- Can anyone provide me with a twincharge tune...
- HE with option b and no dual pass
- What should i do to my Balt now?
- Cheapest place to get stage 2 kit?
- Twincharge goes racing!
- What size TVS pulley can be safely run?
- The DD Engine is Home!
- has any one done this
- how do you tape the boost gauge power wire
- WOT box preference?
- LEmme know what you think
- Stu mod ? Ideas
- OTTP Stage 1 kit
- Struts might be going??
- 240 whp?
- 4 grand to spend tvs or turbo?
- Heat Exchanger
- Wideband questions
- real problem with car's idle
- Those of you with the hastrickstu cooling mod
- Stage 2= No cruise control help please!!!
- just got intake now what?
- My TVS Build & Dyno sheet
- Oil filter Issue
- wideband and plug
- Upgraded ecotec clutch VS Drag Slicks
- Small miss low end
- Stage 2 injector?
- Looking for a tune
- Stage 2?
- Need help with radials
- downpipe and header dilemma!!!
- Makin' power!
- Anybody has tried this ram charger
- meth and 2step
- couple quick questions
- Stage 2 and Stage 1 to 2 Upgrade
- Pulley size question
- Oil Pump Gear Failure
- Need help, car won't start
- mod question
- Stock Downpipe?
- h/e fluid what is the ratio
- supercharger hoses cracking
- Ottp s1 video
- Big turbo LSJ's... I need your help!!!
- Oil loss??
- k&n typhoon intake ss.sc
- interceptor data help?
- Installed OTT Heat Exchanger
- good flow numbers for ported head?
- AC Delete anyone?
- zzp adjustable tensioner
- 255 lph pump...when?
- I need pics Please!!!
- Best possible meth setup for my build...
- Dual Pass Question
- help please
- dual pass
- All out m62 build update!
- do i
- Ecu?
- Meth injection formula??
- How do you do the case relearn???
- how big are your balls
- Noise??
- how would i do??
- Strange noise from engine
- DP & Exhaust Feedback
- Header/Dp need help
- Looking at an SC Things to Check for?
- Suggestions for quiet muffler
- will ss exhaust fit a 09 2.2L?
- No-lift shift possibly causing knock?
- Interior of my resonator cracked?!?!
- New thread on what stage kit to get please
- pulley size question?
- Quick Question about grill replacement!!!
- whats wrong with my car???
- what muffler and resonator for deep tone on lsj?
- Over heating problem need help asap
- e85
- Mass airflow issues
- HP Tuners and tire size calibrations
- Installed CAI on 2.0 LSJ, Loss Of Power
- Having Problems with the SS
- Turbo build missing one thing
- Option B & endplate = Good cooling mods
- help
- Ottp with Meth
- 02 sensor problem....
- Stage 2 problems
- Testing: New Aluminum Water Tank For Added Coolant ("Stu Mod")
- Fan Question
- Need any parts?
- Good Shop
- coolant leak, help!
- zzp stage kits vs GM stage kits
- LSJ Throttle Body bolts
- Stage 4 Loosing Boost
- OTT Stage 1 Kit Question
- missfire cyliner #1
- SLP Loudmouth Exhaust
- idea
- HELP!! Dual Pass Laminova core positioning
- Anyone have 100K miles?
- Need a lil help plz
- recommended vendors?
- 3rd Gen Halo Projector Installation
- 3rd Gen Projector Installation
- Hptuners ? Help
- My cobalt
- meth
- I want so bad my OTTP stage kit installed but I need a case relearn...
- check engine light p2610
- Dyno Results, Port polish S/C and TB, CAI Header and Hahn exhaust
- whats the norm
- whats the norm
- WTB: Opinions on FM H/E
- Air/Fuel Ratio Gauge Wires?
- Air/Fuel Ratio gauge wires
- Intercooler..
- what should i do?
- What if i...
- What if i...
- What if i...
- Jason goes twin charged and gains 150WHP!
- good afr??
- Resonator
- colder plugs?
- Ais Meth help!!!!
- Ais Meth help!!!!
- cobalt ss/sc vs c4 vette
- CXracing heat exchanger
- A record just got crushed. Can anyone guess what it was?
- Saab Exhaust manifold
- Gm wheel hop elimination mounts?
- Limited boos in 1st questions
- tuner
- Tuners
- Clear Image 3" or 2.5"
- Zzp ?
- ? About tune from trifecta
- Performance radiator for ss/sc?
- Need some quick answers plz
- Does anyone think this could be a mod for a SS-SC
- ottp S1 can tune vs street tune
- ZZP all out m62 build What do you think it is capable of?
- Stage 2 bolts
- 02 sensor?
- LSJ PCM Question
- Wingless HELP!
- Kr...
- went to the dyno today
- Airfilter access
- What tool do I need to remove my pulley
- How to remove the stage 2 pulley
- Rush Hour IAT2
- What are the stock plugs for a 2006 SS
- Need help before install
- cobalt takes time shutting off.
- Aftermarket wheels. . .
- how do u know
- Weight of the LSJ engine only?
- Exhaust Issue
- Standard pully
- Dual pass or catback?
- Valve Springs
- what type?
- blower oil
- custom exhaust
- any interests?
- pulley hub?
- Need a tranny
- What resonator?
- Info on parts
- 3rd Gen Halo Installation
- JBP camshafts??
- lsj tuning shops in nj?
- i wanna get in the 13's ! help !
- 60 vs 72?
- need your opinions
- Check your aftercoolers pumps!!!!!
- Spark Plug gap?
- Monza Exhaust
- local muffler shop
- SS/SC brakes question
- low boost, 10.5 afr wtf need help.
- Meth + cutout + WOT box = ?
- Top performance
- who has a bigger intercooler for the lsj?
- Click explained better
- Car wont start, help!
- Interesting info on E85 and injector sizing
- Transmission question. Need help asap.
- Air box mod, worth it ?
- Custom Intake parts
- ZZP S3 HE gains?
- 2.9 pulley with GM stage 2, reliable?
- Questions about the LSJ m62 supercharger...
- High flow cat or Catless DP?
- Anyone know the name of the shop in Massachusetts that does LSJ/Ecotec work?
- Anyone try a Harrop on a stage three tune?
- smaller pulley
- wanna hear a 3"catless dp and 3" catback
- clutch questions
- my pump needs viagra :(
- so, interesting issue...
- zzp gauge pod
- blower housing question
- Exhaust FAQ
- spec 2+ ???????
- An Exhaust question
- WOT wire for peak recall on Autometer Wideband
- liter to ci conversion
- ppl w/ tsudo N1 on a SS Speak up.
- A Few Questions
- Engine Code: P1133?
- is there
- Meth Question (a good one)
- Bad Clutch Pedal Feel
- OTT Intake vs Meth
- is it worth it
- Mmmmm.....got boost?
- 3" Vibrant exhaust
- Engine Swap idea..
- car wont start!!!!!!!!!!!
- zzp header?
- found new header for cobalt
- Oil Residue in Intake side of head
- help please
- s/c oil ?
- what intake with the ls4 throttle body?
- This is Your M62 on Drugs
- turbo lsj help
- clutch and flywheel question spec 2+ SC073H
- looking for input (Heat Shield)
- Need help!!! Meth Question
- part number for fuel injector
- Few questions...
- pulley/exhaust ???
- exhaust question
- Who needs 42lb injectors
- wtf???
- oil
- turbo conversion question..
