- water/meth mix alternatives?
- Adjustable Cam Gears
- help with next mods?
- 2.7 vs 2.8
- ZZP mid-length header/downpipe gasket
- my exhaust restricted????
- not for a cobalt...turbo celice in need of help
- Another big build!!!!
- Genuine GM or aftermarket??? you tell me
- What is?
- these stages wit da dual pass questions
- 2.79 pulley only 16psi help
- Cobalt-addiction Stage6
- Race fuel mixture
- meth and pully
- Air to Air Vs. Water to Air
- friday night track run
- Heat exchanger
- help ASAP PLEASE!!!!
- Summit mufflers.
- Ticking on cold start
- Turbo lsj
- Nitr0's build thread
- Need help!!!
- Lets See Those B & G Springs
- Opt B
- Centerforce Dual Friction Clutch
- Stage 2 = Not worth it.
- Question for those that have had the eaton apart(PICS)
- OBX Helical LSD
- Broken Cat?..
- CEL on my Brother's SS/SC
- question about AEM UEGO
- ZZP H D/P Installed.. Need a muffler?!
- torque specs anyone?
- Fuel Pump
- Intense stage kits.. help please
- How Long are Codes Stored For?
- a wet 75 shot??/
- Searched, but still have a ? about limp mode
- Tuner needed near East Tennessee
- Lower front bumper grille?
- Catback Needed With Header & DP?
- 60k tune guide?
- axis decade
- Stock Timing Maps
- sportlines
- Dyno Tunes??
- car runing like crap
- where is the....
- Do i need new spark plugs?
- Outside Temp sensor
- shaking problem
- Having some problems guys, need help
- Devils own install
- 2.6 w/ 42# injectors
- Where to order a tsudo catback
- sc removal
- Tuning...
- CA or zzp can tune pcm's
- 3 inch pulley, stock belt
- Dyno Numbers with Water/Meth Injection.
- need help.......
- What is the best way to .............
- anyone with this problem?
- Is this true?
- 2007 SS/SC Stage 2 Boost
- dual pass w/ option b
- pulley problem
- gmpp touring+ header dp combo sound clips
- Ported & Polished my TB LOTS of PICS
- jannetty racing
- magnaflow exhaust
- oppinions?
- Cobalt SS Stage 2 Turbo Conversion Results So Far
- 3" pulley on stock injectors...
- I want flames
- what speed
- Nitrous or meth injection?
- Intake Manifold question
- 5000mi update of S/C holes plugged (56k dont even try)
- Need a shop.
- Header/ DP Installation?
- Short throw shifters
- Gas Mileage with 60lb injectors
- places to buy tsudo exhaust?
- Brake Fluid Replacement Advice...
- Heat Exchanger Review
- downpipe issues?
- Next Mod
- LSJ Manifold part number
- are 2.2 rods the same as 2.0 rods?
- Looking for the right header
- Wot Box
- something wrong?
- Magnaflow Resonator
- Twin-Charge anyone?
- Stage 3 and emissions
- Confused, please help
- Future Mods
- typical noob question maybe...
- 2.9 42#'s
- I've got a question *waiting to put flamesuit on just in case*
- Stock tire size???
- CBodnar's 307whp Nitrous Cobalt
- gettin stage 2 need help
- GMPP extruded manifold Q's...
- possibly cams...
- New MRZ 2.0 LSJ Lightweight Crank Pulleys just released!
- ran into trouble taking out stock exhaust
- Question about GM stage 3
- Another cobra haet exchanger thread!
- P2261 on harrop
- would only make sense
- coupler
- What to do...
- Vibrant Header
- Intense prototype Gen 7 blower, what happened to this?
- GMPP Warranty
- victory_red_SS DD engine FIASCO
- Tuned and dynoed with 2.8 and 60's
- COT removed on stage 3?
- this may be a stupid question but.....
- Running 2.9 on stage 2 with these mods
- Resonator ?'s.......Ive done search
- a/c condenser
- I used "search"
- Shift Light on 2.0L SS/SC
- Help im squeaking!!!
- help heat exchanger pump
- CX H/E pics
- So many choices so little time...
- valve train noise?
- 2.85 question
- Exhaust sound clips...
- Vibrant header & new gasket?
- darn...
- S/C Bearing Grease??? Help!!
- 2.9" Probs, Stock StgII none...
- Down pipe
- 60's
- Fujita or Injen
- Front of the car swayin
- Shaking/Tremble during idle
- 70mm Harrop Pulley?
- Fixing my car!
- CNC Head Testing
- AIR intake sensor
- Guess My Dyno #'s
- I want cams! but who has the best ones?
- H/E install ?
- what spark plugs should i run
- Would I need meth for this setup?
- pulley puller?
- Ahh the dreaded WRX sound...
- Boost and CAI
- which meth kit?
- Aeroforce Interceptor users please read!
- Electric exhaust cut-out? Anybody?
- Oil Cooler
- Option B help please
- CX H/E! CX HEAT EXCHANGER Installed *Pic's
- 75MM goes on the Harrop today...
- solid engine + trans mounts
- Stage 2 Dealer in Massachusetts
- CX h/e installed!
- Catless or not?
- How much boost?
- Removing converter. Yes or No
- What should I spend $1000 On???
- Pulley Screws
- Novel Idea
- Quick Question.
- Too good to be true???
- 2.75" Random Tech Exhaust Question
- 60's and tune on sat
- ais meth kit different Q tho
- What is an easy way for a car dummy to see what stage they have?
- help with resonator
- AIS stage 1 trunk mount kit
- Best header?
- No longer STOCK WOOHOO thanks 06blackg85ss
- Turbo GSR
- Got my stage 2 installed yesterday
- Turbo or zzp twincharge or supercharger kit
- Power and Time Estimates??
- Gas Milage?
- Anyone with torque management disabled...
- Apexi S-AFC 2?
- intercooler pump replacement
- Umm...anyone have a chip on their car?
- Magnaflow FTW!!!
- heads
- stage 2
- Trans for my build
- pully size
- anyone have an lsj short block
- intake and ls4 tb question
- Stage II - $632
- Best Exhaust Available
- Injen CAI Vibramount
- ZZP Shorty Header Question??
- Calling All Ss/sc's In Michigan! Stock Gt Needs A Whooping!!
- Which Heat Exchanger
- need help installing my water meth kit
- Starter Location?
- rl stroker kit
- ZZP 3inch exhaust
- clutch
- ok need some help with cams...
- Help w/TB Spacer & CAI Fitment PLEASE!!!
- some ideas
- Help with H/E install
- Air Filter Replacement on SS/SC LSJ
- New High flow lower manifold
- 2.79 with 60s on s2 tune????
- AEM wideband
- Need a tune...PA
- Help me out...
- oh crap
- Parts
- well boys and girls i did again..
- 60lb TTR injectors/harness
- Who elses car feels like a SLUG during the summer heat? like really REALLY slow
- C-A Heat Exchanger
- Wierd Sound help please..
- starter
- need help asap a/f guage install
- Heat exchanger?
- Tvs
- lowering rear crossmember help
- Vibrant H/DP
- Brake Boosting!!
- is a 2.8 ok here?
- am i going to blow my motor up!!!?????
- Boost Actuator
- wideband/cat ?'s
- Traction mods
- H/e?
- Intercooler Bleeder Screw... Problem
- Pulley in cold weather?
- Aem
- Quick HP Tuners question
- installing zzp header and dp
- How to clean carbon
- will this throw a CEL?
- GMPP Maniifold HP increase
- trouble at the track.. engine cut off half way down
- Sooo has anyone else had this problem?
