PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. 2.0 conversion too .2 or .4
  2. LSJ Mean Mini Jetboat
  3. 4 inch down pipe ???
  4. jimbofugs unofficial/ parts list
  5. ZZP Option B + Ingalls Torque Dampener
  6. Ecotec LSJgoing into a Funny Bike in Iowa... anyone want to help?
  7. lsj throttle to saab manifold
  8. ZZP Catless Downpipe
  9. lk9 cams i lsj?
  10. intake systems
  11. Electronic Exhaust Cutout???
  12. Holset lsj
  13. Cobalt ss 2007 help
  14. ported exhaust manifold question
  15. Stage 3 SC questions
  16. fuel injectors
  17. 2007 Cobalt Ss/SC - SC pulley
  18. Why dont ecotecs perform better with cams
  19. 2015 LSJ-T Build Progression
  20. Boost Bypass for LSJ
  21. Corsa Touring Exhuast
  22. Seeking advice on Ariel Atom build
  23. air leakage from rotor bores?
  24. Lsj ice box trunk tank?
  25. Assessing my m62 supercharger
  26. requirements for a 3.1
  27. HKS BOV questions
  28. stage 2 zzp
  29. advice to finish up my mild build
  30. Is ZZP 3 inch intake swapping to a worth it?
  31. Work boredom. LSJ-T Virtual Dyno testing and results
  32. Stock Supercharger ported
  33. Budget build/rebuild
  34. Lsj-turbo vacuum/bov/wastegate routing
  35. Where To Buy LSJ Short Block???
  36. Newbie questions
  37. dissecting tobs. lnf vs lsj
  38. Stock
  39. pulley question
  40. Alans Block Party
  41. Ideal water temps
  42. OTTP Turbo Kit Dyno
  43. Tvs 1900....ottp stg5?
  44. Why don't more people go GM Stage 3?
  45. Trying to decide which performance mods to get?
  46. ZZP/Jbodyperformance Valve spring compare
  47. cooling question
  48. Tjolley's back to 2.0 build
  49. oil cooler help
  50. Dual pass hose question
  51. Heat Exchange questions on new ride
  52. New ride and Set up have some questions
  53. Girdle Bolts on LSJ. Tightening/Replacing question
  54. trying to decide what block
  55. Cobalt turbo swap mini build
  56. lk9 intake mods for turbo swap
  57. Setup Aeroforce Interceptor Gauge
  58. Possible Intercooler Pump Upgrade (Pump Information)
  59. LSJ Rebuild
  60. starting my turbo swap(;
  61. Option B Air Vent Line
  62. Which ECM for Turbo LSJ?
  63. Project Alcoholic help
  64. Im Back !!!!!
  65. Tune on stock?
  66. iat 2 temps toooo high...
  67. Nitrous nozzle placement in charge piping
  68. Reliability of my TVS cobalt
  69. Cobalt ss/sc pulley swap question
  70. about to buy stuff.
  71. Opinions on LSJ build...?
  72. Comp cam springs
  73. LNF airbox on lsj
  74. My "Large" ZZP Parts Order I'm About to Fire Off - Comments?
  75. Possible in tank fuel starvation solution!
  76. Lower a/r vs. higher with QSV
  77. Need lsj turbo swap advice!
  78. OTTP - Stage 2 Blower Cams
  79. deleted posts?
  80. Flow through tank instead of option b
  81. Fuel Cell/Magnafuel Pump install!!!
  82. Smaller pulley ?
  83. Air box mod??
  84. Josh-SS Joins The M62 300+ WHP Club
  85. got dynoed today
  86. 2005 cobalt ss lsj build
  87. tvs info
  88. Hardened oil pump gears
  89. Adjustable Cam Sprockets
  90. Will a 4-2-1 vibrant header bolt up to a zzp dp?
  91. Oil filter relocation kits
  92. any interest... complete Hahn swap
  93. heres the video i promised
  94. LSJ alternator pulley "NEW PRODUCT"
  95. ->trying to find ideas on exhaust size LSJ-T
  96. for those that do not know the difference in followers
  97. lsj turbo build
  98. Should Japeatr go turbo??
  99. LSJ Upgrade Suggestions
  100. Mod Opinions
  101. questions
  102. heat exchanger options
  103. Updates New motor with pictures
  104. cat back exhaust
  105. basic gm cam information
  106. Modification suggestions
  107. Japeatr's knocking at the track rebuild thread
  108. Anybody running OTTP Stage 4 cams?
  109. Performance mods ?
  110. Nitrous
  111. gm stage 2 hub removal
  112. Header questions
  113. went to the rollers
  114. New lsj fuel pump
  115. Build Progress Report
  116. finally dynoed my car
  117. ZZP Stage 3 LSJ cams idle video
  118. Finally going stage 3. Last minute questions.
  119. Future Engine Build
  120. HPT's take on E67 ECU for LSJ
  121. Cold Air Intake
  122. Option B question (Air bleeder hose)
  123. My baseline dyno runs
  124. dyno results are in
  125. Daily driver Budget Build
  126. 2.8 vs 2.9
  127. Tuning exhaust
  128. Dyno Results...
  129. my little build thread (since everyone has one)
  130. About to install some mods finally
  131. Two HE pumps.
  132. Boost
  133. Stock LSJ E47 tune
  134. WOT issue
  135. Phenolinic Spacer with stock pulley/belt
  136. Can anyone Help Engine rebuild ?
  137. Astronomically high iat2 temps
  138. Cloyes Timing Chain sets??
  139. stage 2?
