PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. New exhaust questions
  2. Belt tensioner change
  3. I need stock tune for
  4. arrrgggg 190 deg intake temps on a 40deg day
  5. How to get 300hp
  6. Built Engine
  7. need help.
  8. Opinions on Megan Drift Spec Exhaust
  9. *boostinss*'s build
  10. zach06cobaltss tune???
  11. Think im gonna need to brakes soon... what to get?!
  12. Went to bleed the clutch, leaking fluid out of bottom of trans
  13. eagle rods for the lsj yay!
  14. tuning the lsj
  15. timing chain tensioner
  16. Just installed my new trans... what do you think of this bleed method?
  17. looking for best tuner on css.net
  18. OTTP stage 3
  19. Stage 1 kit
  20. 07 lsj PCM part number
  21. Pressure washing Engine Bay
  22. Bad for Car?
  23. Need longer MAF harness
  24. Oil shooting out the dipstick fix!!! (hopefully)
  25. mod opions
  26. GM>urpos's SS/SC Build Thread
  27. 2.6" Pulley
  28. need help will this hurt my car?
  29. ABS light and P0433/P2229
  30. Iat sensor¿?
  31. Not getting spark on all cylinders
  32. Wtb
  33. New LSJ TSB ....Catalytic coverter
  34. What mods with 2.8in pulley
  35. what going on
  36. So I installed my new transmission today...
  37. Help, no boost
  38. Door Problems
  39. crappy zzp exhaust leak
  40. Spark Plug gap changing hp?
  41. Broken timing chain tensioner bolt..
  42. need help... no boost!!
  43. Burning smell???? Help.
  44. Harness?
  45. overheating problem- need advice bad!
  46. Clutch help
  47. will the n-1 tsudo exhaust fit
  48. throw out bearing lsj vs lnf
  49. What gauges are you running
  50. New Cat-back for teh LSJ
  51. dip stick popping out
  52. Looking for 409 Stainless Header
  53. how much are m62's worth now?
  54. Belt slip?Tensioner??Other problem??
  55. Engine Power Reduced?
  56. heater exchanger - standard-help pls
  57. Have GM Stage 1+2 kit; need PCM update; Where/How?
  58. downpipe
  59. OTTP Stage 3 Kit
  60. E85 questions for people that are running it
  61. ottp steering rack spacers
  62. Possible uh oh
  63. Car broke down.
  64. headers
  65. Engine Rebuild..Need some advice.
  66. colder plugs?
  67. Well I had one shitty night last night..
  68. Help with locating the PCM.
  69. Think my car is done
  70. help on cv axle and IM shaft
  71. A lot of smoke coming from exhaust
  72. help on a how to
  73. zzp header/dp
  74. wow! anyidea?
  75. where my ss/sc shud be?
  76. Car wont stop going rich
  77. Catless Downpipe O2 sensor
  78. ZZP's Neutral Balance Shafts..
  79. Busy Busy Weekend!
  80. Smoke under WOT (Not oil) and SC squeak
  81. pulley imput please
  82. lsj on a sand rail
  83. random misfire in cyc
  84. Stage 2 kit installation
  85. Suction Question
  86. Gm2/zzp3/ott2????
  87. H/E opinion
  88. cam bolt
  89. 340hp just isnt enough..
  90. Meth/E85
  91. Vibrant header
  92. mpg question
  93. 3.1 to 2.9 on 07sc
  94. OTTP Stage 2
  95. NGK BKR7E iridium equivalent? Or general plug discussion.
  96. Fuel Rail!!
  97. difference between ca v1 and v2 header
  98. 1st Oil Change HELP
  99. OTTP Stage 1
  100. Rear Lip
  101. Zzp h/e
  102. mandrel exhaust systems
  103. help needed
  104. which Spark Plug GAP??
  105. meth question
  106. chain guide
  107. wipers stopped working????
  108. 2.0 lsj and hp tuners help
  109. Are these the same ?
  110. Another Header Question
  111. Clutch for sale
  112. GM Stg2 or OTTP Stg2?
  113. LSJ parts and engine diagram reference
  114. Stage III for sale?
  115. Looking for prevous owner.....
  116. 07 Cobalt SS/SC mod ideas?
  117. racing seats
  118. Taking the head off.
  119. pulley question?
