- injector control circuit
- 2.2 cams in a lsj
- what wideband is the best deal?
- Timing?
- Option B with NO Dual Pass?
- track time?
- 17.5 psi to 15.4 psi
- Hmm...Meth ... maybe so
- jbp header unstall help!
- Oil filter??
- P0300 Misfire Code
- new header question
- Porting supercharger
- What should i do now?
- Fuel rail question
- 2005 SS/SC's
- thoughts on this?
- downpipe and o2 sensor question
- boost
- boost
- boost
- Supercharge Engine cover
- Porting Supercharger
- intercooler pump
- Cleaning Cat
- Anybody change boost gauges???
- Lets play guess the problem...
- boost gauge swap?????
- Colder Plugs Good with Stg2?
- What is the boost bypass MOd ?
- TVS price increase
- zzp UPGRADE
- Interceptor shift lights?????
- Broken again....
- Catback Question??? PICS
- Turbo suggestions
- dyno pull
- Spacer plate for meth?
- Please Help! P0171 / P0101
- LSJ clutch install questions
- Carbon build up on spark plugs...
- question regarding boost.
- Downpipe Help...
- Brass fitting for option B
- TVS Boost Problems
- ok what do u think
- meth nozzle????
- let see pic
- how much u think
- it will rise again
- header/dp/exhaust = afr change?
- TVS question
- Trifecta Tune????
- Question for owners of RAW 3" Intake
- noob question on getting stage 2 tune
- iat2 help please
- Running an aftermarket Heat Exchanger
- brake light help asap plz...
- AFR question
- meth injection
- phailed smog
- Oil Breather Cap/Crankcase Vent Filter.
- Intercooler connection
- wideband gauge
- Supercharger issue.
- interceptor question. need help
- redline exhaust on cobalt ss????
- I cant get the vortex header on!!!
- Innovate LC-1 Wide Band AFR Gauge Issue
- 06 redline problems
- Race Fuel?
- First track outing with my SS/SC
- help please
- what tire size can i run?
- Extreme surging/fluctuating RPM & boosting at idle...?
- pulley question
- False Advertisement ZZP?
- hahn turbo kit
- Trans fluid for my ss.sc
- alternator HELP
- best mod for the $$$?
- Tuning......
- what can make this code
- hahn 3" or 2.8 and 60's
- not sure if i can trust my wideband
- codes
- meth pump power
- Belt Squeak with a new Stage2 belt????
- got some money
- heat shield question
- dp question
- Srt-4 Spark Plugs in Ecotec
- mandrel exhaust systems vs gmpp
- Open to suggestions. (cavalier with GMPP charger kit)
- Quick torque on supercharger ??
- HID question
- HID conversion Kit?
- what oil...
- how to unclip o2 sensor?
- periodic knocking
- Please define what a LSJ Shortblock would include
- Interceptor too dimm
- key fob
- Power Band?
- Question?? PLease respond
- I just put a gt4088 turbo on my cobalt and im getting fuel cut
- gasket question
- Problem with the car?
- 07 SS w/ stage 2
- Misfires
- Check Engine Light tripped by CAI
- whats a good lift point?
- weird noise while rpm's drop
- bad boost need help
- C.A.R.B Number
- p0300
- Ottp 304 stainless catback?
- Exhaust Question.
- cobra h/e question
- Twincharge on NOS
- Alternator help
- Zzp vs 0ttp h/e
- Need some opinions
- Boost at the top of third?
- clutch bleed screw
- downpipe question
- I give up with the CEL. P0172
- intercooler issue
- Need help finding something
- Smaller Pulleys Safe for Stock Inj/Tune?
- Can we re-use the intake manifold gasket?
- Got my 60's today
- surging under light throttle
- any1 use windshield washer fluid res for meth?
- Higher Compression
- From (near) stock to 360+WHP in 72 hours
- Meth install help
- Alternater problems
- Which is better?
- TVS Dyno
- tvs
- exhaust cutouts
- ZZP PCM Input?
- 02 ? Again
- So how much is THIS gunna cost me?
- Oversize Pulley Tensioner
- Ottp
- Coolant leak - manifold?
- 2.6 IATs??
- Which Muffler?
- TVS 2.9 and 60's Video
- It happened...pulled over with SLP catback.
- ottp stage 1
- Need intercooler pump
- making meth
- 2004 Saturn Ion Redline
- Tester needed!
- Where does this go?
- LS4 What
- PLZ Help Me! Quick question!
- Exhaust question
- 2.9 and 140% IDC... Oy...
- ZZP S3 Cobalt Heat Exchanger
- TVS @ 8k rpm
- loud squeel
- Tuning ???
- Torque Damper?
- stage kits
- engine power reduce!
- CAI install
- injectors
- Wheels! Big ones!
- Fram or supertech oil filter..??
- Mounting option B tank..
- Ottp h/e help
- cam ground strap?
- header vs downpipe
- exhaust experiment/ur feedback needed
- Need help: No dash and tail lights
- Custom Stage 2
- Supercharger Problem
- ported head
- Painting brake rotors
- Power steering question/problem... Help
- I absolutely have to know if what Im gonna do is correct!
- tensioner and bracket setup question...
- Exhaust question
- the MAF sensor on CAI?
- Superchips
- P2101 Help
- What are the best V-Grooved spark plugs
- Ticking noise under the hood.....?? help
- stage 2 belt size
- Your comments on CEL
- OTT Stage 1 vs ZZP Stage 3
- Dyno Sheet, Does the A/F ratio look right
- Strange noise... HELP
- Cooling Opinions
- Headers
- water meth injection help...
- Updated Exhaust Thread
- some help!
- should i buy this turbo?
- DIC temp(outside) display
- Charger lift?
- MAF tricky question
- How much horsepower...
- Finally Joined the LSJ 300hp club :)
- Port and Polish question..?
- list of mods/horsepower...?
- HPTuners Tune Reset?
- A little help
- Wat size down pipe?? Plz help
- Help me out anyone please with ideas????
- ambient air temp sensor
- To oil or not to oil!?
- Option B bleeder question
- really bad clutch problems
- k&n question
- exhaust poping?
- k&n question CAI
- k&N question
- k&N question
- k&N question
- im about to push this car off a cliff!
- high idel?
- whats next
- Show me your meth tank/ set-up
- need help!!!!!
- Make your own meth mixture?
- Need help asap
- Hahn
- quick question
- Intercooler pump option?
- oil leak. maybe headgasket??
- dyno yesterday...
- Better boost switch for meth.
- need help ASAP!!!
- wire color help
- Turboing lsj need help
- What is this part
- Dry Ice Cooling?
- need a little help...
- LNF boost gauge does not work in LSJ car