  140. Options for a fun daily driver
  141. Aftermarket H/E
  142. Nitrous on a stock lsj
  143. need injector harness help asap
  144. heat exchanger bleed
  145. ZZP Header and Downpipe
  146. GEN III LSJ Block
  147. oversize tensioner vs gm s2 belt
  148. Connecting rod upgrade question
  149. LNF Pistons in a LSJ
  150. ZZP Stealth H/E - How to mount/install?
  151. Intercooler Pump
  152. need help with porting m62 for an ls4 tb
  153. Cai
  154. high iat2
  155. Which exhaust should I get
  156. exhaust
  157. 2.8 pulley question!!
  158. help setting up a mod plan
  159. LNF catback on turbo swapped lsj
  160. rebuilding
  161. head work?
  162. LSJ/LNF/LE5 valve springs all the same?
  163. aluminum option b tank
  164. Turbo x or ZZP?
  165. Which Cams to go with?
  166. hey guys thinking of giving bracket racing a shot
  167. Zzp stage 2 supercharge kit or zzp turbo kit?
  168. Pressure sensor for meth kit
  169. whats this? (porting intake mani)
  170. Stage kit and 94 octane?
  171. 78lb vs 75lb Supertech Springs
  172. know anybody who rebuilds 2.0 lsj motors in peoria il.
  173. devils own stage 2 meth kit
  174. c02 bulb mounted in intercooler tank
  175. Parting out whole 2005 cobalt ss 2.0 supercharged car..
  176. dual pass idea...
  177. building a stand alone harness and i'm looking for clarification
  178. supercharger inlet pressure sensor
  179. Exedy stage 1 clutch
  180. Devils meth injection
  181. 3.5" Intake
  182. TVS really worth it?
  183. sl0wlsj OFFICIAL Build Thread
  184. injector identification
  185. TVS. 10:1 or 9.5:1 pistons?
  186. Need some mod advice
  187. zzp lysom upgrade...
  188. OTTP return style and ZZP boost reference
  189. CAI or SRI?
  190. SAAB guy with LSJ questions
  191. 1870lb / 850kg mid engine car lsj harrop project
  192. Finally Upgrading
  193. ATI problems
  194. 06 Cobalt SS/SC to TC Question
  195. darton sleeves?
  196. boost issues
  197. 3" Inch Downpipe To 2.5" Exhaust
  198. lsj build thread
  199. Clutch HELP!!!
  200. Cobra inter cooling tank and cobra heat exchanger
  201. Stroker LSJ Turbo
  202. Reduf99's Build Thread
  203. Le Riceburners OFFICIAL Build Thread
  204. alternator
  205. what turbo to get
  206. Cams
  207. belt question
  208. At a loss for words
  209. Devilsown boost switch
  210. good read on piston rings
  211. My new build thread
  212. LNF piston rings in an LSJ?
  213. Is there a difference between the Cobalt and Redline
  214. Huge Issue! Car Not Staying Started Multiple Codes
  215. ZZP 2.5" CatBack exhauast
  216. supercharger delete plate
  217. rebuilding m62
  218. Help make my car faster!!
  219. LSJ very low boost pressure
  220. 100k plus lsj reliability?
  221. M62 Porting
  222. 1/2 counterweighted cranks vs. fully counterweighted
  223. wideband vs. angled 02 bung
  224. no gears
  225. Snow Performance Meth
  226. Is a Dyno Tune worth it?
  227. Misfire!!!!! Plz read!!!
  228. Do you out perform others with more HP?
  229. 2.0L LSJ Boost Leak Tester
  230. I Went To The Dark Side With A Gen 3 Motor
  231. LSJ Stock Boost
  232. Asking for some friendly advice.
  233. Timing help
  234. ZZP Stage 3 kit
  235. zzp intake problem
  236. What parts from an LNF will swap onto an LSJ and be considered upgraded?
  237. which brand is best for turbo swap
  238. Tuner shops in Cincinnati
  239. Need wiring pinout of 05 clockspring
  240. LSJ PCV system
  241. flow through
  242. gm performance exhaust flange
  243. Looking for some opinions here
  244. 05 stock boost gauge wiring
  245. shorty header vs. mid length vs. long tube
  246. 100% METH's LSJ Build
  247. Tjolley's stroker LSJ
  248. ARP Valve Cover Bolts
  249. Enable Shift Light?
  250. map needed for TVS and MEFI4B in Lotus
