leaking need help
- mods
- who would be interested in a semi- built shortblock?
- Does anyone have the stock cobalt ss 2.0 lsj running sensor data?
- Coolant temp.
- Tensioner for belt
- LS4 ETC Area Scaler 3688
- Coolant Temp To Low?
- Installed my exhaust!
- 05 cobalt ss sc misfire at operating temp, tried everything!!
- Swap 07 head on 06 2.2 ecotec
- Sad Face
- Play in the shifter
- LSJ-T issues NEED HELP!!!
- Stock Vs GMPP Upgraded Vs SPEC 2+ cluch parts comparo
- Video - Whats wrong with my clutch/engine?
- Fuel Injector Help
- looking at buying a cobalt ss/sc with a bad head gasket
- Dissected LSJ exhaust w/ restrictions measured
- tvs boost drop
- Did dual pass now leaking into intake
- Cobalt ss/sc down :(
- Polishing my m62 and valve cover
- Hahn 3 inch tuboback exhaust unboxing
- ottp stage 2 mounts installed
- impala ss motor
- 3" ZZP Downpipe Questions
- Cause of SS/SC Death Determined: Aeromotive Fuel Pump
- Dual pass 4 orings What size??
- Trifecta Tuning on LSJs?
- oil leak!
- Explain the laminova cores
- Mid RPM Power Feeler
- LSJ running out of injector bone stock?
- LSJ vs Saab B207r Internals
- lsj running bad on a cold start
- exhaust question
- need help,bolts/nuts?
- Bracket on Front of supercharger
- how to modify the lsj thermo and oil cooler adapter for external cooling
- Just my luck!
- air filter question
- How long till I go BOOM?
- Replacing my transmission [2005 SS]
- Not getting spark ... help !
- I think my SS/SC is idling a little too high, please help!
- Gen 1/2 Combo motor
- lnf coil on lsj?
- ZZP pulley puller question
- Dual Supercharger
- Back up lamp switch
- Badmab header thread pitch
- Your opinion on some common mods
- Swap heads???
- explain m62 whine
- CAM sensor, Dealer cant clock it properly...WTF
- More Timing Chain/Tensioner/Guide questions.
- Need some input
- New car/random questions
- tensioner mishap
- Help me!!!!!!
- Air/Oil Sep. Tank and Meth: MP-90
- Exhaust Loud Help
- What do you think of these plugs?
- interior door handle problem
- 03-04 Mustang Cobra guys use this as a bolt in upgrade for there IC pumps.....
- how not to make a timing table PART 2!
- Official TVS thread.. Take 2
- Informational: How not to make a timing table
- Screw LSJ's!
- anyone ever pull the engine cradle by themselves?
- exhaust rusted...options?
- Problem with downpipe
- P0101 issue
- My build/ideas/your thoughts
- bolt sizes?
- cooling mods, best bang for the buck?
- Close out on LSJ Power books
- new sleeves for the lsj and more
- wanna rebuild 2005 lsj
- Carstedts LSJ round 2
- Which setup is better?
- Boost gauge not returning to full vacuum
- Does anyone have this setup?
- Help tell me what i got....
- Exhaust system
- Blowing out cats
- 2.6 or 2.7?
- Exhaust Question
- Heat Exchanger / Intercooler
- Wtf beckey?!?
- More horsepower!!
- Tbandits Build Thread 2.0
- MP90, TVS 1900 or just turbo?
- After clutch install have very sloppy shifter. Hard to find 2nd gear
- bad-mab to stock manifold without retune?
- Spark plug life.
- 4 psi! Need help! I don't know where to start
- Belt slip on 2.6?
- drop in whine
- Disappointing news about modifying the Cobalt SS
- Enter to Win a Supercharged CobaltSS!
- speedo lag
- MP-90 or Modded M-62?
- Meth nozzle not spraying..HELP
- Interceptor wideband add on question...
