PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Car advice..
  2. Just got GM stage 2 installed....question
  3. OTTP vs ZZP tune......
  4. Installing a pulley using a press?
  5. Iat question
  6. Seafoam?
  7. Silicone Radiator Hoses
  8. Trifecta stage 3 questions...
  9. Switching gauge face to psi from kpa... Idle
  10. PCM Tuning Questions - How Can I Tell???
  11. Please help!
  12. Installing Dual Pass. Intake Manifold Gasket Reusable?
  13. Need a new muffler, mine is silly loud, what do you guys recommend?
  14. Pinched exhaust
  15. question on engine mounts
  16. Heat exchanger sprayer
  17. Need help picking which first!!!!!!
  18. Time to Build
  19. hesitation?
  20. Autozone rent pulley pullers?
  21. OTT or ZZP axles
  22. whats next important?
  23. Boost Gauge
  24. Updates on ZZP Turbo Powered LSJ
  25. vacuum reading question.
  26. Meth + E85
  27. going the the dealer need help plz!
  28. auto passenger window?
  29. Going Turbo 2.2 Alternator
  30. transmissions
  31. IC pump replacement
  32. Help!!! Fast!!!
  33. 2.5 or 3.0 exhaust?
  34. From stock to tvs?
  35. Buying GMS2 from CED and installing at chevy Q
  36. Mounts
  37. boost guage
  38. Magnaflow Exhaust
  39. vaccum diagram 2.0 ecotec
  40. 300hp Daily Driver (TVS guys chime in)
  41. 2 questions
  42. Need some experts
  43. Noise That Has Been Going On For Months! Dealership has been unable to fix it, ideas?
  44. ott stage 2 or zzp stage 3
  45. dtc p1182 questions....
  46. ported tvs supercharger??
  47. NOT a boost bypass mod question.........
  48. gm stage 3?
  49. Went to the Track now i have issues!
  50. Engine problems, Help
  51. stage 3 question
  52. About to finnaly bump up to ottp or zzp stage 2
  53. 2.5" Head and DP or 3"?
  54. 2007 SS/Sc fucked up ass transmission and or dealer
  55. manifold gasket
  56. Portland, OR - Stage 2 install...
  57. clutch issues
  58. Supercharger Gasket
  59. boost limit
  60. Dual Pass Endplate Question
  61. Twin charge question
  62. Narrowed my choice down to 2
  63. Anyone ever do this mod?
  64. how would you run a boost leak test?
  65. Stock or should i Mod?
  66. is the ls4 TB worth it?
  67. timming?
  68. Spec 3 + LSJ
  69. Is this dual pass?
  70. 2.8 switch?
  71. stage 2 question
  72. Air Intake Temps
  73. Need Help p0036
  74. Stage 2 to Stage 3 GM Kit
  75. Grinding Reverse gear!
  76. ZZP stage 2 kit
  77. reflash.?
  78. dp bung question
  79. Cooling questions
  80. exhaust question
  81. 2.2 alernator plug
  82. Need expierenced advice or just anyones input please!
  83. Got dynoed today
  84. i need stock or aftermarket flexpipe asap!
  85. intensity stg 5 vs ottp stage 3 vs zzp 3?
  86. RPD for SS/SC??
  87. pot hole + heat exchanger
  88. Cel
  89. port & polish?
  90. Need some exhaust recommendations
  91. any suggestions?
  92. Few questions. Please help
  93. Going Turbo Few Questions
  94. Programmers? Who has em
  95. quick pulley question
  96. GM / Center Force DF Or DFX ( Help )
  97. adjustment for bypass valve actuator?
  98. OTT H/E plug
  99. what happend?
  100. GM Stage 2 Program available for second owner?
  101. Best Bang for $500
  102. new exhaust
  103. GMPP Clutch upgrade
  104. info
  105. 2.5 Catback or OTT over axel piece
  106. NGK plug gap..
  107. exhaust leak?? pic inside...help
  108. Should i get GM stage 2?
  109. new turbo swap opinions
  110. HELP!!! New to cars
  111. What does everyone think?
  112. painted my blower...questions
  113. Turbo?
  114. air filter
  115. OTTP Stage 3?
  116. can you run e85 on #60's?
  117. Buying headlight wiring harness online? Where?
  118. Phenolic Spacers
  119. head sequence for torquing
  120. Stock Header and Dowpipe with Hahn catback?
  121. option b vs stu mod
  122. thinking of getting a different cat-back...
  123. Do I need any gaskets or o-rings to install stage 2?
  124. Bog
  125. gm stage 2 problem? help?
