PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. stupid brake squel
  2. cold start
  3. cutting out my cat
  4. NGK Gap for TVS?
  5. Humm NGK plugs....
  6. just installed my meth kit need some help
  7. what do you guys think?
  8. Wideband after cat
  9. spec -3 clutch
  10. Is my AFR too lean considering the colder time?
  11. Help fast!?
  12. Washer Fluid Tank
  13. To good to be true!?
  14. how many punds of boost do you hit with a 2.7" pulley?????
  15. Dual Pass Endplate Plus Option B Discussion
  16. GT35R Swapped Cobalt SS LSJ
  17. how low can u go?
  18. boost/vac gauge question
  19. supercharger oil problems
  20. REPOST black smoke
  21. black some
  22. low coolant
  23. Header/downpipe
  24. stage 2
  25. spec stage 2 + or 3+
  26. Exhaust vids for cti update
  27. Anyone make a device like the Diablo Mafia for a GM?
  28. P1101 & p0103
  29. headlight problem
  30. ARP Head Stud Install Question
  31. Which Header (again)
  32. Had a deal thrown at me and cant pass it up!
  33. Question on AEM Uego install...?
  34. pcm help!
  35. replaced LCA bushings....still loose steering?
  36. update to cti headers and dp
  37. So what's next?
  38. Need help - hptuners..
  39. mods
  40. Any one with hahns level5
  41. 2.9" whp
  42. intercooler
  43. AEM Dry CAI and winter
  44. GM Stage 2 and HE?
  45. arp head studs
  46. Questions 2.8, 60's, intake
  47. Blow Off Valve On a SC?
  48. throwing a CEL and low Coolant Temp
  49. omg help
  50. Fastest Stock SC Pulley 1/4 mile time?
  51. Megan Racing exhuast the best for the money?
  52. WTF is this code
  53. Centerforce Dual friction Clutch
  54. Help need good meth kit
  55. Will they fit?
  56. downside to twincharging???
  57. halo ring
  58. head studs/gasket replacement
  59. will these fit?
  60. Cel
  61. supercharger mods
  62. Injector quesion
  63. Need some quick help before morning!
  64. LSJ Tech Needed!
  65. Cost of mods
  66. wideband help
  67. it lives again!
  68. e-brake trouble
  69. Coilovers
  70. Other possible meth nozzle placement?
  71. injectors
  72. 02 bung
  73. ottp stage 1 or zzp stage 2 ?
  74. LS4 throttle body Good or bad? answer please
  75. zzp axle
  76. what is this??
  77. alcohole racing fuel
  78. shifting problems after clutch install
  79. Help putting on solid trany mounts
  80. ZZP HE install
  81. do i have a clogged cat?
  82. more help
  83. please help
  84. Going Catless
  85. best exhaust with no rasp for cat delete and headers
  86. how do i remove rear spoiler and fix holes
  87. cat-back
  88. tune time
  89. E brake mod
  90. slp single exhaust to dual
  91. pacesetter headers
  92. cold air intake
  93. building motor need advice
  94. Manifold Question - GMPP Manifold & Ported Stock Manifold
  95. any how to???
  96. Am I boost stacking?
  97. Tensioner pulley...
  98. coolant in my oil
  99. cam timing?
  100. Thoughts on this setup. Lots.
  101. Still slower than GM Stage 2 WTF?
  102. How to get the intake manifold off.
  103. part numbers??? help please
  104. Stainless Steel vs. Stock Sodium filled valves
  105. Downpipe I Needs!!!!
  106. Meth + NLS = Muffler Boom! pics inside
  107. SOS!!!! Starter help
  108. My performance plans
  109. reflash to stock tune
  110. oil in cai, tb and supercharger?!?!
  111. What are most people boosting
  112. Harnesses or connectors.
  113. stock top speed
  114. E95?
  115. tune?
  116. Slight whistle at part throttle
  117. p2261
  118. some question
  119. possible header dp problems
  120. re-tunning
  121. Can someone tell me what this is?
  122. Hurst short throw
  123. P0446 help
  124. supercharger question
  125. need exhaust ideas
  126. E85 questions
  127. 79lb injectors with a 2.8 pulley?