- Exhaust Install Question
- weird buzz/fizz sound
- pick your tuner wisely
- Green plug
- Stainless Steel Option B Tank???
- Emergency help
- Anyone ever use
- Squints Black Beauty
- Car goes into OL at idle.. WHY WHY WHY
- Can I Use a 2005 PCM on a 2007 LSJ?
- e85 mileage for lsjs
- Fuel setup
- 06 SS/SC RPM Hang & Coolant Temp Gauge Issue
- I need some tips on how to properly check meth kit
- help please
- Car is dead at school!
- Crank position sensor
- Meth Injection????
- messed up bov causing lower boost?
- Oil Quantity
- VERY strange electrical issues...
- stage kit
- Help!!!!!!
- where to buy a stock lsj longblock?
- Badmab shorty + ZZP non cat DP?
- E85
- Warranty VS Tune
- Recent accident need advice
- Boost gauge question
- Dyno'd car today..
- Idle vacuum/MAP with ZZP cams?
- Option B
- Close call....
- another exhaust advice question
- Cold start problems
- Custom grind cams from Comp (video)
- Tuners help please!
- Power vs reliability
- Can i swap a blown LSJ for a 2.2 L61??
- Crappy ION's ;)
- Hahn vs zzp
- Turbo Lsj problem
- MRZ Alternator Pulley worth it ?
- E85 FAQ/sticky?
- Gm s3 or zzp s3?
- Belt tensioner....how to tell if its good or not?
- Exhaust Opinions
- LSJ or LNF Themostat Hosing ?
- What the heck is this noise!? Video included.
- Current project..advice?
- Apr torque help head studs
- looking for radiator
- arp head stud confusion
- ID1000 who is running them
- M62 Supercharger bearings
- 2.2 lsj turbo build
- How to Remove TB Plug
- Cobalt SS Throttle Body
- Replaced shift linkage now no 5th gear
- NOT my idea....but whole lot better of an idea to plug silencer ports on M62..
- Tune
- Tensioner Pulley Bracket
- Dyno Problems
- Misfire
- Clutch
- LS4 question #376
- s252et
- LSJ Twincharged
- LSJ Cylinder Head Casting Number
- stock catback with header sound
- Best and quietest 3" mufflers
- Need help checking wiring for boost solenoid
- 3 Gauge Piller Replacement?
- Stage 2 Cobalt Running like a dog
- Cobalt SS/SC intake mani.
- tune in kc?
- side cover gasket
- Stage Kits for Cobalt SS/SC
- the other top motor mount
- SS supercharged upgrades
- safe psi for stock lsj
- New guy question
- Stage 2 Help
- Not the roll pin whats next?
- Increase HP???
- help guys!
- found this unattached...what is it??
- Downpipe vs Header/Downpipe
- 06 LSJ starting issues!!
- Stage 3 GM - Check Engine Light Came and Went
- TVS Pulleys, Help Please!
- Thump noise on bumps??
- Flow through vs standard option b and other cooling mods
- SuperCharger Leak SS 05
- symptoms of broken/stretched roll pin?
- Popping noise from passenger front
- LSJ Oil Temp
- ECU Question ?
- ZZP's Prototype Heat Exchanger!
- Scraaape, Snaaaap, glug glug glug. Drain cock down!
- Snapped my first axle.
- For the TVS guys out there
- Not cranking / starting. looking some outside help
- what mods to do first?
- Will I need a fuel pump?
- Maf screen?
- LS4 Throttle body
- Help!!!
- turbo question
- CAI any offers or best deals
- Bring back the Hahn Catback..
- Everything installed and running great except one problem...
- Spark Plugs - LSJ
- brandnew cynlinder head
- taking her in cant figure this out
- need help stage 2
- NGK BKR7E are these the right ones??
- HELP!!!!! car running like poop!!!
- cobalt ss/sc stage 3 ?
- AC on, car stalls...??
- Stock Boost Gauge
- Car lags for couple seconds
- Air intakes
