- Looking for reviews on peoples header back exhaust systems
- Intake silencer?
- Couple questions...
- obd2
- scan gauge 1/4 mile?
- GM Stage 3 Pulley on GM Stage 2 Calibration
- Wheel hop
- where to tune in montreal?
- Any Naturally Aspirated LSJ's?
- Just did a 70k mile tune up
- just another new guy with a question
- twin charging question
- maryland balters with hptuners help
- to much boost?
- Need help. (FLEX PIPE BROKE)
- Need a Deeper sounding exhaust!!
- Downpipe
- New Clutch?
- leaking flex plate
- Belt Size
- Mahle wrist pins
- Replaced plugs....still misfiring
- header and dp
- Spoiler removal
- 60# fuel injectors and 2.8 pulley
- SS/SC Throttle Body and TPS issue. Where do I find one?
- 2006 ss sc advice
- Hahn Max Flow Downpipe
- Odd Issue with 2.0 LSJ
- ZZP intake!
- GM Stage 2 ?'s & expectations?
- CED Stage 2 yay?
- over cooling
- LSJ Stage 2 vs stock LNF
- Clutch bleed screw..
- Ottp stage 2
- putting a stage 3 clutch in, need torque specs, anyone?
- curious on guage
- Need a part number or a DIY fix...
- different meth setups????
- Ignition Problem?
- boost problem, tuning?
- Multiple problems that I'm having
- '05-'06 PCM swap and crank relearn, please confirm!
- TVS as a daily driver?
- An upgrade even for the tvs guys :) Twinscrew
- straight pipe?
- maybe dyno this saturday...
- slvr 04 rl turbo build
- Knock question?
- Need A New Clutch. But So Many Options
- Drivability of stages and suggestions?
- Cooling mods required to pulley down to a 2.9
- Going in for recalls.
- Clutch Slip & Bad Master Cylinder. Any connection?
- Oil Life Monitor.... How low to go ?
- Oil Temp
- How hard??
- New Dyno Numbers!!
- Cold air CEL
- stage 2 help?
- Brembo Upgrade, and rotor Questions.
- Misfire(Blinking CEL) please help
- Tvs+nitrous stock engine
- pulley puller
- how much boost?
- Whistling Noise After Taking Supercharger Off??
- Meth instail help
- Colder plugs with 60's and 2.8
- Help me with mods!
- dyno numbers with tvs
- K Sport Lowering Springs?
- Went to the track had problems advice needed!
- Clutch Advice
- 3in intake
- Need some help!!!
- Stage 2 belt squeek
- LSJ Throttle Body
- Help!!! Problem!
- hp tuner help
- 2.5 or 3 inch downpipe with 2.5 catback?
- need diameters of head ports
- vibrant exhaust
- easiest way to remove clutch.
- For the SC guys
- Couple DTCs P0036 P0054 P0141
- rev limiter?
- Which exhaust to get??
- Custom tuned in florida driving in maryland
- Injector harness question????
- blow up my 06 ss with 50k miles???
- Option B?
- Need some answers before Wed. LSJ Valve Covers
- ZZP downpipe rattling
- GReddy Exhaust?
- how hard is it to change
- tvs pullies
- is there an intrest for 2 3/4 exhst
- New to modifying cobalts need advice on a good setup thanks!!
- 06 SS/SC BCM Pinout
- Belt Squeak Problem
- help with autometer af guage
- PROBLEM Boost lost withe new intake?
- hose routing for ZZP single pass manifold
- 3" pulley? 30psi?
- TVS install help
- my winter project.
- LSJ belt?!?!
- Highest whp without meth?
- Axles And Mounts
- Headlights with Laser Blue
- BOV on the M62
- misfire question
- Check gas cap?
- Boost on a 2.6" Pulley?
- DIY dual pass
- Several Downpipe questions
- lsjion ported head
- Boost?
- P0171, with no intake
- shift linkage problem
- How Much Oil Turbo Swap
- OTTP Stage 2 ?
