- intake filter/tune?
- Need Help with HPtuners tune for meth!!!
- Heat Exchanger Question???
- stage kit need some opinions
- tuning in New York (Long Island) Area
- striped spark plug threads need your help to rethread the head.
- straight pipes anyone??
- boost cut?
- IAT gauge who has one where did you mount it?
- Help me out.
- Who is on 10.5:1 CR pistons?
- Intense vs zzp tune
- Pacesetter?
- Help! need a new H/E pump
- 2.8 to 2.7
- Bracket for inter cooler fill neck
- *complete* flow thru style option b tank**pics inside**
- HELP cel issues...
- blow up?
- where to look
- Grinding sound + Idle problem after clutch+flywheel install
- Question about the O-RINGS under valve cover
- TVS vs Ported M62
- Pully Size's
- stage 2
- 60 #'s what kinda gain?
- Stage 2 kit assembly
- for sale and how much should i ask for or get
- CEL on. Somethings wrong!
- Car Does not shift at WOT
- 360 whp on an m62 "no nitrous"
- One-Way PCV Valve in Intake Manifold?
- look what just arrived
- Need a TVS update
- Big Problem.
- Clutch
- Need 3.3" pulley to fit GM stage 2 hub
- Estimated Hp Qs?
- pulleys vs psi
- plug in where???
- Black and Red 18 rims and Sport contact 2 tires..
- Hahn Stage V Demo car Done!! a few odds and ends to come!!
- Those with 2.8" and 60lb injectors...
- P2A01 HO2S Circuit Sensor 2 ECM
- Looking at IAT's
- is this possible???
- Supercharger Bushing?
- Anybody who has rebuilt come in
- Engine questions
- Tsudo With Mods
- Copper Exhaust Gaskets...
- dual pass
- Easiest way to install new belt?
- Nitrous+Timing+Methanol
- crank pulley size
- I just DON'T KNOW!
- lsj belts
- wtf wierd lean condition with wideband helo
- Kyb Gr-2???
- 2.9 + St 2
- Fuel injector retaining clip
- Changing m62 pulley
- Running to Lean
- interceptor params that work for our 2.0 sc
- Problems And Dealer is Dumb!!!
- can anyone help me out
- Engine might be goin...
- cel code and broke eugo
- Coolant Temp Issue
- New Supercharger?
- car is down...need help from gurus.
- GM Stage Kit Question ...
- Fuel shutoff in 5th gear (not a top spd question)
- stock clutch on stage 2 kit
- Show me your Cutout Pics
- S/C oil change noise?
- meth Vac?
- intake vs intake
- changing the coupler
- Trans?
- Venom SS
- Aeroforce Interceptor Ques???
- hm....got a problem
- help in 06 ss/sc
- Where to begin...
- New to this lol
- Exige+LSJ+TVS = yes please
- What Next
- Blue SS/SC in South Glens Falls NY
- what gear do you dyno in?
- Better Intercooler Pumps?
- Water wetter??
- how much whp will it make?
- 05 ss S/c. whats with 3rd gear?
- Seafoam
- how much boost are you running?
- muffler
- Need help
- reving
- OTT Rotated Trans Mounts
- Anyone see what's wrong with this? (DynoSheetInside)
- PCM question
- I need all the help i can get yall!!
- CEL. help yall!
- What's your opinion on what to do next?
- Head Removal
- Bad Problem... Helppppp
- Need help asap
- Quick Question About Fuel Injectors and Pulleys
- Boost gage question
- Help please
- Throttle body
- Sputtering sometimes during a hard pull???
- Why would I get a camshaft sensor code only with the R.A.W. intake?
- NEW UPdate. Help yall!!
- hahn level 5 went external wastegate pics and details
- Lost power feels slower help!!!!! and a pulley question
- Beware Corsa Owners!!
- oil pressure gauge
- SS Rebuild - Few Surprises along the way.
- Boost Pressure?
- p1133 ?
- Headgasket?
- Dp question....