  128. Stage 2 SC kit vs custom pulley and injectors
  129. car weight
  130. Adam's Tvs Build: 343 whp 300 tq
  131. help!!!
  132. car talk translation
  133. LSJ stock boost?
  134. Belt tensioner ?
  135. Air box mod dyno
  136. MPS hub Backwards F*** up
  137. how to
  138. Am i lean or not?
  139. bypass valve boost leak? engine code problem
  140. center force clutch
  141. Blower grind Comp Cams
  142. Check my meth mix
  143. n2mb wot box
  144. My M62 E85 car will wax the floor vs most TVS cars on gasoline...
  145. couple questions
  146. pulley/blower efficiency
  147. sensor guid
  148. 02 sensor gone bad?
  149. my friend is a dick
  150. oem looking 2.8" pulley
  151. Smoothflow Group Buy
  152. Can ottp heat exchanger be used with option B?
  153. Factory fluke?
  154. heat exchanger options and opinions?
  155. O2 sensor threads?
  156. Header/DownPipe Help!
  157. opinion on spark plug gap??
  158. What is your opinion?
  159. Car goes rich under slight load
  160. What should I look for?
  161. Smoking Issue
  162. WOT box isnt working
  163. Airbox mod VS CAI?
  164. any ideas with p0172
  165. Apexi ws2 muffler
  166. is my fuel pump going??
  167. Fml!!!!!!!!
  168. devils own meth
  169. which set up?
  170. 70hp missing???? O_o
  171. c02 h/e spray???
  172. Newbie modifier
  173. cel p0172 help!!!
  174. issue with 06 motor/ecu in 05
  175. need to know some torque specs
  176. DEI CryO2
  177. M62 Vs Expensive TVS
  178. How Can I Figure Out If I Have LSD?
  179. How to pull motor?
  180. Best things to do before i go to a stage 2.
  181. Dynatech???
  182. so what does this do?
  183. What went wrong?
  184. SS/SC Hp!
  185. is there a way for more boost
  186. Last Few Questions NEED answers
  187. Problems Boost TVS!! 13-14 boost
  188. Strange noise..
  189. Cai
  190. clutch pedal issues
  191. air conditioning
  192. trifecta ez flash...help
  193. Best exhaust combo?
  194. shifter..
  195. i think i may be misfiring...
  196. New plugs for stock SS/SC?
  197. Need help
  198. WOT issue
  199. help fast, what does this tube connect to
  200. sensor on top of SC
  201. A/c
  202. CEL and jerky car when in boost
  203. Wheel spacers
  204. zzp stage 2
  205. IS my cat clogged
  206. 2 big questions need help asap lmk
  207. TRaction control better on or off
  208. Turbo LSJ...
  209. Stock clutch w/ the most miles?
  210. Tires
  211. Still having meth issues.
  212. Header/Downpipe help
  213. Is it worth or regret going to Meth?
  214. SLP loudmouthII
  215. zzp header dp catback combo
  216. fuel return system problem
  217. watch your gas!!!!
  218. has anyone ?
  219. next mod?? i need some advice!!!
  220. Front And rear Tranny mount need help finding
  221. Can u use other then supercharger oil in the supercharger?
  222. GM Stage 2 Question
  223. Quick exhaust question.
  224. lock tight on pulley
  225. Horsepower
  226. Head gasket and stock H/E question
  227. P0172 PTCM code FIX!
  228. superchrger malfunction
  229. Oil Cartridge?
  230. Port and Polished TB need to know what you guys THINK GOT PICS
  231. An Idea: TVS with ZZP's 2.3L Stroker
  232. My fall teardown sep 25-27
  233. help please!
  234. Does your LSJ take awhile to start?
  235. Bored...Decided to make a list
  236. Downpipe
  237. help a newfag
  238. Rattling and clunking
  239. zzp cat back
  240. Painting Supercharger and Alternator pullies
  241. Warranty vs Power
  242. Exhaust Cut-Out and Tune
  243. Stock internals!!!!
  244. 2 things. help
  245. Vortex header straight pipe setup
  246. Vacume leak
  247. gas mileage / larger injectors
  248. Blue smoke at idle
  249. Tvs
  250. intense stage 4 dyno