  126. do you now what im talking about?
  127. What company makes the 79# that are perfect for e85?
  128. Flashing CEL
  129. ottp stage 3
  130. coolant sensor ?
  131. tranny fluid question
  132. 2nd stage..
  133. looking for lsj tuner in Illinois that has tuned many balts..
  134. So can I get a little advice?
  135. maf
  136. code P1138
  137. WTF is wrong?
  138. LE5 LSJ hybrid running in 2 weeks
  139. LSJ Compression Test
  140. pulley boost chart?
  141. A few things troubling me.
  142. lighting
  143. Rebuild
  144. Canned E85 tune hmmmm.....
  145. It is really an injen??
  146. Noise on start-up
  147. meth ?
  148. GM part numbers request
  149. benifits of heat exchanger?
  150. Pulley help
  151. Looking for a tuner
  152. vibrant dp o2 sensor
  153. wiring question..
  154. Vacuum Leak Around MAP Sensor Causing Misfires? Help!
  155. timing chain tensioner????
  156. Pics of your ZZP S3 (front views)
  157. Spraying Meth Thru TVS???
  158. rpm cant go past 4500
  159. ZZP Single Pass Intake manifold 200 degree IATs?
  160. Air conditioning lines diagram?
  161. Cant anyone help?!?!
  162. Should I Upgrade to 60's and a Smaller Pulley?
  163. Easiest way to 300 crank hp.........
  164. Who's stage 2?
  165. o2 sensors help
  166. stage 3 whp?
  167. help please..
  168. no dual pass
  169. SS/SC Won't Start
  170. Always have problems with fuel when tuning
  171. O.T.T.P Stage 1 kit
  172. 1st to 2nd Gear Sux @ WOT ?
  173. Round 4! Turbo Build, all custom this time. This ones gonna be better than ever!
  174. Installed zzp stage 2, few concerns
  175. Restriction?
  176. Turbo swap cost? Need some advise
  177. Car wont start!
  178. sensors....
  179. launch control on a lsj
  180. Problem with speedo?!?!
  181. top speed wtf
  182. WOW motor stolen
  183. Replacement K&N Intake filter and prefilter
  184. couple questions..
  185. Need advice on Mods
  186. Trifecta Stage 3 or get a HP tune?
  187. Can someone measure something on their car for me.
  188. What goes to the stud behind front left headlight?
  189. Tuned catless, switching back to catted?
  190. False knock?
  191. How Strong Are Our Stock Axles?
  192. OTTP stage 1 mount
  193. Is it just me or my Clutch??? = (
  194. Installing a ZZP S2 H/E, help me out here please.
  195. Help! Dying cat in motor
  196. RPD of ss/sc possible?
  197. For the PPL that have a CAI i have a question. hope you can help.07 cobalt ss..
  198. Quick opinion for tvs exhaust
  199. Need a Tune ASAP..in KY, WV,OH
  200. Which resonator?
  201. supercharger whine
  202. Exhaust cutout
  203. 2.6 on stock supercharger
  204. what plugs for e85 and LS4 TB to intake connector
  205. My Sportlines
  206. jerkyacel. so annoying
  207. 2.8 with stage 2
  208. anyone with tvs but no g85?
  209. Big issue..
  210. help. white smoke
  211. R1 Concept Brake Performance???
  212. Injector Harness?
  213. Black smoke means
  214. Help on wideband
  215. Stage kit that does not require new plugs?
  216. Header question
  217. Please HELP. GM clutch upgrade/throw out bearing problem
  218. which springs and shocks?
  219. spark plug question plz advise
  220. Help asap
  221. Stage 2 help
  222. dual pass...?
  223. HELP gas tank.
  224. Codes :(
  225. 2.5 or 3 in DP
  226. ottp option b kit and ottp dual pass endplate
  227. oil change..
  228. $25 intercooer pump.
  229. N2mb wot users
  230. zzp s3 h/e vs. ottp h/e
  231. P2135 tps???????????????
  232. OTTP long tube header
  233. so i did the tune up on the car and...
  234. can anyone tell me What size is the stock intake
  235. Aftermarket fans: clarification needed.
  236. Exhaust noise
  237. Cams help!!!
  238. help wont keep running
  239. Can't get ZZP on the phone. Why might this be?
  240. cant call ottp?
  241. Eaton M62 Oil fill amount Misconception
  242. Resonator exhaust fix
  243. Wastegate ?
  244. Lean code
  245. tuning
  246. good results from 3" cai
  247. Another boost loss issue
  248. car boggin
  249. Turbocharged Tranny Mounts?
  250. Brakes?