- Higher flowing fuel pumps.
- Interceptor/ CEL
- Help with Innovate LC-1 wideband
- Wondering Something.
- what gaskets to get
- turbo system question
- How Long and other helpful tips
- Help...car wont run in the rain
- Everyone with HAHN exhaust
- Clutch help
- Dipstick Still Popping Out
- No AC???
- What size filter for injen intake?
- Help!!!
- need some advanced help
- Is the LSJ harmonic balancer the same as a 2.2?
- warrenty safe mods
- LS4 Tb ?
- valve cover question
- Please look, has anyone had to replace this?
- What Downpipe to Get????
- new seats in the balt
- straight from the factory with stage 2?
- WTF METH KIT?! Work for me Baby!
- Boost Guage
- zzp d/p broke :-( oh no
- Hahn full exhaust with a TVS in the future?
- Yet Another Exhaust Question
- HAHN 3" catback
- Caution to those with Cobalt Addiction H/E
- 2.4 intake mani to 2.0
- Primary O2 sensor
- option b without dual pass??
- LSJ+Vulcan I/M=FAIL
- what is need to hook up a extra h/e on cobalt s/c
- aluminum option B tank
- if you had to guess...
- got the saab intake manifold on today
- Dialing in meth injection question
- help with sensor
- Check Engine Code
- tsudo exhaust gaskets
- Has anyone done a muffler delete on their SC?
- exhaust gasket
- OBX header and downpipe??
- o2 sensor spacer for downpipe
- i have a question on the eaton m62
- Need Rings & Crank Bearings ASAP
- Most Common Size
- stage 2 questions/ engine
- Pick for me PLEASE!!!!!!!!
- Will this AC Condenser fit? Ebay..
- Devils own injection kit
- What dp will bolt to a saurn motorsports header dp combo
- i just might go turbo!
- What would be better
- header gasket????
- IAT's
- Torque Specs...
- 2 headers n dp choices
- Dual Pass Install Help Needed!
- Super Charger Gasket !
- feels/sounds weird
- Ordered Black Injen intake...but I have a question
- Ok guys, help me find this rattle please
- Header Installation?
- Flat spot with TVS
- Problem cranking sometimes! help!
- Same belt?
- Turbo Converts
- Please I need to be assured!!!!
- anyone willing to....
- P0300 Random cylinder misfire code w/60's
- after a year of waiting...
- Changed S/C coupler and oil
- Voltage Problem?!!?!!?
- SuperCharger bolts
- i need help FAST!!! removing/ installing serpinteen belt
- Megan racing exhaust
- Iat1 and Iat2 Post Them.
- Beat the Heat
- NGK G-Power Spark Plugs ?
- help !
- p0010???
- Who has a catless 3" dp....
- trouble installing header
- black smoke
- ss/sc 300hp
- C/A Heat Exchanger Install ?
- Catback Systems
- friend just got the stage two and problem....
- Hatrickstu's Icebox Mod
- new tune
- 1 step colder plugs cel?
- Track help
- need a downpipe
- question bout sound
- TVS owners how much whp?
- Magnaflow exhaust
- Tell me why.
- this be a good buy?
- header ?
- Making the LS4 TB driveable
- ottp stage 1 kit pulley has to be machined??
- Need help with OTTP Heat Exchanger
- spark pulg gap? asap
- OTTP Stage 1
- OTTP Pissed me off
- AEM cold air intake????
- Missing my torque
- Turboing a redline via removing SC Bypass
- I think im getting lag.
- Dual pass with option b or Meth
- wheres the wire go?
- Does anybody know how much the HP gain is from a AEM cold air??
- Hahn Exhaust Modular Exhaust Inlet - Stock & 2.5" Downpipes SS/SC
- pistons and ???
- Real simple battery question
- Which Header?
- Tuning question
- Quiet Performance 2.5" exhaust
- what to gap the plugs at
- Performace trouble
- Boost ...
- Quick HPTuners question..
- Runs Like Crap....