- went to the dyno
- hellp me boost dies 05 ss sc
- Supercharger Whine.
- Help with meth
- block weight?
- valve spring install
- difference in Magnaflow Standard 5x8 Inch and Magnaflow Increased Air 6 Inch
- exaust question
- SC Bearings
- 3rd gen halo projetors!?!?!?!?!
- installing tvs
- Reducing wheel hop
- Stage 2 help
- wideband question
- Royal Purple trans fluid answered..
- Possibly a new stage kit found??
- jbp header install
- help please!
- Header question PLEASE help
- Need help car wont run!!!!
- Pheonix Friction products suck
- ottp's griffin Heat Exchanger
- zzp stage 2
- MAF / Vacuum Leak?
- supercharger knocking?
- Spark plug gap?????
- Exhaust questions
- coil packs
- Crank Pulley
- cel po446
- ls4 TB on turbo swap lsj
- ZZP OTS Tune
- just put my header on!
- lsj vacuum diagram?
- used 2006 cobalt ss/sc with 140k
- belt ??
- Stage 2 or Stage 3?
- intercooler air bleed idea
- electrical and power steering problem
- What next?
- wrf
- Stage 6??
- Tire Sizes
- misfire!!!!!
- IAT's way to high... need some insight
- Big Bang Weird Incident Today
- Thermostat
- LSJ Intercooler?
- Vibrant Header/dp Leak?
- Slobalt LSJ @ the track
- A few stage 2 questions
- drag radials and wheel hop?
- OTTP stage 3 opinions?
- idle problem
- zzp stage 3 kit question
- weapon r
- one of those guys...
- HELP, Stage kit installed/case relearn
- Finally Connected the AEM Uego Question
- How much hp does a Gm stage 2 Gobalt SS/SC have?
- need tune!!!! indiana or chi-town
- bolt specs?
- LSJ Exhaust
- Engine Power Reduced
- Stock airbox filter
- 2 months later..
- question to all you tranny guys
- IC Pump Question
- E85 question
- intake whine!
- help!?!! looking to go stage 2..
- Downpipes
- OTTP 2.6 pulley?
- Do I need 80's??
- trouble code help
- Help! cars makin weird ass noise
- Do you use a oil catch can
- Hey guys heres a weird one for ya
- throttle body
- i have the spectre custom CAI problems
- fuel pressure?
- Coolant
- 06 ss/sc oil pressure issue
- Boost Leak?!?
- What engine oil are you running???
- LSJ Turbo vs. Stock Axle
- 0T-2 Car Diagnostic Meter for iPhone/PCs/Smartphones
- Rear mount turbo for SS/SC
- FrozenBoost H/E
- Full tank of gas = misfires WTF
- What type of resonator should I get?
- very important question asap
- Anyone have a downpipe from mandrel exhaust systems?
- CEL codes
- My Experience With ZZP Stage 3
- clutch is sliping or something!!!!!!!!!!!
- a quick thought about return style fuel systems.
- This doesnt sound right to me?
- copper gaskets
- I need oil filter help. 2 diffrent A/C filters
- clutch help
- Header/downpipe question
- timing chain tensioner
- Install Yeaya!
- quick question
- Possible problem with Vibrant downpipe?
- SS/SC starts for a sec and shuts down.
- Torque specs rotated mount
- How do I Enable HOM
- she don't run now!!!
- Would this benifit my car
- Age Old Question: Balance Shaft Removal and Installation
- Need Crank Case Relearn.
- bogging issue please helpp
- Gm stage 2 and ZZP CAi installed!
- 2.8 pulley, belt prob?
- intake.
- warranty--diagnostics charge??
- ZZP S3 HE. Yes, I searched.
- Water Cooled Turbo Coolant feed/return lines
- GM Stage II Tune
- codes p1101 and p0101 help.
- Head work..Like a Boss
- Custom Aluminum Raditor
- Why is my torque curve all jagged
- twin charge turbo size
- Nitrous and TVS