  120. Header tip!!
  121. need cat back exhaust and intake
  122. clutch
  123. Saturn motorsports header and downpipe
  124. New 06 ss owner need help!!!
  125. I need a clutch
  126. small sc build.. what you think..
  127. stage kit.. and premium gas problem.. help..
  128. lsj injectors quick question
  129. What's next to do?
  130. brake setup opinion
  131. Milk at the bottom of the stick...
  132. ic pump problem; going into limp mode.
  133. more boost?
  134. how to gt lugs off
  135. downpipe question
  136. guesses anyone?
  137. 2.5" pulley question
  138. check engine light! 3rd cylinder misfire!
  139. cai installation?
  140. Pulley install question?
  141. SO CAL LSJ Questions. Smog, Mods, and fuel.
  142. so i bent a valve
  143. Strut bar
  144. 2.2 crank on 2.0 block
  145. fuelfilter
  146. exhaust
  147. Boost Gauge fuse?
  148. suggestions for exhaust 06 cobalt sc
  149. Anyone join Fquick?
  150. Custom exhaust idea
  151. code throw
  152. stock exhaust size?
  153. exhaust ?
  154. tq control
  155. Cant Decide Between Stock Head gasket/bolts or Aftermarket.
  156. Turbo Question?
  157. horrible idle problem, hpt logfile attached
  158. lsj for sale at foothill chevrolet
  159. hid questions asap
  160. bump stop cutting..
  161. what should i do?
  162. Jabsco Pumps
  163. Does anyone know anything about this header?
  164. 2nd MAF sensor in less than a year... PLEASE HELP
  165. P2176 and other problems
  166. can i drive to the tuner?
  167. Merge Collectors
  168. spark plugs and my setup
  169. crank relearn?
  170. Another header question
  171. bracket ID requested
  172. Does the AEM wideband come with an 02 bung?
  173. I need help!!
  174. spark plugs?
  175. stage 2 really that much over stock?
  176. Intake Manifold....Im stuck lol
  177. boost gauge malfunction- any help please?
  178. happy newyear
  179. Can't figure out whats wrong v. again
  180. dyno'd my cobalt
  181. Pros Cons
  182. cat less downpipe
  183. Superhcarger bolts what size allen wrench
  184. Aftermarket parts question?
  185. 2007 SS/SC setup
  186. 2 better than 1
  187. give me your whp estimate
  188. my car is to loud!
  189. is stage 2 worth the money?
  190. IAT2's
  191. Cracked piston, possible build in progress. Need some advice
  192. Cracked piston, possible build in progress. Need some advice
  193. for those seeking info
  194. Coilover question
  195. Advice?
  196. Help!!!
  197. GM stage 2 numbers
  198. Tuning in Chicago
  199. Help! My car wnt boost past 1.7 psi
  200. Injector harness?
  201. Short throw shifter people
  202. Problems caused by a leak in intake
  203. Anyone else has this happen with the crankcase cover hose?
  204. Coilovers
  205. need help fail inspection
  206. Someone help! Please!
  207. Radiator help.......
  208. standard fuel pressure regulator
  209. Well, been a good week!
  210. ottp
  211. gasket
  212. Single Pass DIY
  213. Help! stage 2 belt troubles
  214. hear her whine
  215. Decisions?! suck!
  216. 3 Grand Two Decisions YOU DECIDED!
  217. Clutch issue Question?
  218. Cutout
  219. TVS Build Thread (anyone have one)
  220. its official
  221. Tensioner
  222. i need a parts list for head install
  223. rings
  224. phenolic intake spacer HELP
  225. Pacesetter Downpipe!
  226. O2 sensor delete
  227. Need some good reference !
  228. Rod Knock Fuuuuuu
  229. clooged cat?
  230. No heat!!!!!!! Helpppppppp
  231. need site for ottp
  232. Thermostat and evap code....
  233. best intrest
  234. cheap meth kit found here
  235. need injectors???
  236. Cobalt ss and Deep water
  237. Harmonic balancer key is gone!!
  238. Pacesetter Header
  239. 02 bung placement
  240. Cylinder Compression
  241. Max Safe Temp
  242. Wtf please help
  243. Safe rpm limit for stock LSJ
  244. out of luck..
  245. looking for...
  246. SS/SC springs over LT springs
  247. wheel weight
  248. Custom Tune in Dallas / Ft. Worth area
  249. No Power!?!?!
  250. Spark plugs ungappin!!
